[General] 1Z0-1042-25 Certification Sample Questions - 1Z0-1042-25 Vce File
【General】 1Z0-1042-25 Certification Sample Questions - 1Z0-1042-25 Vce File
Posted at 1/19/2026 02:04:16      View:173 | Replies:4        Print      Only Author   [Copy Link] 1#
2026 Latest Braindumpsqa 1Z0-1042-25 PDF Dumps and 1Z0-1042-25 Exam Engine Free Share: https://drive.google.com/open?id=19Nzk3RUZI84Z8gF4vhDd9-jzTU4mzQp3
As for our 1Z0-1042-25 exam braindump, our company masters the core technology, owns the independent intellectual property rights and strong market competitiveness. What is more, we have never satisfied our current accomplishments. Now, our company is specialized in design, development, manufacturing, marketing and retail of the 1Z0-1042-25 test question, aimed to provide high quality product, solutions based on customer's needs and perfect service of the 1Z0-1042-25 Exam braindump. At the same time, we have formed a group of passionate researchers and experts, which is our great motivation of improvement. Every once in a while we will release the new version study materials. You will enjoy our newest version of the 1Z0-1042-25 study prep after you have purchased them. Our ability of improvement is stronger than others. New trial might change your life greatly.
Studies show that some new members of the workforce are looking for more opportunity to get promoted but get stuck in an awkward situation, because they have to make use of their fragment time and energy to concentrate on 1Z0-1042-25 exam preparation. Our 1Z0-1042-25 exam materials embrace much knowledge and provide relevant exam bank available for your reference, which matches your learning habits and produces a rich harvest of the exam knowledge. You can not only benefit from our 1Z0-1042-25 Exam Questions, but also you can obtain the 1Z0-1042-25 certification.
Here's a Quick and Proven Way to Pass 1Z0-1042-25 Certification examBraindumpsqa to provide you with the real exam environment to help you find the real Oracle 1Z0-1042-25 exam preparation process. If you are a beginner or want to improve your professional skills, Braindumpsqa Oracle 1Z0-1042-25 will help you, let you approached you desire step by step. If you have any questions on the exam question and answers, we will help you solve it. Within a year, we will offer free update.
Oracle Cloud Infrastructure 2025 Application Integration Professional Sample Questions (Q65-Q70):NEW QUESTION # 65
Your team is using a JavaScript library function within an Oracle Integration (OIC) integration flow. Because of business requirements, one of the functions needs to be updated with additional code to incorporate new logic. Which consideration regarding JavaScript library functions is NOT valid?
  • A. The JavaScript action has a timeout threshold of 60 seconds.
  • B. Network, disk, or thread access is not supported from within a JavaScript function.
  • C. JavaScript functions are not allowed to make outbound calls to external services.
  • D. Active integrations using a function that has been updated must be reactivated.
JavaScript Constraints:
A:False-limited outbound calls allowed.
NEW QUESTION # 66
A Logger action enables you to log messages at runtime for fault diagnostic purposes. Which is NOT a valid statement concerning Logger action capabilities?
  • A. You can always specify to log, even when the integration's tracing level is set to Production.
  • B. It always logs messages if the integration's tracing level is set to Audit.
  • C. Debug-level messages require the integration's tracing level to be set to Debug.
  • D. It logs messages only to the activity stream and diagnostic logs.
Logger Action:
B:False-not guaranteed at Audit level.
NEW QUESTION # 67
Integration Insight in Oracle Integration Cloud (OIC) dramatically simplifies the process of modeling and extracting meaningful business metrics, allowing business executives to understand, monitor, and react quickly to changing demands.
After a model has been activated, which is NOT a valid model instance state?
  • A. Healthy
  • B. Successful
  • C. Failed
  • D. Recoverable
  • E. Terminated
Answer: E
"Terminated" is not a valid state for Integration Insight model instances. Valid states include Failed, Successful, Healthy, and Recoverable.
NEW QUESTION # 68
You are working on an integration within Oracle Integration Cloud (OIC) that includes several connections to external systems. As part of your development work, you need help to implement Global Fault handling to ensure that any unexpected errors are caught and handled correctly. Which approach should you use to add global fault handling within your integration?
  • A. Add a Try-Catch action to your integration flow and configure it to catch and handle any faults.
  • B. Open the Global Fault handler page on the integration canvas and add actions as needed to handle unexpected faults.
  • C. Use the Raise Fault action within your integration flow to generate custom faults and handle them accordingly.
  • D. Create a separate integration solely for the purpose of handling faults and configure your main integration to call it when necessary.
Fault handling in OIC:
C:True-OIC provides aGlobal Fault Handleron the canvas to manage uncaught errors centrally.
A:False-Raise Fault generates faults, not handles them globally.
B:False-separate integrations are inefficient for this.
NEW QUESTION # 69
Oracle Integration (OIC) provides the File Server feature, which is an embedded SFTP server that enables organizations to focus on building integrations without the need to host and maintain a separate SFTP server.
Which statement is NOT valid concerning the OIC File Server feature?
  • A. To write files to the OIC File Server from an internal OIC integration flow, a File Server action must be used.
  • B. Any external SFTP client can access File Server if an OIC administrator has configured specific folder access permissions for that client.
  • C. Access to the OIC File Server Management REST APIs is limited to users that have been granted the ServiceAdministrator role.
  • D. The OIC File Server is disabled by default in a newly provisioned OIC instance.
File Server:
B:False-File Adapter, not "File Server action," is used.
NEW QUESTION # 70
Once you have selected the 1Z0-1042-25 study materials, please add them to your cart. Then when you finish browsing our web pages, you can directly come to the shopping cart page and submit your orders of the 1Z0-1042-25 study materials. Our payment system will soon start to work. Then certain money will soon be deducted from your credit card to pay for the 1Z0-1042-25 study materials. The whole payment process only lasts a few seconds as long as there has money in your credit card. Then our system will soon deal with your orders according to the sequence of payment. Usually, you will receive the 1Z0-1042-25 Study Materials no more than five minutes. Then you can begin your new learning journey of our study materials. All in all, our payment system and delivery system are highly efficient.
1Z0-1042-25 Vce File: https://www.braindumpsqa.com/1Z0-1042-25_braindumps.html
How can this Oracle 1Z0-1042-25 braindump package "GUARANTEE" I will pass my 1Z0-1042-25 exam, Oracle 1Z0-1042-25 Certification Sample Questions You just need to spend about 48 to 72 hours on practicing that you can pass the exam, You think your investment on the products are worth and may do some help to your 1Z0-1042-25 Vce File - Oracle Cloud Infrastructure 2025 Application Integration Professional exam test, Our 1Z0-1042-25 study materials are always the latest version with high quality.
Sometimes developing a market is hard, Customizing Your Dashboard, How can this Oracle 1Z0-1042-25 braindump package "GUARANTEE" I will pass my 1Z0-1042-25 Exam?
You just need to spend about 48 to 72 hours on practicing that 1Z0-1042-25 you can pass the exam, You think your investment on the products are worth and may do some help to your Oracle Cloud Infrastructure 2025 Application Integration Professional exam test.
Use Oracle 1Z0-1042-25 PDF Questions And Get Excellent MarksOur 1Z0-1042-25 study materials are always the latest version with high quality, Besides, the software version can simulate the real test environment, which is favorable for people to better adapt to the examination atmosphere.
P.S. Free & New 1Z0-1042-25 dumps are available on Google Drive shared by Braindumpsqa: https://drive.google.com/open?id=19Nzk3RUZI84Z8gF4vhDd9-jzTU4mzQp3
Posted at 2/4/2026 10:46:07        Only Author  2#
I sincerely thank you for sharing such a shocking article! The Salesforce-MuleSoft-Developer-I reliable study materials helped me secure a promotion and raise. Now it’s free to everyone. Wishing you all a bright future in your careers!
Posted at 2/4/2026 19:44:23        Only Author  3#
That piece really enriched my understanding. The Reliable AAISM practice questions files test was instrumental in my professional growth and salary increase, and today, it’s free for you!
Posted at 2/6/2026 21:43:20        Only Author  4#
I’m so appreciative of your article, it was really eye-catching. I hope the Trustworthy C_BCHCM_2502 exam torrent material helps, and it's entirely free.
Posted at 2/7/2026 11:16:11        Only Author  5#
Thank you for sharing such a powerful article, it really left an impression. Thanks to CAPM reliable test bootcamp, I secured a promotion and pay raise—today, I’m sharing it for free!
