[General] WGU Scripting-and-Programming-Foundations Exam Questions - Easily Pass Your Exam
103
General WGU Scripting-and-Programming-Foundations Exam Questions - Easily Pass Your Exam
Posted at 1/25/2026 07:06:49      View154 | Replies0        Print      Only Author   [Copy Link] 1#
2026 Latest DumpsReview Scripting-and-Programming-Foundations PDF Dumps and Scripting-and-Programming-Foundations Exam Engine Free Share: https://drive.google.com/open?id=1qAEAQfHM2Q0ywaoR1tWWTUXuTP1zKRzY
The only aim of our company is to help each customer pass their exam as well as getting the important certification in a short time. If you want to pass your exam and get the Scripting-and-Programming-Foundations certification which is crucial for you successfully, I highly recommend that you should choose the Scripting-and-Programming-Foundations certification preparation materials from our company so that you can get a good understanding of the exam that you are going to prepare for. We believe that if you decide to buy the Scripting-and-Programming-Foundations Exam Materials from our company, you will pass your exam and get the certification in a more relaxed way than other people.
Investing in a WGU Scripting and Programming Foundations Exam (Scripting-and-Programming-Foundations) certification is essential for professionals looking to advance their careers and stay competitive in the job market. With our actual WGU Scripting-and-Programming-Foundations questions PDF, Scripting-and-Programming-Foundations practice exams along with the support of our customer support team, you can be confident that you are getting the best possible Scripting-and-Programming-Foundations Preparation material for the test. Download Real Scripting-and-Programming-Foundations questions today and start your journey to success.
Scripting-and-Programming-Foundations Reliable Braindumps Questions | Intereactive Scripting-and-Programming-Foundations Testing EngineIt is human nature to pursue wealth and success. No one wants to be a common person. In order to become a successful person, you must sharpen your horizons and deepen your thoughts. Our Scripting-and-Programming-Foundations practice guide can help you update yourself in the shortest time. And according to the data of our loyal customers, we can claim that if you study with our Scripting-and-Programming-Foundations Exam Questions for 20 to 30 hours, then you can pass the exam with ease. And the price of our Scripting-and-Programming-Foundations study materials is quite favourable.
WGU Scripting-and-Programming-Foundations Exam Syllabus Topics:
  • Scripting and Programming Foundations: This section of the exam measures the skills of Junior Software Developers and covers the essential building blocks of programming. It focuses on variables, data types, flow control, and basic design concepts. Learners understand how programming logic works and how different languages handle similar tasks. The section also introduces the difference between interpreted and compiled languages in a simple and practical way.
  • Using Fundamental Programming Elements: This section of the exam measures skills of Entry Level Programmers and covers the use of basic programming components required in everyday tasks. It includes working with variables, loops, conditions, and simple logic to perform common operations. The focus is on applying these elements correctly to complete small programming assignments in a clear and organized way.
  • Identifying Scripts for Computer Program Requirements: This section of the exam measures the skills of Junior Software Developers and covers the ability to match a task with the correct script or programming approach. It highlights how different scripts can satisfy specific requirements and how to recognize the right structure for a given programming problem.
  • Explaining Logic and Outcomes of Simple Algorithms: This section of the exam measures the skills of Entry Level Programmers and covers the ability to read simple algorithms and understand how they work. It focuses on predicting outputs, understanding step by step logic, and identifying how basic instructions create a final result. The goal is to help learners understand algorithm reasoning without requiring advanced coding knowledge.
WGU Scripting and Programming Foundations Exam Sample Questions (Q37-Q42):NEW QUESTION # 37
What is one task that could be accomplished using a while loop?
  • A. The user inputs an integer, and the program prints out whether the number is even or odd and whether the number is positive, negative, or zero.
  • B. When the user inputs a number, the program outputs "True" when the number is a multiple of 10.
  • C. A user is asked to enter a password repeatedly until either a correct password is entered or five attempts have been made.
  • D. After inputting two numbers, the program prints out the larger of the two.
A while loop repeatedly executes a block of code as long as a condition is true, making it suitable for tasks requiring iteration until a condition changes. According to foundational programming principles, while loops are ideal for scenarios with an unknown number of iterations or conditional repetition.
* Option A: "When the user inputs a number, the program outputs 'True' when the number is a multiple of
10." This is incorrect. This task requires a single check (number % 10 == 0), which can be done with an if statement, not a loop.
* Option B: "The user inputs an integer, and the program prints out whether the number is even or odd and whether the number is positive, negative, or zero." This is incorrect. This task involves a single input and multiple conditional checks, handled by if statements, not a loop.
* Option C: "After inputting two numbers, the program prints out the larger of the two." This is incorrect.
Comparing two numbers requires a single if statement (e.g., if (a > b)), not a loop.
* Option D: "A user is asked to enter a password repeatedly until either a correct password is entered or five attempts have been made." This is correct. This task requires repeated input until a condition is met (correct password or five attempts), which is ideal for a while loop. For example, in Python:
attempts = 0
while attempts < 5 and input("Password: ") != "correct":
attempts += 1
Certiport Scripting and Programming Foundations Study Guide (Section on Control Structures: Loops).
Python Documentation: "While Statements" (https://docs.python.org/3/reference/compound_stmts.
html#while).
W3Schools: "C While Loop" (https://www.w3schools.com/c/c_while_loop.php).
NEW QUESTION # 38
A program calculates the average miles per gallon given miles traveled and gas consumed How should the item that holds me miles per gallon be declared?
  • A. Variable float milesPerGallon
  • B. Constant float milesPerGallon
  • C. Constant float milesTraveled
  • D. Variable float milesTraveled
In a program that calculates the average miles per gallon based on miles traveled and gas consumed, the item that holds the miles per gallon should be declared as a variable because it will change depending on the input values. The data type should be a floating-point number (float) because miles per gallon is a value that can have a fractional part, and it is not a fixed value, hence it should not be a constant.
* Best practices in programming suggest using variables for values that change and constants for values that remain the same throughout the program execution.
* The concept of variables and data types is fundamental in programming and is covered in foundational programming documentation and textbooks.
NEW QUESTION # 39
What does the following algorithm determine?
  • A. Whether x is evenly divisible by 2 or 3
  • B. Whether x is even
  • C. Whether x r> negative. 0, <x positive
  • D. Whether x is odd
The algorithm provided in the image performs a modulo operation with 2 (x % 2) and checks if the result is 1.
In programming, the modulo operation gives the remainder of the division of two numbers. For any integer x, if x % 2 equals 1, it means that x is odd because it has a remainder of 1 when divided by 2. Even numbers, when divided by 2, have no remainder and thus would return 0 in a modulo 2 operation.
References: The explanation is based on the standard definition and behavior of the modulo operation in programming and mathematics. For more information on algorithms and their applications, you can refer to resources such as GeeksforGeeks1 and Built In2.
NEW QUESTION # 40
What does a function definition consist of?
  • A. A list of all other functions that call the function
  • B. An invocation of a function's name
  • C. The function's name, inputs, outputs, and statements
  • D. The function's argument values
A function definition is the blueprint for a block of code designed to perform a specific task. Here's what it includes:
* Function Name: A unique name to identify and call the function (e.g., calculate_area).
* Inputs (Parameters/Arguments): Values or variables passed into the function when it's called (e.g., width, height).
* Outputs (Return Value): The result the function produces after processing (e.g., the calculated area).
This value may or may not be explicitly returned.
* Statements (Function Body): Contains the code that performs the actions and calculations within the function.
NEW QUESTION # 41
Which expression evaluates to 14 if integer y = 13?
  • A. 11 + y % 5
  • B. 11 - y / 5.0
  • C. (11 + y) % 5
  • D. 11.0 - y / 5
To find an expression that evaluates to 14 when y = 13, let's evaluate each option:
A: 11 + y % 5: The modulo operation (%) gives the remainder after division. For y = 13, 13 % 5 equals 3.
Adding 11 to 3 results in 14, so this expression is correct.
B: 11 - y / 5.0: Dividing 13 by 5.0 gives 2.6. Subtracting 2.6 from 11 does not yield 14, so this expression is incorrect.
C: (11 + y) % 5: Adding 11 to 13 results in 24. Taking the modulo of 24 with 5 gives 4, which is not equal to
14. Therefore, this expression is incorrect.
D: 11.0 - y / 5: Dividing 13 by 5 gives 2.6. Subtracting 2.6 from 11.0 does not yield 14, so this expression is incorrect.
The correct expression is A. 11 + y % 5.
* Prealgebra: Simplifying and Evaluating Expressions With Integers
* MathPapa: Evaluating Expressions Using Algebra Calculator
* GeeksforGeeks: Expression Evaluation
NEW QUESTION # 42
If you have decided to participate in the WGU Scripting-and-Programming-Foundations exam, DumpsReview is here. We can help you achieve your goals. We know that you need to pass your WGU Scripting-and-Programming-Foundations Exam, we promise that provide high quality exam materials for you, Which can help you through WGU Scripting-and-Programming-Foundations exam.
Scripting-and-Programming-Foundations Reliable Braindumps Questions: https://www.dumpsreview.com/Scripting-and-Programming-Foundations-exam-dumps-review.html
