[General] SD-WAN-Engineer Latest Dumps & SD-WAN-Engineer Latest Exam Question
80
General SD-WAN-Engineer Latest Dumps & SD-WAN-Engineer Latest Exam Question
Posted at 1/20/2026 05:32:18      View182 | Replies3        Print      Only Author   [Copy Link] 1#
Don't you want to make a splendid achievement in your career? Certainly hope so. Then it is necessary to constantly improve yourself. Working in the Palo Alto Networks industry, what should you do to improve yourself? In fact, it is a good method to improve yourself by taking Palo Alto Networks certification exams and getting Palo Alto Networks certificate. Palo Alto Networks certificate is very important certificate, so more and more people choose to attend SD-WAN-Engineer Certification Exam.
Palo Alto Networks SD-WAN-Engineer Exam Syllabus Topics:
  • Unified SASE: This domain covers Prisma SD-WAN integration with Prisma Access, ADEM configuration, IoT connectivity via Device-ID, Cloud Identity Engine integration, and User
  • Group-based policy implementation.
  • Troubleshooting: This domain focuses on resolving connectivity, routing, forwarding, application performance, and policy issues using co-pilot data analysis and analytics for network optimization and reporting.
  • Operations and Monitoring: This domain addresses monitoring device statistics, controller events, alerts, WAN Clarity reports, real-time network visibility tools, and SASE-related event management.
  • Planning and Design: This domain covers SD-WAN planning fundamentals including device selection, bandwidth and licensing planning, network assessment, data center and branch configurations, security requirements, high availability, and policy design for path, security, QoS, performance, and NAT.
Topic 5
  • Deployment and Configuration: This domain focuses on Prisma SD-WAN deployment procedures, site-specific settings, configuration templates for different locations, routing protocol tuning, and VRF implementation for network segmentation.
Free PDF Quiz Palo Alto Networks - Useful SD-WAN-Engineer Latest DumpsMany people dream about occupying a prominent position in the society and being successful in their career and social circle. Thus owning a valuable certificate is of paramount importance to them and passing the test SD-WAN-Engineer Certification can help them realize their goals. We treat your time as our own time, as precious as you see, so we never waste a minute or two in some useless process. Please rest assured that use, we believe that you will definitely pass the exam.
Palo Alto Networks SD-WAN Engineer Sample Questions (Q25-Q30):NEW QUESTION # 25
Two branch sites, "Branch-A" and "Branch-B", are both behind active NAT devices (Source NAT) on their local internet circuits.
What requirement must be met for these two branches to successfully establish a direct Dynamic VPN (ION-to-ION) tunnel over the internet?
  • A. One of the sites must have a Static Public IP (1:1 NAT) to act as the initiator.
  • B. Dynamic VPNs are not supported if both sides are behind NAT.
  • C. Both sites must disable NAT and use public IPs on the ION interface.
  • D. The ION devices automatically use STUN (Session Traversal Utilities for NAT) to discover their public IPs and negotiate the connection.
Comprehensive and Detailed Explanation
Prisma SD-WAN supports Dynamic VPNs (Branch-to-Branch) even when both endpoints are behind Source NAT (e.g., typical broadband connections).
To achieve this, the ION devices utilize standard NAT Traversal techniques, specifically leveraging STUN (Session Traversal Utilities for NAT).
Discovery: Each ION communicates with the Cloud Controller (which acts as a STUN server/signaling broker). Through this communication, the controller observes the public IP and Port that the ION's traffic is coming from (the post-NAT address).
Signaling: The controller shares this public reachability information with the peer ION.
Hole Punching: The IONs then attempt to initiate connections to each other's discovered public IP/Port. This "UDP Hole Punching" allows them to establish a direct IPSec tunnel through the NAT devices without requiring static 1:1 NAT mapping or manual port forwarding on the provider routers, enabling mesh connectivity in commodity internet environments.
NEW QUESTION # 26
A network engineer is able to ping and traceroute from SD-WAN branch IP 192.168.1.123 to servers in primary data center - DC1, but is unable to ping or traceroute to a server 10.2.2.22 in the newly configured secondary data center, DC2.
The DC2 ION device is advertising the branch IP subnet 192.168.1.0/24 to the DC2 core via eBGP Core Peer. The DC2 data center site has site prefix 10.2.2.0/23 configured.
Which configuration will resolve the issue in this scenario?
  • A. Reconfigure eBGP Core Peer as Edge Peer type.
  • B. Remove site prefix 10.2.2.0/23 from DC2 site configuration.
  • C. The default 0.0.0.0/0 static route to the DC2 ION pointing to the DC2 next hop.
  • D. Reconfigure eBGP Core Peer to iBGP Core Peer.
Comprehensive and Detailed Explanation at least 150 to 250 words each from Palo Alto Networks SD-WAN Engineer documents:
In a Prisma SD-WAN deployment, the routing of traffic between branches and Data Centers (DCs) relies on the proper synchronization between the AppFabric (the overlay) and the local routing protocols (the underlay/LAN side). In this scenario, the branch can successfully reach DC1, indicating the branch ION is correctly participating in the fabric. However, traffic to DC2 (10.2.2.22) is failing.
The DC2 site has the site prefix 10.2.2.0/23 configured. In Prisma SD-WAN, defining a site prefix informs the Controller that this specific subnet "belongs" to that site, causing the Controller to advertise reachability for this prefix to all other ION devices in the fabric. Consequently, when the branch ION (192.168.1.123) attempts to reach 10.2.2.22, it correctly identifies DC2 as the destination and encapsulates the traffic toward the DC2 ION.
The bottleneck occurs once the packet arrives at the DC2 ION. While the ION is advertising the branch subnet (192.168.1.0/24) to the DC Core (ensuring the return path), the ION itself must know how to forward the incoming traffic from the branch to the internal DC network. If the DC2 ION does not have a specific route in its local routing table for the 10.2.2.0/23 subnet pointing to the DC Core's internal interface, the packet will be dropped.
According to Palo Alto Networks best practices for Data Center ION deployment, a static default route (0.0.0.0/0) should be configured on the ION device pointing toward the DC Core's next-hop IP address. This ensures that any traffic received from the AppFabric destined for internal DC resources-which are not directly connected to the ION-is successfully handed off to the core switching fabric for final delivery. Adding this default route (Option A) resolves the reachability issue by providing the "last-hop" routing instruction within the DC.
NEW QUESTION # 27
User-ID integration is configured for a Prisma SD-WAN deployment. Branch-1 has the user-to-IP mappings available, and User-1 is mapped to IP-1.
To which two use cases can User-ID based zone-based firewall policies be applied? (Choose two.)
  • A. User-1 accessing a private application in data center via SD-WAN overlay, and destination User-ID based zone-based firewall rules on DC ION
  • B. User-1 accessing a SaaS application on direct internet and source User-ID based zone-based firewall rules on Branch-1 ION
  • C. User-1 accessing a private application in Branch-2 via SD-WAN overlay, and destination User-ID based zone-based firewall rules on Branch-2 ION
  • D. User-1 accessing a private application within Branch-1, and source User-ID based zone-based firewall rules on Branch-1 ION
In Prisma SD-WAN (CloudGenix), Zone-Based Firewall (ZBFW) policies rely on the device's ability to map an IP address to a User-ID to enforce identity-based rules. The key to this question is understanding where the mapping exists and which direction the policy attributes (Source User vs. Destination User) apply to.
1. Mapping Location (Branch-1): The prompt states that Branch-1 has the user-to-IP mapping for User-1. For the most effective and scalable security enforcement, policies should be applied at the source (ingress) device where the traffic originates and where the user identity is known. This prevents unauthorized traffic from consuming WAN bandwidth only to be dropped at the destination. Therefore, the Branch-1 ION is the correct enforcement point for User-1's traffic.
2. Source vs. Destination User:
User-1 is the Source: In all scenarios, User-1 is the initiator of the traffic. Therefore, the security rule must match on Source User-ID.
Options C and D are incorrect because they suggest using Destination User-ID based rules to control User-1. Destination User-ID rules are used when the target of the traffic is a known user (e.g., VoIP calls to a specific user's phone), not when filtering based on the sender. Furthermore, relying on the DC or Branch-2 ION to enforce policies for User-1 would require the propagation of User-ID mappings across the overlay, whereas local enforcement at Branch-1 is the standard architectural model.
3. Valid Use Cases (A and B):
Option A (SaaS/Internet): The Branch-1 ION acts as the internet gateway. It can use the local mapping (IP-1 = User-1) to allow or deny access to specific SaaS applications (Direct Internet Access) based on the user's identity (e.g., "Allow Marketing Group to access Social Media").
Option B (Internal Segmentation): The Branch-1 ION can enforce policies for traffic moving between local zones (e.g., from a "Users" VLAN to a "Servers" VLAN within the branch). Since the ION routes this traffic and holds the mapping, it can enforce Source User-ID policies to secure local private applications.
NEW QUESTION # 28
An administrator is configuring an ION 2000 device for a deployment where high availability is required, but the site has only a single internet circuit. The administrator configures a Bypass Pair (Fail-to-Wire) on ports 1 and 2 connecting the ISP modem to the legacy firewall.
If the ION device loses power, what is the resulting behavior of the traffic flowing through this Bypass Pair?
  • A. Traffic is blocked to prevent uninspected packets from entering the network (Fail-to-Block).
  • B. Traffic is rerouted to the LTE modem automatically.
  • C. The internal relay closes, physically bridging Port 1 and Port 2, allowing traffic to flow transparently between the modem and firewall.
  • D. The device reboots into "Safe Mode" and acts as a Layer 2 switch.
The Bypass Pair feature on Prisma SD-WAN ION devices (specifically supported models like ION 2000, 3000, 7000, 9000) is a hardware-based resiliency mechanism known as Fail-to-Wire.
Operation: A "Bypass Pair" logically groups two physical interfaces (e.g., WAN 1 and LAN 1). Under normal operation, the ION processes traffic between them.
Power Loss: In the event of a total power loss (or critical software failure), a mechanical relay inside the device physically closes the circuit between the two ports.
Result: This creates a direct electrical connection (like a patch cable) between the upstream device (ISP Modem) and the downstream device (Legacy Firewall or Router). This ensures that internet connectivity is preserved for the site, even if the SD-WAN appliance is completely dead. This is critical for single-point-of-failure deployments where maintaining basic dial-tone is more important than SD-WAN optimization during a hardware outage.
NEW QUESTION # 29
An administrator has configured a Path Policy for "ERP_Traffic". The policy allows two public internet links, "ISP-A" and "ISP-B", both marked as "Active". The Path Quality Profile (SLA) requires a latency of less than 150ms. Currently, both ISP-A and ISP-B have a latency of 40ms, well within the SLA.
How does the Prisma SD-WAN ION determine which link to use for a new flow of "ERP_Traffic" when both active paths meet the SLA requirements?
  • A. It selects the path that appears first in the interface configuration list.
  • B. It selects the path with the highest available bandwidth capacity.
  • C. It selects the path with the lowest numerical latency (e.g., if ISP-A drops to 39ms).
  • D. It duplicates the packets across both paths (Packet Duplication) to ensure delivery.
Prisma SD-WAN utilizes a sophisticated decision engine for Application-Based Path Selection that goes beyond simple failover. When configuring a Path Policy, the administrator defines "Active" paths and a "Path Quality Profile" (SLA).
SLA Compliance (The Filter): First, the system filters the available paths based on the Path Quality Profile. In this scenario, both ISP-A and ISP-B have 40ms latency against a 150ms threshold. Both are "green" or compliant paths.
Selection Criteria (The Tie-Breaker): When multiple paths are configured as "Active" and all meet the performance SLA, the ION device aims to optimize the overall user experience and network utilization. The default behavior for load balancing across healthy, compliant active paths is to select the path with the highest available bandwidth capacity.
By steering new flows to the link with the most "headroom" (available Mbps), the system prevents the saturation of a smaller link (e.g., a 20Mbps DSL line) while a larger link (e.g., 1Gbps Fiber) sits underutilized. This maximizes the aggregate throughput for the site. While latency is the qualifier, bandwidth availability is often the selector for compliant paths. Note that if the application was defined as "Real-Time" and configured for packet duplication, behavior would differ, but for standard traffic, capacity-based distribution is the standard active/active logic.
NEW QUESTION # 30
In the 21 Century, the SD-WAN-Engineer certification became more and more recognized in the society because it represented the certain ability of examinees. However, in order to obtain SD-WAN-Engineer certification, you have to spend a lot of time preparing for the SD-WAN-Engineer Exam. Many people gave up because of all kinds of difficulties before the examination, and finally lost the opportunity to enhance their self-worth. But our SD-WAN-Engineer exam questions will help you pass the exam for sure.
SD-WAN-Engineer Latest Exam Question: https://www.testkingpdf.com/SD-WAN-Engineer-testking-pdf-torrent.html
Posted at 2/1/2026 03:17:10        Only Author  2#
I really appreciate the inspiration in this article, thank you for sharing! Best of luck to everyonefree Latest 220-1202 practice questions pdf questions are now available!
Posted at 2/9/2026 23:35:13        Only Author  3#
우리 ExamPassdump사이트에서 제공되는Huawei인증H19-427_V1.0-ENU시험덤프의 일부분인 데모 즉 문제와 답을 다운받으셔서 체험해보면 우리ExamPassdump에 믿음이 갈 것입니다. 우리ExamPassdump의 제품을 구매하신다고 하면 우리는 최선을 다하여 여러분들한테 최고의 버전을 제공함으로 한번에Huawei인증H19-427_V1.0-ENU시험을 패스하도록 하겠습니다. IT시험이라고 모두 무조건 외우고 장악하고 많은 시간을 투자해야만 된다는 사상을 깨게 될 것입니다.
Posted at 2/11/2026 18:00:42        Only Author  4#
The content is deep, and Ive gained a lot of useful knowledge from it. Free Test JN0-481 cram pdf resources are the key to unlocking promotions and salary increases!
