[Linux] kernel 5.x.x :[ end Kernel panic - not syncing: VFS: Unable to mount root fs on
19
Linux kernel 5.x.x :[ end Kernel panic - not syncing: VFS: Unable to mount root fs on
Posted at 5/17/2022 02:49:39      View6415 | Replies1        Print      Only Author   [Copy Link] 1#
I intend to upgrade my system kernel on a Firefly board with RK3288W SoC.
To do this, I used the kernel found in your RockMy repository and 5.17.6 kernel mainline. I was able to build the image successfully, but for some reason the kernel can't mount the file system and I'm not understanding why.In the old kernel that I was using (4.4.70), I don't have this problem.
The partitions and the kernel commands line are given by the parameter.txt file, which contains the following:
PARMLFIRMWARE_VER:2.0.0
MACHINE_MODEL:rk3288
MACHINE_ID:007
MANUFACTURER:RK3288
MAGIC: 0x5041524B
ATAG: 0x60000800
MACHINE: 3288
CHECK_MASK: 0x80
PWR_HLD: 0,0,A,0,1
TYPE: GPT
CMDLINE:init=/sbin/init root=/dev/mmcblk2p7 rw rootwait console=ttyS2,115200 splash loglevel=7 acpi=off apm=off vt.global_cursor_default=0 consoleblank=0 initrd=0x62000000,0x00800000 mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00008000@0x00016000(back),0x00010000@0x0001e000(backup),0xc01000@0x0002e000(linuxroot)
It would be very helpful to find a solution to this problem.
LOGs:
kernel 5.8 (rockmyy):
U-Boot 2017.02-RK3288-06-g8adeb23-dirty (Jun 02 2017 - 17:57:28)
CPU: rk3288
cpu version = 0
CPU's clock information:
    arm pll = 816000000HZ
    periph pll = 297000000HZ
    ddr pll = 396000000HZ
    codec pll = 384000000HZ
Board:        Rockchip platform Board
DRAM:  Found dram banks: 1
Adding bank:0000000000000000(0000000080000000)
128 MiB
GIC CPU mask = 0x00000001
SdmmcInit = 0 400
SdmmcInit = 2 0
ERROR: v7_dcache_inval_range - start address is not aligned - 0x059bc50c
ERROR: v7_dcache_inval_range - stop address is not aligned - 0x059bc70c
ERROR: v7_dcache_inval_range - start address is not aligned - 0x059cc30c
ERROR: v7_dcache_inval_range - stop address is not aligned - 0x059cc50c
storage init OK!
Using default environment
GetParam
Load FDT from resource image.
no key node
No pmic detect.
can't find dts node for pwm0
Can't find dts node for fuel guage cw201x
SecureBootEn = 0, SecureBootLock = 0
#Boot ver: 0000-00-00#0.00
empty serial no.
normal boot.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
read logo on state from dts [0]
no fuel gauge found
Hit any key to stop autoboot:  0
'boot' does not seem to be a partition nor an address
Unable to boot:boot
try to start recovery
'recovery' does not seem to be a partition nor an address
Unable to boot:recovery
try to start backup
load fdt from resouce.
Secure Boot state: 0
kernel   @ 0x02000000 (0x00c215b0)
ramdisk  @ 0x05bf0000 (0x00000000)
bootrk: do_bootm_linux...
   Loading Device Tree to 05600000, end 0560d124 ... OK
Add bank:0000000000000000, 0000000080000000
Starting kernel ...
[    0.000000][    T0] Booting Linux on physical CPU 0x500
[    0.000000][    T0] Linux version 5.8.0-RockMyy32-Frosty (checho@checho-pc) (arm-linux-gnueabihf-gcc (Ubuntu 9.4.0-1ubuntu1~20.04.1) 9.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1 SMP PREEMPT Mon May 16 12:24:11 -03 2022
[    0.000000][    T0] CPU: ARMv7 Processor [410fc0d1] revision 1 (ARMv7), cr=10c5387d
[    0.000000][    T0] CPU: div instructions available: patching division code
[    0.000000][    T0] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000][    T0] OF: fdt: Machine model: Firefly-RK3288
[    0.000000][    T0] Memory policy: Data cache writealloc
[    0.000000][    T0] Zone ranges:
[    0.000000][    T0]   DMA      [mem 0x0000000000000000-0x000000002fffffff]
[    0.000000][    T0]   Normal   empty
[    0.000000][    T0]   HighMem  [mem 0x0000000030000000-0x000000007fffffff]
[    0.000000][    T0] Movable zone start for each node
[    0.000000][    T0] Early memory node ranges
[    0.000000][    T0]   node   0: [mem 0x0000000000000000-0x000000007fffffff]
[    0.000000][    T0] Initmem setup node 0 [mem 0x0000000000000000-0x000000007fffffff]
[    0.000000][    T0] percpu: Embedded 20 pages/cpu s51032 r8192 d22696 u81920
[    0.000000][    T0] Built 1 zonelists, mobility grouping on.  Total pages: 522752
[    0.000000][    T0] Kernel command line: init=/sbin/init root=/dev/mmcblk2p7 rw rootwait console=ttyS2,115200 quiet splash loglevel=7  acpi=off apm=off vt.global_cursor_default=0 consoleblank=0  mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00008000@0x00016000(back),0x00010000@0x0001e000(backup),0xc00800@0x0002e000(linuxroot) storagemedia=emmc loader.timestamp=2017-06-02_17:57:28 SecureBootCheckOk=0
[    0.000000][    T0] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[    0.000000][    T0] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.000000][    T0] mem auto-init: stackff, heap allocn, heap freeff
[    0.000000][    T0] Memory: 2050644K/2097152K available (13312K kernel code, 1419K rwdata, 7576K rodata, 1024K init, 4876K bss, 46508K reserved, 0K cma-reserved, 1310720K highmem)
[    0.000000][    T0] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000][    T0] rcu: Preemptible hierarchical RCU implementation.
[    0.000000][    T0]         Trampoline variant of Tasks RCU enabled.
[    0.000000][    T0] rcu: RCU calculated value of scheduler-enlistment delay is 100 jiffies.
[    0.000000][    T0] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000][    T0] random: get_random_bytes called from start_kernel+0x578/0x7b8 with crng_init=0
[    0.000000][    T0] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[    0.000000][    T0] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000005][    T0] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.000018][    T0] Switching to timer-based delay loop, resolution 41ns
[    0.001152][    T0] Console: colour dummy device 80x30
[    0.001187][    T0] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=24000)
[    0.001201][    T0] pid_max: default: 32768 minimum: 301
[    0.001304][    T0] LSM: Security Framework initializing
[    0.001325][    T0] Yama: becoming mindful.
[    0.001381][    T0] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.001395][    T0] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.002033][    T0] CPU: Testing write buffer coherency: ok
[    0.002068][    T0] CPU0: Spectre v2: using BPIALL workaround
[    0.002327][    T1] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
[    0.003039][    T1] Setting up static identity map for 0x100000 - 0x100060
[    0.003179][    T1] rcu: Hierarchical SRCU implementation.
[    0.003596][    T1] smp: Bringing up secondary CPUs ...
[    0.005328][    T0] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
[    0.005335][    T0] CPU1: Spectre v2: using BPIALL workaround
[    0.007110][    T0] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
[    0.007116][    T0] CPU2: Spectre v2: using BPIALL workaround
[    0.008859][    T0] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503
[    0.008866][    T0] CPU3: Spectre v2: using BPIALL workaround
[    0.008989][    T1] smp: Brought up 1 node, 4 CPUs
[    0.009001][    T1] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[    0.009010][    T1] CPU: All CPU(s) started in SVC mode.
[    0.009591][    T1] devtmpfs: initialized
[    0.018632][    T1] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
[    0.018945][    T1] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[    0.018984][    T1] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.019226][    T1] xor: measuring software checksum speed
[    0.028429][    T1]    arm4regs  :  1716.000 MB/sec
[    0.038502][    T1]    8regs     :  1324.000 MB/sec
[    0.048577][    T1]    32regs    :  1320.000 MB/sec
[    0.048587][    T1] xor: using function: arm4regs (1716.000 MB/sec)
[    0.048602][    T1] pinctrl core: initialized pinctrl subsystem
[    0.049075][    T1] thermal_sys: Registered thermal governor 'step_wise'
[    0.049949][    T1] NET: Registered protocol family 16
[    0.050752][    T1] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.052190][    T1] cpuidle: using governor ladder
[    0.052229][    T1] cpuidle: using governor menu
[    0.053183][    T1] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.053195][    T1] hw-breakpoint: maximum watchpoint size is 4 bytes.
[    0.121630][    T1] raid6: int32x8  gen()   228 MB/s
[    0.138739][    T1] raid6: int32x8  xor()   131 MB/s
[    0.155942][    T1] raid6: int32x4  gen()   221 MB/s
[    0.173090][    T1] raid6: int32x4  xor()   128 MB/s
[    0.190216][    T1] raid6: int32x2  gen()   344 MB/s
[    0.207375][    T1] raid6: int32x2  xor()   180 MB/s
[    0.224548][    T1] raid6: int32x1  gen()   377 MB/s
[    0.241726][    T1] raid6: int32x1  xor()   122 MB/s
[    0.241737][    T1] raid6: using algorithm int32x1 gen() 377 MB/s
[    0.241768][    T1] raid6: .... xor() 122 MB/s, rmw enabled
[    0.241777][    T1] raid6: using intx1 recovery algorithm
[    0.243750][    T1] vcc_5v: supplied by vcc_sys
[    0.244469][    T1] vcc_host_5v: supplied by vcc_5v
[    0.244955][    T1] vcc_otg_5v: supplied by vcc_5v
[    0.245878][    T1] iommu: Default domain type: Translated
[    0.247295][    T1] vgaarb: loaded
[    0.247774][    T1] SCSI subsystem initialized
[    0.247957][    T1] usbcore: registered new interface driver usbfs
[    0.248067][    T1] usbcore: registered new interface driver hub
[    0.248149][    T1] usbcore: registered new device driver usb
[    0.248278][    T1] mc: Linux media interface: v0.10
[    0.248310][    T1] videodev: Linux video capture interface: v2.00
[    0.248419][    T1] pps_core: LinuxPPS API ver. 1 registered
[    0.248430][    T1] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.248449][    T1] PTP clock support registered
[    0.248808][    T1] Advanced Linux Sound Architecture Driver Initialized.
[    0.249370][    T1] Bluetooth: Core ver 2.22
[    0.249411][    T1] NET: Registered protocol family 31
[    0.249421][    T1] Bluetooth: HCI device and connection manager initialized
[    0.249435][    T1] Bluetooth: HCI socket layer initialized
[    0.249447][    T1] Bluetooth: L2CAP socket layer initialized
[    0.249470][    T1] Bluetooth: SCO socket layer initialized
[    0.250242][    T1] clocksource: Switched to clocksource arch_sys_counter
[    1.327468][    T1] FS-Cache: Loaded
[    1.327685][    T1] CacheFiles: Loaded
[    1.336921][    T1] NET: Registered protocol family 2
[    1.337553][    T1] tcp_listen_portaddr_hash hash table entries: 512 (order: 1, 12288 bytes, linear)
[    1.337594][    T1] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[    1.337726][    T1] TCP bind hash table entries: 8192 (order: 5, 163840 bytes, linear)
[    1.337857][    T1] TCP: Hash tables configured (established 8192 bind 8192)
[    1.338210][    T1] UDP hash table entries: 512 (order: 2, 24576 bytes, linear)
[    1.338290][    T1] UDP-Lite hash table entries: 512 (order: 2, 24576 bytes, linear)
[    1.338591][    T1] NET: Registered protocol family 1
[    1.339072][    T1] RPC: Registered named UNIX socket transport module.
[    1.339083][    T1] RPC: Registered udp transport module.
[    1.339091][    T1] RPC: Registered tcp transport module.
[    1.339098][    T1] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.339536][    T1] PCI: CLS 0 bytes, default 64
[    1.340779][    T1] hw perfevents: enabled with armv7_cortex_a12 PMU driver, 7 counters available
[    1.342694][    T1] Initialise system trusted keyrings
[    1.342814][    T1] workingset: timestamp_bits=30 max_order=19 bucket_order=0
[    1.349387][    T1] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    1.350266][    T1] FS-Cache: Netfs 'nfs' registered for caching
[    1.350866][    T1] NFS: Registering the id_resolver key type
[    1.350891][    T1] Key type id_resolver registered
[    1.350901][    T1] Key type id_legacy registered
[    1.350918][    T1] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.350933][    T1] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[    1.352632][    T1] Key type cifs.spnego registered
[    1.352658][    T1] Key type cifs.idmap registered
[    1.352674][    T1] ntfs: driver 2.1.32 [Flags: R/W].
[    1.353034][    T1] fuse: init (API version 7.31)
[    1.353759][    T1] JFS: nTxBlock = 8192, nTxLock = 65536
[    1.361680][    T1] SGI XFS with security attributes, no debug enabled
[    1.450994][    T1] NET: Registered protocol family 38
[    1.451010][    T1] Key type asymmetric registered
[    1.451020][    T1] Asymmetric key parser 'x509' registered
[    1.451028][    T1] Asymmetric key parser 'pkcs8' registered
[    1.451036][    T1] Key type pkcs7_test registered
[    1.451169][    T1] bounce: pool size: 64 pages
[    1.451220][    T1] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[    1.451280][    T1] io scheduler mq-deadline registered
[    1.451291][    T1] io scheduler kyber registered
[    1.457155][    T1] dma-pl330 ff250000.dma-controller: Loaded driver for PL330 DMAC-241330
[    1.457173][    T1] dma-pl330 ff250000.dma-controller:         DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[    1.457825][    T1] dma-pl330 ffb20000.dma-controller: Loaded driver for PL330 DMAC-241330
[    1.457840][    T1] dma-pl330 ffb20000.dma-controller:         DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10
[    1.458342][    T1] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    1.460013][    T1] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 38, base_baud = 1500000) is a 16550A
[    1.460798][    T1] ff190000.serial: ttyS1 at MMIO 0xff190000 (irq = 39, base_baud = 1500000) is a 16550A
[    1.461593][    T1] ff690000.serial: ttyS2 at MMIO 0xff690000 (irq = 40, base_baud = 1500000) is a 16550A
[    2.592568][    T1] printk: console [ttyS2] enabled
[    2.598800][    T1] ff1b0000.serial: ttyS3 at MMIO 0xff1b0000 (irq = 41, base_baud = 1500000) is a 16550A
[    2.611405][    T1] rockchip-vop ff930000.vop: Adding to iommu group 0
[    2.619263][    T1] rockchip-vop ff940000.vop: Adding to iommu group 1
[    2.629954][    T1] rockchip-drm display-subsystem: bound ff930000.vop (ops 0xc11f9004)
[    2.639307][    T1] rockchip-drm display-subsystem: bound ff940000.vop (ops 0xc11f9004)
[    2.648680][    T1] usbcore: registered new interface driver udl
[    2.659055][    T1] brd: module loaded
[    2.671826][    T1] loop: module loaded
[    2.676600][    T1] zram: Added device: zram0
[    2.681556][    T1] usbcore: registered new interface driver rtsx_usb
[    2.691375][    T1] libphy: Fixed MDIO Bus: probed
[    2.696805][    T1] tun: Universal TUN/TAP device driver, 1.6
[    2.704369][    T1] rk_gmac-dwmac ff290000.ethernet: IRQ eth_lpi not found
[    2.712166][    T1] rk_gmac-dwmac ff290000.ethernet: PTP uses main clock
[    2.719700][    T1] rk_gmac-dwmac ff290000.ethernet: phy regulator is not available yet, deferred probing
[    2.731062][    T1] PPP generic driver version 2.4.2
[    2.737076][    T1] usbcore: registered new interface driver rt2500usb
[    2.744443][    T1] usbcore: registered new interface driver rt73usb
[    2.751600][    T1] usbcore: registered new interface driver rt2800usb
[    2.758983][    T1] usbcore: registered new interface driver rndis_wlan
[    2.766401][    T1] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[    2.775509][    T1] usbcore: registered new interface driver pegasus
[    2.782654][    T1] usbcore: registered new interface driver rtl8150
[    2.789819][    T1] usbcore: registered new interface driver r8152
[    2.796784][    T1] usbcore: registered new interface driver asix
[    2.803648][    T1] usbcore: registered new interface driver ax88179_178a
[    2.811287][    T1] usbcore: registered new interface driver cdc_ether
[    2.818632][    T1] usbcore: registered new interface driver dm9601
[    2.825696][    T1] usbcore: registered new interface driver smsc75xx
[    2.832963][    T1] usbcore: registered new interface driver smsc95xx
[    2.840216][    T1] usbcore: registered new interface driver net1080
[    2.847371][    T1] usbcore: registered new interface driver rndis_host
[    2.854814][    T1] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[    2.863923][    T1] usbcore: registered new interface driver cdc_ncm
[    2.871076][    T1] usbcore: registered new interface driver cdc_mbim
[    2.878675][    T1] dwc2 ff540000.usb: supply vusb_d not found, using dummy regulator
[    2.887544][    T1] dwc2 ff540000.usb: supply vusb_a not found, using dummy regulator
[    2.948467][    T1] dwc2 ff540000.usb: DWC OTG Controller
[    2.954552][    T1] dwc2 ff540000.usb: new USB bus registered, assigned bus number 1
[    2.963265][    T1] dwc2 ff540000.usb: irq 45, io mem 0xff540000
[    2.970199][    T1] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.08
[    2.980248][    T1] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.989118][    T1] usb usb1: Product: DWC OTG Controller
[    2.995170][    T1] usb usb1: Manufacturer: Linux 5.8.0-RockMyy32-Frosty dwc2_hsotg
[    3.003747][    T1] usb usb1: SerialNumber: ff540000.usb
[    3.010257][    T1] hub 1-0:1.0: USB hub found
[    3.015273][    T1] hub 1-0:1.0: 1 port detected
[    3.021022][    T1] dwc2 ff580000.usb: supply vusb_d not found, using dummy regulator
[    3.029864][    T1] dwc2 ff580000.usb: supply vusb_a not found, using dummy regulator
[    3.162297][    T1] dwc2 ff580000.usb: EPs: 10, dedicated fifos, 972 entries in SPRAM
[    3.171249][    T1] dwc2 ff580000.usb: DWC OTG Controller
[    3.177320][    T1] dwc2 ff580000.usb: new USB bus registered, assigned bus number 2
[    3.186023][    T1] dwc2 ff580000.usb: irq 46, io mem 0xff580000
[    3.192923][    T1] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.08
[    3.202963][    T1] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.211833][    T1] usb usb2: Product: DWC OTG Controller
[    3.217876][    T1] usb usb2: Manufacturer: Linux 5.8.0-RockMyy32-Frosty dwc2_hsotg
[    3.226532][    T1] usb usb2: SerialNumber: ff580000.usb
[    3.232973][    T1] hub 2-0:1.0: USB hub found
[    3.237994][    T1] hub 2-0:1.0: 1 port detected
[    3.244756][    T1] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    3.252859][    T1] ehci-pci: EHCI PCI platform driver
[    3.258669][    T1] ehci-platform: EHCI generic platform driver
[    3.265568][    T1] usbcore: registered new interface driver cdc_acm
[    3.272692][    T1] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    3.282537][    T1] usbcore: registered new interface driver usblp
[    3.289506][    T1] usbcore: registered new interface driver cdc_wdm
[    3.296707][    T1] usbcore: registered new interface driver usbserial_generic
[    3.304823][    T1] usbserial: USB Serial support registered for generic
[    3.312369][    T1] usbcore: registered new interface driver ftdi_sio
[    3.319608][    T1] usbserial: USB Serial support registered for FTDI USB Serial Device
[    3.328652][    T1] usbcore: registered new interface driver keyspan
[    3.335794][    T1] usbserial: USB Serial support registered for Keyspan - (without firmware)
[    3.345442][    T1] usbserial: USB Serial support registered for Keyspan 1 port adapter
[    3.354540][    T1] usbserial: USB Serial support registered for Keyspan 2 port adapter
[    3.363528][    T1] usbserial: USB Serial support registered for Keyspan 4 port adapter
[    3.372534][    T1] usbcore: registered new interface driver option
[    3.379578][    T1] usbserial: USB Serial support registered for GSM modem (1-port)
[    3.388268][    T1] usbcore: registered new interface driver oti6858
[    3.395409][    T1] usbserial: USB Serial support registered for oti6858
[    3.402937][   T83] usb 1-1: new high-speed USB device number 2 using dwc2
[    3.410728][    T1] usbcore: registered new interface driver pl2303
[    3.417782][    T1] usbserial: USB Serial support registered for pl2303
[    3.425254][    T1] usbcore: registered new interface driver qcserial
[    3.432491][    T1] usbserial: USB Serial support registered for Qualcomm USB modem
[    3.441111][    T1] usbcore: registered new interface driver sierra
[    3.448157][    T1] usbserial: USB Serial support registered for Sierra USB modem
[    3.457208][    T1] usbcore: registered new interface driver iforce
[    3.464285][    T1] usbcore: registered new interface driver pxrc
[    3.471166][    T1] usbcore: registered new interface driver xpad
[    3.478093][    T1] usbcore: registered new interface driver usbtouchscreen
[    3.486382][    T1] i2c /dev entries driver
[    3.494570][    T1] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[    3.503076][    T1] fan53555-reg: supplied by vcc_sys
[    3.511575][    T1] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[    3.520107][    T1] fan53555-reg: supplied by vcc_sys
[    3.529684][    T1] rtc-hym8563 0-0051: registered as rtc0
[    3.536180][    T1] rtc-hym8563 0-0051: setting system clock to 2017-01-01T14:29:04 UTC (1483280944)
[    3.548407][    T1] REG1: supplied by vcc_sys
[    3.554005][    T1] REG2: supplied by vcc_sys
[    3.559628][    T1] REG3: supplied by vcc_sys
[    3.565220][    T1] REG4: supplied by vcc_sys
[    3.570823][    T1] REG5: supplied by vcc_sys
[    3.576447][    T1] REG6: supplied by vcc_sys
[    3.582166][    T1] REG7: supplied by vcc_sys
[    3.587633][    T1] REG8: supplied by vcc_sys
[    3.588621][   T83] usb 1-1: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.00
[    3.593103][    T1] REG9: supplied by vcc_sys
[    3.602464][   T83] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    3.607906][    T1] REG10: supplied by vcc_20
[    3.616097][   T83] usb 1-1: Product: USB 2.0 Hub [MTT]
[    3.621410][   T83] hub 1-1:1.0: USB hub found
[    3.627722][    T1] REG11: supplied by vcc_20
[    3.631904][   T83] hub 1-1:1.0: 4 ports detected
[    3.637593][    T1] REG12: supplied by vcc_20
[    3.649027][    T1] IR NEC protocol handler initialized
[    3.654934][    T1] IR RC5(x/sz) protocol handler initialized
[    3.661404][    T1] IR RC6 protocol handler initialized
[    3.667261][    T1] IR JVC protocol handler initialized
[    3.673116][    T1] IR Sony protocol handler initialized
[    3.679069][    T1] IR SANYO protocol handler initialized
[    3.685117][    T1] IR Sharp protocol handler initialized
[    3.691165][    T1] IR MCE Keyboard/mouse protocol handler initialized
[    3.698475][    T1] IR XMP protocol handler initialized
[    3.704329][    T1] ir_imon_decoder: IR iMON protocol handler initialized
[    3.711930][    T1] IR RCMM protocol handler initialized
[    3.717958][    T1] usbcore: registered new interface driver uvcvideo
[    3.725177][    T1] USB Video Class driver (1.1.1)
[    3.730546][    T1] gspca_main: v2.14.0 registered
[    3.736643][    T1] vcc28_dvp: supplied by vcc_io
[    3.742138][    T1] dovdd_1v8: supplied by vcc28_dvp
[    3.746363][    C0] random: fast init done
[    3.747847][    T1] vcc_flash: supplied by vcc_io
[    3.762027][    T1] device-mapper: ioctl: 4.42.0-ioctl (2020-02-27) initialised: dm-devel@redhat.com
[    3.776199][    T1] sdhci: Secure Digital Host Controller Interface driver
[    3.783926][    T1] sdhci: Copyright(c) Pierre Ossman
[    3.789594][    T1] Synopsys Designware Multimedia Card Interface Driver
[    3.797529][    T1] dwmmc_rockchip ff0c0000.mmc: IDMAC supports 32-bit address mode.
[    3.806206][    T1] dwmmc_rockchip ff0c0000.mmc: Using internal DMA controller.
[    3.814378][    T1] dwmmc_rockchip ff0c0000.mmc: Version ID is 270a
[    3.821414][    T1] dwmmc_rockchip ff0c0000.mmc: DW MMC controller at irq 30,32 bit host data width,256 deep fifo
[    3.832909][    T1] vcc_sd: supplied by vcc_io
[    3.959080][    T1] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    3.983103][    T1] dwmmc_rockchip ff0d0000.mmc: IDMAC supports 32-bit address mode.
[    3.991804][    T1] dwmmc_rockchip ff0d0000.mmc: Using internal DMA controller.
[    3.999996][    T1] dwmmc_rockchip ff0d0000.mmc: Version ID is 270a
[    4.007026][    T1] dwmmc_rockchip ff0d0000.mmc: DW MMC controller at irq 31,32 bit host data width,256 deep fifo
[    4.018715][    T1] dwmmc_rockchip ff0d0000.mmc: Failed getting OCR mask: 0
[    4.026558][    T1] mmc_host mmc1: card is non-removable.
[    4.032656][    T1] dwmmc_rockchip ff0d0000.mmc: could not set regulator OCR (-22)
[    4.041125][    T1] dwmmc_rockchip ff0d0000.mmc: failed to enable vmmc regulator
[    4.062452][    T1] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    4.086443][    T1] dwmmc_rockchip ff0f0000.mmc: IDMAC supports 32-bit address mode.
[    4.095146][    T1] dwmmc_rockchip ff0f0000.mmc: Using internal DMA controller.
[    4.103351][    T1] dwmmc_rockchip ff0f0000.mmc: Version ID is 270a
[    4.110392][    T1] dwmmc_rockchip ff0f0000.mmc: DW MMC controller at irq 32,32 bit host data width,256 deep fifo
[    4.122167][    T1] mmc_host mmc2: card is non-removable.
[    4.133857][  T122] dwmmc_rockchip ff0d0000.mmc: could not set regulator OCR (-22)
[    4.140967][    T1] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    4.142326][  T122] dwmmc_rockchip ff0d0000.mmc: failed to enable vmmc regulator
[    4.166141][    T1] sdhci-pltfm: SDHCI platform and OF driver helper
[    4.173675][    T1] ledtrig-cpu: registered to indicate activity on CPUs
[    4.174711][  T122] mmc_host mmc1: Bus speed (slot 0) = 300000Hz (slot req 300000Hz, actual 300000HZ div = 0)
[    4.181236][    T1] hid: raw HID events driver (C) Jiri Kosina
[    4.199196][    T1] usbcore: registered new interface driver usbhid
[    4.206206][    T1] usbhid: USB HID core driver
[    4.211432][    T1] ashmem: initialized
[    4.217055][    T1] usbcore: registered new interface driver snd-usb-audio
[    4.223160][  T122] dwmmc_rockchip ff0d0000.mmc: could not set regulator OCR (-22)
[    4.225804][    T1] u32 classifier
[    4.233234][  T122] dwmmc_rockchip ff0d0000.mmc: failed to enable vmmc regulator
[    4.237030][    T1]     input device check on
[    4.242610][   T83] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 52000000Hz, actual 50000000HZ div = 0)
[    4.242749][   T83] mmc2: new high speed MMC card at address 0001
[    4.243357][   T83] mmcblk2: mmc2:0001 AJTD4R 14.6 GiB
[    4.243786][   T83] mmcblk2boot0: mmc2:0001 AJTD4R partition 1 4.00 MiB
[    4.244313][   T83] mmcblk2boot1: mmc2:0001 AJTD4R partition 2 4.00 MiB
[    4.245412][   T83] mmcblk2rpmb: mmc2:0001 AJTD4R partition 3 4.00 MiB, chardev (240:0)
[    4.250705][    T1] Initializing XFRM netlink socket
[    4.258421][  T122] mmc_host mmc1: Bus speed (slot 0) = 200000Hz (slot req 200000Hz, actual 200000HZ div = 0)
[    4.265560][   T83]  mmcblk2: p1 p2 p3 p4 p5 p6 p7 p8
[    4.268975][    T1] NET: Registered protocol family 10
[    4.296016][  T122] dwmmc_rockchip ff0d0000.mmc: could not set regulator OCR (-22)
[    4.298874][    T1] Segment Routing with IPv6
[    4.303825][  T122] dwmmc_rockchip ff0d0000.mmc: failed to enable vmmc regulator
[    4.314905][    T1] RPL Segment Routing with IPv6
[    4.333626][  T122] mmc_host mmc1: Bus speed (slot 0) = 187500Hz (slot req 100000Hz, actual 93750HZ div = 1)
[    4.334916][    T1] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    4.371870][    T1] NET: Registered protocol family 17
[    4.377641][    T1] NET: Registered protocol family 15
[    4.383523][    T1] Bluetooth: RFCOMM TTY layer initialized
[    4.389775][    T1] Bluetooth: RFCOMM socket layer initialized
[    4.396329][    T1] Bluetooth: RFCOMM ver 1.11
[    4.401317][    T1] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    4.408732][    T1] Bluetooth: HIDP socket layer initialized
[    4.415184][    T1] 8021q: 802.1Q VLAN Support v1.8
[    4.420658][    T1] lib80211: common routines for IEEE802.11 drivers
[    4.427791][    T1] Key type dns_resolver registered
[    4.433622][    T1] ThumbEE CPU extension supported.
[    4.439179][    T1] Registering SWP/SWPB emulation handler
[    4.445437][    T1] Loading compiled-in X.509 certificates
[    4.453544][    T1] Btrfs loaded, crc32c=crc32c-generic
[    4.473907][  T113] rockchip-drm display-subsystem: bound ff930000.vop (ops 0xc11f9004)
[    4.483184][  T113] rockchip-drm display-subsystem: bound ff940000.vop (ops 0xc11f9004)
[    4.492272][  T113] dwhdmi-rockchip ff980000.hdmi: Detected HDMI TX controller v2.01a with HDCP (DWC HDMI 2.0 TX PHY)
[    4.504640][  T113] rockchip-drm display-subsystem: bound ff980000.hdmi (ops 0xc11fc264)
[    4.513700][  T113] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    4.521910][  T113] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
[    4.531156][  T113] [drm] Initialized rockchip 1.0.0 20140818 for display-subsystem on minor 0
[    4.541261][  T113] rk_gmac-dwmac ff290000.ethernet: IRQ eth_lpi not found
[    4.549007][  T113] rk_gmac-dwmac ff290000.ethernet: PTP uses main clock
[    4.556566][  T113] rk_gmac-dwmac ff290000.ethernet: clock input or output? (input).
[    4.565233][  T113] rk_gmac-dwmac ff290000.ethernet: TX delay(0x30).
[    4.572338][  T113] rk_gmac-dwmac ff290000.ethernet: RX delay(0x10).
[    4.579436][  T113] rk_gmac-dwmac ff290000.ethernet: integrated PHY? (no).
[    4.587146][  T113] rk_gmac-dwmac ff290000.ethernet: cannot get clock clk_mac_speed
[    4.595707][  T113] rk_gmac-dwmac ff290000.ethernet: clock input from PHY
[    4.608302][  T113] rk_gmac-dwmac ff290000.ethernet: init for RGMII
[    4.615559][  T113] rk_gmac-dwmac ff290000.ethernet: User ID: 0x10, Synopsys ID: 0x35
[    4.624326][  T113] rk_gmac-dwmac ff290000.ethernet:         DWMAC1000
[    4.630949][  T113] rk_gmac-dwmac ff290000.ethernet: DMA HW capability register supported
[    4.640093][  T113] rk_gmac-dwmac ff290000.ethernet: RX Checksum Offload Engine supported
[    4.649233][  T113] rk_gmac-dwmac ff290000.ethernet: COE Type 2
[    4.655852][  T113] rk_gmac-dwmac ff290000.ethernet: TX Checksum insertion supported
[    4.664502][  T113] rk_gmac-dwmac ff290000.ethernet: Wake-Up On Lan supported
[    4.672492][  T113] rk_gmac-dwmac ff290000.ethernet: Normal descriptors
[    4.679889][  T113] rk_gmac-dwmac ff290000.ethernet: Ring mode enabled
[    4.687190][  T113] rk_gmac-dwmac ff290000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[    4.696921][  T113] rk_gmac-dwmac ff290000.ethernet: device MAC address 7a:91:66:34:ed:94
[    5.538272][  T129] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
[    5.737357][  T113] libphy: stmmac: probed
[    5.741945][  T113] mdio_bus stmmac-0:00: attached PHY driver [unbound] (mii_bus:phy_addr=stmmac-0:00, irq=POLL)
[    5.753326][  T113] mdio_bus stmmac-0:01: attached PHY driver [unbound] (mii_bus:phy_addr=stmmac-0:01, irq=POLL)
[    5.765509][    T1] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    5.774135][    T1] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    5.785188][    T1] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    5.793363][  T122] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[    5.795484][    T1] ALSA device list:
[    5.803790][  T122] cfg80211: failed to load regulatory.db
[    5.807873][    T1]   No soundcards found.
[    5.818695][    T1] dw-apb-uart ff690000.serial: forbid DMA for kernel console
[    5.843507][    T1] erofs: (device mmcblk2p7): erofs_read_superblock: cannot find valid erofs superblock
[    5.870548][    T1] erofs: (device mmcblk2p7): erofs_read_superblock: cannot find valid erofs superblock
[    5.881532][    T1] List of all partitions:
[    5.886236][    T1] 0100            4096 ram0
[    5.886238][    T1]  (driver?)
[    5.894662][    T1] b300        15267840 mmcblk2
[    5.894664][    T1]  driver: mmcblk
[    5.903825][    T1]   b301            4096 mmcblk2p1 2d230000-0000-4e50-8000-07bf00004ea9
[    5.903826][    T1]
[    5.915409][    T1]   b302            4096 mmcblk2p2 2c170000-0000-4472-8000-6173000065f3
[    5.915410][    T1]
[    5.926982][    T1]   b303            4096 mmcblk2p3 4b650000-0000-487c-8000-2fb100007d14
[    5.926983][    T1]
[    5.938564][    T1]   b304           32768 mmcblk2p4 b4590000-0000-4111-8000-70a100007eb5
[    5.938565][    T1]
[    5.950148][    T1]   b305           32768 mmcblk2p5 8c520000-0000-4728-8000-3a6c0000247d
[    5.950149][    T1]
[    5.961730][    T1]   b306           32768 mmcblk2p6 fe460000-0000-440c-8000-363a00007e15
[    5.961731][    T1]
[    5.973311][    T1]   b307         2094080 mmcblk2p7 614e0000-0000-4b53-8000-1d28000054a9
[    5.973312][    T1]
[    5.984892][    T1]   b308        12989423 mmcblk2p8 4a510000-0000-4d08-8000-507d00003353
[    5.984893][    T1]
[    5.996476][    T1] No filesystem could mount root, tried:
[    5.996477][    T1]  reiserfs
[    6.002706][    T1]  ext3
[    6.006024][    T1]  ext4
[    6.008951][    T1]  ext2
[    6.011877][    T1]  squashfs
[    6.014803][    T1]  vfat
[    6.018117][    T1]  iso9660
[    6.021043][    T1]  hfsplus
[    6.024261][    T1]  ntfs
[    6.027478][    T1]  fuseblk
[    6.030404][    T1]  udf
[    6.033620][    T1]  jfs
[    6.036449][    T1]  xfs
[    6.039277][    T1]  erofs
[    6.042105][    T1]  btrfs
[    6.045127][    T1]
[    6.050587][    T1] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,7)
[    6.060793][    T1] CPU: 3 PID: 1 Comm: swapper/0 Not tainted 5.8.0-RockMyy32-Frosty #1
[    6.069732][    T1] Hardware name: Rockchip (Device Tree)
[    6.075775][    T1] [<c010e0c0>] (unwind_backtrace) from [<c0109e40>] (show_stack+0x10/0x14)
[    6.085206][    T1] [<c0109e40>] (show_stack) from [<c06c345c>] (dump_stack+0x80/0x9c)
[    6.094055][    T1] [<c06c345c>] (dump_stack) from [<c01210fc>] (panic+0xd4/0x2dc)
[    6.102516][    T1] [<c01210fc>] (panic) from [<c1601938>] (mount_block_root+0x294/0x328)
[    6.111656][    T1] [<c1601938>] (mount_block_root) from [<c1601cdc>] (prepare_namespace+0x170/0x1ac)
[    6.121960][    T1] [<c1601cdc>] (prepare_namespace) from [<c16014b8>] (kernel_init_freeable+0x1f8/0x264)
[    6.132653][    T1] [<c16014b8>] (kernel_init_freeable) from [<c0d7c978>] (kernel_init+0x8/0x110)
[    6.142569][    T1] [<c0d7c978>] (kernel_init) from [<c0100148>] (ret_from_fork+0x14/0x2c)
[    6.151802][    T1] Exception stack(0xee8f9fb0 to 0xee8f9ff8)
[    6.158211][    T1] 9fa0:                                     00000000 00000000 00000000 00000000
[    6.168124][    T1] 9fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    6.178037][    T1] 9fe0: 00000000 00000000 00000000 00000000 00000013 00000000
[    6.186198][    C2] CPU2: stopping
[    6.189994][    C2] CPU: 2 PID: 0 Comm: swapper/2 Not tainted 5.8.0-RockMyy32-Frosty #1
[    6.198935][    C2] Hardware name: Rockchip (Device Tree)
[    6.204967][    C2] [<c010e0c0>] (unwind_backtrace) from [<c0109e40>] (show_stack+0x10/0x14)
[    6.214397][    C2] [<c0109e40>] (show_stack) from [<c06c345c>] (dump_stack+0x80/0x9c)
[    6.223243][    C2] [<c06c345c>] (dump_stack) from [<c010cf4c>] (handle_IPI+0x2bc/0x39c)
[    6.232286][    C2] [<c010cf4c>] (handle_IPI) from [<c06d93e4>] (gic_handle_irq+0x84/0x90)
[    6.241521][    C2] [<c06d93e4>] (gic_handle_irq) from [<c0100b0c>] (__irq_svc+0x6c/0xa8)
[    6.250656][    C2] Exception stack(0xee921f60 to 0xee921fa8)
[    6.257073][    C2] 1f60: 00000000 eefbe3f0 00000000 c0117b80 00000000 00000000 ee920000 00000004
[    6.266987][    C2] 1f80: c170a730 ee921fb8 c170a770 00000000 00000009 ee921fb0 c0106e08 c0106df8
[    6.276897][    C2] 1fa0: 60000013 ffffffff
[    6.281569][    C2] [<c0100b0c>] (__irq_svc) from [<c0106df8>] (arch_cpu_idle+0x1c/0x38)
[    6.290613][    C2] [<c0106df8>] (arch_cpu_idle) from [<c014b5d0>] (do_idle+0x108/0x28c)
[    6.299655][    C2] [<c014b5d0>] (do_idle) from [<c014b9e8>] (cpu_startup_entry+0x18/0x20)
[    6.308889][    C2] [<c014b9e8>] (cpu_startup_entry) from [<0010162c>] (0x10162c)
[    6.317246][    C0] CPU0: stopping
[    6.321033][    C0] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 5.8.0-RockMyy32-Frosty #1
[    6.329974][    C0] Hardware name: Rockchip (Device Tree)
[    6.336007][    C0] [<c010e0c0>] (unwind_backtrace) from [<c0109e40>] (show_stack+0x10/0x14)
[    6.345436][    C0] [<c0109e40>] (show_stack) from [<c06c345c>] (dump_stack+0x80/0x9c)
[    6.354283][    C0] [<c06c345c>] (dump_stack) from [<c010cf4c>] (handle_IPI+0x2bc/0x39c)
[    6.363324][    C0] [<c010cf4c>] (handle_IPI) from [<c06d93e4>] (gic_handle_irq+0x84/0x90)
[    6.372559][    C0] [<c06d93e4>] (gic_handle_irq) from [<c0100b0c>] (__irq_svc+0x6c/0xa8)
[    6.381693][    C0] Exception stack(0xc1701f18 to 0xc1701f60)
[    6.388109][    C0] 1f00:                                                       00000000 eef963f0
[    6.398023][    C0] 1f20: 00000000 c0117b80 00000000 00000000 c1700000 00000001 c170a730 c1701f70
[    6.407936][    C0] 1f40: c170a770 000001c9 00000000 c1701f68 c0106e08 c0106df8 60000013 ffffffff
[    6.417850][    C0] [<c0100b0c>] (__irq_svc) from [<c0106df8>] (arch_cpu_idle+0x1c/0x38)
[    6.426891][    C0] [<c0106df8>] (arch_cpu_idle) from [<c014b5d0>] (do_idle+0x108/0x28c)
[    6.435931][    C0] [<c014b5d0>] (do_idle) from [<c014b9e8>] (cpu_startup_entry+0x18/0x20)
[    6.445166][    C0] [<c014b9e8>] (cpu_startup_entry) from [<c16011cc>] (start_kernel+0x6c4/0x7b8)
[    6.455080][    C0] [<c16011cc>] (start_kernel) from [<00000000>] (0x0)
[    6.462467][    C1] CPU1: stopping
[    6.466264][    C1] CPU: 1 PID: 0 Comm: swapper/1 Not tainted 5.8.0-RockMyy32-Frosty #1
[    6.475205][    C1] Hardware name: Rockchip (Device Tree)
[    6.481238][    C1] [<c010e0c0>] (unwind_backtrace) from [<c0109e40>] (show_stack+0x10/0x14)
[    6.490667][    C1] [<c0109e40>] (show_stack) from [<c06c345c>] (dump_stack+0x80/0x9c)
[    6.499514][    C1] [<c06c345c>] (dump_stack) from [<c010cf4c>] (handle_IPI+0x2bc/0x39c)
[    6.508555][    C1] [<c010cf4c>] (handle_IPI) from [<c06d93e4>] (gic_handle_irq+0x84/0x90)
[    6.517791][    C1] [<c06d93e4>] (gic_handle_irq) from [<c0100b0c>] (__irq_svc+0x6c/0xa8)
[    6.526925][    C1] Exception stack(0xee91ff60 to 0xee91ffa8)
[    6.533344][    C1] ff60: 00000000 eefaa3f0 00000000 c0117b80 00000000 00000000 ee91e000 00000002
[    6.543259][    C1] ff80: c170a730 ee91ffb8 c170a770 00000000 00000000 ee91ffb0 c0106e08 c0106df8
[    6.553170][    C1] ffa0: 60000013 ffffffff
[    6.557841][    C1] [<c0100b0c>] (__irq_svc) from [<c0106df8>] (arch_cpu_idle+0x1c/0x38)
[    6.566883][    C1] [<c0106df8>] (arch_cpu_idle) from [<c014b5d0>] (do_idle+0x108/0x28c)
[    6.575924][    C1] [<c014b5d0>] (do_idle) from [<c014b9e8>] (cpu_startup_entry+0x18/0x20)
[    6.585158][    C1] [<c014b9e8>] (cpu_startup_entry) from [<0010162c>] (0x10162c)
[    6.593523][    T1] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,7) ]---
-kernel 4.4.70:
empty serial no.
normal boot.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
no fuel gauge found
Unable to boot:boot
try to start backup
kernel   @ 0x02000000 (0x007146a0)
   Loading Device Tree to 05600000, end 0560fb4d ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x500
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 4.4.70 (forkworks@forkworks-ThinkPad-W520) (gcc version 4.8.4 (Ubuntu/Linaro 4.8.4-2ubuntu1~14.04.1) ) #25 SMP Thu May 24 20:20:01 ART 2018
[    0.000000] CPU: ARMv7 Processor [410fc0d1] revision 1 (ARMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine model: Firefly-RK3288
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] PERCPU: Embedded 13 pages/cpu @eef8a000 s24448 r8192 d20608 u53248
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 522752
[    0.000000] Kernel command line: init=/sbin/init root=/dev/mmcblk2p7 rw rootwait console=ttyS2,115200 quiet splash loglevel=7  acpi=off apm=off vt.global_cursor_default=0 consoleblank=0  mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00008000@0x00016000(back),0x00010000@0x0001e000(backup),0xc00800@0x0002e000(linuxroot) storagemedia=emmc loader.timestamp=2017-06-02_17:57:28 SecureBootCheckOk=0
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 2060564K/2097152K available (11264K kernel code, 863K rwdata, 3076K rodata, 2048K init, 601K bss, 36588K reserved, 0K cma-reserved, 1310720K highmem)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
[    0.000000]     vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xf0000000   ( 768 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .text : 0xc0008000 - 0xc0c00000   (12256 kB)
[    0.000000]       .init : 0xc1000000 - 0xc1200000   (2048 kB)
[    0.000000]       .data : 0xc1200000 - 0xc12d7db0   ( 864 kB)
[    0.000000]        .bss : 0xc12d9000 - 0xc136f53c   ( 602 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[    0.000000]         Build-time adjustment of leaf fanout to 32.
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] L2C: failed to init: -19
[    0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000005] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.000018] Switching to timer-based delay loop, resolution 41ns
[    0.001652] Console: colour dummy device 80x30
[    0.001679] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    0.001695] pid_max: default: 32768 minimum: 301
[    0.001781] Security Framework initialized
[    0.001792] Yama: becoming mindful.
[    0.001846] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.001858] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.002531] Initializing cgroup subsys devices
[    0.002549] Initializing cgroup subsys freezer
[    0.002575] CPU: Testing write buffer coherency: ok
[    0.002605] ftrace: allocating 40724 entries in 120 pages
[    0.074904] CPU0: update cpu_capacity 430
[    0.074918] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
[    0.075163] Setting up static identity map for 0x100000 - 0x100058
[    0.077707] CPU1: update cpu_capacity 430
[    0.077713] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
[    0.079344] CPU2: update cpu_capacity 430
[    0.079349] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
[    0.080965] CPU3: update cpu_capacity 430
[    0.080971] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503
[    0.081038] Brought up 4 CPUs
[    0.081064] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[    0.081070] CPU: All CPU(s) started in SVC mode.
[    0.082184] devtmpfs: initialized
[    0.095727] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
[    0.096032] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.096056] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.096431] pinctrl core: initialized pinctrl subsystem
[    0.097269] NET: Registered protocol family 16
[    0.098002] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.124745] cpuidle: using governor ladder
[    0.154763] cpuidle: using governor menu
[    0.180094] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.180104] hw-breakpoint: maximum watchpoint size is 4 bytes.
[    0.227137] vcc_5v: supplied by vcc_sys
[    0.227552] vcc_host_5v: supplied by vcc_5v
[    0.227982] vcc_otg_5v: supplied by vcc_5v
[    0.228967] iommu: Adding device ff930000.vop to group 0
[    0.229044] iommu: Adding device ff940000.vop to group 1
[    0.229126] iommu: Adding device ff9a0000.vpu-service to group 2
[    0.229204] iommu: Adding device ff9c0000.hevc-service to group 3
[    0.230667] SCSI subsystem initialized
[    0.230894] usbcore: registered new interface driver usbfs
[    0.230953] usbcore: registered new interface driver hub
[    0.231003] usbcore: registered new device driver usb
[    0.231126] Linux video capture interface: v2.00
[    0.231169] pps_core: LinuxPPS API ver. 1 registered
[    0.231176] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.231205] PTP clock support registered
[    0.232361] Advanced Linux Sound Architecture Driver Initialized.
[    0.232978] Bluetooth: Core ver 2.21
[    0.233011] NET: Registered protocol family 31
[    0.233019] Bluetooth: HCI device and connection manager initialized
[    0.233031] Bluetooth: HCI socket layer initialized
[    0.233042] Bluetooth: L2CAP socket layer initialized
[    0.233069] Bluetooth: SCO socket layer initialized
[    0.234390] clocksource: Switched to clocksource arch_sys_counter
[    0.282257] NET: Registered protocol family 2
[    0.282767] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    0.282843] TCP bind hash table entries: 8192 (order: 5, 163840 bytes)
[    0.283006] TCP: Hash tables configured (established 8192 bind 8192)
[    0.283059] UDP hash table entries: 512 (order: 2, 24576 bytes)
[    0.283104] UDP-Lite hash table entries: 512 (order: 2, 24576 bytes)
[    0.283315] NET: Registered protocol family 1
[    0.283604] RPC: Registered named UNIX socket transport module.
[    0.283613] RPC: Registered udp transport module.
[    0.283619] RPC: Registered tcp transport module.
[    0.283625] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.284610] hw perfevents: enabled with armv7_cortex_a12 PMU driver, 7 counters available
[    0.286425] Initialise system trusted keyring
[    0.295364] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.297070] NFS: Registering the id_resolver key type
[    0.297097] Key type id_resolver registered
[    0.297104] Key type id_legacy registered
[    0.297125] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[    0.297730] fuse init (API version 7.23)
[    0.301726] NET: Registered protocol family 38
[    0.301756] Key type asymmetric registered
[    0.301769] Asymmetric key parser 'x509' registered
[    0.301841] bounce: pool size: 64 pages
[    0.302022] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[    0.302038] io scheduler noop registered
[    0.302051] io scheduler deadline registered
[    0.302084] io scheduler cfq registered (default)
[    0.302406] rockchip-usb-phy ff770000.syscon:usbphy: vbus_drv is not assigned!
[    0.305167] rk-vcodec ff9a0000.vpu-service: probe device
[    0.305216] rk-vcodec ff9a0000.vpu-service: vpu mmu dec eeb14e10
[    0.305407] rk-vcodec ff9a0000.vpu-service: allocator is drm
[    0.305472] rk-vcodec ff9a0000.vpu-service: checking hw id 4831
[    0.305955] rk-vcodec ff9a0000.vpu-service: init success
[    0.306433] rk-vcodec ff9c0000.hevc-service: probe device
[    0.306482] rk-vcodec ff9c0000.hevc-service: vpu mmu dec eeb15210
[    0.306651] rk-vcodec ff9c0000.hevc-service: allocator is drm
[    0.306712] rk-vcodec ff9c0000.hevc-service: checking hw id 6867
[    0.307036] rk-vcodec ff9c0000.hevc-service: init success
[    0.309052] dma-pl330 ff250000.dma-controller: Loaded driver for PL330 DMAC-241330
[    0.309066] dma-pl330 ff250000.dma-controller:         DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[    0.309800] dma-pl330 ffb20000.dma-controller: Loaded driver for PL330 DMAC-241330
[    0.309813] dma-pl330 ffb20000.dma-controller:         DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10
[    0.310358] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[    0.312154] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 36, base_baud = 1500000) is a 16550A
[    0.312802] ff190000.serial: ttyS1 at MMIO 0xff190000 (irq = 37, base_baud = 1500000) is a 16550A
[    0.313443] console [ttyS2] disabled
[    0.313482] ff690000.serial: ttyS2 at MMIO 0xff690000 (irq = 38, base_baud = 1500000) is a 16550A
[    1.155682] console [ttyS2] enabled
[    1.159861] ff1b0000.serial: ttyS3 at MMIO 0xff1b0000 (irq = 39, base_baud = 1500000) is a 16550A
[    1.169382] ff1c0000.serial: ttyS4 at MMIO 0xff1c0000 (irq = 40, base_baud = 1500000) is a 16550A
[    1.179411] [drm:drm_core_init] Initialized drm 1.1.0 20060810
[    1.186930] ff960000.mipi.0 supply power not found, using dummy regulator
[    1.196453] rockchip-drm display-subsystem: bound ff940000.vop (ops 0xc0c5293c)
[    1.204419] rockchip-drm displaU-Boot 2017.02-RK3288-06-g8adeb23-dirty (Jun 02 2017 - 17:57:28)
CPU: rk3288
cpu version = 0
128 MiB
SdmmcInit = 0 400
SdmmcInit = 2 0
storage init OK!
GetParam
no key node
No pmic detect.
empty serial no.
normal boot.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
no fuel gauge found
Unable to boot:boot
try to start backup
Starting kernel ...
[    0.301726] NET: Registered proy-subsystem: bound ff930000.vop (ops 0xc0c5293c)
[    1.211774] dw-mipi-dsi ff960000.mipi: No PHY APB clock specified
[    1.217885] dw-mipi-dsi ff960000.mipi: no reset control specified
[    1.224032] rockchip-drm display-subsystem: bound ff960000.mipi (ops 0xc0c4f6d4)
[    1.231643] i2c i2c-6: of_i2c: modalias failure on /hdmi@ff980000/ports
[    1.238274] dwhdmi-rockchip ff980000.hdmi: registered DesignWare HDMI I2C bus driver
[    1.246074] dwhdmi-rockchip ff980000.hdmi: Detected HDMI TX controller v2.01a with HDCP (DWC HDMI 2.0 TX PHY)
[    1.256562] rockchip-drm display-subsystem: bound ff980000.hdmi (ops 0xc0c4f354)
[    1.263954] [drm:drm_vblank_init] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    1.271969] [drm:drm_vblank_init] No driver support for vblank timestamp query.
[    1.279298] rockchip-drm display-subsystem: failed to parse display resources
[    1.335672] dw-mipi-dsi ff960000.mipi: failed to wait for phy clk lane stop state
[    1.400427] Console: switching to colour frame buffer device 170x48
[    1.456814] rockchip-drm display-subsystem: fb0:  frame buffer device
[    1.485622] usbcore: registered new interface driver udl
[    1.491662] mali ffa30000.gpu: Failed to get regulator
[    1.496820] mali ffa30000.gpu: Power control initialization failed
[    1.504096] brd: module loaded
[    1.512815] loop: module loaded
[    1.516632] zram: Added device: zram0
[    1.520329] lkdtm: No crash points registered, enable through debugfs
[    1.527509] tun: Universal TUN/TAP device driver, 1.6
[    1.532555] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    1.539989] rk_gmac-dwmac ff290000.ethernet: phy regulator is not available yet, deferred probing
[    1.549449] PPP generic driver version 2.4.2
[    1.553972] usbcore: registered new interface driver rndis_wlan
[    1.560109] usbcore: registered new interface driver rt2800usb
[    1.566019] Rockchip WiFi SYS interface (V1.00) ...
[    1.571013] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[    1.578471] usbcore: registered new interface driver pegasus
[    1.584171] usbcore: registered new interface driver rtl8150
[    1.589884] usbcore: registered new interface driver r8152
[    1.595441] usbcore: registered new interface driver asix
[    1.600878] usbcore: registered new interface driver ax88179_178a
[    1.607034] usbcore: registered new interface driver cdc_ether
[    1.612907] usbcore: registered new interface driver dm9601
[    1.618557] usbcore: registered new interface driver smsc75xx
[    1.624346] usbcore: registered new interface driver smsc95xx
[    1.630149] usbcore: registered new interface driver net1080
[    1.635873] usbcore: registered new interface driver rndis_host
[    1.641832] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[    1.649318] usbcore: registered new interface driver cdc_ncm
[    1.655042] usbcore: registered new interface driver cdc_mbim
[    1.661115] ff540000.usb supply vusb_d not found, using dummy regulator
[    1.667789] ff540000.usb supply vusb_a not found, using dummy regulator
[    1.794552] dwc2 ff540000.usb: DWC OTG Controller
[    1.799272] dwc2 ff540000.usb: new USB bus registered, assigned bus number 1
[    1.806368] dwc2 ff540000.usb: irq 45, io mem 0x00000000
[    1.811896] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.818697] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.825931] usb usb1: Product: DWC OTG Controller
[    1.830631] usb usb1: Manufacturer: Linux 4.4.70 dwc2_hsotg
[    1.836209] usb usb1: SerialNumber: ff540000.usb
[    1.841396] hub 1-0:1.0: USB hub found
[    1.845199] hub 1-0:1.0: 1 port detected
[    1.849651] ff580000.usb supply vusb_d not found, using dummy regulator
[    1.856325] ff580000.usb supply vusb_a not found, using dummy regulator
[    2.134430] dwc2 ff580000.usb: EPs: 10, dedicated fifos, 972 entries in SPRAM
[    2.141924] dwc2 ff580000.usb: DWC OTG Controller
[    2.146673] dwc2 ff580000.usb: new USB bus registered, assigned bus number 2
[    2.153734] dwc2 ff580000.usb: irq 46, io mem 0x00000000
[    2.159187] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    2.165994] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.173208] usb usb2: Product: DWC OTG Controller
[    2.177927] usb usb2: Manufacturer: Linux 4.4.70 dwc2_hsotg
[    2.183494] usb usb2: SerialNumber: ff580000.usb
[    2.188710] hub 2-0:1.0: USB hub found
[    2.192485] hub 2-0:1.0: 1 port detected
[    2.197619] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.204159] ehci-platform: EHCI generic platform driver
[    2.209602] ehci-platform ff500000.usb: EHCI Host Controller
[    2.215459] ehci-platform ff500000.usb: new USB bus registered, assigned bus number 3
[    2.223382] ehci-platform ff500000.usb: irq 44, io mem 0xff500000
[    2.244421] usb 1-1: new high-speed USB device number 2 using dwc2
[    2.264420] ehci-platform ff500000.usb: USB 2.0 started, EHCI 1.00
[    2.270753] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[    2.277554] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.284800] usb usb3: Product: EHCI Host Controller
[    2.289674] usb usb3: Manufacturer: Linux 4.4.70 ehci_hcd
[    2.295083] usb usb3: SerialNumber: ff500000.usb
[    2.300314] hub 3-0:1.0: USB hub found
[    2.304090] hub 3-0:1.0: 1 port detected
[    2.308641] usbcore: registered new interface driver cdc_acm
[    2.314294] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    2.322375] usbcore: registered new interface driver cdc_wdm
[    2.328166] usbcore: registered new interface driver usb-storage
[    2.334252] usbcore: registered new interface driver usbserial
[    2.340211] usbcore: registered new interface driver usbserial_generic
[    2.346791] usbserial: USB Serial support registered for generic
[    2.352841] usbcore: registered new interface driver cp210x
[    2.358463] usbserial: USB Serial support registered for cp210x
[    2.364460] usbcore: registered new interface driver ftdi_sio
[    2.370229] usbserial: USB Serial support registered for FTDI USB Serial Device
[    2.377679] usbcore: registered new interface driver keyspan
[    2.383364] usbserial: USB Serial support registered for Keyspan - (without firmware)
[    2.391227] usbserial: USB Serial support registered for Keyspan 1 port adapter
[    2.398644] usbserial: USB Serial support registered for Keyspan 2 port adapter
[    2.406536] usbserial: USB Serial support registered for Keyspan 4 port adapter
[    2.413902] usbcore: registered new interface driver option
[    2.419514] usbserial: USB Serial support registered for GSM modem (1-port)
[    2.426645] usbcore: registered new interface driver oti6858
[    2.432337] usbserial: USB Serial support registered for oti6858
[    2.438406] usbcore: registered new interface driver pl2303
[    2.444000] usbserial: USB Serial support registered for pl2303
[    2.449982] usbcore: registered new interface driver qcserial
[    2.455854] usbserial: USB Serial support registered for Qualcomm USB modem
[    2.462870] usbcore: registered new interface driver sierra
[    2.468483] usbserial: USB Serial support registered for Sierra USB modem
[    2.475641] usb 1-1: New USB device found, idVendor=1a40, idProduct=0101
[    2.482337] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    2.489496] usb 1-1: Product: USB 2.0 Hub [MTT]
[    2.490343] usbcore: registered new interface driver iforce
[    2.490415] usbcore: registered new interface driver xpad
[    2.505213] usbcore: registered new interface driver usbtouchscreen
[    2.505711] hub 1-1:1.0: USB hub found
[    2.505784] hub 1-1:1.0: 4 ports detected
[    2.519246] ==gsl_ts_init==
[    2.522067] ret=0
[    2.524276] i2c /dev entries driver
[    2.529057] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[    2.536001] fan53555-reg: supplied by vcc_sys
[    2.540659] vdd_cpu: No configuration
[    2.546192] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[    2.553093] fan53555-reg: supplied by vcc_sys
[    2.557770] vdd_gpu: No configuration
[    2.565157] rtc-hym8563 0-0051: rtc core: registered hym8563 as rtc0
[    2.572364] REG1: supplied by vcc_sys
[    2.576907] REG2: supplied by vcc_sys
[    2.581322] vcc28_dvp: supplied by vcc_io
[    2.585519] dovdd_1v8: supplied by vcc28_dvp
[    2.589845] vcc_sd: supplied by vcc_io
[    2.593771] vcc_flash: supplied by vcc_io
[    2.598005] REG3: supplied by vcc_sys
[    2.602441] REG4: supplied by vcc_sys
[    2.606878] REG5: supplied by vcc_sys
[    2.611294] REG6: supplied by vcc_sys
[    2.615851] REG7: supplied by vcc_sys
[    2.620136] REG8: supplied by vcc_sys
[    2.624694] REG9: supplied by vcc_sys
[    2.628968] REG10: supplied by vcc_20
[    2.633514] REG11: supplied by vcc_20
[    2.638070] REG12: supplied by vcc_20
[    2.642725] rk3x-i2c ff650000.i2c: Initialized RK3xxx I2C bus at f0d34000
[    2.650321] GSLX680 Enter gsl_ts_probe
[    2.974405] gsl_ts_probe--1317, i2c_master_recv fail
[    2.979390] rk3x-i2c ff140000.i2c: Initialized RK3xxx I2C bus at f0d36000
[    2.986705] rk3x-i2c ff160000.i2c: Initialized RK3xxx I2C bus at f0d38000
[    2.994140] rk3x-i2c ff660000.i2c: Initialized RK3xxx I2C bus at f0d3a000
[    3.001599] usbcore: registered new interface driver uvcvideo
[    3.007356] USB Video Class driver (1.1.1)
[    3.015825] rockchip-thermal ff280000.tsadc: Missing rockchip,grf property
[    3.022749] rk_tsadcv2_temp_to_code: Invalid conversion table: code=4095, temperature=2147483647
[    3.032361] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[    3.041093] Bluetooth: Virtual HCI driver ver 1.5
[    3.045975] Bluetooth: HCI UART driver ver 2.3
[    3.050417] Bluetooth: HCI UART protocol H4 registered
[    3.055569] Bluetooth: HCI UART protocol LL registered
[    3.060701] Bluetooth: HCI UART protocol ATH3K registered
[    3.066198] usbcore: registered new interface driver bfusb
[    3.071745] usbcore: registered new interface driver btusb
[    3.079285] cpu cpu0: Failed to get cpu_leakage
[    3.084171] cpufreq-dt cpufreq-dt: failed register driver: -17
[    3.090066] cpufreq-dt: probe of cpufreq-dt failed with error -17
[    3.096278] sdhci: Secure Digital Host Controller Interface driver
[    3.102450] sdhci: Copyright(c) Pierre Ossman
[    3.106838] Synopsys Designware Multimedia Card Interface Driver
[    3.113448] dwmmc_rockchip ff0c0000.dwmmc: IDMAC supports 32-bit address mode.
[    3.120732] dwmmc_rockchip ff0c0000.dwmmc: Using internal DMA controller.
[    3.127532] dwmmc_rockchip ff0c0000.dwmmc: Version ID is 270a
[    3.133311] dwmmc_rockchip ff0c0000.dwmmc: DW MMC controller at irq 29,32 bit host data width,256 deep fifo
[    3.143063] dwmmc_rockchip ff0c0000.dwmmc: 'clock-freq-min-max' property was deprecated.
[    3.274643] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    3.296104] dwmmc_rockchip ff0c0000.dwmmc: 1 slots initialized
[    3.304710] dwmmc_rockchip ff0d0000.dwmmc: IDMAC supports 32-bit address mode.
[    3.312097] dwmmc_rockchip ff0d0000.dwmmc: Using internal DMA controller.
[    3.319124] dwmmc_rockchip ff0d0000.dwmmc: Version ID is 270a
[    3.324934] dwmmc_rockchip ff0d0000.dwmmc: DW MMC controller at irq 30,32 bit host data width,256 deep fifo
[    3.334684] dwmmc_rockchip ff0d0000.dwmmc: 'clock-freq-min-max' property was deprecated.
[    3.343008] dwmmc_rockchip ff0d0000.dwmmc: Failed getting OCR mask: 0
[    3.349640] dwmmc_rockchip ff0d0000.dwmmc: allocated mmc-pwrseq
[    3.356234] dwmmc_rockchip ff0d0000.dwmmc: could not set regulator OCR (-22)
[    3.363272] dwmmc_rockchip ff0d0000.dwmmc: failed to enable vmmc regulator
[    3.384430] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    3.404468] dwmmc_rockchip ff0d0000.dwmmc: 1 slots initialized
[    3.410828] dwmmc_rockchip ff0f0000.dwmmc: IDMAC supports 32-bit address mode.
[    3.419139] dwmmc_rockchip ff0f0000.dwmmc: Using internal DMA controller.
[    3.425967] dwmmc_rockchip ff0f0000.dwmmc: Version ID is 270a
[    3.433751] dwmmc_rockchip ff0f0000.dwmmc: DW MMC controller at irq 31,32 bit host data width,256 deep fifo
[    3.443510] dwmmc_rockchip ff0f0000.dwmmc: 'clock-freq-min-max' property was deprecated.
[    3.465475] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    3.483780] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[    3.490783] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    3.496327] dwmmc_rockchip ff0f0000.dwmmc: 1 slots initialized
[    3.503354] sdhci-pltfm: SDHCI platform and OF driver helper
[    3.512433] hidraw: raw HID events driver (C) Jiri Kosina
[    3.517841] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    3.524957] usbcore: registered new interface driver usbhid
[    3.527760] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[    3.531083] mmc1: queuing unknown CIS tuple 0x81 (9 bytes)
[    3.541473] usbhid: USB HID core driver
[    3.545557] ashmem: initialized
[    3.550120] usbcore: registered new interface driver snd-usb-audio
[    3.558909] u32 classifier
[    3.561616] Netfilter messages via NETLINK v0.30.
[    3.566398] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[    3.567029] mmc2: MAN_BKOPS_EN bit is not set
[    3.567988] mmc_host mmc2: Bus speed (slot 0) = 49500000Hz (slot req 52000000Hz, actual 49500000HZ div = 0)
[    3.568104] mmc2: new high speed MMC card at address 0001
[    3.568404] mmcblk2: mmc2:0001 AJTD4R 14.6 GiB
[    3.576913] mmcblk2boot0: mmc2:0001 AJTD4R partition 1 4.00 MiB
[    3.577025] mmcblk2boot1: mmc2:0001 AJTD4R partition 2 4.00 MiB
[    3.581285] mmc_host mmc1: Bus speed (slot 0) = 49500000Hz (slot req 50000000Hz, actual 49500000HZ div = 0)
[    3.584492] mmcblk2rpmb: mmc2:0001 AJTD4R partition 3 4.00 MiB
[    3.586720]      uboot: 0x000400000 -- 0x000800000 (4 MB)
[    3.586723]       misc: 0x000800000 -- 0x000c00000 (4 MB)
[    3.586726]   resource: 0x000c00000 -- 0x001c00000 (16 MB)
[    3.586728]     kernel: 0x001c00000 -- 0x002c00000 (16 MB)
[    3.586730]       back: 0x002c00000 -- 0x003c00000 (16 MB)
[    3.586732]     backup: 0x003c00000 -- 0x005c00000 (32 MB)
[    3.586735]  linuxroot: 0x005c00000 -- 0x185d00000 (6145 MB)
[    3.589343]  mmcblk2: p1 p2 p3 p4 p5 p6 p7
[    3.589344] dwmmc_rockchip ff0d0000.dwmmc: Successfully tuned phase to 97
[    3.591132] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[    3.591149] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[    3.685389] ctnetlink v0.93: registering with nfnetlink.
[    3.690767] ip_set: protocol 6
[    3.693820] IPVS: Registered protocols ()
[    3.697857] IPVS: Connection hash table configured (size=4096, memory=32Kbytes)
[    3.705217] IPVS: Creating netns size=1104 id=0
[    3.709764] IPVS: ipvs loaded.
[    3.712994] ip_tables: (C) 2000-2006 Netfilter Core Team
[    3.718383] Initializing XFRM netlink socket
[    3.723042] NET: Registered protocol family 10
[    3.728006] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    3.733501] sit: IPv6 over IPv4 tunneling driver
[    3.738445] NET: Registered protocol family 17
[    3.742892] NET: Registered protocol family 15
[    3.747368] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[    3.759978] Bridge firewalling registered
[    3.764049] Bluetooth: RFCOMM socket layer initialized
[    3.769204] Bluetooth: RFCOMM ver 1.11
[    3.772954] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    3.778874] Bluetooth: HIDP socket layer initialized
[    3.783872] 8021q: 802.1Q VLAN Support v1.8
[    3.788067] lib80211: common routines for IEEE802.11 drivers
[    3.793740] [WLAN_RFKILL]: Enter rfkill_wlan_init
[    3.798599] [WLAN_RFKILL]: Enter rfkill_wlan_probe
[    3.803405] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6335
[    3.810275] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control.
[    3.817410] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by gpio.
[    3.824834] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_wake_irq = 150, flags = 0.
[    3.834035] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio
[    3.839260] [WLAN_RFKILL]: Exit rfkill_wlan_probe
[    3.843987] [BT_RFKILL]: Enter rfkill_rk_init
[    3.848546] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts_gpios = 139.
[    3.856740] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset_gpio = 149.
[    3.864839] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_gpio = 146.
[    3.872836] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_host_irq = 151.
[    3.881188] [BT_RFKILL]: bluetooth_platdata_parse_dt: clk_get failed!!!.
[    3.887927] [BT_RFKILL]: Request irq for bt wakeup host
[    3.893161] [BT_RFKILL]: BT_WAKE_HOST IRQ fired
[    3.897718] [BT_RFKILL]: ** disable irq
[    3.901624] [BT_RFKILL]: bt_default device registered.
[    3.906799] Key type dns_resolver registered
[    3.911475] ThumbEE CPU extension supported.
[    3.915766] Registering SWP/SWPB emulation handler
[    3.921008] Loading compiled-in X.509 certificates
[    3.926724] W : [File] : drivers/gpu/arm/midgard_for_linux/platform/rk/mali_kbase_config_rk.c; [Line] : 107; [Func] : kbase_platform_rk_init(); power-off-delay-ms not available.
[    3.942577] vendor storage:20160801 ret = 0
[    3.942766] mali ffa30000.gpu: GPU identified as 0x0750 r1p0 status 0
[    3.943100] I : [File] : drivers/gpu/arm/midgard_for_linux/backend/gpu/mali_kbase_devfreq.c; [Line] : 271; [Func] : kbase_devfreq_init(); success initing power_model_simple.
[    3.954551] mali ffa30000.gpu: Probed as mali0
[    3.955079] rk_gmac-dwmac ff290000.ethernet: clock input or output? (input).
[    3.955084] rk_gmac-dwmac ff290000.ethernet: TX delay(0x30).
[    3.955087] rk_gmac-dwmac ff290000.ethernet: RX delay(0x10).
[    3.955155] rk_gmac-dwmac ff290000.ethernet: clock input from PHY
[    3.955158] rk_gmac-dwmac ff290000.ethernet: init for RGMII
[    3.960330] stmmac - user ID: 0x10, Synopsys ID: 0x35
[    3.960331]  Ring mode enabled
[    3.960334]  DMA HW capability register supported
[    3.960334]  Normal descriptors
[    3.960335]  RX Checksum Offload Engine supported (type 2)
[    3.960336]  TX Checksum insertion supported
[    3.960337]  Wake-Up On Lan supported
[    3.960363]  Enable RX Mitigation via HW Watchdog Timer
[    3.975125] devfreq ffa30000.gpu: Couldn't update frequency transition information.
[    4.991322] libphy: stmmac: probed
[    4.994958] eth%d: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
[    5.001455] eth%d: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
[    5.139924] asoc-simple-card es8323-sound: ES8323 HiFi <-> ff890000.i2s mapping ok
[    5.147741] asoc-simple-card es8323-sound: ASoC: no source widget found for MICBIAS1
[    5.155634] asoc-simple-card es8323-sound: ASoC: Failed to add route MICBIAS1 -> direct -> Mic Jack
[    5.164867] asoc-simple-card es8323-sound: ASoC: no sink widget found for IN1P
[    5.172108] asoc-simple-card es8323-sound: ASoC: Failed to add route Mic Jack -> direct -> IN1P
[    5.180802] asoc-simple-card es8323-sound: ASoC: no source widget found for HPOL
[    5.188205] asoc-simple-card es8323-sound: ASoC: Failed to add route HPOL -> direct -> Headphone Jack
[    5.197417] asoc-simple-card es8323-sound: ASoC: no source widget found for HPOR
[    5.204813] asoc-simple-card es8323-sound: ASoC: Failed to add route HPOR -> direct -> Headphone Jack
[    5.217061] asoc-simple-card sound: dit-hifi <-> ff8b0000.sound mapping ok
[    5.224452] dhd_module_init: in
[    5.224453]
[    5.224458] =======================================================
[    5.224460] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
[    5.224461] =======================================================
[    5.224463] Realtek 8188EU USB WiFi driver (Powered by Rockchip,Ver 2.20.WFD) init.
[    5.224465] [WLAN_RFKILL]: rockchip_wifi_power: 1
[    5.224468] [WLAN_RFKILL]: wifi turn on power. -1
[    5.224470] RTL871X: module init start
[    5.224472] RTL871X: rtl8188eu v4.3.24_16705.20160509
[    5.224558] usbcore: registered new interface driver rtl8188eu
[    5.224561] RTL871X: module init ret=0
[    5.224961] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[    5.227600] rtc-hym8563 0-0051: setting system clock to 2017-01-01 13:44:52 UTC (1483278292)
[    5.235364] dovdd_1v8: disabling
[    5.235368] vcc_sd: disabling
[    5.235803] ALSA device list:
[    5.235806]   #0: rockchip,es8323-codec
[    5.235807]   #1: SPDIF
[   5.313847] ======== dhd_wlan_init_plat_data ========
[dE[    5.319095] dhd_wlan_init_gpio: GPIO(WL_HOST_WAKE) = -1
[    5.319100] ttyS2 - failed to request DMA
[    5.328324] [WLAN_RFKILL]: rockchip_wifi_get_oob_irq: Enter
[    5.333888] dhd_wlan_init_gpio: host_oob_irq: 232
[    5.334555] EXT4-fs (mmcblk2p7): couldn't mount as ext3 due to feature incompatibilities
[    5.334846] EXT4-fs (mmcblk2p7): couldn't mount as ext2 due to feature incompatibilities
[    5.354758] dhd_wlan_init_gpio: host_oob_irq_flags=0x414
[    5.360061] dhd_wifi_platform_load: Enter
[    5.364111] Power-up adapter 'DHD generic adapter'
[    5.369128] wifi_platform_set_power = 1
[    5.372960] ======== PULL WL_REG_ON(-1) HIGH! ========
[    5.378114] [WLAN_RFKILL]: rockchip_wifi_power: 1
[    5.382811] [WLAN_RFKILL]: wifi turn on power. -1
[    5.405740] EXT4-fs (mmcblk2p7): recovery complete
[    5.410948] EXT4-fs (mmcblk2p7): mounted filesystem with ordered data mode. Opts: (null)
[    5.419074] VFS: Mounted root (ext4 filesystem) on device 179:7.
[    5.425492] devtmpfs: mounted
[    5.429370] Freeing unused kernel memory: 2048K (c1000000 - c1200000)
[    5.594465] wifi_platform_bus_enumerate device present 1
[    5.599787] ======== Card detection to detect SDIO card! ========
[    5.605918] mmc1:mmc host rescan start!
[    5.625901] bcmsdh_register: register client driver
[    5.631003] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[    5.636038] bcmsdh_sdmmc: bcmsdh_sdmmc_probe Enter
[    5.640835] bus num (host idx)=1, slot num (rca)=1
[    5.645683] found adapter info 'DHD generic adapter'
[    5.650740] sdioh_attach: set sd_f2_blocksize 256
[    5.655984] F1 signature read @0x18000000=0x15264345
[    5.657825] random: init: uninitialized urandom read (12 bytes read, 70 bits of entropy available)
[    5.673257] F1 signature OK, socitype:0x1 chip:0x4345 rev:0x6 pkg:0x2
[    5.680299] DHD: dongle ram size is set to 819200(orig 819200) at 0x198000
[    5.687300] dhd_conf_set_chiprev: chip=0x4345, chiprev=6
[    5.692661] dhd_conf_set_conf_path_by_nv_path: config_path=/system/etc/firmware/config.txt
[    5.701493] wl_create_event_handler(): thread:wl_event_handler:88 started
[    5.701501] tsk Enter, tsk = 0xedf815c8
[    5.712296] wl_escan_attach: Enter
[    5.715744] wl_escan_init: Enter
[    5.723138] wl_create_event_handler(): thread:wl_escan_handler:8c started
[    5.724147] tsk Enter, tsk = 0xedff0170
[    5.733891] dhd_attach(): thread:dhd_watchdog_thread:91 started
[    5.741903] dhd_attach(): thread:dhd_dpc:92 started
[    5.743731] init: plymouth-upstart-bridge main process (135) terminated with status 1
[    5.743758] init: plymouth-upstart-bridge main process ended, respawning
[[    5.761533] dhd_deferred_work_init: work queue initialized
[    5.773645] Dongle Host Driver, version 1.363.59.144.7 (r)
[    5.779556] Register interface [wlan0]  MAC: cc:4b:73:8a:fa:94
[    5.779556]
[    5.780697] init: plymouth-upstart-bridge main process (148) terminated with status 1
[    5.780721] init: plymouth-upstart-bridge main process ended, respawning
[   5.801394] wl_event_handler: was terminated
[t[    5.805791] dhd_wl_ioctl: returning as busstate=0
[    5.810529] bcmsdh_oob_intr_unregister: Enter
[    5.814908] bcmsdh_oob_intr_unregister: irq is not registered
[    5.814922] dhd_txglom_enable: enable 0
[    5.814925] dhd_conf_set_txglom_params: swtxglom=0, txglom_ext=0, txglom_bucket_size=0
[    5.814927] dhd_conf_set_txglom_params: txglomsize=0, deferred_tx_len=0, bus_txglom=-1
[   5.814929] dhd_conf_set_txglom_params: tx_in_rx=1, txinrx_thres=-1, dhd_txminmax=1
[    5.814931] dhd_conf_set_txglom_params: tx_max_offset=0, txctl_tmo_fix=1
[    5.814933] sdioh_set_mode: set txglom_mode to copy
[    5.814935] dhd_bus_devreset:  WLAN OFF DONE
[    5.814985] wifi_platform_set_power = 0
[    5.814987] ======== PULL WL_REG_ON(-1) LOW! ========
[    5.814989] [WLAN_RFKILL]: rockchip_wifi_power: 0
[    5.815000] [WLAN_RFKILL]: wifi shut off power.
[    5.815045] dhd_module_init: Exit err=0
[    5.848378] init: ureadahead main process (139) terminated with status 5
[    5.848479] init: plymouth-upstart-bridge main process (153) terminated with status 1
[    5.848497] init: plymouth-upstart-bridge main process ended, respawning
[    5.960400] random: mountall: uninitialized urandom read (12 bytes read, 92 bits of entropy available)
* Starting Mount filesystems on boot[ OK ]
* Starting Signal sysvinit that the rootfs is mounted[ OK ]
* Starting Populate /dev filesystem[ OK ]
* Stopping Populate /dev filesystem[ OK ]
* Starting Fix-up /sys/kernel/debug filesystem[ OK ]
* Stopping Fix-up /sys/kernel/debug filesystem[ OK ]
* Starting Clean /tmp directory[ OK ]
* Starting Populate and link to /run filesystem[ OK ]
* Stopping Populate and link to /run filesystem[ OK ]
* Stopping Track if upstart is running in a container[ OK ]
* Stopping Clean /tmp directory[ OK ]
* Starting Initialize or finalize resolvconf[ OK ]
* Starting set console keymap[ OK ]
* Starting Signal sysvinit that virtual filesystems are mounted[ OK ]
* Starting Bridge udev events into upstart[ OK ]
* Stopping set console keymap[ OK ]
* Starting Signal sysvinit that local filesystems are mounted[ OK ]
* Starting restore software rfkill state[ OK ]
* Starting device node and kernel event manager[ OK ]
* Starting Signal sysvinit that remote filesystems are mounted[ OK ]
* Starting NFSv4 id <-> name mapper[ OK ]
* Starting load modules from /etc/modules[ OK ]
* Starting cold plug devices[ OK ]
* Starting run fbset before lightdm[ OK ]
* Starting log initial device creation[ OK ]
* Stopping restore software rfkill state[ OK ]
* Stopping load modules from /etc/modules[ OK ]
* Stopping run fbset before lightdm[ OK ]
* Starting flush early job output to logs[ OK ]
* Starting D-Bus system message bus[ OK ]
* Stopping Mount filesystems on boot[ OK ]
* Stopping flush early job output to logs[ OK ]
* Stopping cold plug devices[ OK ]
* Stopping log initial device creation[ OK ]
* Starting SystemD login management service[ OK ]
* Starting configure network device security[ OK ]
* Starting save udev log and update rules[ OK ]
* Starting set console font[ OK ]
* Stopping save udev log and update rules[ OK ]
* Stopping set console font[ OK ]
* Starting userspace bootsplash[ OK ]
* Stopping userspace bootsplash[ OK ]
* Starting Send an event to indicate plymouth is up[ OK ]
* Starting system logging daemon[ OK ]
* Stopping Send an event to indicate plymouth is up[ OK ]
* Stopping rpcsec_gss daemon[ OK ]
* Starting System V initialisation compatibility[ OK ]
* Starting configure virtual network devices[ OK ]
* Starting configure network device[ OK ]
* Starting Mount network filesystems[ OK ]
* Starting Upstart job to start rpcbind on boot only[ OK ]
* Starting Failsafe Boot Delay[ OK ]
* Stopping Upstart job to start rpcbind on boot only[ OK ]
* Stopping System V initialisation compatibility[ OK ]
* Starting System V runlevel compatibility[ OK ]
* Starting anac(h)ronistic cron[ OK ]
* Starting save kernel messages[ OK ]
* Starting Restore Sound Card State[ OK ]
* Starting regular background program processing daemon[ OK ]
* Stopping Restore Sound Card State[ OK ]
* Stopping save kernel messages[ OK ]
* Starting RPC portmapper replacement[ OK ]
* Stopping Mount network filesystems[ OK ]
* Starting NSM status monitor[ OK ]
* Loading cpufreq kernel modules...
* Starting Bridge file events into upstart[ OK ]
* Starting Bridge socket events into upstart[ OK ]
[ OK ]
* CPU0...         * Starting NFSv4 id <-> name mapper[ OK ]
* CPU1...         * Starting NFSv4 id <-> name mapper[ OK ]
* CPU2...         * CPU3...         * CPUFreq Utilities: Setting performance CPUFreq governor...
[ OK ]
* Starting NTP server ntpd        * Starting NFSv4 id <-> name mapper[ OK ]
[ OK ]
* Starting NFSv4 id <-> name mapper[fail]
* Stopping NFSv4 id <-> name mapper[ OK ]
* Starting OpenSSH server[ OK ]
mount: can't find /storage/sbox in /etc/fstab or /etc/mtab
 * Stopping System V runlevel compatibility[ OK ]
void Serial::setUsbPort() AVAILABLE USB-PORTS: ()
Ubuntu 14.04.5 LTS ubuntu ttyS2
ubuntu login: root (automatic login)
Welcome to Ubuntu 14.04.5 LTS (GNU/Linux 4.4.70 armv7l)
* Documentation:  https://help.ubuntu.com/
root@ubuntu:~# ^C
root@ubuntu:~# ^C
root@ubuntu:~#
Terminating...
Thanks for using picocom
- kernel 5.17.6:
CPU: rk3288
cpu version = 0
CPU's clock information:
    arm pll = 816000000HZ
    periph pll = 297000000HZ
    ddr pll = 396000000HZ
    codec pll = 384000000HZ
Board:        Rockchip platform Board
DRAM:  Found dram banks: 1
Adding bank:0000000000000000(0000000080000000)
128 MiB
GIC CPU mask = 0x00000001
SdmmcInit = 0 400
SdmmcInit = 2 0
ERROR: v7_dcache_inval_range - start address is not aligned - 0x059bc50c
ERROR: v7_dcache_inval_range - stop address is not aligned - 0x059bc70c
ERROR: v7_dcache_inval_range - start address is not aligned - 0x059cc30c
ERROR: v7_dcache_inval_range - stop address is not aligned - 0x059cc50c
storage init OK!
Using default environment
GetParam
Load FDT from resource image.
no key node
No pmic detect.
can't find dts node for pwm0
Can't find dts node for fuel guage cw201x
SecureBootEn = 0, SecureBootLock = 0
#Boot ver: 0000-00-00#0.00
empty serial no.
normal boot.
checkKey
vbus = 1
no fuel gauge found
no fuel gauge found
read logo on state from dts [0]
no fuel gauge found
Hit any key to stop autoboot:  0
'boot' does not seem to be a partition nor an address
Unable to boot:boot
try to start recovery
'recovery' does not seem to be a partition nor an address
Unable to boot:recovery
try to start backup
load fdt from resouce.
Secure Boot state: 0
kernel   @ 0x02000000 (0x00779780)
ramdisk  @ 0x05bf0000 (0x00000000)
bootrk: do_bootm_linux...
   Loading Device Tree to 05600000, end 0560d1ef ... OK
Add bank:0000000000000000, 0000000080000000
Starting kernel ...
[    0.000000] Linux version 5.17.6 (checho@checho-pc) (arm-linux-gnueabihf-gcc (Ubuntu 9.4.0-1ubuntu1~20.04.1) 9.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #2 SMP Thu May 12 17:14:15 -03 2022
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] OF: fdt: Machine model: Firefly-RK3288
[    0.000000] Zone ranges:
[    0.000000]   Normal   [mem 0x0000000000000000-0x000000002fffffff]
[    0.000000]   HighMem  [mem 0x0000000030000000-0x000000007fffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000000000-0x000000007fffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000007fffffff]
[    0.000000] percpu: Embedded 16 pages/cpu s34072 r8192 d23272 u65536
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 522752
[    0.000000] Unknown kernel command line parameters "splash acpi=off apm=off mtdparts=rk29xxnand:0x00002000@0x00002000(uboot),0x00002000@0x00004000(misc),0x00008000@0x00006000(resource),0x00008000@0x0000e000(kernel),0x00008000@0x00016000(back),0x00010000@0x0001e000(backup),0xc00800@0x0002e000(linuxroot) storagemedia=emmc SecureBootCheckOk=0", will be passed to user space.
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.000000] mem auto-init: stackff, heap allocff, heap freeff
[    0.000000] Memory: 2059792K/2097152K available (12288K kernel code, 1870K rwdata, 3512K rodata, 1024K init, 449K bss, 37360K reserved, 0K cma-reserved, 1310720K highmem)
[    0.000000] ftrace: allocating 48189 entries in 95 pages
[    0.000000] ftrace: allocated 95 pages with 6 groups
[    0.000000] trace event string verifier disabled
[    0.000000] rcu: Hierarchical RCU implementation.
[    0.000000]         Rude variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] random: get_random_bytes called from start_kernel+0x3f8/0x6b4 with crng_init=0
[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[    0.000001] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.000020] Switching to timer-based delay loop, resolution 41ns
[    0.001122] Console: colour dummy device 80x30
[    0.001172] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    0.001192] pid_max: default: 32768 minimum: 301
[    0.001279] LSM: Security Framework initializing
[    0.001302] Yama: becoming mindful.
[    0.001420] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.001440] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.002081] CPU: Testing write buffer coherency: ok
[    0.002129] CPU0: Spectre v2: using BPIALL workaround
[    0.002354] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500
[    0.003144] cblist_init_generic: Setting adjustable number of callback queues.
[    0.003164] cblist_init_generic: Setting shift to 2 and lim to 1.
[    0.003281] Setting up static identity map for 0x100000 - 0x100060
[    0.003397] rcu: Hierarchical SRCU implementation.
[    0.003843] smp: Bringing up secondary CPUs ...
[    0.005517] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501
[    0.005532] CPU1: Spectre v2: using BPIALL workaround
[    0.007314] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502
[    0.007329] CPU2: Spectre v2: using BPIALL workaround
[    0.009077] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503
[    0.009092] CPU3: Spectre v2: using BPIALL workaround
[    0.009212] smp: Brought up 1 node, 4 CPUs
[    0.009228] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[    0.009241] CPU: All CPU(s) started in SVC mode.
[    0.009890] devtmpfs: initialized
[    0.021153] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
[    0.021387] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.021413] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.021642] pinctrl core: initialized pinctrl subsystem
[    0.022608] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.023389] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.024945] thermal_sys: Registered thermal governor 'step_wise'
[    0.025629] cpuidle: using governor ladder
[    0.025675] cpuidle: using governor menu
[    0.026637] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.026655] hw-breakpoint: maximum watchpoint size is 4 bytes.
[    0.041915] platform ff980000.hdmi: Fixing up cyclic dependency with ff940000.vop
[    0.042000] platform ff980000.hdmi: Fixing up cyclic dependency with ff930000.vop
[    0.053153] rockchip-gpio ff750000.gpio: probed /pinctrl/gpio@ff750000
[    0.053849] rockchip-gpio ff780000.gpio: probed /pinctrl/gpio@ff780000
[    0.054531] rockchip-gpio ff790000.gpio: probed /pinctrl/gpio@ff790000
[    0.055205] rockchip-gpio ff7a0000.gpio: probed /pinctrl/gpio@ff7a0000
[    0.055956] rockchip-gpio ff7b0000.gpio: probed /pinctrl/gpio@ff7b0000
[    0.056635] rockchip-gpio ff7c0000.gpio: probed /pinctrl/gpio@ff7c0000
[    0.057317] rockchip-gpio ff7d0000.gpio: probed /pinctrl/gpio@ff7d0000
[    0.058071] rockchip-gpio ff7e0000.gpio: probed /pinctrl/gpio@ff7e0000
[    0.058741] rockchip-gpio ff7f0000.gpio: probed /pinctrl/gpio@ff7f0000
[    0.082256] iommu: Default domain type: Translated
[    0.082272] iommu: DMA domain TLB invalidation policy: strict mode
[    0.084444] SCSI subsystem initialized
[    0.084642] usbcore: registered new interface driver usbfs
[    0.084704] usbcore: registered new interface driver hub
[    0.084751] usbcore: registered new device driver usb
[    0.084857] videodev: Linux video capture interface: v2.00
[    0.084907] pps_core: LinuxPPS API ver. 1 registered
[    0.084917] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.084941] PTP clock support registered
[    0.085350] Advanced Linux Sound Architecture Driver Initialized.
[    0.085940] Bluetooth: Core ver 2.22
[    0.085985] NET: Registered PF_BLUETOOTH protocol family
[    0.085997] Bluetooth: HCI device and connection manager initialized
[    0.086013] Bluetooth: HCI socket layer initialized
[    0.086026] Bluetooth: L2CAP socket layer initialized
[    0.086062] Bluetooth: SCO socket layer initialized
[    0.086914] clocksource: Switched to clocksource arch_sys_counter
[    0.157661] NET: Registered PF_INET protocol family
[    0.157840] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.159000] tcp_listen_portaddr_hash hash table entries: 512 (order: 1, 12288 bytes, linear)
[    0.159047] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[    0.159126] TCP bind hash table entries: 8192 (order: 5, 163840 bytes, linear)
[    0.159314] TCP: Hash tables configured (established 8192 bind 8192)
[    0.159420] UDP hash table entries: 512 (order: 2, 24576 bytes, linear)
[    0.159471] UDP-Lite hash table entries: 512 (order: 2, 24576 bytes, linear)
[    0.159681] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.160252] RPC: Registered named UNIX socket transport module.
[    0.160269] RPC: Registered udp transport module.
[    0.160278] RPC: Registered tcp transport module.
[    0.160286] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.736332] hw perfevents: enabled with armv7_cortex_a12 PMU driver, 7 counters available
[    0.746313] Initialise system trusted keyrings
[    0.746473] workingset: timestamp_bits=30 max_order=19 bucket_order=0
[    0.753201] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.754651] NFS: Registering the id_resolver key type
[    0.754681] Key type id_resolver registered
[    0.754692] Key type id_legacy registered
[    0.754710] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[    0.755620] fuse: init (API version 7.36)
[    0.850567] NET: Registered PF_ALG protocol family
[    0.850586] Key type asymmetric registered
[    0.850597] Asymmetric key parser 'x509' registered
[    0.850771] bounce: pool size: 64 pages
[    0.850892] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[    0.850905] io scheduler mq-deadline registered
[    0.850915] io scheduler kyber registered
[    0.857402] dma-pl330 ff250000.dma-controller: Loaded driver for PL330 DMAC-241330
[    0.857424] dma-pl330 ff250000.dma-controller:         DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[    0.858279] dma-pl330 ffb20000.dma-controller: Loaded driver for PL330 DMAC-241330
[    0.858297] dma-pl330 ffb20000.dma-controller:         DBUFF-64x8bytes Num_Chans-5 Num_Peri-6 Num_Events-10
[    0.859485] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    0.861297] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 42, base_baud = 1500000) is a 16550A
[    0.862272] ff190000.serial: ttyS1 at MMIO 0xff190000 (irq = 43, base_baud = 1500000) is a 16550A
[    0.863180] ff690000.serial: ttyS2 at MMIO 0xff690000 (irq = 44, base_baud = 1500000) is a 16550A
[    1.876062] printk: console [ttyS2] enabled
[    1.881707] ff1b0000.serial: ttyS3 at MMIO 0xff1b0000 (irq = 45, base_baud = 1500000) is a 16550A
[    1.893465] rockchip-vop ff930000.vop: Adding to iommu group 0
[    1.900723] rockchip-vop ff940000.vop: Adding to iommu group 1
[    1.911692] rockchip-drm display-subsystem: bound ff930000.vop (ops 0xc0d66830)
[    1.920275] rockchip-drm display-subsystem: bound ff940000.vop (ops 0xc0d66830)
[    1.928959] usbcore: registered new interface driver udl
[    1.939328] brd: module loaded
[    1.949147] loop: module loaded
[    1.953013] lkdtm: No crash points registered, enable through debugfs
[    1.962780] tun: Universal TUN/TAP device driver, 1.6
[    1.969986] PPP generic driver version 2.4.2
[    1.975129] usbcore: registered new interface driver rt2800usb
[    1.981733] usbcore: registered new interface driver rndis_wlan
[    1.988366] pegasus: Pegasus/Pegasus II USB Ethernet driver
[    1.994647] usbcore: registered new interface driver pegasus
[    2.001064] usbcore: registered new interface driver rtl8150
[    2.007458] usbcore: registered new interface driver r8152
[    2.013631] usbcore: registered new interface driver asix
[    2.019727] usbcore: registered new interface driver ax88179_178a
[    2.026574] usbcore: registered new interface driver cdc_ether
[    2.033149] usbcore: registered new interface driver dm9601
[    2.039448] usbcore: registered new interface driver smsc75xx
[    2.045918] usbcore: registered new interface driver smsc95xx
[    2.052391] usbcore: registered new interface driver net1080
[    2.058771] usbcore: registered new interface driver rndis_host
[    2.065424] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[    2.073760] usbcore: registered new interface driver cdc_ncm
[    2.080151] usbcore: registered new interface driver cdc_mbim
[    2.087086] dwc2 ff540000.usb: supply vusb_d not found, using dummy regulator
[    2.095198] dwc2 ff540000.usb: supply vusb_a not found, using dummy regulator
[    2.167185] dwc2 ff540000.usb: DWC OTG Controller
[    2.172467] dwc2 ff540000.usb: new USB bus registered, assigned bus number 1
[    2.180404] dwc2 ff540000.usb: irq 49, io mem 0xff540000
[    2.186559] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.17
[    2.195828] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.203920] usb usb1: Product: DWC OTG Controller
[    2.209192] usb usb1: Manufacturer: Linux 5.17.6 dwc2_hsotg
[    2.215422] usb usb1: SerialNumber: ff540000.usb
[    2.221188] hub 1-0:1.0: USB hub found
[    2.225417] hub 1-0:1.0: 1 port detected
[    2.230534] dwc2 ff580000.usb: supply vusb_d not found, using dummy regulator
[    2.238673] dwc2 ff580000.usb: supply vusb_a not found, using dummy regulator
[    2.386979] dwc2 ff580000.usb: EPs: 10, dedicated fifos, 972 entries in SPRAM
[    2.395116] dwc2 ff580000.usb: DWC OTG Controller
[    2.400423] dwc2 ff580000.usb: new USB bus registered, assigned bus number 2
[    2.408345] dwc2 ff580000.usb: irq 50, io mem 0xff580000
[    2.414466] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.17
[    2.423733] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.431834] usb usb2: Product: DWC OTG Controller
[    2.437109] usb usb2: Manufacturer: Linux 5.17.6 dwc2_hsotg
[    2.443345] usb usb2: SerialNumber: ff580000.usb
[    2.449094] hub 2-0:1.0: USB hub found
[    2.453321] hub 2-0:1.0: 1 port detected
[    2.459501] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.466805] ehci-platform: EHCI generic platform driver
[    2.472985] usbcore: registered new interface driver cdc_acm
[    2.479341] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    2.488456] usbcore: registered new interface driver cdc_wdm
[    2.494862] usbcore: registered new interface driver usb-storage
[    2.501687] usbcore: registered new interface driver usbserial_generic
[    2.509037] usbserial: USB Serial support registered for generic
[    2.515797] usbcore: registered new interface driver cp210x
[    2.522067] usbserial: USB Serial support registered for cp210x
[    2.528753] usbcore: registered new interface driver ftdi_sio
[    2.535198] usbserial: USB Serial support registered for FTDI USB Serial Device
[    2.543482] usbcore: registered new interface driver keyspan
[    2.549847] usbserial: USB Serial support registered for Keyspan - (without firmware)
[    2.558639] usbserial: USB Serial support registered for Keyspan 1 port adapter
[    2.566830] usbserial: USB Serial support registered for Keyspan 2 port adapter
[    2.575044] usbserial: USB Serial support registered for Keyspan 4 port adapter
[    2.583274] usbcore: registered new interface driver option
[    2.589542] usbserial: USB Serial support registered for GSM modem (1-port)
[    2.596935] usb 1-1: new high-speed USB device number 2 using dwc2
[    2.597462] usbcore: registered new interface driver oti6858
[    2.610579] usbserial: USB Serial support registered for oti6858
[    2.617350] usbcore: registered new interface driver pl2303
[    2.623608] usbserial: USB Serial support registered for pl2303
[    2.630290] usbcore: registered new interface driver qcserial
[    2.636736] usbserial: USB Serial support registered for Qualcomm USB modem
[    2.644585] usbcore: registered new interface driver sierra
[    2.650854] usbserial: USB Serial support registered for Sierra USB modem
[    2.659122] usbcore: registered new interface driver iforce
[    2.665412] usbcore: registered new interface driver xpad
[    2.671563] usbcore: registered new interface driver usbtouchscreen
[    2.679069] i2c_dev: i2c /dev entries driver
[    2.686879] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
[    2.696965] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
[    2.708624] rtc-hym8563 0-0051: registered as rtc0
[    2.714294] rtc-hym8563 0-0051: setting system clock to 2017-01-01T13:50:09 UTC (1483278609)
[    2.737360] usbcore: registered new interface driver uvcvideo
[    2.745961] device-mapper: ioctl: 4.45.0-ioctl (2021-03-22) initialised: dm-devel@redhat.com
[    2.755828] Bluetooth: HCI UART driver ver 2.3
[    2.760823] Bluetooth: HCI UART protocol H4 registered
[    2.766568] Bluetooth: HCI UART protocol ATH3K registered
[    2.772681] usbcore: registered new interface driver bfusb
[    2.778883] usbcore: registered new interface driver btusb
[    2.788110] sdhci: Secure Digital Host Controller Interface driver
[    2.795023] sdhci: Copyright(c) Pierre Ossman
[    2.797787] random: fast init done
[    2.799903] Synopsys Designware Multimedia Card Interface Driver
[    2.810674] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.810927] dwmmc_rockchip ff0d0000.mmc: IDMAC supports 32-bit address mode.
[    2.824894] dwmmc_rockchip ff0d0000.mmc: Using internal DMA controller.
[    2.832296] dwmmc_rockchip ff0d0000.mmc: Version ID is 270a
[    2.838560] dwmmc_rockchip ff0d0000.mmc: DW MMC controller at irq 35,32 bit host data width,256 deep fifo
[    2.838814] hid: raw HID events driver (C) Jiri Kosina
[    2.849603] dwmmc_rockchip ff0d0000.mmc: Failed getting OCR mask: 0
[    2.857167] usb 1-1: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.00
[    2.862455] usbcore: registered new interface driver usbhid
[    2.862459] usbhid: USB HID core driver
[    2.862602] ashmem: initialized
[    2.864256] usbcore: registered new interface driver snd-usb-audio
[    2.865634] u32 classifier
[    2.865637]     input device check on
[    2.866085] IPVS: Registered protocols ()
[    2.866104] IPVS: Connection hash table configured (size=4096, memory=16Kbytes)
[    2.866194] IPVS: ipvs loaded.
[    2.866309] Initializing XFRM netlink socket
[    2.866567] NET: Registered PF_INET6 protocol family
[    2.871140] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    2.871577] Segment Routing with IPv6
[    2.871596] In-situ OAM (IOAM) with IPv6
[    2.871672] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    2.872015] NET: Registered PF_PACKET protocol family
[    2.872029] NET: Registered PF_KEY protocol family
[    2.872061] Bridge firewalling registered
[    2.872144] Bluetooth: RFCOMM socket layer initialized
[    2.872164] Bluetooth: RFCOMM ver 1.11
[    2.872173] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    2.872179] Bluetooth: HIDP socket layer initialized
[    2.872205] 8021q: 802.1Q VLAN Support v1.8
[    2.872220] lib80211: common routines for IEEE802.11 drivers
[    2.872249] Key type dns_resolver registered
[    2.872540] ThumbEE CPU extension supported.
[    2.872547] Registering SWP/SWPB emulation handler
[    2.872907] Loading compiled-in X.509 certificates
[    2.881656] usb 1-1: Product: USB 2.0 Hub [MTT]
[    2.915285] mmc_host mmc0: card is non-removable.
[    2.925673] dwmmc_rockchip ff0d0000.mmc: could not set regulator OCR (-22)
[    2.933665] hub 1-1:1.0: USB hub found
[    2.937661] dwmmc_rockchip ff0d0000.mmc: failed to enable vmmc regulator
[    2.939618] rockchip-drm display-subsystem: bound ff930000.vop (ops 0xc0d66830)
[    2.939882] rockchip-drm display-subsystem: bound ff940000.vop (ops 0xc0d66830)
[    2.939990] dwhdmi-rockchip ff980000.hdmi: Detected HDMI TX controller v2.01a with HDCP (DWC HDMI 2.0 TX PHY)
[    2.940460] rockchip-drm display-subsystem: bound ff980000.hdmi (ops 0xc0d69d7c)
[    2.940881] [drm] Initialized rockchip 1.0.0 20140818 for display-subsystem on minor 0
[    2.940943] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
[    2.941013] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes
[    2.941512] rk_gmac-dwmac ff290000.ethernet: IRQ eth_lpi not found
[    2.941576] rk_gmac-dwmac ff290000.ethernet: PTP uses main clock
[    2.941678] rk_gmac-dwmac ff290000.ethernet: clock input or output? (input).
[    2.941684] rk_gmac-dwmac ff290000.ethernet: TX delay(0x30).
[    2.941689] rk_gmac-dwmac ff290000.ethernet: RX delay(0x10).
[    2.941696] rk_gmac-dwmac ff290000.ethernet: integrated PHY? (no).
[    2.941724] rk_gmac-dwmac ff290000.ethernet: cannot get clock clk_mac_speed
[    2.941729] rk_gmac-dwmac ff290000.ethernet: clock input from PHY
[    2.942114] hub 1-1:1.0: 4 ports detected
[    2.946739] rk_gmac-dwmac ff290000.ethernet: init for RGMII
[    2.947004] rk_gmac-dwmac ff290000.ethernet: User ID: 0x10, Synopsys ID: 0x35
[    2.947013] rk_gmac-dwmac ff290000.ethernet:         DWMAC1000
[    2.947017] rk_gmac-dwmac ff290000.ethernet: DMA HW capability register supported
[    2.947021] rk_gmac-dwmac ff290000.ethernet: RX Checksum Offload Engine supported
[    2.947025] rk_gmac-dwmac ff290000.ethernet: COE Type 2
[    2.947029] rk_gmac-dwmac ff290000.ethernet: TX Checksum insertion supported
[    2.947033] rk_gmac-dwmac ff290000.ethernet: Wake-Up On Lan supported
[    2.947072] rk_gmac-dwmac ff290000.ethernet: Normal descriptors
[    2.947077] rk_gmac-dwmac ff290000.ethernet: Ring mode enabled
[    2.947080] rk_gmac-dwmac ff290000.ethernet: Enable RX Mitigation via HW Watchdog Timer
[    2.947089] rk_gmac-dwmac ff290000.ethernet: device MAC address d2:97:32:1b:d2:86
[    2.961756] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    3.294053] dwmmc_rockchip ff0d0000.mmc: could not set regulator OCR (-22)
[    3.301755] dwmmc_rockchip ff0d0000.mmc: failed to enable vmmc regulator
[    3.323184] mmc_host mmc0: Bus speed (slot 0) = 300000Hz (slot req 300000Hz, actual 300000HZ div = 0)
[    3.364631] dwmmc_rockchip ff0d0000.mmc: could not set regulator OCR (-22)
[    3.372356] dwmmc_rockchip ff0d0000.mmc: failed to enable vmmc regulator
[    3.393911] mmc_host mmc0: Bus speed (slot 0) = 200000Hz (slot req 200000Hz, actual 200000HZ div = 0)
[    3.442432] dwmmc_rockchip ff0d0000.mmc: could not set regulator OCR (-22)
[    3.450220] dwmmc_rockchip ff0d0000.mmc: failed to enable vmmc regulator
[    3.471384] mmc_host mmc0: Bus speed (slot 0) = 187500Hz (slot req 100000Hz, actual 93750HZ div = 1)
[    4.006743] mdio_bus stmmac-0:00: attached PHY driver [unbound] (mii_bus:phy_addr=stmmac-0:00, irq=POLL)
[    4.017538] mdio_bus stmmac-0:01: attached PHY driver [unbound] (mii_bus:phy_addr=stmmac-0:01, irq=POLL)
[    4.031317] input: adc-keys as /devices/platform/adc-keys/input/input0
[    4.040732] dwmmc_rockchip ff0c0000.mmc: IDMAC supports 32-bit address mode.
[    4.041009] dwmmc_rockchip ff0f0000.mmc: IDMAC supports 32-bit address mode.
[    4.048680] dwmmc_rockchip ff0c0000.mmc: Using internal DMA controller.
[    4.048698] dwmmc_rockchip ff0c0000.mmc: Version ID is 270a
[    4.056614] dwmmc_rockchip ff0f0000.mmc: Using internal DMA controller.
[    4.064066] dwmmc_rockchip ff0c0000.mmc: DW MMC controller at irq 34,32 bit host data width,256 deep fifo
[    4.070259] dwmmc_rockchip ff0f0000.mmc: Version ID is 270a
[    4.094764] dwmmc_rockchip ff0f0000.mmc: DW MMC controller at irq 36,32 bit host data width,256 deep fifo
[    4.106751] mmc_host mmc2: card is non-removable.
[    4.222095] input: gpio-keys as /devices/platform/gpio-keys/input/input1
[    4.230783] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    4.231852] mmc_host mmc2: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    4.231991] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    4.241569] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    4.267485] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[    4.269042] ALSA device list:
[    4.277301] cfg80211: failed to load regulatory.db
[    4.280683]   No soundcards found.
[    4.290192] dw-apb-uart ff690000.serial: forbid DMA for kernel console
[    4.298006] Waiting for root device /dev/mmcblk2p7...
[    4.335586] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 52000000Hz, actual 50000000HZ div = 0)
[    4.346745] mmc2: new high speed MMC card at address 0001
[    4.353340] mmcblk2: mmc2:0001 AJTD4R 14.6 GiB
[    4.362332]  mmcblk2: p1 p2 p3 p4 p5 p6 p7 p8
[    4.368604] mmcblk2boot0: mmc2:0001 AJTD4R 4.00 MiB
[    4.375351] mmcblk2boot1: mmc2:0001 AJTD4R 4.00 MiB
[    4.381984] mmcblk2rpmb: mmc2:0001 AJTD4R 4.00 MiB, chardev (246:0)
[    4.448820] List of all partitions:
[    4.452733] 0100            4096 ram0
[    4.452738]  (driver?)
[    4.459613] b300        15267840 mmcblk2
[    4.459622]  driver: mmcblk
[    4.467233]   b301            4096 mmcblk2p1 2d230000-0000-4e50-8000-07bf00004ea9
[    4.467239]
[    4.477274]   b302            4096 mmcblk2p2 2c170000-0000-4472-8000-6173000065f3
[    4.477280]
[    4.487316]   b303            4096 mmcblk2p3 4b650000-0000-487c-8000-2fb100007d14
[    4.487322]
[    4.497353]   b304           32768 mmcblk2p4 b4590000-0000-4111-8000-70a100007eb5
[    4.497358]
[    4.507389]   b305           32768 mmcblk2p5 8c520000-0000-4728-8000-3a6c0000247d
[    4.507394]
[    4.517426]   b306           32768 mmcblk2p6 fe460000-0000-440c-8000-363a00007e15
[    4.517431]
[    4.527463]   b307         2094080 mmcblk2p7 614e0000-0000-4b53-8000-1d28000054a9
[    4.527468]
[    4.537499]   b308        12989423 mmcblk2p8 4a510000-0000-4d08-8000-507d00003353
[    4.537503]
[    4.547540] b310            4096 mmcblk2boot0
[    4.547545]  (driver?)
[    4.555139] b320            4096 mmcblk2boot1
[    4.555144]  (driver?)
[    4.562748] No filesystem could mount root, tried:
[    4.562751]  ext3
[    4.568213]  ext2
[    4.570351]  ext4
[    4.572500]  squashfs
[    4.574644]  vfat
[    4.577191]  iso9660
[    4.579336]  hfsplus
[    4.581776]  fuseblk
[    4.584213]  udf
[    4.586649]
[    4.590357] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,7)
[    4.599786] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.17.6 #2
[    4.606399] Hardware name: Rockchip (Device Tree)
[    4.611650] Backtrace:
[    4.614379]  dump_backtrace from show_stack+0x20/0x24
[    4.620034]  r7:c0f19d84 r6:00000000 r5:60000093 r4:c0fd2ed8
[    4.626352]  show_stack from dump_stack_lvl+0x48/0x54
[    4.631997]  dump_stack_lvl from dump_stack+0x14/0x1c
[    4.637641]  r5:00000000 r4:c13d4498
[    4.641628]  dump_stack from panic+0xf8/0x300
[    4.646495]  panic from mount_block_root+0x188/0x210
[    4.652045]  r3:00000000 r2:00000000 r1:c1969ea4 r0:c0f19d84
[    4.658364]  r7:c0f256e0
[    4.661185]  mount_block_root from mount_root+0x80/0x1a0
[    4.667123]  r10:000001b7 r9:c113e864 r8:c106aa18 r7:c13d4000 r6:c113e844 r5:c113e874
[    4.675869]  r4:00000007
[    4.678691]  mount_root from prepare_namespace+0x154/0x190
[    4.684822]  r10:000001b7 r9:c113e864 r8:c106aa18 r7:c13d4000 r6:c113e844 r5:c113e874
[    4.693569]  r4:c13d4028
[    4.696390]  prepare_namespace from kernel_init_freeable+0x200/0x260
[    4.703491]  r5:00000008 r4:c120fcd4
[    4.707478]  kernel_init_freeable from kernel_init+0x24/0x140
[    4.713903]  r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c0c73848
[    4.722649]  r4:c120af40
[    4.725470]  kernel_init from ret_from_fork+0x14/0x2c
[    4.731115] Exception stack(0xc1969fb0 to 0xc1969ff8)
[    4.736747] 9fa0:                                     00000000 00000000 00000000 00000000
[    4.745885] 9fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    4.755021] 9fe0: 00000000 00000000 00000000 00000000 00000013 00000000
[    4.762399]  r5:c0c73848 r4:00000000
[    4.766388] CPU3: stopping
[    4.769408] CPU: 3 PID: 0 Comm: swapper/3 Not tainted 5.17.6 #2
[    4.776021] Hardware name: Rockchip (Device Tree)
[    4.781271] Backtrace:
[    4.783998]  dump_backtrace from show_stack+0x20/0x24
[    4.789647]  r7:c120b7d4 r6:c19e9ec0 r5:60000193 r4:c0fd2ed8
[    4.795965]  show_stack from dump_stack_lvl+0x48/0x54
[    4.801610]  dump_stack_lvl from dump_stack+0x14/0x1c
[    4.807254]  r5:00000003 r4:00000004
[    4.811240]  dump_stack from do_handle_IPI+0x1ac/0x258
[    4.816981]  do_handle_IPI from ipi_handler+0x24/0x30
[    4.822627]  r7:c120b7d4 r6:00000014 r5:c1804c80 r4:c18eb200
[    4.828945]  ipi_handler from handle_percpu_devid_irq+0x68/0x10c
[    4.835659]  handle_percpu_devid_irq from handle_irq_desc+0x2c/0x3c
[    4.842666]  r9:c19e9ec0 r8:c119ba70 r7:c1987f54 r6:f0802000 r5:00000004 r4:c18f0000
[    4.851315]  handle_irq_desc from generic_handle_domain_irq+0x68/0x74
[    4.858511]  generic_handle_domain_irq from gic_handle_irq+0x74/0x84
[    4.865612]  r5:c119b454 r4:c120b7d4
[    4.869598]  gic_handle_irq from generic_handle_arch_irq+0x30/0x44
[    4.876506]  r7:c1987f54 r6:ffffffff r5:00000000 r4:c1987f20
[    4.882816]  generic_handle_arch_irq from __irq_svc+0x50/0x68
[    4.889235] Exception stack(0xc1987f20 to 0xc1987f68)
[    4.894870] 7f20: 00000742 00000003 00000003 c0118be0 c19e9ec0 00000000 c120af90 00000008
[    4.904007] 7f40: c119ba70 410fc0d1 00000000 c1987f7c c1987f80 c1987f70 c01076f0 c01076e0
[    4.913143] 7f60: 60000013 ffffffff
[    4.917025]  r5:60000013 r4:c01076e0
[    4.921012]  arch_cpu_idle from default_idle_call+0x40/0x5c
[    4.927242]  default_idle_call from do_idle+0x128/0x2a0
[    4.933081]  r5:00000000 r4:00000000
[    4.937068]  do_idle from cpu_startup_entry+0x28/0x2c
[    4.942713]  r9:410fc0d1 r8:0000406a r7:c13d4344 r6:10c0387d r5:00000003 r4:00000097
[    4.951361]  cpu_startup_entry from secondary_start_kernel+0xf4/0x110
[    4.958557]  secondary_start_kernel from 0x1016d4
[    4.963813]  r5:00000051 r4:019ac06a
[    4.967800] CPU2: stopping
[    4.970819] CPU: 2 PID: 0 Comm: swapper/2 Not tainted 5.17.6 #2
[    4.977432] Hardware name: Rockchip (Device Tree)
[    4.982682] Backtrace:
[    4.985409]  dump_backtrace from show_stack+0x20/0x24
[    4.991058]  r7:c120b7d4 r6:c19e9480 r5:60000193 r4:c0fd2ed8
[    4.997376]  show_stack from dump_stack_lvl+0x48/0x54
[    5.003021]  dump_stack_lvl from dump_stack+0x14/0x1c
[    5.008665]  r5:00000002 r4:00000004
[    5.012652]  dump_stack from do_handle_IPI+0x1ac/0x258
[    5.018393]  do_handle_IPI from ipi_handler+0x24/0x30
[    5.024038]  r7:c120b7d4 r6:00000014 r5:c1804c80 r4:c18eb200
[    5.030356]  ipi_handler from handle_percpu_devid_irq+0x68/0x10c
[    5.037069]  handle_percpu_devid_irq from handle_irq_desc+0x2c/0x3c
[    5.044075]  r9:c19e9480 r8:c119ba70 r7:c1985f54 r6:f0802000 r5:00000004 r4:c18f0000
[    5.052724]  handle_irq_desc from generic_handle_domain_irq+0x68/0x74
[    5.059921]  generic_handle_domain_irq from gic_handle_irq+0x74/0x84
[    5.067022]  r5:c119b454 r4:c120b7d4
[    5.071009]  gic_handle_irq from generic_handle_arch_irq+0x30/0x44
[    5.077917]  r7:c1985f54 r6:ffffffff r5:00000000 r4:c1985f20
[    5.084235]  generic_handle_arch_irq from __irq_svc+0x50/0x68
[    5.090655] Exception stack(0xc1985f20 to 0xc1985f68)
[    5.096288] 5f20: 000008b2 00000002 00000002 c0118be0 c19e9480 00000000 c120af90 00000004
[    5.105425] 5f40: c119ba70 410fc0d1 00000000 c1985f7c c1985f80 c1985f70 c01076f0 c01076e0
[    5.114560] 5f60: 60000013 ffffffff
[    5.118451]  r5:60000013 r4:c01076e0
[    5.122437]  arch_cpu_idle from default_idle_call+0x40/0x5c
[    5.128665]  default_idle_call from do_idle+0x128/0x2a0
[    5.134504]  r5:00000000 r4:00000000
[    5.138491]  do_idle from cpu_startup_entry+0x28/0x2c
[    5.144136]  r9:410fc0d1 r8:0000406a r7:c13d4344 r6:10c0387d r5:00000002 r4:00000097
[    5.152785]  cpu_startup_entry from secondary_start_kernel+0xf4/0x110
[    5.159981]  secondary_start_kernel from 0x1016d4
[    5.165236]  r5:00000051 r4:019ac06a
[    5.169214] CPU1: stopping
[    5.172234] CPU: 1 PID: 0 Comm: swapper/1 Not tainted 5.17.6 #2
[    5.178847] Hardware name: Rockchip (Device Tree)
[    5.184098] Backtrace:
[    5.186825]  dump_backtrace from show_stack+0x20/0x24
[    5.192474]  r7:c120b7d4 r6:c19e8a40 r5:60000193 r4:c0fd2ed8
[    5.198791]  show_stack from dump_stack_lvl+0x48/0x54
[    5.204436]  dump_stack_lvl from dump_stack+0x14/0x1c
[    5.210080]  r5:00000001 r4:00000004
[    5.214058]  dump_stack from do_handle_IPI+0x1ac/0x258
[    5.219799]  do_handle_IPI from ipi_handler+0x24/0x30
[    5.225445]  r7:c120b7d4 r6:00000014 r5:c1804c80 r4:c18eb200
[    5.231762]  ipi_handler from handle_percpu_devid_irq+0x68/0x10c
[    5.238475]  handle_percpu_devid_irq from handle_irq_desc+0x2c/0x3c
[    5.245481]  r9:c19e8a40 r8:c119ba70 r7:c1983f54 r6:f0802000 r5:00000004 r4:c18f0000
[    5.254129]  handle_irq_desc from generic_handle_domain_irq+0x68/0x74
[    5.261326]  generic_handle_domain_irq from gic_handle_irq+0x74/0x84
[    5.268427]  r5:c119b454 r4:c120b7d4
[    5.272414]  gic_handle_irq from generic_handle_arch_irq+0x30/0x44
[    5.279321]  r7:c1983f54 r6:ffffffff r5:00000000 r4:c1983f20
[    5.285630]  generic_handle_arch_irq from __irq_svc+0x50/0x68
[    5.292050] Exception stack(0xc1983f20 to 0xc1983f68)
[    5.297684] 3f20: 000007b0 00000001 00000001 c0118be0 c19e8a40 00000000 c120af90 00000002
[    5.306821] 3f40: c119ba70 410fc0d1 00000000 c1983f7c c1983f80 c1983f70 c01076f0 c01076e0
[    5.315957] 3f60: 60000013 ffffffff
[    5.319848]  r5:60000013 r4:c01076e0
[    5.323835]  arch_cpu_idle from default_idle_call+0x40/0x5c
[    5.330063]  default_idle_call from do_idle+0x128/0x2a0
[    5.335901]  r5:00000000 r4:00000000
[    5.339888]  do_idle from cpu_startup_entry+0x28/0x2c
[    5.345532]  r9:410fc0d1 r8:0000406a r7:c13d4344 r6:10c0387d r5:00000001 r4:00000097
[    5.354182]  cpu_startup_entry from secondary_start_kernel+0xf4/0x110
[    5.361378]  secondary_start_kernel from 0x1016d4
[    5.366632]  r5:00000051 r4:019ac06a
[    5.370625] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,7) ]---
Regards!
Posted at 1/24/2026 21:21:37        Only Author  2#
Im so grateful for your article, it was truly eye-catching and insightful. Free Popular FCP_FML_AD-7.4 Exams to help you enhance your IT skills. Wishing you good luck!
