[Hardware] 100% Pass 312-97 - EC-Council Certified DevSecOps Engineer (ECDE)–High Pass-Rate
112
【Hardware】 100% Pass 312-97 - EC-Council Certified DevSecOps Engineer (ECDE)–High Pass-Rate
Posted at 1/24/2026 10:17:35      View:137 | Replies:1        Print      Only Author   [Copy Link] 1#
You get a specific amount of time per day to study, you have a job, need to go to the office daily, and take time to relax from the hectic work schedule. So, planning a long study schedule is not possible. Some people study while traveling to the office, some prefer to check the office breaks and some even take it to late-night study especially when they are left with little time to prepare EC-Council Certified DevSecOps Engineer (ECDE) 312-97 for certification exam. For this reason, we want to make your journey smooth by providing you with smart tips to make the most out of your EC-Council Certified DevSecOps Engineer (ECDE) 312-97 study material for the EC-Council Certified DevSecOps Engineer (ECDE) 312-97 certification programs and clear it in one go.
If you want to get promotions or high-paying jobs in the ECCouncil sector, then it is important for you to crack the EC-Council Certified DevSecOps Engineer (ECDE) (312-97) certification exam. The ECCouncil 312-97 certification has become the best way to validate your skills and accelerate your tech career. 312-97 Exam applicants who are doing jobs or busy with their other matters usually don't have enough time to study for the test.
ECCouncil 312-97 Reliable Exam Braindumps & Valid Test 312-97 TutorialECCouncil dumps are designed according to the ECCouncil 312-97 certification exam standard and have hundreds of questions similar to the actual 312-97 exam. SurePassExams EC-Council Certified DevSecOps Engineer (ECDE) (312-97) web-based practice exam software also works without installation. It is browser-based; therefore no need to install it, and you can start practicing for the EC-Council Certified DevSecOps Engineer (ECDE) (312-97) exam by creating the ECCouncil 312-97 practice test.
ECCouncil EC-Council Certified DevSecOps Engineer (ECDE) Sample Questions (Q92-Q97):NEW QUESTION # 92
(Cheryl Hines has been working as a senior DevSecOps engineer over the past 5 years in an IT company. Due to the robust features offered by Keywhiz secret management tool such as compatibility with all software, untraceable secrets, no impact of power cut or server outage, etc., Cheryl's organization is using it for managing and distributing secrets. To add a secret using Keywhiz CLI, which of the following commands should Cheryl use?)
  • A. $ keywhiz.cli --devTrustStore --admin keywhizAdmin login
    $ keywhiz.cli add secret --name mySecretName < mySecretFile.
  • B. $ keywhiz.cli --devsecTrustStore --admin keywhizAdmin login
  • C. $ keywhiz.cli --devTrustStore --user keywhizAdmin login
  • D. $ keywhiz.cli --DevSecTrustStore --user keywhizAdmin login
Keywhiz CLI requires authentication before secrets can be added. The correct process involves logging in using the --devTrustStore option and authenticating as an administrator using the --admin flag. Once authenticated, the add secret command is used with input redirection to securely store the secret. Options that use incorrect flag names, incorrect casing, or invalid trust store identifiers do not follow Keywhiz CLI syntax.
Adding secrets through Keywhiz instead of embedding them in code supports secure secret distribution and management, which is a fundamental aspect of DevSecOps culture. This approach ensures secrets remain protected, auditable, and available even during outages.
NEW QUESTION # 93
(Rachel Maddow has been working at RuizSoft Solution Pvt. Ltd. for the past 7 years as a senior DevSecOps engineer. To develop software products quickly and securely, her organization has been using AWS DevOps services. On January 1, 2022, the software development team of her organization developed a spring boot application with microservices and deployed it in AWS EC2 instance. Which of the following AWS services should Rachel use to scan the AWS workloads in EC2 instance for security issues and unintended network exposures?.)
  • A. Amazon CloudWatch.
  • B. AWS Config.
  • C. AWS Inspector.
  • D. AWS WAF.
AWS Inspector is a managed vulnerability assessment service designed specifically to scan workloads running on Amazon EC2 instances and container images for security vulnerabilities and unintended network exposures. It automatically evaluates instances against known vulnerabilities and security best practices, providing detailed findings and risk severity levels. AWS WAF protects web applications from common web exploits but does not perform host-based vulnerability scanning. AWS Config tracks configuration changes and compliance but does not actively scan workloads for vulnerabilities. Amazon CloudWatch focuses on monitoring logs, metrics, and alarms rather than security scanning. For a Spring Boot microservices application deployed on EC2, AWS Inspector is the correct choice to continuously assess security posture during the Build, Deploy, and Operate phases of the DevSecOps pipeline.
NEW QUESTION # 94
(Joyce Vincent has been working as a senior DevSecOps engineer at MazeSoft Solution Pvt. Ltd. She would like to integrate Trend Micro Cloud One RASP tool with Microsoft Azure to secure container-based application by inspecting the traffic, detecting vulnerabilities, and preventing threats. In Microsoft Azure PowerShell, Joyce created the Azure container instance in a resource group (ACI) (named "aci-test-closh") and loaded the container image to it. She then reviewed the deployment of the container instance. Which of the following commands should Joyce use to get the logging information from the container?.)
  • A. az container logs --resource-group ACI --name aci-test-closh.
  • B. azure container logs -resource-group ACI -name aci-test-closh.
  • C. azure container logs --resource-group ACI --name aci-test-closh.
  • D. az container logs -resource-group ACI -name aci-test-closh.
Azure Container Instances (ACI) exposes container logs via the Azure CLI using the az container logs command. To retrieve logs, you must provide the resource group and the container group name using the long- form parameters --resource-group and --name. Option A matches the correct CLI structure and parameter format: az container logs --resource-group ACI --name aci-test-closh. Options B and D incorrectly use single- dash forms (-resource-group and -name), which are not valid for these long option names. Options C and D incorrectly use azure instead of az; the Azure CLI command group is invoked with az, not azure. Getting logs after deployment review is a critical Operate and Monitor activity: it helps confirm the container started correctly, diagnose runtime errors, and validate that runtime protection (such as a RASP/micro-agent) is functioning. This visibility supports faster incident response and helps ensure the containerized workload remains secure and stable in its runtime environment.
NEW QUESTION # 95
(William McDougall has been working as a DevSecOps engineer in an IT company located in Sacramento, California. His organization has been using Microsoft Azure DevOps service to develop software products securely and quickly. To take proactive decisions related to security issues and to reduce the overall security risk, William would like to integrate ThreatModeler with Azure Pipelines. How can ThreatModeler be integrated with Azure Pipelines and made a part of William's organization DevSecOps pipeline?)
  • A. By using a bidirectional UI.
  • B. By using a unidirectional API.
  • C. By using a unidirectional UI.
  • D. By using a bidirectional API.
ThreatModeler integration with Azure Pipelines is achieved using abidirectional API, which allows automated and continuous interaction between the pipeline and the threat modeling platform. This bidirectional communication enables Azure Pipelines to trigger threat modeling activities while also receiving results, risk scores, and actionable insights back from ThreatModeler. Such feedback loops are critical for proactive security decision-making during the Plan stage of DevSecOps. Unidirectional APIs or UI-based integrations limit automation and do not support continuous feedback, making them unsuitable for pipeline- driven workflows. UI-based approaches also introduce manual steps, which conflict with DevSecOps principles of automation and consistency. By using a bidirectional API, William's organization can embed threat modeling into the planning process, identify architectural risks early, and ensure security considerations are continuously enforced as part of the pipeline.
NEW QUESTION # 96
(Kevin Williamson has been working as a DevSecOps engineer in an MNC company for the past 5 years. In January of 2017, his organization migrated all the applications and data from on-prem to AWS cloud due to the robust security feature and cost-effective services provided by Amazon. His organization is using Amazon DevOps services to develop software products securely and quickly. To detect errors in the code and to catch bugs in the application code, Kevin integrated PHPStan into the AWS pipeline for static code analysis. What will happen if security issues are detected in the application code?.)
  • A. The integrated PHPStan into the AWS pipeline will invoke AWS Config to parse and send result to the security hub.
  • B. The integrated PHPStan into the AWS pipeline will invoke AWS Elastic BeanStalk to parse and send result to the security hub.
  • C. The integrated PHPStan into the AWS pipeline will invoke AWS CloudFormation to parse and send result to the security hub.
  • D. The integrated PHPStan into the AWS pipeline will invoke the AWS Lambda function to parse and send result to the security hub.
In AWS-based DevSecOps pipelines, static analysis tools such as PHPStan commonly send their results to AWS services through event-driven processing. When PHPStan detects security issues, the results are typically parsed and processed by anAWS Lambda function, which can transform findings and forward them to AWS Security Hub. CloudFormation is used for infrastructure provisioning, AWS Config evaluates configuration compliance, and Elastic Beanstalk is an application deployment service-none of these are suited for parsing and relaying scan results. Lambda functions provide a scalable and serverless way to handle scan outputs automatically. This integration ensures that security findings are centralized, visible, and actionable, aligning with secure automation practices during the Code stage.
NEW QUESTION # 97
If you are forced to pass exams and obtain certification by your manger, our 312-97 original questions will be a good choice for you. Our products can help you clear exams at first shot. We promise that we provide you with best quality 312-97 original questions and competitive prices. We offer 100% pass products with excellent service. We provide one year studying assist service and one year free updates downloading of ECCouncil 312-97 Exam Questions. If you fail exam we support to exchange and full refund.
312-97 Reliable Exam Braindumps: https://www.surepassexams.com/312-97-exam-bootcamp.html
Once you pay we have one year service warranty for 312-97 exam simulation you pay, If you want to get a better job and relieve your employment pressure, it is essential for you to get the 312-97 certification, ECCouncil Valid Dumps 312-97 Pdf We have got a mature technology which makes our software running more smoothly and more accessible, You can surely answer all exam questions by doing our ECCouncil 312-97 exam dumps frequently.
Finally, if you're a creative type, you can syndicate your own content 312-97 to your partner sites, Essential Guide to Web Strategy for Entrepreneurs, TheEssential Guide to Web Strategy for Entrepreneurs, The.
312-97 Practice Materials: EC-Council Certified DevSecOps Engineer (ECDE) - 312-97 Test Preparation - SurePassExamsOnce you pay we have one year service warranty for 312-97 Exam simulation you pay, If you want to get a better job and relieve your employment pressure, it is essential for you to get the 312-97 certification.
Let's explore the different features of our dumps exam before purchase.
Posted at 3/7/2026 15:53:35        Only Author  2#
KoreaDumps의Huawei인증 H12-821_V1.0덤프는 인터넷에서 검색되는Huawei인증 H12-821_V1.0시험공부자료중 가장 출중한 시험준비 자료입니다. Huawei인증 H12-821_V1.0덤프를 공부하면 시험패스는 물론이고 IT지식을 더 많이 쌓을수 있어 일거량득입니다.자격증을 취득하여 자신있게 승진하여 연봉협상하세요.
