Completely erase EMMC flash storage/userdata from PC?
543
Posted at 2/28/2015 00:00:44        Only Author  1#
Hi
How do you completely erase EMMC flash storage from PC?
I use Android_Console_Tool.exe and type
Android_Console_Tool.exe EF RK3288Loader_uboot_V2.17.02.bin in command prompt
It then says 50000 KB or something erased and then boots to maskrom mode.
AndroidTool then says maskrom mode and in different flashtool it has blue color square in Rockchip Batchtool v1.8.
I then flash my firmware again(modded dual-boot firefly firmware) but my previous ROM's userdata and apps is still there, it hasn't been cleaned.
How to completely erase EMMC flash in RK3288 from PC to flash a new ROM?
Want to flash my own modified Firefly dual-boot ROM, so it won't have Android Recovery in Recovery partition because it has been replaced by linux-boot.img to boot Linux from recovery. Misc will then not be able to tell recovery to wipe userdata and cache.
1. Is there a way to completely erase userdata and cache from PC when flashing a dual-boot ROM?
2. Or maybe keep Android Recovery in Recovery partition and put linux-boot.img in a new different partition and be able to boot to it from Android.
I know how to edit parameter file, but how to boot to linux-boot.img in a different partition from Android?
3. Or is it possible to wipe userdata - 'wipe data' command as in terminal but upon first boot automatically before booting to Android homescreen and only the first time firmware is run and then not again.
It would be really nice if help can be provided for above situations and if there is a solution for one of them.
Thanks
Posted at 2/28/2015 09:43:34        Only Author  2#
Re: Completely erase EMMC flash storage/userdata from PC?
Hi dewet, plz see this post:
Dual boot on Firefly-RK3288
http://developer.t-firefly.com/en/viewt ... f=12&t=263
Posted at 2/28/2015 12:01:23        Only Author  3#
Very helpful
Didn't know about the firstboot, will add something like it and see if it works.
Posted at 3/1/2015 03:43:09        Only Author  4#
@dewet
Had much the same problem, but mine was with the s/d card.  Found that the MBR (Parameter) on the s/d card was not being addressed (erased) when changing Operational system and the new MBR (New Parameter) wasn't there.  Also when just using it in different formats, including windows.  So I found this tool to erase the s/d MBR.  https://www.sdcard.org/downloads/formatter_4/
--cappybob
Posted at 1/9/2026 08:26:28        Only Author  5#
Im utterly amazed by your article, thank you for sharing it! Sharing the Reliable CWDP-305 exam blueprint test materials with you allbest of luck!
Posted at 1/11/2026 07:29:38        Only Author  6#
I really appreciate your article, it left a strong impression. Im confident the Latest exam GDAT certification cost content will be helpful, and it's free for everyone.
Posted at 1/26/2026 19:32:42        Only Author  7#
Your article was so refreshing, I really appreciate it. The SecOps-Pro valid braindumps free helped me secure a promotion and raise. Now its free to everyone. Wishing you all a bright future in your careers!
Posted at 2/17/2026 08:10:53        Only Author  8#
I was really impressed with how much I learned from the article. Using this Reliable NCP-CI-AWS exam answers, I earned a promotion and raise. Now, its free for everyone. Best of luck in your career growth!
Posted at 4/20/2026 06:34:30        Only Author  9#
Thank you for sharing, this article really left a deep impression on me! The AB-900 reliable real test question material is very useful, and its available at no charge.
