[Linux] What are the correct steps to compile a ubuntu with buildroot for RK3566-PC.
67
Linux What are the correct steps to compile a ubuntu with buildroot for RK3566-PC.
Posted at 4/10/2023 19:46:10      View4888 | Replies7        Print      Only Author   [Copy Link] 1#
  • SDK Package Name: ROC-RK3566-PC_Rk356x_v1.3.2b_230407
  • Modification Content: none
  • Log: test.zip
Hi,
I want to compile an ubuntu-18.04 with buildroot for ROC-RK3566-PC
but I couldn't find a correct steps for build.
I am following to the steps in documentations which are following line.
1. https://wiki.t-firefly.com/en/RO ... d-firefly-linux-sdk
2. https://wiki.t-firefly.com/en/Fi ... nual_buildroot.html
If follow the only first documentation, I can combine img but the custom builded img doesn't apply my changes.
If I apply the steps of second documentation after make sync the repo with steps of first documentation,
I am getting this error "cp: cannot stat 'kernel/.config': No such file or directory error".
I runned the command for custom build
-  sudo apt update
- sudo apt install -y repo git python
- mkdir ~/proj/rk356x_linux_release_v1.3.0b_20221213/
- cd ~/proj/rk356x_linux_release_v1.3.0b_20221213/
- repo init --no-clone-bundle --repo-url https://gitlab.com/firefly-linux/git-repo.git -u https://gitlab.com/firefly-linux/manifests.git -b master -m rk356x_linux_release.xml
- .repo/repo/repo sync -c --no-tags
- .repo/repo/repo start firefly --all
- sudo apt-get install repo git ssh make gcc libssl-dev liblz4-tool expect g++ patchelf chrpath gawk texinfo chrpath diffstat binfmt-support qemu-user-static live-build bison flex fakeroot cmake unzip device-tree-compiler python-pip ncurses-dev python-pyelftools
- ./build.sh roc-rk3566-pc-ubuntu.mk
- Download: Ubuntu rootfs(64-bit)put in SDK path Unzip
- copy image file to ~/proj/rk356x_linux_release_v1.3.0b_20221213/ubuntu_rootfs
- source envsetup.sh rockchip_rk3568
- make menuconfig
- # I changed to the system hostname and banner and I saved
- make savedefconfig
- make clean all
After that, I got an error that looking like following line.
Executing post-build.sh...
Top of tree: /home/melih/proj/rk356x_linux_release_v1.3.0b_20221213/device/rockchip/common/../../..
Adding information to /etc/os-release...
Makefile:707: recipe for target 'target-finalize' failed
make[1]: *** [target-finalize] Error 1
/home/melih/proj/rk356x_linux_release_v1.3.0b_20221213/buildroot/output/rockchip_rk3566/Makefile:16: recipe for target '_all' failed
make: *** [_all] Error 2
Can you explain how to compile the ubuntu 18.04 for my rk3566
I want to do dts modification and apply some changes on kernel
test.zip
436 Bytes, Down times: 0
Posted at 4/10/2023 19:53:22        Only Author  2#
I misspelled this line in the post
Normally I runned it like this
- source envsetup.sh rockchip_rk3566
I cannot edit the post
Posted at 4/11/2023 10:21:56        Only Author  3#
You can't compile a ubuntu with buildroot, it just for Buildroot system.
If you want to compile the Ubuntu system, please refer to the following:
https://wiki.t-firefly.com/en/RO ... ile-ubuntu-firmware
Posted at 4/11/2023 15:39:22        Only Author  4#
ʱĺ Posted at 4/11/2023 10:21
If you want to compile t ...
Hi,
Thanks for your answer
I applied this documentation and I created the image finally.
However I couldn't find how to change settings of kernel (for example menuconfig, kernel-menuconfig).
When I run the command "make menuconfig" in "buildroot" directory, I can change the settings (hostname, banner etc.) but the changes couldn't be apply on new image
How can I change menuconfig and kernel settings
Posted at 4/14/2023 10:27:59        Only Author  5#
myarikkaya Posted at 4/11/2023 15:39
Hi,
kernel:
https://wiki.t-firefly.com/en/RO ... l_introduction.html
buildroot system: `source envsetup.sh rockchip_rk3566`
https://wiki.t-firefly.com/en/Fi ... ildroot-development
Posted at 1/15/2026 01:27:41        Only Author  6#
It truly opened my eyes to a new world of ideas. Free F3 new real test resourcesyour key to career advancement and salary growth!
Posted at 1/25/2026 15:17:32        Only Author  7#
This article is very well written and worth studying. Best wishes to everyone! C-THR84-2505 new exam cram materials test questions are now available for free.
Posted at 2/14/2026 15:34:28        Only Author  8#
Thank you for sharing; it was truly incredible! The Latest examcollection NS0-528 helped me secure my promotion and raise. Its free now for everyone. Best of luck with your career!
