[General] New HPE7-J02 Exam Format | HPE7-J02 Downloadable PDF
89
【General】 New HPE7-J02 Exam Format | HPE7-J02 Downloadable PDF
Posted at 1/29/2026 02:05:37      View:143 | Replies:2        Print      Only Author   [Copy Link] 1#
P.S. Free & New HPE7-J02 dumps are available on Google Drive shared by PassTorrent: https://drive.google.com/open?id=1yNsBAGsmPy_u5WqBqlucg9ZM37jQiz3R
You have to change the way your study. Get the best Advanced HPE Storage Integrator Solutions Written Exam HPE7-J02 exam questions for your text, check all the chapters, and carefully take note of the important points. You can even highlight the important ones to get a quick revision whenever you want. Cramming the Advanced HPE Storage Integrator Solutions Written Exam HPE7-J02 books is not a good idea because it will not help you in understanding the concept. You just read the lines, try to remember them, and believe that you can keep those lines in your mind during the HP Certification Exams.
HP HPE7-J02 Exam Syllabus Topics:
  • Competitive Positioning of HPE Storage: This part of the exam focuses on the ability of Trusted Advisors to identify competitive opportunities for HPE Storage solutions. It requires articulating HPE’s strengths in comparison to multi-vendor environments, customer needs, and market trends, helping customers make informed technology choices.
  • HPE Storage Portfolio and Strategy: This domain measures the knowledge of Solution Advisors in positioning HPE’s Storage portfolio within enterprise infrastructure. Candidates must understand HPE Storage hardware, procurement options, available tools, and the overarching storage strategy, including its relevance to enterprise-scale solutions.
  • Remote Support Configuration: This small but important section tests the ability of System Administrators to configure HPE solutions for remote support, ensuring proactive monitoring and timely resolution of technical issues.
  • Optimizing the Customer’s Environment: This domain evaluates the skills of Optimization Specialists in identifying opportunities for improvement. Candidates will design and validate optimization plans that enhance customer environments, ensuring measurable performance and efficiency gains.
HPE7-J02 Downloadable PDF | Exam HPE7-J02 GuideUp to now, we have business connection with tens of thousands of exam candidates who adore the quality of them. Besides, we try to keep our services brief, specific and courteous with reasonable prices of HPE7-J02 practice materials. All your questions will be treated and answered fully and promptly. We guarantee that you can pass the exam at one time even within one week based on practicing our HPE7-J02 studying materials regularly. 98 to 100 percent of former exam candidates have achieved their success by them.
HP Advanced HPE Storage Integrator Solutions Written Exam Sample Questions (Q37-Q42):NEW QUESTION # 37
You are sizing an HPE Alletra Storage MP B10000 as shown in the graphic below.
What change must be made to the current storage configuration to achieve maximum IOPS performance?
  • A. Additional disks need to be added to the system
  • B. The controller must be upgraded to a 32-core model
  • C. No change needed - the system is already operating at maximum performance
  • D. Additional network cards or HBAs need to be added for more throughput
Detailed Explanation:
Rationale for Correct Answer:
From the exhibit, the system shows maximum estimated IOPS performance (over 250K IOPS read, 115K IOPS mixed, 62K write). These values align with HPE's published performance specifications for this model with full cores enabled. The network interface count and disk count are balanced relative to controller capability. Therefore, no further upgrades are required to achieve maximum performance.
Distractors:
A: Adding NICs/HBAs may improve throughput but will not exceed controller-bound IOPS.
B: Adding disks increases capacity, not peak IOPS, as performance is primarily controller-driven.
D: The system already matches controller capability; upgrading cores is not an option in Alletra MP B10000 mid-range systems.
Key Concept: Understanding performance sizing based on controller and architecture limits, not just capacity or NICs.
Reference: HPE Alletra MP Performance and Sizing Guide.
NEW QUESTION # 38
A pool of Microsoft SQL servers started to use the Alletra 6000 family array six months ago. The data growth has been higher than expected, and the performance of the databases is facing some latency issues.
Which method would allow both capacity and performance to grow when expanding the array, while keeping the management simple?
  • A. By including more NIC cards to load balance host traffic.
  • B. By initially selecting the timeless storage option for the array.
  • C. By adding more arrays and capacity to a single scale-out group.
  • D. By selecting more flash to cache ratio on the expansion shelves.
HPE Alletra 6000 is a scale-out architecture array. Adding more arrays to a single scale-out group increases both performance (IOPS, throughput) and capacity, while maintaining single-pane management via HPE Data Services Cloud Console. This is the most efficient way to address both capacity growth and latency reduction for SQL workloads.
Distractors:
B: Adding NICs may help with throughput but not backend latency or capacity scaling.
C: Flash-to-cache ratios can optimize read caching but don't fundamentally increase system-wide performance.
D: Timeless storage is a procurement/licensing option, not a performance/capacity scaling method.
Key Concept: Alletra 6000 scale-out clustering for balanced growth of capacity and performance.
Reference: HPE Alletra 6000 Technical Architecture Guide.
NEW QUESTION # 39
You need to evaluate a customer virtual server environment to size an HPE Block storage solution according to the metrics seen on the system over a period of time. The environment consists of Lenovo servers and Pure Storage as the storage vendor for a Microsoft Hyper-V cluster managed by Microsoft SCVMM.
Which HPE tools can you utilize to gather the usage metrics of this setup?
  • A. Import the HPE CloudPhysics.vhdx collector to the Hyper-V cluster to gather the analytics.
  • B. Install the SAFcollector agents into the environment and use SAFanalyze to import the agent output.
  • C. Export the Microsoft System Center Virtual Machine Manager database for NinjaProtected analysis.
  • D. Use the HPE InfoSight Primary Storage sizing tool to calculate the competitive performance metrics.
HPE CloudPhysics provides comprehensive environment assessment and competitive sizing for virtualized environments (VMware, Hyper-V, etc.). The CloudPhysics collector (available as a .vhdx for Hyper-V) is deployed into the cluster to gather metrics on CPU, memory, storage IOPS/latency, and utilization trends.
These analytics feed into the sizing of HPE storage solutions.
Distractors:
B: InfoSight sizing tools work with HPE systems, not competitive 3rd-party storage like Pure.
C: SAF is a manual assessment requiring email submission and is not the correct modern method for this case.
D: NinjaProtected applies to backup analysis, not production Hyper-V cluster sizing.
Key Concept: CloudPhysics.vhdx collector for Hyper-V sizing with 3rd-party infrastructure.
Reference: HPE CloudPhysics Assessment Guide.
NEW QUESTION # 40
Your customer is using 2 HPE StoreOnce appliances across 2 sites with replication enabled for disaster recovery. They are concerned about the fact that the StoreOnce administrators have full access to the systems, which allows them to delete backup copies on these systems.
What needs to be used to address the concern of your customer?
  • A. Data at rest encryption
  • B. Resource restriction policies
  • C. Challenge Handshake Authentication Protocol (CHAP)
  • D. Dual Authorization
HPE StoreOnce Dual Authorization prevents a single administrator from deleting, expiring, or modifying backup data. Instead, any destructive action requires approval from a second administrator, mitigating insider threats and accidental deletions. This is the correct feature for immutability protection in a replicated StoreOnce environment.
Distractors:
B (CHAP): Used for iSCSI authentication, not backup immutability.
C: Encryption protects data confidentiality, not accidental deletion.
D: Resource restrictions are policy-driven but don't enforce dual control over destructive actions.
Key Concept: Dual Authorization for ransomware and insider-threat protection on StoreOnce.
Reference: HPE StoreOnce Security Features White Paper.
NEW QUESTION # 41
Two HPE Alletra 6000 arrays are configured for peer persistence between datacenters A and B, which have a fiber distance of 50km (31mi). The datacenter B hardware will be relocated to a new location that will increase the fiber distance to 150km (93mi).
Which condition is valid once the relocation is finished?
  • A. The fiber distance exceeds the distance supported for peer persistence setup.
  • B. The peer persistence setup needs to be changed to active peer persistence.
  • C. The peer persistence configuration is supported, when latency remains <10ms.
  • D. The peer persistence replication links need to be changed to RC transport.
HPE Peer Persistence is supported over distances of up to 150-200 km, as long as the round-trip latency is
#10ms. Therefore, even after relocation to 150km, Peer Persistence remains supported provided latency requirements are met.
Distractors:
B: RC (Remote Copy) transport is already the underlying technology, but no change is required.
C: Peer Persistence is already an active-active design; no change to "active" mode is needed.
D: Distance does not exceed the supported range; only latency matters.
Key Concept: Latency <10ms is the critical requirement for Peer Persistence.
Reference: HPE Alletra 6000/Primera Peer Persistence Best Practices.
NEW QUESTION # 42
Our company has spent more than 10 years on compiling HPE7-J02 study materials for the exam in this field, and now we are delighted to be here to share our HPE7-J02 learnign guide with all of the candidates for the exam in this field. There are so many striking points of our HPE7-J02 Preparation exam. If you want to have a better understanding of our HPE7-J02 exam braindumps, just come and have a try!
HPE7-J02 Downloadable PDF: https://www.passtorrent.com/HPE7-J02-latest-torrent.html
Posted at 2/4/2026 02:36:01        Only Author  2#
This article is truly top-notch, thank you for sharing it with me. Here comes the C_BCSPM_2502 reliable test simulator online exam. Wish me success!
Posted at 2/4/2026 09:37:53        Only Author  3#
What a remarkable piece of writing, thank you for sharing this with us! Here’s the Valid test cram Fire-Inspector-II materials test that contributed to my career advancement and salary raise. It's open to everyone today at no cost. May you reach your career goals soon!
