[General] JN0-351 Practice Exam Pdf - Latest JN0-351 Dumps Book
107
【General】 JN0-351 Practice Exam Pdf - Latest JN0-351 Dumps Book
Posted at 1/11/2026 07:08:17      View:127 | Replies:0        Print      Only Author   [Copy Link] 1#
P.S. Free & New JN0-351 dumps are available on Google Drive shared by ExamTorrent: https://drive.google.com/open?id=1M0d1ETW-0Hik_lNBjB6XebBE6FmXgvEM
The pass rate is 98.75%, and we will ensure you pass the exam if you buy JN0-351 exam torrent from us. Since the high pass rate, we have received many good feedbacks from candidates. What’s more, we pass guarantee and money back guarantee if you fail to pass the exam after purchasing JN0-351 Exam Torrent from us. We have online and offline chat service stuff, and they possess the professional knowledge about the JN0-351 exam dumps, if you have any questions, just have a chat with them.
Our clients come from all around the world and our company sends the products to them quickly. The clients only need to choose the version of the product, fill in the correct mails and pay for our JN0-351 study materials. Then they will receive our mails in 5-10 minutes. Once the clients click on the links they can use our JN0-351 Study Materials immediately. If the clients can’t receive the mails they can contact our online customer service and they will help them solve the problem. Finally the clients will receive the mails successfully. The purchase procedures are simple and the delivery of our JN0-351 study materials is fast.
High Hit Rate JN0-351 Practice Exam Pdf – Find Shortcut to Pass JN0-351 ExamAs the old saying goes, Rome was not built in a day. For many people, it’s no panic passing the JN0-351 exam in a short time. Luckily enough,as a professional company in the field of JN0-351 practice questions ,our products will revolutionize the issue. The JN0-351 Study Materials that our professionals are compiling which contain the most accurate questions and answers will effectively solve the problems you may encounter in preparing for the JN0-351 exam.
Juniper Enterprise Routing and Switching, Specialist (JNCIS-ENT) Sample Questions (Q90-Q95):NEW QUESTION # 90
Two routers share the same highest priority and start time. In this situation, what is evaluated next when determining the designated router?
  • A. The routers perform another DR election.
  • B. The router with the highest router ID becomes the DR
  • C. The router with the highest MAC address become the DR
  • D. The router with the lowest router ID become the DR.
According to the OSPF protocol, the designated router (DR) is the router that acts as the focal point for exchanging routing information on a multi-access network segment, such as a LAN. The DR election process is based on the following criteria, in order of precedence:
The router with the highest OSPF priority becomes the DR. The default priority is 1, and a priority of 0 means the router will not participate in the election.
If there is a tie in priority, the router with the highest router ID becomes the DR. The router ID is a
32-bit number that uniquely identifies a router in an OSPF domain. It can be manually configured or automatically derived from the highest IP address of a loopback interface or a physical interface. If there is a tie in router ID, the router that was first to become an OSPF neighbor becomes the DR. In your scenario, two routers share the same highest priority and start time.
This means that they have equal chances of becoming the DR based on the first and third criteria. Therefore, the second criterion will be used to break the tie, which is the router ID. The router with the highest router ID will become the DR, and the other router will become the backup designated router (BDR), which is ready to take over the role of DR if it fails.
NEW QUESTION # 91
What is the management IP address of the device shown in the exhibit?
  • A. 172.23.11.10
  • B. 172.23.12.100
  • C. 128.0.0.1
  • D. 10.210.20.233
The management IP address of the device shown in the exhibit is indicated by the interface
"me0." In the provided output, the "me0" interface is listed with the IP address 10.210.20.233.
NEW QUESTION # 92
Exhibit
Referring to the exhibit, which statement is correct?
  • A. The root bridge has not been elected for this RSTP topology.
  • B. The root bridge is using a bridge priority of 4k.
  • C. The local device is the root bridge for this RSTP topology.
  • D. The local device is using a bridge priority of 4k.
In a Rapid Spanning Tree Protocol (RSTP) topology, the root bridge is determined by the switch with the lowest bridge priority value12. If all switches have the same priority, then the root bridge is assigned to the switch whose MAC address's hex value is the lowest2. The default bridge priority value is 3276832. However, without the actual exhibit, it's difficult to definitively determine which device is the root bridge. But based on the options provided, if we assume that the local device has a lower bridge priority or a lower MAC address than other devices in the network, then it could be considered as the root bridge for this RSTP topology45.
NEW QUESTION # 93
Which OSPF packet type is sent when an OSPF router detects its database is stale?
  • A. database description
  • B. link-state acknowledgment
  • C. hello
  • D. link-state request
NEW QUESTION # 94
Which two statements about redundant trunk groups on EX Series switches are correct? (Choose two.)
  • A. Redundant trunk groups load balance traffic across two designated uplink interfaces.
  • B. Redundant trunk groups use spanning tree to provide loop-free redundant uplinks.
  • C. If the active link fails, then the secondary link automatically takes over.
  • D. Layer 2 control traffic is permitted on the secondary link.
Redundant trunk groups are designed to provide link redundancy. If the primary link fails, the secondary link will automatically take over to ensure continued connectivity.
In redundant trunk groups, while regular data traffic is sent over the primary link, Layer 2 control traffic (such as STP, LACP, etc.) is allowed on the secondary link to maintain network stability and protocol operations.
https://www.juniper.net/document ... st-l2/topics/topic- map/redundant-trunk-groups.html
NEW QUESTION # 95
Our ExamTorrent website has a long history of providing JN0-351 test training materials. With many years'hard work, our passing rate of ExamTorrent's JN0-351 exam has achieved 100%. In order to make sure that the accuracy of JN0-351 test of ExamTorrent, our JN0-351 test training materials are continuing update. If you purchase our JN0-351 exam dumps, we will offer one year-free update service.
Latest JN0-351 Dumps Book: https://www.examtorrent.com/JN0-351-valid-vce-dumps.html
JN0-351 online test engine is selected by many candidates because of its intelligence and interactive features, Juniper JN0-351 Practice Exam Pdf >> Purchase Questions Payment Options Q1, Our real collection of ExamTorrent JN0-351 Q&A helps you to prepare and pass the exam in first attempt, Dear everyone, we offer some JN0-351 Enterprise Routing and Switching, Specialist (JNCIS-ENT) free dumps for you, Come and buy JN0-351 study guide now!
Honeywall Kernel Configuration, Instead, you JN0-351 can simply plug and play" with ICs, resistors, lead wires, buttons, and other components, JN0-351 Online Test engine is selected by many candidates because of its intelligence and interactive features.
100% Pass 2026 Accurate Juniper JN0-351: Enterprise Routing and Switching, Specialist (JNCIS-ENT) Practice Exam Pdf>> Purchase Questions Payment Options Q1, Our real collection of ExamTorrent JN0-351 Q&A helps you to prepare and pass the exam in first attempt, Dear everyone, we offer some JN0-351 Enterprise Routing and Switching, Specialist (JNCIS-ENT) free dumps for you.
P.S. Free 2026 Juniper JN0-351 dumps are available on Google Drive shared by ExamTorrent: https://drive.google.com/open?id=1M0d1ETW-0Hik_lNBjB6XebBE6FmXgvEM
