[General] 專業最新NCP-MCI-6.10考證通過Nutanix Certified Professional - Multicloud Infrastructure (
88
【General】 專業最新NCP-MCI-6.10考證通過Nutanix Certified Professional - Multicloud Infrastructure (
Posted at 1/16/2026 08:45:19      View:208 | Replies:3        Print      Only Author   [Copy Link] 1#
2026 VCESoft最新的NCP-MCI-6.10 PDF版考試題庫和NCP-MCI-6.10考試問題和答案免費分享:https://drive.google.com/open?id=1QBw3Yu2PInMRtBgU3nv5qI-tlaMxyFl1
現在有許多IT培訓機構都能為你提供Nutanix NCP-MCI-6.10 認證考試相關的培訓資料,但通常考生通過這些網站得不到詳細的資料。因為他們提供的關於Nutanix NCP-MCI-6.10 認證考試資料都比較寬泛,不具有針對性,所以吸引不了考生的注意力。
Nutanix NCP-MCI-6.10 考試大綱:
主題簡介
主題 1
  • Configure Disaster Recovery and Data Protection within a Nutanix Multicloud Environment: This section of the exam measures the skills of Disaster Recovery Specialists and Cloud Engineers and covers configuring protection policies and domains for data security and recovery. Candidates need to identify the right entities for protection, schedule backups, define retention policies, and set up replication to remote sites. Recovery plans must be configured and executed with proper scripting, network mapping, and failover strategies. Metro replication requires understanding failover methodologies, comparing solutions on different hypervisors, and preventing split-brain scenarios. Effective disaster recovery planning ensures minimal downtime and data integrity across environments.
主題 2
  • Manage VMs within a Nutanix Multicloud Environment: This section of the exam measures the skills of Cloud Administrators and Virtualization Engineers and covers managing virtual machines (VMs) within a Nutanix multicloud environment. It includes creating and updating VMs by determining hardware requirements, boot modes, sizing, and configuration based on application needs. Candidates must understand how to deploy VMs using templates, snapshots, and image configurations, ensuring the correct formats for importing and exporting VMs. Migration processes require knowledge of prerequisites, storage, network settings, and software compatibility. Additionally, configuring VM categories and attributes is essential for proper organization and management within the environment, ensuring alignment with labels, storage policies, and security settings.
主題 3
  • Conduct Custom Monitoring within a Nutanix Multicloud Environment: This section of the exam measures the skills of Cloud Analysts and Systems Engineers and covers custom monitoring for optimized performance management. Candidates must analyze performance charts, set retention policies, create custom service level agreements (SLAs), and manage storage based on policies. Creating reports involves identifying the required type, selecting generation frequency, determining retention properties, and customizing report formats for different monitoring needs. Effective monitoring ensures better resource utilization, system efficiency, and proactive issue resolution within the multi-cloud environment.
主題 4
  • Manage Clusters within a Nutanix Multicloud Environment: This section of the exam measures the skills of Infrastructure Engineers and Systems Administrators and covers the administration of Nutanix clusters. Storage management includes creating, reading, updating, and deleting storage containers and volume groups. Configuring AOS and Prism Central settings involves authentication, SSL certificate management, IAM role-based access control, and configuring network segmentation. Network administration procedures focus on creating VLAN-backed subnets, virtual switches, and load-balancing policies while monitoring NIC usage. Lifecycle management includes performing hardware and software updates and maintaining firmware. Hardware maintenance involves adding or removing nodes and physical disks while ensuring proper upgrades and replacements. Intelligent operations require configuring capacity policies, discovering application relationships, and simulating scenarios to optimize performance.
主題 5
  • Troubleshoot a Nutanix Multicloud Environment: This section of the exam measures the skills of Technical Support Engineers and IT Operations Specialists and covers diagnosing and resolving common issues within a Nutanix multi-cloud environment. Troubleshooting protection policies and recovery plans requires identifying network mapping failures, vNIC issues, script execution problems, and connectivity failures. Metro replication troubleshooting involves addressing naming conventions, network limitations, and replication states. Security issues in AOS and Prism Central must be resolved by managing CVM communications, security warnings, and log analysis. LCM operations require diagnosing failures in inventory updates and version upgrades. Performance troubleshooting involves analyzing logs, reading performance charts, and adjusting VM configurations to meet performance needs.
快速下載的最新NCP-MCI-6.10考證&保證Nutanix NCP-MCI-6.10考試成功與優秀的NCP-MCI-6.10考試重點還在為不知道怎麼通過的NCP-MCI-6.10認證考試而煩惱嗎?現在終於不用擔心這個問題啦。VCESoft多年致力於NCP-MCI-6.10認證考試的研究,有著豐富的經驗,強大的考古題,幫助你高效率的通過考試。能否成功通過一項考試,並不在於你看了多少東西,而在於你是否找對了方法,VCESoft就是你通過NCP-MCI-6.10認證考試的正確方法!
最新的 NCM-MCI NCP-MCI-6.10 免費考試真題 (Q50-Q55):問題 #50
An administrator needs to create astorage containernamed TestData with the following conditions:
Replication Factor (RF) = 1 (RF1)
Inline Compression enabled
Deduplication disabled
Maximum storage capacity = 100 GiB
How should the administrator complete this task?
  • A. Log intoPrism Centraland create the storage container with aReserved Capacity of 100 GiB.
  • B. Log intoPrism Centraland create the storage container.
  • C. Log intoPrism Elementand create the storage container.
  • D. Log intoPrism Elementand create the storage container with anAdvertised Capacity of 100 GiB.
答案:D
問題 #51
An administrator attempted toenable Data-in-Transit Encryptionon aScale-Out Prism Central clusterto encrypt service-level traffic between nodes. However, the featuredid not work correctly due to a firewall restriction.
Which CVM-specific port should be allowed through the firewall for Data-in-Transit Encryption?
  • A. 0
  • B. 1
  • C. 2
  • D. 3
答案:A
解題說明:
Data-in-Transit Encryption in Nutanix requires inter-node communication over specific CVM ports.
* Option A (Port 2009) is correct:
* Port2009 is used for Data-in-Transit Encryption between Nutanix CVMs.
* Firewall rules must allow traffic on this portto enable secure encrypted communication.
* Option B (Port 2010) is incorrect:
* Port2010 is used for CVM-to-CVM communication but does not handle encryption.
* Option C (Port 2020) is incorrect:
* This port is used forAcropolis File Services (AFS), not encryption.
* Option D (Port 9440) is incorrect:
* Port9440 is used for Prism Central web access, not internal CVM encryption.
* Nutanix Security Guide#Data-at-Rest vs. Data-in-Transit Encryption
* Nutanix KB#Firewall Port Requirements for Secure Cluster Communication
問題 #52
LCM Framework Check
A Lcm prechecks detected 3 issues that would cause upgrade failures.
Check test lacp_configuration' failed: test_lacp_configuration: Unable to find Vcenter details for connection.
Please refer to KB 14277 Check test esx_ha_enabled' failed: Unable to find Vcenter details for connection Check test_es_entering_mm_pinned_vms' failed: Unable to find Vcenter details for connection X LCM Framework Check An administrator is attempting to upgrade the NIC firmware on a Nutanix cluster and sees the error displayed in the exhibit.
Which log is the most appropriate to analyze the LCM precheck failure?
  • A. catalog.out
  • B. 1cm_ops.out
  • C. genesis.out
  • D. 1cm_wget.out
答案:B
解題說明:
The LCM (Life Cycle Manager) precheck failures in this scenario indicate an inability to connect to vCenter to validate ESXi-specific checks, such as LACP configuration, HA, and pinned VMs. The appropriate log to analyze the details of the LCM precheck failures is the 1cm_ops.out log.
From theNutanix Enterprise Cloud Administration (ECA)course materials:
"The 1cm_ops.out log file contains detailed output and error information related to LCM operations, including prechecks, execution, and post-checks. This log is essential for troubleshooting LCM framework failures and understanding the root cause of any issues preventing upgrades."
問題 #53
Which two entities can be categorized? (Choose two.)
  • A. Virtual Machines
  • B. ISO Images
  • C. Alerts
  • D. Storage Containers
答案:A,C
解題說明:
In Nutanix Prism Central,categoriesallow administrators togroup and organize entitiesfor management, automation, and policy enforcement.
* Alerts (Option B) can be categorizedto group similar system events and create filtering rules.
* Virtual Machines (Option C) can be categorizedto apply security policies, automation tasks, and resource allocation rules.
* Option A (Storage Containers) cannot be categorizedin Prism Central. Storage policies apply at the container level but are not managed via categories.
* Option D (ISO Images) cannot be categorizedbecause ISOs arestatic objects, not active entities.
* Nutanix Prism Central Guide #Working with Categories
* Nutanix Bible #Category-Based Management and Security Policies
* Nutanix KB #Using Categories for VM Management in Prism Central
問題 #54
An administrator is executing a storage performance test between two Microsoft Windows VMs. The first VM was deployed by using a template, while the second one was created from scratch.
Results show that VMs have very different metrics when using the same performance test. The first VM reaches 8000 IOPS, while the second struggles reaching 500/800 IOPS. Currently the AHV cluster is not under pressure.
How can the administrator determine why these results were produced?
  • A. Compare vDisk bus type between VMs.
  • B. Enable AHV Turbo on the second VM.
  • C. Verify both VMs have installed Nutanix Guest Tools.
  • D. Check number of VCPUs assigned to VMs
答案:A
問題 #55
每每談及到 VCESoft 網站的 NCP-MCI-6.10 考題,很多人都稱贊其出題率是很高的,讓許多人的 Nutanix 證照之路沒有後顧之憂。“萬事俱備,只欠東風。”如果你沒有最新的 NCP-MCI-6.10 考題作參照,再多的努力,是沒有用的,畢竟我們的 NCP-MCI-6.10 考題可以作為真實考題題型的參照,讓大家順利進入了理想的單位。
NCP-MCI-6.10考試重點: https://www.vcesoft.com/NCP-MCI-6.10-pdf.html
BONUS!!! 免費下載VCESoft NCP-MCI-6.10考試題庫的完整版:https://drive.google.com/open?id=1QBw3Yu2PInMRtBgU3nv5qI-tlaMxyFl1
Posted at 1/16/2026 09:18:54        Only Author  2#
I’m truly grateful for your article, it was really eye-catching. Valid test COBIT-Design-and-Implementation tips offers a wealth of content, available for free, hoping it aids your learning.
Posted at 2/5/2026 01:56:21        Only Author  3#
Your article has truly stayed with me, thank you for sharing. The Latest IIA-CIA-Part2 exam experience test was the key to unlocking my promotion and raise. Grab it for free today!
Posted at 2/9/2026 08:08:03        Only Author  4#
I am deeply inspired by this article, thanks for sharing! Thanks to the Valid exam C_P2W62_2023 registration, I received a promotion and raise. It’s now free to everyone. Wishing you all a rapid climb in your career!
