[Hardware] Firefly StationPC M2: UEFI
13
Hardware Firefly StationPC M2: UEFI
Posted at 4/13/2024 04:09:40      View5333 | Replies7        Print      Only Author   [Copy Link] 1#
Hi all!
I received my Firefly StationPC M2 a couple of days ago.
I want to install ESXi ARM on it, which is supported, see: Supported Devices
I already enabled the bootloader for this device and managed to install the ROC-RK3566 EFI image to an TFCard as described here using the pre-compiled image and it shows as boot device in the bootloader.
But I am unable to load the ESXi ARM installer from the USB key I created using balenaEtcher.
Over the serial console the following is displayed:
The device won't load the UEFI bios from the SD card but is detecting it and also detecting the USB stick I connected that contains the ESXi ARM installer.
The main issue seems to be that the device is not loading the UEFI bootloader from the SD card.
I downloaded the correct pre-compiled image version "
ROC-RK3566-PC_EFI.img.gz" from here, so it should work.
Can someone please tell me what am I doing wrong?
Why is the M2 not loading the UEFI FW from the SD card?
The device has a SPI NOR flash. Is it possible to install the UEFI to it?
Any other method to get an UEFI FW running?
Do I have to flash or modify something else on the device before?
Thanks and regards!
Posted at 4/15/2024 15:31:48        Only Author  2#
Hi all!
any advice on this?
It looks like the M2 is ignoring the SD card with the EDK2 UEFI and still loading some Android stuff, maybe related to Station OS.
Do I have to flash or enable something else first?
Any help would be much appreciated.
Thanks and regards
Posted at 4/15/2024 18:25:15        Only Author  3#
Hi all!
after some digging, I found the issue by myself.
By default, StationOS is on the internal eMMC. If this is the case, SD card WILL NOT BOOT without Multi Boot enabled.
So I disabled the bootloader again and now it is working.
The Firefly documentation explains it quite well:
Station M2 Multi Boot Function Supported List
https://wiki.stationpc.com/docs/stationpc/systembootloader
Hope this helps other people.
Posted at 3/6/2025 12:00:14        Only Author  4#
My raft wars are still not working, I don't understand why, although I have enabled Multi Boot, do you know the reason and how to fix it, please help me.
Posted at 1/14/2026 22:12:53        Only Author  5#
Im deeply thankful for your article, it really stood out to me. Get the C_S4CPR_2508 test discount questions that helped me succeed in my careerfor free today!
Posted at 1/20/2026 17:28:17        Only Author  6#
It was a real eye-opener. Good luck with your exam! Here are the free Valid exam FCP_FAZ_AD-7.4 practice materials.
Posted at 1/27/2026 14:42:35        Only Author  7#
ȫmԤθߤAmazonMLA-C01-JPN}؜ӥȤȤơҡϤ͘΂ھw֧BΰȫԤ^Ƥޤ顢ҡAmazonMLA-C01-JPN}ΤޤޤʥЩ`ĤُIǤޤNITԇYYϤФ뤫顢ʤτeAmazonMLA-C01-JPNԇYvĤĤʤ顢It-PassportsǤҪYϤ򌤤ͤꡢšTˆϤ碌ꤷƤޤ
Posted at 2/18/2026 01:05:17        Only Author  8#
I was truly inspired by what I read. Here comes the Reliable JN0-105 dumps sheet exam! Wish me luck and success!
