[General] MS-102 PDF VCE, MS-102 Reliable Dumps Ppt
96
【General】 MS-102 PDF VCE, MS-102 Reliable Dumps Ppt
Posted at 1/11/2026 02:28:53      View:106 | Replies:0        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest DumpsReview MS-102 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=129ePvBYTyr2fdLpvo8u3YoiL0MN7xMXL
With MS-102 test answers, you are not like the students who use other materials. As long as the syllabus has changed, they need to repurchase new learning materials. This not only wastes a lot of money, but also wastes a lot of time. Our industry experts are constantly adding new content to MS-102 test dumps based on constantly changing syllabus and industry development breakthroughs. All the language used in MS-102 Study Materials is very simple and easy to understand. With MS-102 test answers, you don't have to worry about that you don't understand the content of professional books. You also don't need to spend expensive tuition to go to tutoring class. MS-102 test dumps can help you solve all the problems in your study.
Microsoft MS-102 Exam Syllabus Topics:
  • Manage compliance by using Microsoft Purview: Implementation of Microsoft Purview information protection and data lifecycle management is discussed in this topic. Moreover, questions about implementing Microsoft Purview data loss prevention (DLP) also appear.
  • Manage security and threats by using Microsoft Defender XDR: This topic discusses how to use Microsoft Defender portal to manage security reports and alerts. It also focuses on usage of Microsoft Defender for Office 365 to implement and manage email and collaboration protection. Lastly, it discusses the usage of Microsoft Defender for Endpoint for the implementation and management of endpoint protection.
  • Implement and manage Microsoft Entra identity and access: In this topic, questions about Microsoft Entra tenant appear. Moreover, it delves into implementation and management of authentication and secure access.
  • Deploy and manage a Microsoft 365 tenant: Management of roles in Microsoft 365 and management of users and groups are discussion points of this topic. It also focuses on implementing and managing a Microsoft 365 tenant.
MS-102 Reliable Dumps Ppt | MS-102 Exam OnlineIt is very convenient for all people to use the MS-102 study materials from our company. Our study materials will help a lot of people to solve many problems if they buy our products. The online version of MS-102 study materials from our company is not limited to any equipment, which means you can apply our study materials to all electronic equipment, including the telephone, computer and so on. So the online version of the MS-102 Study Materials from our company will be very useful for you to prepare for your exam. We believe that our study materials will be a good choice for you.
Microsoft 365 Administrator Sample Questions (Q398-Q403):NEW QUESTION # 398
You have a Microsoft 365 E5 subscription that has auditing turned on. The subscription contains the users shown in the following table.
You plan to create a new user named User1.
How long will the user creation audit event be available if Admin1 or Admin2 creates User1? To answer, select the appropriate options in the answer area.
Each correct selection is worth one point.
NEW QUESTION # 399
You have a Microsoft 365 E5 subscription that contains two sensitivity labels named Label1 and Label2. The subscription contains a Windows device named Device1 that is onboarded to Microsoft Purview. Device1 contains the files shown in the following table.
You create a data loss prevention (DLP) policy named Policy1 that has the following configurations:
NEW QUESTION # 400
HOTSPOT
You have a Microsoft 365 subscription.
A user named user1@contoso.com was recently provisioned.
You need to use PowerShell to assign a Microsoft Office 365 E3 license to User1. Microsoft Bookings must NOT be enabled.
How should you complete the command? To answer, select the appropriate options in the answer area.
Box 1: Connect-MgGraph
Assign Microsoft 365 licenses to user accounts with PowerShell
Use the Microsoft Graph PowerShell SDK
First, connect to your Microsoft 365 tenant.
Assigning and removing licenses for a user requires the User.ReadWrite.All permission scope or one of the other permissions listed in the 'Assign license' Microsoft Graph API reference page.
The Organization.Read.All permission scope is required to read the licenses available in the tenant.
Connect-MgGraph -Scopes User.ReadWrite.All, Organization.Read.All
Box 2: Get-MgSubscribedSku
Run the Get-MgSubscribedSku command to view the available licensing plans and the number of available licenses in each plan in your organization. The number of available licenses in each plan is ActiveUnits - WarningUnits - ConsumedUnits.
Box 3: Set-MgUserLicense
Assigning licenses to user accounts
To assign a license to a user, use the following command in PowerShell.
Set-MgUserLicense -UserId $userUPN -AddLicenses @{SkuId = "<SkuId>"} -RemoveLicenses @() This example assigns a license from the SPE_E5 (Microsoft 365 E5) licensing plan to the unlicensed user belindan@litwareinc.com:
$e5Sku = Get-MgSubscribedSku -All | Where SkuPartNumber -eq 'SPE_E5'
Set-MgUserLicense -UserId "belindan@litwareinc.com" -AddLicenses @{SkuId = $e5Sku.SkuId} - RemoveLicenses @() Reference:
https://learn.microsoft.com/en-u ... nts-with-microsoft-
365-powershell
NEW QUESTION # 401
After you answer a question in this section, you will NOT be able to return to it As a result these questions will not appear in the review screen.
Your network contains an Active Directory forest.
You deploy Microsoft 365.
You plan to implement directory synchronization.
You need to recommend a security solution for the synchronized identities. The solution must meet the following requirements:
* Users must be able to authenticate successfully to Microsoft 365 services if Active Directory becomes unavailable.
* User passwords must be 10 characters or more.
Solution: implement password hash synchronization and configure password protection in the Azure AD tenant.
Does this meet the goal?
  • A. Yes
  • B. No
NEW QUESTION # 402
Your company has a Microsoft 365 E5 tenant that contains a user named User1.
You review the company's compliance score.
You need to assign the following improvement action to User1:Enable self-service password reset.
What should you do first?
  • A. From the Azure Active Directory admin center, enable self-service password reset (SSPR).
  • B. From the Microsoft 365 admin center, modify the self-service password reset (SSPR) settings.
  • C. From the Azure Active Directory admin center, add User1 to the Compliance administrator role.
  • D. From Compliance Manager, turn off automated testing.
https://docs.microsoft.com/en-us ... mprovement-actions?
view=o365-worldwide
https://docs.microsoft.com/en-us ... -assign-role-azure- portal
NEW QUESTION # 403
We provide three versions of MS-102 study materials to the client and they include PDF version, PC version and APP online version. Different version boosts own advantages and using methods. The content of MS-102 exam torrent is the same but different version is suitable for different client. For example, the PC version of MS-102 study materials supports the computer with Windows system and its advantages includes that it simulates real operation exam environment and it can simulates the exam and you can attend time-limited exam on it. And whatever the version is the users can learn the MS-102 Guide Torrent at their own pleasures. The titles and the answers are the same and you can use the product on the computer or the cellphone or the laptop.
MS-102 Reliable Dumps Ppt: https://www.dumpsreview.com/MS-102-exam-dumps-review.html
P.S. Free 2026 Microsoft MS-102 dumps are available on Google Drive shared by DumpsReview: https://drive.google.com/open?id=129ePvBYTyr2fdLpvo8u3YoiL0MN7xMXL
