Fortinet FCP_FMG_AD-7.6 Reliable Test Guide - FCP_FMG_AD-7.6 Valid Guide Files
93
Posted at 2/12/2026 13:14:01      View126 | Replies0        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of Free4Torrent FCP_FMG_AD-7.6 dumps for free: https://drive.google.com/open?id=1iQPsrCt-_RdulSXotn7Y9U53bSrFa34j
With our Fortinet FCP_FMG_AD-7.6 study matetials, you can make full use of those time originally spent in waiting for the delivery of exam files so that you can get preparations as early as possible. There is why our Fortinet FCP_FMG_AD-7.6 learning prep exam is well received by the general public.
Fortinet FCP_FMG_AD-7.6 Exam Syllabus Topics:
  • Policy and Objects: This section of the exam measures the skills of System Administrators and evaluates their ability to manage policies and objects within FortiManager. It involves ADOM revisions, workspace mode, and policy imports and installations, emphasizing consistent policy control across networks.
  • Troubleshooting
  • This section of the exam measures the skills of System Administrators and focuses on resolving problems at different levels of FortiManager. Candidates must troubleshoot deployment scenarios, imports, installations, and both device-level and ADOM-level issues, as well as identify and resolve system problems effectively.
Topic 5
  • Administration: This section of the exam measures the skills of System Administrators and covers the essential features of FortiManager. It includes the initial configuration process and the setup of administrative domains (ADOMs), ensuring smooth system management.
FCP_FMG_AD-7.6 Valid Guide Files, FCP_FMG_AD-7.6 Interactive CourseThe objective of the Free4Torrent is to help FCP_FMG_AD-7.6 exam applicants crack the test. It follows its goal by giving a completely free demo of Real FCP_FMG_AD-7.6 Exam Questions. The free demo will enable users to assess the characteristics of the FCP - FortiManager 7.6 Administrator exam product.
Fortinet FCP - FortiManager 7.6 Administrator Sample Questions (Q70-Q75):NEW QUESTION # 70
An administrator assigned a new policy package to FortiGate HQ-NGFW-1. In the installation preview, they noticed some settings they did not modify and are unsure about the changes.
Based on the exhibit, which two things will happen if they continue with the installation? (Choose two.)
  • A. FortiGate HQ-NGFW-1 can contact the FortiManager acting as FortiGuard Distribution Server (FDS) to download FortiGuard updates.
  • B. FortiManager will install the CA certificate named root_CA3 to authenticate FortiGate-to-FortiManager communication protocol (FGFM) tunnel connections with FortiGate HQ- NGFW-1.
  • C. FortiGate HQ-NGFW-1 will use the root_CA3 certificate in firewall address objects or policies.
  • D. FortiGate HQ-NGFW-1 can use FortiManager firmware templates to upgrade firmware and ratings.
The configuration includes a server-list with server-type set to "update rating," which enables FortiGate HQ- NGFW-1 to contact FortiManager as a FortiGuard Distribution Server (FDS) for FortiGuard updates.
The installation includes a root_CA3 certificate, which FortiManager will install on FortiGate HQ-NGFW-1 to authenticate FGFM tunnel connections between the devices.
NEW QUESTION # 71
An administrator has created a firewall address object that is used in multiple policy packages for multiple FortiGate devices in an ADOM.
After the installation operation is performed, which IP/netmask will be installed on Remote-Firewall
[VDOM1] for the LAN firewall address object?
  • A. 21.21.2.5/255.255.255.255
  • B. 172.16.5.0/255.255.255.0
  • C. 10.10.10.5/255.255.255.255
  • D. 172.16.5.20/255.255.255.255
The per-device mapping overrides the global IP/netmask setting for the firewall address object. For the device
"Remote-Firewall," the mapped IP/netmask is 21.21.2.5/255.255.255.255, so this value will be installed on Remote-Firewall [VDOM1].
NEW QUESTION # 72
Refer to the exhibit. An administrator has created a firewall address object that is used in multiple policy packages for multiple FortiGate devices in an ADOM.
After the installation operation is performed, which IP/netmask will be installed on Remote- Firewall [VDOM1] for the LAN firewall address object?
For the device "Remote-Firewall," the mapped IP/netmask is 21.21.2.5/255.255.255.255, so this value will be installed on Remote-Firewall [VDOM1].
NEW QUESTION # 73
An administrator is copying a system template profile between ADOMs by running the following command:
execute fmprofile export-profile ADOM 3547 /tmp/Backup_File
output dump to file: [/tmp/Backup_File]
Where does this command export the system template profile from?
  • A. ADOM device database
  • B. FortiManager /tmp/Backup_File folder
  • C. FortiManager ADOM policy database
  • D. FortiManager configuration backup file
The command exports the system template profile from the FortiManager ADOM policy database, which stores the configuration templates for devices within that ADOM.
NEW QUESTION # 74
A FortiManager administrator has moved a FortiGate device to a new ADOM, but they cannot see the policy or object configurations for that FortiGate.
What should the administrator do to see the policy or object configurations?
  • A. Import the policy package manually using the Import Configuration wizard.
  • B. Use ADOM shared objects to restore all missing data.
  • C. Use ADOM sync to restore the missing configurations.
  • D. Reset the device and add it to the new ADOM again.
When a FortiGate device is moved from its original ADOM (Source ADOM) to a new ADOM (Target ADOM), only the Device Database (the device's running configuration) moves with it.
The Policy Package and the Policy/Object configurations are not automatically transferred because they are considered part of the Source ADOM's specific policy logic.
NEW QUESTION # 75
Both practice exams (web-based & desktop) give a Fortinet FCP_FMG_AD-7.6 real exam feeling and identify your mistakes so you can overcome your weaknesses before the FCP_FMG_AD-7.6 final test. The desktop Fortinet FCP_FMG_AD-7.6 Practice Test software works on Windows after software installation. You can take the web-based FCP - FortiManager 7.6 Administrator FCP_FMG_AD-7.6 practice exam via any operating system.
FCP_FMG_AD-7.6 Valid Guide Files: https://www.free4torrent.com/FCP_FMG_AD-7.6-braindumps-torrent.html
2026 Latest Free4Torrent FCP_FMG_AD-7.6 PDF Dumps and FCP_FMG_AD-7.6 Exam Engine Free Share: https://drive.google.com/open?id=1iQPsrCt-_RdulSXotn7Y9U53bSrFa34j
