[General] Latest Salesforce Exam Revision Plan¨CPass-Sure Plat-Con-201 Preparation
27
¡¾General¡¿ Latest Salesforce Exam Revision Plan¨CPass-Sure Plat-Con-201 Preparation
Posted at 4/20/2026 00:12:20      View£º99 | Replies£º0        Print      Only Author   [Copy Link] 1#
P.S. Free & New Plat-Con-201 dumps are available on Google Drive shared by LatestCram: https://drive.google.com/open?id=1ksAeBno7wbQTKEzn5CNateThFqZujwoQ
LatestCram is the only website which is able to supply all your needed information about Salesforce certification Plat-Con-201 exam. Using The information provided by LatestCram to pass Salesforce Certification Plat-Con-201 Exam is not a problem, and you can pass the exam with high scores.
You can find yourself sitting in your dream office and enjoying the new opportunity. So, don't wait, get the Salesforce Plat-Con-201 certification by preparing through LatestCram Salesforce Plat-Con-201 exam questions that will help you crack the Salesforce Plat-Con-201 Exam. LatestCram will provide you with all the Salesforce Plat-Con-201 exam dumps, practice exams, and other necessary documentation that will help you understand the Salesforce Plat-Con-201 exam questions and pass the Salesforce Plat-Con-201 exam.
Plat-Con-201 Preparation - Key Plat-Con-201 ConceptsOur company has dedicated ourselves to develop the Plat-Con-201 study materials for all candidates to pass the exam easier, also has made great achievement after more than ten years' development. As the certification has been of great value, a right Plat-Con-201 study material can be your strong forward momentum to help you pass the exam like a hot knife through butter. On the contrary, it might be time-consuming and tired to prepare for the Plat-Con-201 Exam without a specialist study material. So it's would be the best decision to choose our Plat-Con-201 study materials as your learning partner.
Salesforce Certified Omnistudio Consultant Sample Questions (Q85-Q90):NEW QUESTION # 85
Which two OmniScript components should the consultant recommend using to meet this validation requirement?
Choose 2 answers
  • A. Messaging
  • B. Alert
  • C. Formula
  • D. Calculation
Comprehensive and Detailed In-Depth Explanation:The question asks for two OmniScript components that are best suited to meet a "validation requirement." Since the specific validation requirement isn't provided, I' ll assume a common scenario in OmniStudio: validating user input or data within an OmniScript to ensure it meets certain conditions (e.g., checking if a field value is within an acceptable range, matches a pattern, or satisfies a business rule). Based on official Salesforce OmniStudio documentation, the Calculation and Formula components are the most appropriate tools for implementing validation logic within an OmniScript.
Here's why Calculation and Formula are the correct answers:
* C. Calculation: The Calculation component (specifically, a Calculation Action) in OmniScript is used to perform operations on data, including validation logic. It allows you to execute calculations, manipulate data, and set conditions based on user inputs or retrieved data. For example, a Calculation Action can check if a numeric input exceeds a threshold (e.g., Quantity > 100) or if a text field matches a required format. It can then set a flag (e.g., isValid = true/false) that can be used to control the OmniScript flow-such as displaying an error or blocking navigation. Calculation Actions are highly versatile because they support OmniScript's JSON data structure and can integrate with external data sources via DataRaptors or Integration Procedures. According to the OmniStudio documentation, Calculation Actions are ideal for complex validations requiring multiple steps or data transformations.
* D. Formula: The Formula component is a lightweight, inline element in OmniScript used to evaluate expressions and perform simple validations directly within the script. It leverages OmniScript's formula syntax (similar to Salesforce formulas) to compute values or check conditions. For instance, a Formula can validate that a date input is not in the past (e.g., TODAY() <= InputDate) or that a text field contains a specific substring. Unlike Calculation Actions, Formulas are embedded within a specific field or step and are best for straightforward, single-expression validations. The result of a Formula can be used to show/hide elements, set field values, or trigger other actions, making it a key tool for real- time validation.
Now, let's examine why the other options are incorrect:
* A. Messaging: The Messaging component in OmniScript is designed to display informational, warning, or error messages to the user based on predefined conditions or data. While it can communicate the result of a validation (e.g., "lease enter a valid phone number"), it does not perform the validation itself. It is a presentation tool, not a validation mechanism. For example, you might use a Formula to check if a field is empty and then use Messaging to display an error, but Messaging alone cannot enforce or evaluate the validation requirement.
* B. Alert: The Alert component is similar to Messaging in that it displays notifications or prompts to the user, often with more prominence (e.g., a pop-up). It's useful for alerting users about validation failures (e.g., "Input exceeds maximum allowed value"), but it does not contain logic to perform the validation.
Like Messaging, it relies on other components (e.g., Calculation or Formula) to determine whether an alert should be shown.
Why Calculation and Formula Together?
In practice, Calculation and Formula complement each other for validation requirements:
* Use Formula for simple, field-level validations that need immediate feedback (e.g., checking if an email contains "@").
* Use Calculation for multi-step or complex validations that involve multiple fields, external data, or conditional logic (e.g., validating a combination of inputs against a business rule).Together, they provide a robust framework to enforce validation within an OmniScript, ensuring data integrity before submission or progression.
Example Scenario:
Suppose the validation requirement is to ensure a user-entered "Discount Percentage" is between 0 and 50:
* A Formula could be added to the Discount field: AND(Discount >= 0, Discount <= 50), setting a Boolean flag (isDiscountValid).
* A Calculation Action could then check isDiscountValid and, if false, update a variable to trigger an error message or block the Next button.
This combination ensures both the validation logic and its enforcement are handled effectively.
* Salesforce OmniStudio Documentation: OmniScript Actions - Describes Calculation Action for data manipulation and validation.
* Salesforce OmniStudio Developer Guide: Formula Element - Details how Formulas evaluate conditions and support validation.
* Salesforce Help: OmniScript Designer - Explains Messaging and Alert as display tools, not validation components.
NEW QUESTION # 86
A company has a legacy application to display customer information. The application currently uses custom CS / HTML to display information in the company's color scheme and fonts. The application also provides users will access to more than 25 processes. Recently, a new project was started to build a 360¡ã view using FlexCards to replace the legacy application.
In this scenario, which three FlexCard features should the consultant recommend?
Choose 3 answers
  • A. Actions
  • B. Custom Styles
  • C. Menu elements
  • D. Data tables
  • E. Newport Design System
Answer: A,B,D
FlexCards are used to display contextual customer information in a compact and customizable way. They can also provide access to related processes or actions. In this scenario, the features that the consultant should recommend are:
* Actions: These are buttons or links that can launch OmniScripts, DataRaptors, or other processes from the FlexCard. They can help the users to perform tasks related to the customer information displayed on the FlexCard.
* Custom Styles: These are CSS classes that can be applied to the FlexCard elements to match the company's color scheme and fonts. They can help the users to have a consistent and branded user interface.
* Data Tables: These are elements that can display tabular data from one or more data sources on the FlexCard. They can help the users to see relevant data in a structured and sortable way.
The features that the consultant should not recommend are:
* Menu Elements: These are elements that can display a list of options or submenus on the FlexCard.
They are not suitable for this scenario because they do not provide access to processes or actions, but only to other FlexCards or pages.
* Newport Design System: This is a design system that provides a set of predefined styles and components for OmniStudio applications. It is not suitable for this scenario because it does not match the company's color scheme and fonts, and it may require additional customization.
NEW QUESTION # 87
A consultant is designing a FlexCard for a client. The client wants to customize the look of each element on the FlexCard. What tool should the consultant use to meet the client's requirements?
  • A. Use OmniScripts to customize the look of each element.
  • B. Use Integration Procedures to customize the look of each element.
  • C. Use the style panel in the FlexCard Designer to customize the look of each element.
  • D. Use DataRaptor to customize the look of each element.
Comprehensive and Detailed In-Depth Explanation:The requirement is to customize the appearance (look) of each element on a FlexCard. In Salesforce OmniStudio, the Style Panel in the FlexCard Designer is the dedicated tool for this purpose, making C the correct answer.
Here's why C. Use the style panel in the FlexCard Designer to customize the look of each element is the correct answer:
* Style Panel Overview: The FlexCard Designer includes a Style Panel (accessed in the properties pane) that allows consultants to customize the visual properties of individual elements (e.g., Text, Image, Button, Datatable) on a FlexCard. This includes settings like:
* Font size, color, and weight.
* Background color or image.
* Borders (style, width, color).
* Padding and margins.
* Custom CSS for advanced styling.
* Meeting the Requirement:
* Element-Level Customization: The Style Panel enables granular control over each element. For example, a Text element displaying a customer name can be styled with a bold red font, while a Button can have a blue background and rounded corners.
* Ease of Use: It's a no-code solution within the FlexCard Designer, requiring no external tools or coding expertise, aligning with OmniStudio's low-code philosophy.
* Preview: Changes made in the Style Panel are instantly previewable in the designer, ensuring the client's vision is met efficiently.
* Example: If the FlexCard shows case details, the consultant could use the Style Panel to make the case number bold and blue, add a red border to an "Open" status badge, and adjust the Datatable's row height-all tailored to the client's preferences.
* A. Use DataRaptor to customize the look of each element: A DataRaptor (e.g., DataRaptor Extract or Transform) handles data retrieval and manipulation, not visual styling. It provides the data displayed on the FlexCard but has no role in customizing the appearance of elements.
* B. Use Integration Procedures to customize the look of each element: Integration Procedures orchestrate backend logic and API calls, not UI styling. They can fetch data or process actions but don't influence the look of FlexCard elements.
* D. Use OmniScripts to customize the look of each element: OmniScripts are for guided processes, not for designing or styling FlexCards. While OmniScripts have their own styling options, they're separate from FlexCards and irrelevant to this requirement.
* Salesforce OmniStudio Documentation: FlexCard Designer - Describes the Style Panel for customizing element appearance.
* Salesforce OmniStudio Developer Guide: Styling FlexCards - Details CSS and style options in the designer.
NEW QUESTION # 88
When a customer calls to add a new primary contact to their account, call center agents need to complete a I contact form. The agent enters the new contact information using an OmniScript and then needs to generate PDF with the contact information pre-filled that can be shared with the customer.
Which OmniStudio tool should the consultant recommend to generate the pre-filled PDF'
  • A. Calculation Procedure
  • B. Data Maptor
  • C. Integration Procedure
  • D. OmniStudio Action
The OmniStudio tool that the consultant should recommend to generate the pre-filled PDF is DataRaptor. A DataRaptor is a tool that can read, transform, and write data from Salesforce objects or JSON objects. A DataRaptor Load can write data to a PDF template using a PDF mapping file, and generate a PDF document with the contact information pre-filled. The PDF document can be stored as an attachment or a content document in Salesforce
NEW QUESTION # 89
A company has a process that requires minimum age to purchase. Potential customers must fill in an application form. Rather than have someone fill in the entire form and be denied at the end, 2 consultant recommends using an Omniscript that will ask users to input their birthdate. If the user is younger than than
18 years, then the Omniscript needs to display a message stating "You must be 18 years or older to purchase" and also prevent users from continuing. If the user is 18 or older, then the Omniscript should allow them to proceed without any message.
Which two Omniscript components should the using to meet this validation requirement?
Choose 2 answers
  • A. Messaging
  • B. Formula
  • C. Alert
  • D. Calculation
* Formula (C) - The Formula element calculates whether the user is 18 years or older based on the birthdate they input.
* It performs a real-time calculation using the current date minus the birthdate to determine the age.
* Alert (A) - The Alert element is used to display an error message when the user does not meet the age requirement.
* It prevents the user from proceeding until the condition (age >= 18) is met.
* B. Calculation - Calculation is used for business logic and rules processing, but a Formula element is more suitable for real-time validation within an OmniScript.
* D. Messaging - The Messaging element displays information but does not prevent further progress, while an Alert stops the user from continuing.
Comprehensive and Detailed In-Depth Explanation:Why not the other options?? Salesforce OmniStudio Reference:
* OmniScript Formula Element
* OmniScript Alert Element
NEW QUESTION # 90
You may want to have a preliminary understanding of our Plat-Con-201 training materials before you buy them. Don't worry our Plat-Con-201 study questions will provide you with a free trial. Each user can learn what the Plat-Con-201 Exam Guide will look like when it opens from the free trial version we provide. Since that the free demos are a small part of our Plat-Con-201 practice braindumps and they are contained in three versions.
Plat-Con-201 Preparation: https://www.latestcram.com/Plat-Con-201-exam-cram-questions.html
Plat-Con-201 exam has grabbed the interest of IT students with its rising need and importance in the field, Our Soft version of Plat-Con-201 practice materials combine knowledge with the latest technology to greatly stimulate your learning power, Find the same core area Plat-Con-201 exam questions with professionally verified answers, and PASS YOUR EXAM, But we regret that it'll spend a little more on the basis of high quality and careful preparation of our Salesforce Plat-Con-201 demo cram.
To turn on this feature, open the Program panel menu and choose Show Dropped Frames Indicator, Create in Spark Page, Plat-Con-201 exam has grabbed the interest of IT students with its rising need and importance in the field.
Hot Exam Plat-Con-201 Revision Plan | Pass-Sure Salesforce Plat-Con-201 Preparation: Salesforce Certified Omnistudio ConsultantOur Soft version of Plat-Con-201 practice materials combine knowledge with the latest technology to greatly stimulate your learning power, Find the same core area Plat-Con-201 exam questions with professionally verified answers, and PASS YOUR EXAM.
But we regret that it'll spend a little more Plat-Con-201 on the basis of high quality and careful preparation of our Salesforce Plat-Con-201 demo cram, Or you will miss tens of thousands Plat-Con-201 Advanced Testing Engine of opportunities during each hour you are trapped in the swamp of hesitation.
BONUS!!! Download part of LatestCram Plat-Con-201 dumps for free: https://drive.google.com/open?id=1ksAeBno7wbQTKEzn5CNateThFqZujwoQ
