Unique Pure Storage FAAA_005 Pdf Questions
Posted at 1/13/2026 14:41:27
With the development of science, our life has become more and more comfortable and convenient than ever before. Pure Storage certifications are attractive and FAAA_005 exam learning materials become popular since IT workers positions are much in demand. Technology change world. There are many opportunities in the internet every day. Ambitious people may choose FAAA_005 Exam Learning materials into internet area and want to do something different.
Under the support of our study materials, passing the exam won’t be an unreachable mission. More detailed information is under below. We are pleased that you can spare some time to have a look for your reference about our FAAA_005 test prep. As long as you spare one or two hours a day to study with our laTest FAAA_005 Quiz prep, we assure that you will have a good command of the relevant knowledge before taking the exam. What you need to do is to follow the FAAA_005 exam guide system at the pace you prefer as well as keep learning step by step.
FAAA_005 Latest Braindumps Sheet & FAAA_005 Valid Test NotesExam4Docs FAAA_005 desktop and web-based practice exams are distinguished by their excellent features. The FAAA_005 web-based practice exam is supported by all operating systems and can be taken through popular browsers including Chrome, MS Edge, Internet Explorer, Opera, Firefox, and Safari. Windows computers can run the desktop Pure Storage FAAA_005 Practice Test software. You won't require a live internet connection to use the desktop Pure Storage exam simulation software once you've verified the product's license.
Pure Storage FlashArray Architect Associate Sample Questions (Q21-Q26):NEW QUESTION # 21
A customer currently has a FlashArray//X for their block storage with 40 TB of available storage. They need 10 TB of file workloads and want to spend the least amount possible on infrastructure.
What should the SE recommend?
- A. Add another disk pool for file storage to their current FlashArray
- B. Purchase an entry level FlashBlade for the file workload
- C. NDU the FlashArray //X to a //XL and run both workloads there
- D. Run both workloads on the current FlashArray
The customer currently has a FlashArray//X with 40 TB of available block storage and needs to add 10 TB of file workloads while minimizing infrastructure costs. Let's analyze the options:
Analysis of Options:
A). Run both workloads on the current FlashArray:
Pure Storage FlashArray supports both block and file workloads using the Purity File Services feature, which allows customers to run file workloads directly on their FlashArray.
Since the FlashArray already has 40 TB of available storage, adding 10 TB of file workloads is feasible without requiring additional hardware. This is the most cost-effective solution.
B). Add another disk pool for file storage to their current FlashArray:
Adding a separate disk pool for file storage is unnecessary because Purity File Services can handle both block and file workloads on the same array.
C). Purchase an entry-level FlashBlade for the file workload:
While FlashBlade is designed for file and object workloads, purchasing a new FlashBlade would be significantly more expensive than leveraging the existing FlashArray. This option does not align with the customer's goal of minimizing costs.
D). NDU the FlashArray //X to a //XL and run both workloads there:
Upgrading the FlashArray//X to a FlashArray//XL via a Non-Disruptive Upgrade (NDU) is unnecessary for this use case. The current FlashArray//X has sufficient capacity to handle both workloads, and upgrading to a higher-tier array would increase costs unnecessarily.
Recommendation:
The most cost-effective solution is
A). Run both workloads on the current FlashArray, leveraging Purity File Services to support the file workload.
Reference: Purity File Services Documentation:
Explains how to configure and use file services on FlashArray.
FlashArray Use Cases:
Highlights the versatility of FlashArray for both block and file workloads.
NEW QUESTION # 22
What is the total amount of usable storage space consumed on this FlashArray system?
- A. 1.22 T
- B. 3.87 T
- C. 5.58 T
- D. 4.36 T
Why This Matters:
Usable Storage Space Consumed:
The "usable storage space consumed" refers to the actual physical capacity used on the array after accounting for RAID overhead but before applying data reduction techniques like deduplication and compression.
This value represents the raw space utilized by the data stored on the array, excluding any logical space savings from data reduction.
Why Not the Other Options?
B). 5.58 T:
This value likely represents the logical capacity provisioned or consumed after applying data reduction techniques (e.g., deduplication and compression). However, the question specifically asks for the usable storage space consumed, which excludes logical space savings.
C). 1.22 T:
This value might represent the raw capacity of the drives or some other metric unrelated to the usable storage space consumed. It does not align with the definition of usable storage space.
D). 4.36 T:
This value could represent an intermediate calculation or another metric, but it does not match the usable storage space consumed as shown in the exhibit.
Key Points:
Usable Storage Space Consumed: Represents the physical capacity used on the array after RAID overhead but before data reduction.
Logical vs. Physical Capacity: Logical capacity reflects space savings from deduplication and compression, while usable storage space reflects the actual physical usage.
Exhibit Analysis: Carefully interpret the metrics provided in the exhibit to identify the correct value.
Reference: Pure Storage FlashArray Documentation: "Understanding Array Capacity Metrics" Pure Storage Whitepaper: "Capacity Management and Data Reduction" Pure Storage Knowledge Base: "What is Usable Space vs. Raw Space?"
NEW QUESTION # 23
A Storage Administrator has two //X50R3 FlashArrays. The two FlashArrays are located in different data centers with a network link between them. The ethernet link between data centers has a latency of 35 ms.
Which Purity feature will provide protection against a site failure with the lowest recovery point?
- A. Local snapshots
- B. ActiveDR
- C. Snapshot replication
- D. ActiveCluster
Given that the two FlashArrays are located in different data centers with a network link latency of 35 ms, the best Purity feature to provide protection against a site failure with the lowest recovery point is ActiveDR.
Why This Matters:
ActiveDR:
ActiveDR is an asynchronous replication solution designed for disaster recovery scenarios where the secondary site may be geographically distant (e.g., >10 ms latency).
It provides low RPOs (typically seconds to minutes) and supports fast failover and failback capabilities, ensuring minimal data loss and downtime.
With a 35 ms latency between sites, synchronous replication (e.g., ActiveCluster) is not feasible due to the high latency impacting performance.
A). ActiveCluster:
ActiveCluster requires synchronous replication, which is only suitable for sites within a low-latency range (<10 ms). At 35 ms latency, ActiveCluster would cause significant performance degradation.
C). Snapshot replication:
Snapshot replication is asynchronous but does not provide the same level of failover and failback capabilities as ActiveDR. It is better suited for backup purposes rather than disaster recovery with low RPOs.
D). Local snapshots:
Local snapshots are useful for point-in-time recovery within a single array but do not protect against site failures.
Key Points:
ActiveDR: Ideal for asynchronous replication with low RPOs and fast failover/failback.
Latency Considerations: ActiveDR supports higher latencies (e.g., 35 ms) compared to synchronous solutions like ActiveCluster.
Disaster Recovery: Ensures protection against site failures with minimal data loss and downtime.
Reference: Pure Storage FlashArray Documentation: "ActiveDR for Disaster Recovery" Pure Storage Whitepaper: "Meeting RPO and RTO Requirements with FlashArray" Pure Storage Knowledge Base: "Choosing the Right Replication Solution for High Latency"
NEW QUESTION # 24
Which Pure Storage offering can be deployed in AWS?
- A. ObjectEngine
- B. CloudSnap
- C. Cloud Block Store
The Pure Storage offering that can be deployed in AWS is Cloud Block Store.
Why This Matters:
Cloud Block Store:
Cloud Block Store is a cloud-native block storage solution that runs in public clouds like AWS and Azure.
It provides enterprise-grade storage features, including deduplication, compression, and thin provisioning, while seamlessly integrating with on-premises FlashArray environments.
A). ObjectEngine:
ObjectEngine is a backup and recovery solution designed for rapid restores and backups. It is not a storage solution that can be deployed in AWS.
C). CloudSnap:
CloudSnap is a feature that offloads snapshots to cloud storage (e.g., AWS S3 or Azure Blob). It is not a standalone storage solution but rather a feature of FlashArray.
Key Points:
Cloud Block Store: Provides block storage in AWS with enterprise-grade features.
Integration: Seamlessly integrates with on-premises FlashArray environments for hybrid cloud architectures.
Scalability: Enables scalable and cost-effective storage in the cloud.
Reference: Pure Storage Cloud Block Store Documentation: "Deploying Cloud Block Store in AWS" Pure Storage Whitepaper: "Hybrid Cloud Architectures with FlashArray and Cloud Block Store" Pure Storage Knowledge Base: "Cloud Block Store Use Cases and Deployment"
NEW QUESTION # 25
A potential customer has a use case where they need to use a stretched cluster for high availability and also require a third copy of their data in a remote geographic location.
Which replication method should be recommended?
- A. CloudSnap to an offload target
- B. Fan-out asynchronous snapshot replication
- C. ActiveDR with periodic snapshot replication
- D. ActiveCluster with asychronous snapshot replication
The customer requires a storage solution that supports a stretched cluster for high availability and also maintains a third copy of their data in a remote geographic location. The best replication method to recommend is ActiveCluster with asynchronous snapshot replication.
Why This Matters:
ActiveCluster:
ActiveCluster provides synchronous replication between two sites within a stretched cluster, ensuring zero RPO and near-zero RTO for high availability.
It is ideal for scenarios where applications require continuous access to data across two locations.
Asynchronous Snapshot Replication:
Asynchronous replication extends the disaster recovery strategy by replicating snapshots to a third site. This ensures an additional layer of protection against regional failures.
A). CloudSnap to an offload target:
CloudSnap is used to offload snapshots to cloud storage (e.g., AWS S3 or Azure Blob). While it satisfies the requirement for a third copy, it does not integrate with ActiveCluster for high availability in a stretched cluster.
B). Fan-out asynchronous snapshot replication:
Fan-out replication involves sending snapshots to multiple targets asynchronously. However, it does not provide the synchronous replication required for a stretched cluster.
C). ActiveDR with periodic snapshot replication:
ActiveDR is designed for asynchronous replication and failover/failback scenarios but does not support synchronous replication for a stretched cluster.
Key Points:
ActiveCluster: Ensures high availability with synchronous replication in a stretched cluster.
Async Replication: Adds a third-site replication target for comprehensive disaster recovery.
Integrated Solution: Combines high availability and disaster recovery into a single architecture.
Reference: Pure Storage FlashArray Documentation: "ActiveCluster with Async Replication" Pure Storage Whitepaper: "Disaster Recovery Strategies with FlashArray" Pure Storage Knowledge Base: "Using Protection Groups in Stretched Pods"
NEW QUESTION # 26
The clients can use the shortest time to prepare the exam and the learning only costs 20-30 hours. The questions and answers of our FAAA_005 Exam Questions are refined and have simplified the most important information so as to let the clients use little time to learn. The client only need to spare 1-2 hours to learn our Pure Storage FlashArray Architect Associate study question each day or learn them in the weekends. Commonly speaking, people like the in-service staff or the students are busy and don’t have enough time to prepare the exam. Learning our Pure Storage FlashArray Architect Associate test practice dump can help them save the time and focus their attentions on their major things.
FAAA_005 Latest Braindumps Sheet: https://www.exam4docs.com/FAAA_005-study-questions.html
For PDF version, you can print FAAA_005 : Pure Storage FlashArray Architect Associate dump out as you may want to have some notes in the process of learning, Pure Storage New FAAA_005 Braindumps Questions In addition, some preferential activities will be provided in further cooperation, Pure Storage New FAAA_005 Braindumps Questions SOFT is proper to all Windows systems and it is equipped with real examination style, FAAA_005 practice dumps are the trustworthy source which can contribute to your actual exam test.
If you decide to buy the FAAA_005 study question from our company, you will receive a lot beyond your imagination, Wait, not the sloppy grunting kind, For PDF version, you can print FAAA_005 : Pure Storage FlashArray Architect Associate dump out as you may want to have some notes in the process of learning.
Free PDF Pure Storage - FAAA_005 - Pure Storage FlashArray Architect Associate –Professional New Braindumps QuestionsIn addition, some preferential activities will be provided FAAA_005 in further cooperation, SOFT is proper to all Windows systems and it is equipped with real examination style.
FAAA_005 practice dumps are the trustworthy source which can contribute to your actual exam test, In the same way, Exam4Docs update its Selling Pure Storage FlashArray Architect Associate (FAAA_005) exam questions bank in the PDF version so users get the latest material for FAAA_005 exam preparation.
- FAAA_005 Real Dumps 👼 Valid Braindumps FAAA_005 Free 😘 FAAA_005 Valid Test Question 🥿 The page for free download of 【 FAAA_005 】 on ➥ [url]www.prep4sures.top 🡄 will open immediately 🍿FAAA_005 Latest Exam Forum[/url]
- New FAAA_005 Exam Questions 👧 New FAAA_005 Exam Questions 🎣 FAAA_005 Real Dumps 🏖 Search for ✔ FAAA_005 ️✔️ on ⇛ [url]www.pdfvce.com ⇚ immediately to obtain a free download 🤼FAAA_005 Latest Test Preparation[/url]
- FAAA_005 Latest Test Preparation 🚈 Unlimited FAAA_005 Exam Practice 🦇 FAAA_005 Reliable Test Dumps ↗ Copy URL [ [url]www.prep4away.com ] open and search for ⮆ FAAA_005 ⮄ to download for free 🚛New FAAA_005 Exam Book[/url]
- FAAA_005 Latest Test Preparation 😹 FAAA_005 Valid Test Question 📥 FAAA_005 Top Dumps 🏌 Search for ✔ FAAA_005 ️✔️ on “ [url]www.pdfvce.com ” immediately to obtain a free download 😟FAAA_005 Vce File[/url]
- Free PDF Quiz 2026 High Hit-Rate Pure Storage New FAAA_005 Braindumps Questions 🥓 Copy URL 「 [url]www.easy4engine.com 」 open and search for [ FAAA_005 ] to download for free ⌛FAAA_005 Latest Test Preparation[/url]
- Authentic Pure Storage FAAA_005 Exam Questions with Accurate Answers 🧚 Open website 「 [url]www.pdfvce.com 」 and search for ▶ FAAA_005 ◀ for free download 🧈FAAA_005 Sample Questions[/url]
- FAAA_005 Latest Demo 🚔 FAAA_005 Latest Test Preparation 🤨 FAAA_005 Vce File 🌝 Download ( FAAA_005 ) for free by simply entering 【 [url]www.verifieddumps.com 】 website 🥶FAAA_005 Latest Test Preparation[/url]
- 100% Pass Pure Storage - FAAA_005 –High-quality New Braindumps Questions 🍊 Download ✔ FAAA_005 ️✔️ for free by simply searching on ➡ [url]www.pdfvce.com ️⬅️ 🔌FAAA_005 Valid Torrent[/url]
- Reliable FAAA_005 Test Cram 🎋 FAAA_005 Real Dumps 🏙 Latest FAAA_005 Material 🏋 Easily obtain ➥ FAAA_005 🡄 for free download through ➽ [url]www.examcollectionpass.com 🢪 🤹Exam FAAA_005 Fee[/url]
- FAAA_005 valid study dumps -FAAA_005 actual prep torrent 😛 Search for ✔ FAAA_005 ️✔️ and download exam materials for free through ⇛ [url]www.pdfvce.com ⇚ 🩸Latest FAAA_005 Material[/url]
- Free Demo Version and Free Updates of Real Pure Storage FAAA_005 Questions 🕡 Easily obtain free download of 「 FAAA_005 」 by searching on ☀ [url]www.prep4sures.top ️☀️ 📆New FAAA_005 Exam Book[/url]
- myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, www.9kuan9.com, www.stes.tyc.edu.tw, ncon.edu.sa, www.stes.tyc.edu.tw, bbs.t-firefly.com, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, bbs.t-firefly.com, www.stes.tyc.edu.tw, Disposable vapes
