NSE5_FSM-6.3ԇݣNSE5_FSM-6.3Cտԇ
Posted at 1/16/2026 00:13:45
View149
Replies2
ϵҳɞһЌˣһÿIJޡxITИIĕrѽϵCҵČϵǂoMˣһֱϡ@ͨ^ FortinetNSE5_FSM-6.3ԇJCеһƴŬW^ҪoُIFast2test FortinetNSE5_FSM-6.3ԇJCӖYϣҾˌͨ^ FortinetNSE5_FSM-6.3ԇJCxFast2testӖWվֻf·҂_£]˛QķFast2test FortinetNSE5_FSM-6.3ԇӖYϣ͵춓һõδ
Ҫ@Fortinet NSE5_FSM-6.3JCITIˆTҪͨ^60ɆĶxԇԓԇwcFortinet FortisiemgPĸN}簲ȫϢͻӹSIEMA֪RFortisiemBúúúúúãԼԼ¼¼
Fortinet NSE5_FSM-6.3Fortinet NSE 5 - FortiSIEM 6.3JCԇǾWjȫIеһ헟TJCԇԓԇּڜyԇcFortiSIEMQČIʿļ֪ܺRԓJCԇһȫĜyԇwFortiSIEMábͲȸN}
NSE5_FSM-6.3ԇõFortinet NSE 5 - FortiSIEM 6.3кܶWվṩYӍFortinetNSE5_FSM-6.3ԇṩ FortinetNSE5_FSM-6.3ԇJCӖYϣFast2testΨһľWվṩ|FortinetNSE5_FSM-6.3ԇJCYϣFast2testָ͎£ȫͨ^ĵһFortinetNSE5_FSM-6.3ԇ҂Fast2testṩԇ}ɬFͳMYӍgS֪RͲe۵ĽδITИIһӘǡ
µ NSE 5 Network Security Analyst NSE5_FSM-6.3 Mԇ} (Q47-Q52):} #47
What is a prerequisite for FortiSIEM Linux agent installation?
- A. The auditd service must be installed on the Linux server being monitored
- B. The Linux agent manager server must be installed.
- C. The web server must be installed on the Linux server being monitored
- D. Both the web server and the audit service must be installed on the Linux server being monitored
𰸣A
}f
FortiSIEM Linux Agent: The FortiSIEM Linux agent is used to collect logs and performance metrics from Linux servers and send them to the FortiSIEM system.
Prerequisite for Installation: Theauditdservice, which is the Linux Audit Daemon, must be installed and running on the Linux server to capture and log security-related events.
* auditd Service: This service collects and logs security events on Linux systems, which are essential for monitoring and analysis by FortiSIEM.
Importance of auditd: Without the auditd service, the FortiSIEM Linux agent will not be able to collect the necessary event data from the Linux server.
References: FortiSIEM 6.3 User Guide, Linux Agent Installation section, which lists the prerequisites and steps for installing the FortiSIEM Linux agent.
} #48
Refer to the exhibits.
Three events are collected over a 10-minute time period from two servers: Server A and Server B.
Based on thesettings tor the rule subpattern. how many incidents will the servers generate?
- A. Server A will generate one incident and Server B will not generate any incidents.
- B. Server A will generate one incident and Server B will generate one incident.
- C. Server B will generate one incident and Server A will not generate any incidents.
- D. Server A will not generate any incidents and Server B will not generate any incidents.
𰸣A
}f
Event Collection Overview: The exhibits show three events collected over a 10-minute period from two servers, Server A and Server B.
Rule Subpattern Settings: The rule subpattern specifies two conditions:
* AVG(CPU Util) > DeviceToCMDBAttr(Host IP : Server CPU Util Critical Threshold): This checks if the average CPU utilization exceeds the critical threshold defined for each server.
* COUNT(Matched Events) >= 2: This requires at least two matching events within the specified period.
Server A Analysis:
* Events: Three events (CPU=90, CPU=90, CPU=95).
* Average CPU Utilization: (90+90+95)/3 = 91.67, which exceeds the critical threshold of 90.
* Matched Events Count: 3, which meets the condition of being greater than or equal to 2.
* Incident Generation: Server A meets both conditions, so it generates one incident.
Server B Analysis:
* Events: Three events (CPU=70, CPU=50, CPU=60).
* Average CPU Utilization: (70+50+60)/3 = 60, which does not exceed the critical threshold of 90.
* Matched Events Count: 3, but since the average CPU utilization condition is not met, no incident is generated.
Conclusion: Based on the rule subpattern, Server A will generate one incident, and Server B will not generate any incidents.
References: FortiSIEM 6.3 User Guide, Event Correlation Rules and Incident Management sections, which explain how incidents are generated based on rule subpatterns and event conditions.
} #49
An administrator defines SMTP as a critical process on a Linux server.
It the SMTP process is stopped. FortiSIEM will generate a critical event with which event type?
- A. PH_DEV_MON_PROC_STOP
- B. Generic_SMTP_Procoss_Exit
- C. Postfix-Mail-Stop
- D. PH_DEV_MON_SMTP_STOP
𰸣A
}f
* Process Monitoring in FortiSIEM: FortiSIEM can monitor critical processes on managed devices, such as an SMTP process on a Linux server.
* Event Generation: When a critical process stops, FortiSIEM generates an event to alert administrators.
* Event Types: Specific event types correspond to different monitored conditions. For a stopped process, the event type PH_DEV_MON_PROC_STOP is used.
* Reasoning: The name PH_DEV_MON_PROC_STOP (Device Monitoring Process Stop) is a generic event type used by FortiSIEM to indicate that any monitored process, including SMTP, has stopped.
* Reference: FortiSIEM 6.3 User Guide, Event Types section, explains the predefined event types and their usage in different monitoring scenarios.
} #50
Which FortiSIEM feature must you use to produce a report on which FortiGate devices in your environment are running which firmware version?
- A. Run a CMDB report
- B. Run a query using the Inventory tab.
- C. Run an analytic search.
- D. Run a baseline report.
𰸣B
}f
* Feature Overview: FortiSIEM provides several tools for querying and reporting on device information within an environment.
* Inventory Tab: The Inventory tab is specifically designed to display detailed information about devices, including their firmware versions.
* Query Functionality: Within the Inventory tab, you can run queries to filter and display devices based on specific attributes, such as the firmware version for FortiGate devices.
* Report Generation: By running a query in the Inventory tab, you can produce a report that lists the FortiGate devices and their corresponding firmware versions.
* Reference: FortiSIEM 6.3 User Guide, Inventory Management section, explains how to use the Inventory tab to query and report on device attributes.
} #51
If an incident's status is Cleared, what does this mean?
- A. A security rule issue has been resolved.
- B. Two hours have passed since the incident occurred and the incident has not reoccurred.
- C. A clear condition set an a rule was satisfied.
- D. The incident was cleared by an operator.
𰸣C
} #52
xFast2testṩʴ_PFortinet NSE5_FSM-6.3ԇaƷijɹڲh̎
NSE5_FSM-6.3Cտԇ: https://tw.fast2test.com/NSE5_FSM-6.3-premium-file.html
- NSE5_FSM-6.3ԇ 🐌 NSE5_FSM-6.3ԇָ 🚾 NSE5_FSM-6.3ԇָ 🤔 ➤ [url]www.newdumpspdf.com ⮘ь☀ NSE5_FSM-6.3 ️☀️ԫ@ȡMdԇYNSE5_FSM-6.3JC[/url]
- NSE5_FSM-6.3ԇݣFortinetJCӖ - Fortinet Fortinet NSE 5 - FortiSIEM 6.3 🏥 ➽ [url]www.newdumpspdf.com 🢪WվM➽ NSE5_FSM-6.3 🢪}NSE5_FSM-6.3}[/url]
- NSE5_FSM-6.3ԇݣFortinetJCӖ - Fortinet Fortinet NSE 5 - FortiSIEM 6.3 🗳 }uWַ▷ [url]www.vcesoft.com ◁_K▛ NSE5_FSM-6.3 ▟MdNSE5_FSM-6.3T}[/url]
- °NSE5_FSM-6.3}Ͼ 👔 NSE5_FSM-6.3T} 😺 NSE5_FSM-6.3ԇ ⛰ _[ [url]www.newdumpspdf.com ]ݔ▷ NSE5_FSM-6.3 ◁K@ȡMdNSE5_FSM-6.3T}[/url]
- NSE5_FSM-6.3JC 🗼 NSE5_FSM-6.3Cָ 😑 NSE5_FSM-6.3] 🌊 _Wվ [url]www.pdfexamdumps.com ⏩ NSE5_FSM-6.3 ⏪MdNSE5_FSM-6.3T}[/url]
- NSE5_FSM-6.3} 🚬 NSE5_FSM-6.3}Md 🕜 NSE5_FSM-6.3ԇY 👔 { [url]www.newdumpspdf.com }☀ NSE5_FSM-6.3 ️☀️pȡMdNSE5_FSM-6.3CYӍ[/url]
- NSE5_FSM-6.3ԇ 🦥 NSE5_FSM-6.3JC 🏍 NSE5_FSM-6.3Cָ ✡ _➤ [url]www.newdumpspdf.com ⮘K NSE5_FSM-6.3 ԫ@ȡMdNSE5_FSM-6.3¿C[/url]
- [url=https://rebeccakiessling.com/?s=%e9%81%b8%e6%93%87NSE5_FSM-6.3%e8%80%83%e8%a9%a6%e5%85%a7%e5%ae%b9%20-%20%e8%b7%9fFortinet%20NSE%205%20-%20FortiSIEM%206.3%e8%80%83%e8%a9%a6%e9%9b%a3%e9%a1%8c%e8%aa%aa%e5%86%8d%e8%a6%8b%20%f0%9f%9a%be%20[%20www.newdumpspdf.com%20]%e6%98%af%e7%8d%b2%e5%8f%96%e2%96%9b%20NSE5_FSM-6.3%20%e2%96%9f%e5%85%8d%e8%b2%bb%e4%b8%8b%e8%bc%89%e7%9a%84%e6%9c%80%e4%bd%b3%e7%b6%b2%e7%ab%99NSE5_FSM-6.3%e8%80%83%e8%a9%a6%e6%8c%87%e5%8d%97]xNSE5_FSM-6.3ԇ - Fortinet NSE 5 - FortiSIEM 6.3ԇy}fҊ 🚾 [ www.newdumpspdf.com ]ǫ@ȡ▛ NSE5_FSM-6.3 ▟MdѾWվNSE5_FSM-6.3ԇָ[/url]
- NSE5_FSM-6.3} 🆓 NSE5_FSM-6.3ԇ 🍲 NSE5_FSM-6.3CYӍ 🚵 ڡ [url]www.vcesoft.com µġ NSE5_FSM-6.3 }NSE5_FSM-6.3[/url]
- ڙNSE5_FSM-6.3ԇݺYԇIõĿԇNSE5_FSM-6.3Cտԇ 🙀 Md⇛ NSE5_FSM-6.3 ⇚ֻM➤ [url]www.newdumpspdf.com ⮘Wվ°NSE5_FSM-6.3}Ͼ[/url]
- NSE5_FSM-6.3ԇ - H[url]www.pdfexamdumps.comƽ_ 🚮 Ո⇛ www.pdfexamdumps.com ⇚WվMd➡ NSE5_FSM-6.3 ️⬅️}NSE5_FSM-6.3ԇָ[/url]
- www.stes.tyc.edu.tw, hhi.instructure.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, elearnzambia.cloud, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
