100% Pass Quiz Linux Foundation - High-quality CKA Latest Test Bootcamp
44
Posted at 3/9/2026 00:06:39      View114 | Replies0        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of PassCollection CKA dumps for free: https://drive.google.com/open?id=1oZv319sHVGxQdHxLKgb4W0j3nEXcNBxm
With the rapid development of computer, network, and semiconductor techniques, the market for people is becoming more and more hotly contested. Passing a CKA exam to get a certificate will help you to look for a better job and get a higher salary. If you are tired of finding a high quality study material, we suggest that you should try our CKA Exam Prep. Because our CKA exam materials not only has better quality than any other same learn products, but also can guarantee that you can pass the CKA exam with ease.
Linux Foundation CKA (Certified Kubernetes Administrator) program is a certification that recognizes an individual's expertise in managing and deploying applications on the Kubernetes platform. Certified Kubernetes Administrator (CKA) Program Exam certification is designed for professionals who have a solid understanding of Kubernetes and its underlying components, including networking, storage, security, and cluster architecture. The CKA program is ideal for individuals who are looking to enhance their Kubernetes skillset and are interested in pursuing a career in DevOps, cloud computing, or containerization.
Linux Foundation CKA Program Exam is designed for system administrators, DevOps engineers, and IT professionals who are responsible for deploying and managing Kubernetes clusters in a production environment. Certified Kubernetes Administrator (CKA) Program Exam certification helps professionals demonstrate their expertise in Kubernetes, which is one of the most popular container orchestration tools used in the industry.
Accessible PDF Format for Linux Foundation CKA Exam QuestionsIf you decide to buy our CKA study questions, you can get the chance that you will pass your CKA exam and get the certification successfully in a short time. For we have helped tens of thousands of our customers achieved their dreams. We believe you won't be the exception, so if you want to achieve your dream and become the excellent people in the near future, please buy our CKA Actual Exam, it will help you.
The CKA program is a hands-on certification program that assesses an individual's ability to perform tasks related to Kubernetes administration. The program covers a wide range of topics such as Kubernetes cluster architecture, installation, configuration, networking, security, storage, and troubleshooting. The program also requires individuals to demonstrate their ability to use Kubernetes command-line tools effectively.
Linux Foundation Certified Kubernetes Administrator (CKA) Program Exam Sample Questions (Q44-Q49):NEW QUESTION # 44
List all the events sorted by timestamp and put them into file.log and verify
  • A. kubectl get events --sort-by=.metadata.creationTimestamp
    // putting them into file.log
    kubectl get events --sort-by=.metadata.creationTimestamp >
    test-file.log
    cat test-file.log
  • B. kubectl get events --sort-by=.metadata.creationTimestamp
    cat test-file.log
  • C. kubectl get events --sort-by=.metadata.creationTimestamp
    test-file.log
    cat test-file.log
NEW QUESTION # 45
Score: 5%
Task
Monitor the logs of pod bar and:
* Extract log lines corresponding to error file-not-found
* Write them to /opt/KUTR00101/bar
Solution:
kubectl logs bar | grep 'unable-to-access-website' > /opt/KUTR00101/bar cat /opt/KUTR00101/bar
NEW QUESTION # 46
List all the pods showing name and namespace with a json path expression See the solution below.
kubectl get pods -o=jsonpath="{.items
  • ['metadata.name',
    'metadata.namespace']}"
    NEW QUESTION # 47
    Print all pod name and all image name and write it to a file
    name "/opt/pod-details.txt"
    kubectl get pods -o=custom-columns='Pod Name:metadata.name','Image:spec.containers
  • .image' > /opt/pod-details.txt
    NEW QUESTION # 48
    For this item, you will havetosshto the nodesik8s-master-0andik8s-node-0and complete all tasks on thesenodes. Ensure that you return tothe base node (hostname:node-1) when you havecompleted this item.
    Context
    As an administrator of a smalldevelopment team, you have beenasked to set up a Kubernetes clusterto test the viability of a newapplication.
    Task
    You must usekubeadmto performthis task. Anykubeadminvocationswill require the use of the
    --ignore-preflight-errors=alloption.
    * Configure thenodeik8s-master-Oas a masternode. .
    * Join the nodeik8s-node-otothe cluster.
    solution
    You must use thekubeadmconfiguration file located at   when initializingyour cluster.
    You may use any CNI pluginto complete this task, but ifyou don't have your favouriteCNI plugin's manifest URL athand, Calico is one popularoption:https://docs.projectcalico.org/v3.14/manifests/calico.yaml Docker is already installedon both nodes and hasbeen configured so that you caninstall the required tools.
    NEW QUESTION # 49
    Most CKA Reliable Questions: https://www.passcollection.com/CKA_real-exams.html
    BTW, DOWNLOAD part of PassCollection CKA dumps from Cloud Storage: https://drive.google.com/open?id=1oZv319sHVGxQdHxLKgb4W0j3nEXcNBxm
  • Reply
