FirePrime with Android5.1+Ubuntu15.04 will be avilibale
1661
administrator
Rank: 9Rank: 9Rank: 9
Posted at 6/5/2015 17:11:30      View14060 | Replies9        Print      Only Author   [Copy Link] 1#
FirePrime support the latest Android5.1 and Ubuntu15.04FirePrime is core board combined with backplane, core board is on the basis of standard PCIE interface design, with minimum function
FirePrime's :RK3128
Excellent ability of image processing
The latest Android5.1 and Ubuntu15.04 dual system
Core-board combines with Backplane
LPDDR2+Nandfls
Excellent network function
More interface
Firefly WeChatfireflytee
Posted at 6/7/2015 04:35:02        Only Author  2#
Guess we should have a Firefly Kernel soon.  The RockChip SDK can be found here  https://bitbucket.org/T-Firefly/firenow-lollipop but this is only for the newer chips with the RK32xx and RK31xx are listed as generic.
Posted at 6/8/2015 16:34:40        Only Author  3#
cappybob Posted at 6/7/2015 04:35
Guess we should have a Firefly Kernel soon.  The RockChip SDK can be found here  https://bitbucket.o ...
Looks nice
Did you ever thought of providing different CPU daughter boards with the same connectivity, for instance a daughter board equipped with an RK3288 processor? Or maybe later processors based on 64 bits ARM cores (Cortex A57 and A72)?
Thx
Posted at 6/9/2015 12:29:49        Only Author  4#
FesterBester38 Posted at 6/8/2015 16:34
Looks nice
Did you ever thought of providing different CPU daughter boards with the same con ...
FesterBester,
   I AGREE, but am not seeing  Sata, USB 3, and etc  need to be added also.  The 3288 has fallen through the "no more any support hole".  Newer chip soc's will be 64 bit (AMD),  x86, and etc. to be build compliant with the big chip Companies Hierarchies and also with new android Hierarchies which started with Android build 5.  I am not buying anything for awhile until "M" comes out and is on the shelf for awhile.  Tired of being left with no support for what I have and I do not like AMD and Intel their open source sucks past, now, and in the future.
  MSoft is still the same, asked for some files for their new RK adventure and was rewarded with a return E-Mail with all the licensing agreements reminding me to read them.  Open source is going good-bye fairly fast.
Posted at 7/19/2016 15:37:55        Only Author  5#
Dear Firefly
Could you recommended a JTAG debugger for Your Products, fireprime.
Because, Now We're developing a new products based on fireprime with Android 5.1.
We need to debugging and developing the Linux device driver.
Thank you.
Posted at 1/11/2026 15:00:38        Only Author  6#
Im so grateful for your article, it truly stayed with me. Excited but nervous for the Latest C_BCBTM_2509 exam practice exam. Hope I ace it!
Posted at 1/13/2026 00:37:10        Only Author  7#
This article has helped me look at the problem from different perspectives, and Ive gained a lot. Free C_THR94_2505 reliable test cram pdf exam resourcesyour gateway to promotions and higher pay!
