1z0-1104-25 Real Question & 1z0-1104-25 Real Questions
Posted at 2/11/2026 11:54:37
View140
Replies2
P.S. Free & New 1z0-1104-25 dumps are available on Google Drive shared by Actualtests4sure: https://drive.google.com/open?id=1XH8Vyz4mtae_QyvN2PpBZpRsT0UYoj9_
No matter you are exam candidates of high caliber or newbies, our Oracle 1z0-1104-25 exam quiz will be your propulsion to gain the best results with least time and reasonable money. Not only because the outstanding content of Oracle 1z0-1104-25 Real Dumps that produced by our professional expert but also for the reason that we have excellent vocational moral to improve our Oracle 1z0-1104-25 learning materials quality.
Reliable Oracle Cloud Infrastructure 2025 Security Professional 1z0-1104-25 Dumps Questions and dumps ebook make your career more successful. Oracle provides updated, free reliable Oracle Cloud Infrastructure 2025 Security Professional dumps free download. And the Oracle Cloud Infrastructure 2025 Security Professional Oracle Cloud Infrastructure 2025 Security Professionalprice is affordable.With 365 days updatrs. It works with all operating systems like Linux, Windows, Android, Mac, and IOS, etc.
1z0-1104-25 Real Questions - Reliable 1z0-1104-25 Exam SimulationsOur products passing rate is 99% which means that you almost can pass the test with no doubts. The reasons why our 1z0-1104-25 study materials passing rate is so high are varied. Firstly, our test bank includes two forms and they are the PDF test questions which are selected by the senior lecturer, published authors and professional experts and the practice test software which can test your mastery degree of our 1z0-1104-25 Study Materials at any time. The two forms cover the syllabus of the entire test. Our questions and answers include all the questions which may appear in the exam and all the approaches to answer the questions. So we provide the strong backing to help clients to help them pass the test.
Oracle 1z0-1104-25 Exam Syllabus Topics:| Topic | Details | | Topic 1 | - Implementing OS and Workload Protection: This section of the exam measures the skills of OCI Administrators and looks at securing workloads and operating systems. It includes the use of OCI Bastion for time-limited access, vulnerability scanning of hosts and containers, and the use of OS management for automated updates. The goal is to ensure that workloads remain resilient and well-protected.
| | Topic 2 | - Detecting, Remediating, and Monitoring OCI Resources: This section of the exam measures the skills of OCI Administrators and emphasizes monitoring and maintaining security posture across cloud resources. It focuses on the use of Cloud Guard, security zones, and the Security Advisor. Candidates also need to understand how to identify rogue users with threat intelligence, as well as use monitoring, logging, and event services for continuous visibility into performance and security.
| | Topic 3 | - Protecting Data: This section of the exam measures the skills of Cloud Security Professionals and highlights data security practices in OCI. It tests knowledge of using the Key Management Service for encryption keys, managing secrets in the OCI Vault, and applying features of OCI Data Safe to ensure sensitive data remains protected.
| | Topic 4 | - OCI Security Introduction: This section of the exam measures the skills of Cloud Security Professionals and covers the basics of security in Oracle Cloud Infrastructure. It introduces the shared security responsibility model, the core principles of security design, and the use of foundational security services to secure deployments on OCI.
Oracle Cloud Infrastructure 2025 Security Professional Sample Questions (Q27-Q32):NEW QUESTION # 27
Task 6: Create Load Balancer and Attach Certificate
Create a Load Balancer with the name PBT-CERT-LB-01 in subnet LB-Subnet-PBT-CERT-SNET-02 Create a Listener for the load balancer, where:
Protocol: HTTPS
Port: 443
Attach the certificate PBT-CERT-01-<username> to the load balancer
Attach the security list PBT-CERT-LB-SL-01 to subnet LB-Subnet-PBT-CERT-SNET-02 See the solution below in Explanation.
Step 1: Create the Load Balancer
* Log in to the OCI Console.
* Navigate toNetworking>Load Balancers.
* ClickCreate Load Balancer.
* Enter the following details:
* Name: PBT-CERT-LB-01
* Compartment: Select your assigned compartment.
* Load Balancer Type: SelectPublic.
* Virtual Cloud Network: Select PBT-CERT-VCN-01.
* Subnet: Select LB-Subnet-PBT-CERT-SNET-02.
* Shape: Choose a shape (e.g., 10 Mbps, adjust based on needs).
* ClickNext.
* Leave backend sets and listeners as default for now (we'll configure the listener next).
* ClickCreate Load Balancerand wait for it to be provisioned.
Step 2: Create a Listener
* Once the load balancer is created, go to theLoad Balancerspage and click on PBT-CERT-LB-01.
* UnderResources, clickListeners.
* ClickCreate Listener.
* Name: PBT-CERT-LB_LTSN_01
* Protocol: SelectHTTPS.
* Port: Enter 443.
* Certificate: ClickAdd Certificate, then select the PBT-CERT-01<username> certificate (e.g., PBT-CERT-0199008677labuser01) created in Task 5.
* Leave other settings (e.g., SSL handling) as default unless specified.
* ClickCreate.
Step 3: Configure the Backend Set
* In the PBT-CERT-LB-01 details page, underResources, clickBackend Sets.
* ClickCreate Backend Set(if not already created).
* Enter basic details (e.g., name like PBT-CERT-BS-01).
* Add a backend server:
* IP Address: Use the private IP of PBT-CERT-VM-01 (find this in the instance details under Compute>Instances).
* Port: 80 (HTTP, as configured on the web server).
* Protocol: HTTP.
* ClickCreate.
Step 4: Attach the Security List to the Subnet
* Navigate toNetworking>Virtual Cloud Networks.
* Select PBT-CERT-VCN-01 and clickSubnets.
* Click on LB-Subnet-PBT-CERT-SNET-02.
* UnderSecurity Lists, ensure PBT-CERT-LB-SL-01 is attached. If not:
* ClickEdit.
* Remove the default security list and add PBT-CERT-LB-SL-01.
* ClickSave Changes.
Step 5: Verify the Configuration
* Ensure the load balancer health status is OK (check underBackend Sets>Health).
* Test by accessing https://<load-balancer-public-ip> in a browser (replace with the public IP from the load balancer details).
NEW QUESTION # 28
An OCI administrator notices that a compute instance running in the production compartment is unable to create Object Storage buckets using the OCI CLI command:
oci os bucket create --name mybucket --compartment-id <compartment_OCID> --auth instance_principal The error message returned states:
"NotAuthorizedOrNotFound: You are not authorized to perform this action." The administrator verifies that the instance has Internet access and can reach OCI endpoints.
What then could be causing the issue?
- A. The policy is written at the root compartment instead of the production compartment.
- B. The instance is not part of any Dynamic Group or the matching rule is incorrect.
- C. The instance is using the wrong OCI CLI authentication method.
- D. The bucket name is already in use, causing a conflict.
NEW QUESTION # 29
Challenge 2 -Task 1
In deploying a new application, a cloud customer needs to reflect different security postures. If a security zone is enabled with the Maximum Security Zone recipe, the customer will be unable to create or update a resource in the security zone if the action violates the attached Maximum Security Zone policy.
As an application requirement, the customer requires a compute instance in the public subnet. You therefore, need to configure Custom Security Zones that allow the creation of compute instances in the public subnet.
Review the architecture diagram, which outlines the resoures you'll need to address the requirement:
Preconfigured
To complete this requirement, you are provided with the following:
Access to an OCI tenancy, an assigned compartment, and OCI credentials
Required IAM policies
Task3: Create and configure a Virtual Cloud Network and Private Subnet
Createand configure virtual cloud Network (VCN) named IAD SP-PBT-VCN-01, with an internet Gateway and configure appropriate route rules to allow external connectivity.
Enter the OCID of the created VCN in the text box below.
To create and configure a Virtual Cloud Network (VCN) named IAD-SP-PBT-VCN-01 with an Internet Gateway and appropriate route rules for external connectivity, follow these steps based on the Oracle Cloud Infrastructure (OCI) Networking documentation.
Step-by-Step Solution for Task 3: Create and Configure a VCN and Private Subnet
* Log in to the OCI Console:
* Use your OCI credentials to log in to the OCI Console (https://console.us-ashburn-1.oraclecloud.
com).
* Ensure you have access to the assigned compartment.
* Navigate to Virtual Cloud Networks:
* From the OCI Console, click the navigation menu (hamburger icon) on the top left.
* UnderNetworking, selectVirtual Cloud Networks.
* Create a New VCN:
* ClickStart VCN Wizardand selectCreate VCN with Internet Connectivity.
* VCN Name:Enter IAD-SP-PBT-VCN-01.
* Compartment:Select the assigned compartment.
* VCN CIDR Block:Enter 10.0.0.0/16 (matches the diagram's VCN CIDR).
* Public Subnet CIDR Block:Enter 10.0.10.0/24 (matches the diagram's public subnet).
* Accept the default settingsfor the public subnet and Internet Gateway creation.
* ClickCreateto provision the VCN, Internet Gateway, and public subnet.
* Verify the Internet Gateway:
* After creation, go to the VCN details page for IAD-SP-PBT-VCN-01.
* UnderResources, selectInternet Gateways.
* Ensure the Internet Gateway is attached and enabled.
* Configure Route Rules:
* In the VCN details page, underResources, selectRoute Tables.
* Select the default route table associated with the public subnet (10.0.10.0/24).
* ClickAdd Route Rules.
* Target Type:SelectInternet Gateway.
* Destination CIDR Block:Enter 0.0.0.0/0.
* Target Internet Gateway:Select the Internet Gateway created with the VCN.
* ClickAdd Route Ruleto save.
* Update Security List (if needed):
* UnderResources, selectSecurity Lists.
* Edit the default security list for the public subnet.
* Add an ingress rule:
* Source CIDR:0.0.0.0/0
* IP Protocol:TCP
* Source Port Range:All
* Destination Port Range:22 (for SSH) or as required by your application.
* Add an egress rule:
* Destination CIDR:0.0.0.0/0
* IP Protocol:All
* Save the changes.
* Note the VCN OCID:
* Return to the VCN details page for IAD-SP-PBT-VCN-01.
* Copy theOCIDdisplayed (e.g., ocid1.vcn.oc1..<unique_string>).
OCID of the Created VCN
* Enter the OCID of the created VCN (IAD-SP-PBT-VCN-01) into the text box. The exact OCID will be available after Step 3 (e.g., ocid1.vcn.oc1..<unique_string>).
NEW QUESTION # 30
You have created a compartment TEST in your subscribed tenancy. Then, you created two groups, test1 and test2, and want the users in these groups to be able to manage all the resources in the TEST compartment.
Which policy would you use to achieve this?
- A. Allow group/test*/to manage all resources in compartment test.
- B. Allow group test1, test2 to manage all resources in compartment test.
- C. Allow any-user to manage all resources in compartment test where request.group='test*'
- D. Allow any-user to manage all resources in compartment test where any {request.groups.test1, test2}
NEW QUESTION # 31
"A business has a hybrid cloud infrastructure with Oracle Linux instances running in OCI and on-premises.
They want to reduce the amount of bandwidth used when patching systems.
Which component of OS Management Hub can help to reduce the bandwidth usage for patching?
- A. Management stations
- B. Profiles"
- C. Dynamic groups
- D. Management agents
NEW QUESTION # 32
Some practice materials keep droning on the useless points of knowledge. In contrast, being venerated for high quality and accuracy rate, our 1z0-1104-25 training quiz received high reputation for their efficiency and accuracy rate originating from your interests, and the whole review process may cushier than you have imagined before. Numerous of our loyal customers wrote to us to praise that the 1z0-1104-25 Exam Questions are the same with the real exam questions and they passed 1z0-1104-25 exam with ease.
1z0-1104-25 Real Questions: https://www.actualtests4sure.com/1z0-1104-25-test-questions.html
- 1z0-1104-25 Valid Exam Blueprint ⏹ 1z0-1104-25 Exam Testking 🏨 Online 1z0-1104-25 Test 🚤 Search for 1z0-1104-25 and download it for free immediately on [url]www.exam4labs.com 💃Test 1z0-1104-25 Answers[/url]
- Free PDF Oracle - 1z0-1104-25 - Oracle Cloud Infrastructure 2025 Security Professional Pass-Sure Real Question 🕧 Download ➤ 1z0-1104-25 ⮘ for free by simply entering [url]www.pdfvce.com website 👟Online 1z0-1104-25 Test[/url]
- Reliable Oracle - 1z0-1104-25 Real Question 🛫 Search for ⮆ 1z0-1104-25 ⮄ on [url]www.examdiscuss.com immediately to obtain a free download 🧂New Exam 1z0-1104-25 Materials[/url]
- 1z0-1104-25 Reliable Dumps Ebook 🚤 New Soft 1z0-1104-25 Simulations 🥄 1z0-1104-25 Valid Exam Blueprint 🅾 Search for ⏩ 1z0-1104-25 ⏪ and obtain a free download on [url]www.pdfvce.com 🍯New Exam 1z0-1104-25 Materials[/url]
- 1z0-1104-25 Real Exams 🤥 1z0-1104-25 Exam Testking 🅰 1z0-1104-25 Cheap Dumps 🏦 Download ➠ 1z0-1104-25 🠰 for free by simply searching on ⮆ [url]www.examcollectionpass.com ⮄ 🏯Reliable 1z0-1104-25 Practice Materials[/url]
- Study 1z0-1104-25 Center 🈺 1z0-1104-25 Reliable Dumps Ebook 🤳 New Exam 1z0-1104-25 Materials 💥 Search for ▷ 1z0-1104-25 ◁ and download exam materials for free through ➤ [url]www.pdfvce.com ⮘ ⛲New Exam 1z0-1104-25 Materials[/url]
- 1z0-1104-25 Test Dumps: Oracle Cloud Infrastructure 2025 Security Professional - Oracle Cloud Infrastructure 2025 Security Professional Questions - Answers 🕒 Enter ➡ [url]www.pdfdumps.com ️⬅️ and search for 1z0-1104-25 to download for free 🧮Online 1z0-1104-25 Test[/url]
- Authoritative 1z0-1104-25 Real Question - Find Shortcut to Pass 1z0-1104-25 Exam 🍩 Search for ▛ 1z0-1104-25 ▟ and download it for free immediately on ▛ [url]www.pdfvce.com ▟ 😓1z0-1104-25 Testking Exam Questions[/url]
- Reliable Oracle - 1z0-1104-25 Real Question 🍸 Open website [url]www.prepawayete.com and search for 1z0-1104-25 for free download 🕠Study 1z0-1104-25 Center[/url]
- 1z0-1104-25 Reliable Exam Papers 💨 1z0-1104-25 Relevant Questions 🐤 1z0-1104-25 Relevant Questions 👄 Open ▶ [url]www.pdfvce.com ◀ and search for ⇛ 1z0-1104-25 ⇚ to download exam materials for free 🧣1z0-1104-25 Exam Testking[/url]
- Newest 1z0-1104-25 Real Question - Unparalleled 1z0-1104-25 Exam Tool Guarantee Purchasing Safety 😸 Easily obtain free download of ▷ 1z0-1104-25 ◁ by searching on ☀ [url]www.exam4labs.com ️☀️ 🔵Reliable 1z0-1104-25 Practice Materials[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, bbs.t-firefly.com, bicyclebuysell.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.education.indiaprachar.com, Disposable vapes
2026 Latest Actualtests4sure 1z0-1104-25 PDF Dumps and 1z0-1104-25 Exam Engine Free Share: https://drive.google.com/open?id=1XH8Vyz4mtae_QyvN2PpBZpRsT0UYoj9_
