[General] 2026 High-quality 1Z0-1151-25: Oracle Cloud Infrastructure 2025 Multicloud Archi
93
General 2026 High-quality 1Z0-1151-25: Oracle Cloud Infrastructure 2025 Multicloud Archi
Posted at 1/13/2026 16:39:46      View175 | Replies2        Print      Only Author   [Copy Link] 1#
P.S. Free & New 1Z0-1151-25 dumps are available on Google Drive shared by Exams4sures: https://drive.google.com/open?id=1PeBRW4Yq4hxOvebaKjnlCr-uf-NiaXjD
Our company is trying to satisfy every customers demand. Of course, we also attach great importance on the quality of our 1Z0-1151-25 real test. Every product will undergo a strict inspection process. In addition, there will have random check among different kinds of 1Z0-1151-25 Study Materials. The quality of our 1Z0-1151-25 exam quiz deserves your trust. Most of our customers are willing to introduce their friends to purchase our 1Z0-1151-25 learning dumps.
Passing an Oracle Cloud Infrastructure 2025 Multicloud Architect Professional exam on the first attempt can be stressful, but Oracle 1Z0-1151-25 exam questions can help manage stress and allow you to perform at your best. We at Exams4sures give you the techniques and resources to make sure you get the most out of your exam study. We provide preparation material for the Oracle Cloud Infrastructure 2025 Multicloud Architect Professional exam that will guide you when you sit to study for it. 1Z0-1151-25 updated questions give you enough confidence to sit for the Oracle exam.
1Z0-1151-25 Flexible Learning Mode & 1Z0-1151-25 Reliable Test BootcampThe main key to passing the 1Z0-1151-25 exam is to use your time affectionately and grasp every topic so you can attempt the maximum number of questions in the actual 1Z0-1151-25 Exam. By studying the questions mentioned in the prep material, the candidates have control over the exam anxiety in no time.
Oracle Cloud Infrastructure 2025 Multicloud Architect Professional Sample Questions (Q52-Q57):NEW QUESTION # 52
Which OCI native database service can you provision with Oracle Database@Google Cloud?
  • A. HeatWave
  • B. Base Database Service
  • C. HeatWave
  • D. Autonomous Database on Dedicated Infrastructure
Oracle Database@Google Cloud is a multicloud service that integrates OCI database offerings into the Google Cloud Platform (GCP). According to official Oracle documentation, the Autonomous Database on Dedicated Infrastructure is a key service available in this offering. This service provides a fully managed database environment running on dedicated Exadata infrastructure, optimized for performance and isolation. The Base Database Service is a more basic offering not specifically highlighted in the Oracle Database@Google Cloud context, while HeatWave (listed twice in the original, corrected here as a single option) is a MySQL-focused analytics engine, not the primary native database service for this integration. The partnership between Oracle and Google Cloud, announced in June 2024, emphasizes Autonomous Database capabilities for enterprise workloads.
NEW QUESTION # 53
What is the purpose of the Autonomous System Number (ASN) in a BGP configuration?
  • A. It uniquely identifies your network to the internet routing system, allowing for proper routing of traffic.
  • B. It is used to authenticate the connection between your on-premises network and OCI.
  • C. It is used to encrypt the traffic traversing the connection.
  • D. It determines the bandwidth allocated to your connection.
Here's why:
Autonomous System Number (ASN): An ASN is a unique number assigned to an autonomous system (AS), which is a network or a group of networks under a common administration that has a consistent routing policy. In the context of BGP (Border Gateway Protocol), ASNs are used to identify each network participating in BGP routing. When you configure BGP for your FastConnect connection, you and Oracle each provide an ASN. This allows routers on both sides to exchange routing information and ensure that traffic is correctly routed between your on-premises network and your OCI VCN.
A). It is used to encrypt the traffic traversing the FastConnect connection: Encryption is handled by other mechanisms, such as IPsec VPNs (if used in conjunction with FastConnect) or encryption at the application layer. The ASN itself does not provide encryption.
C). It determines the bandwidth allocated to your FastConnect connection: The bandwidth of your FastConnect connection is determined by the service level you purchase from Oracle, not by the ASN.
D). It is used to authenticate the connection between your on-premises network and OCI: While BGP does have some built-in authentication mechanisms (like MD5 authentication), the primary purpose of the ASN is network identification for routing, not authentication. The FastConnect circuit itself is authenticated through other means.
NEW QUESTION # 54
A company is deploying multiple applications in Google Cloud and wants to access a centralized Oracle Exadata Database Service located in Oracle Database@Google Cloud. They want to ensure that the applications in different VPCs can securely communicate with the database without any direct peering between the application VPCs. Which network topology should the company use to securely connect applications in different VPCs to the centralized Oracle Exadata Database Service?
  • A. Mesh topology with VPC peering
  • B. Direct Connect between applications and Oracle Exadata Database Service
  • C. Flat topology with public IPs
  • D. Hub and spoke topology with a network virtual appliance (NVA) for centralized connectivity
A hub-and-spoke topology with a network virtual appliance (NVA) in GCP allows multiple application VPCs (spokes) to securely connect to a centralized Exadata Database Service (hub) without direct peering between VPCs. The NVA manages traffic and security. Direct Connect (Option B) isn't a GCP term here, mesh peering (Option C) requires inter-VPC connections, and flat topology (Option D) is insecure. Oracle's networking guide supports this topology for Database@Google Cloud.
NEW QUESTION # 55
Where can you obtain the Partner Service Key when setting up Oracle Interconnect for Azure?
  • A. From OCI when setting up the FastConnect virtual circuit
  • B. From OCI when creating the Dynamic Routing Gateway
  • C. From Microsoft when setting up a Site-to-Site VPN connection
  • D. From Microsoft when setting up the ExpressRoute circuit
Here's why:
The Partner Service Key is a crucial piece of information needed to establish the connection between Oracle Cloud Infrastructure (OCI) and Microsoft Azure using Oracle Interconnect. This key is specifically associated with the ExpressRoute circuit on the Azure side.
Here's a breakdown of the process and why the answer is B:
Setting up ExpressRoute in Azure: You first configure an ExpressRoute circuit in your Azure subscription. During this process, Microsoft generates a Service Key that uniquely identifies your ExpressRoute circuit.
Setting up FastConnect in OCI: When you configure FastConnect in OCI to connect to Azure, you need to provide this Service Key.1 This key tells OCI which ExpressRoute circuit in Azure to connect to.
From OCI when creating the Dynamic Routing Gateway: The Dynamic Routing Gateway (DRG) is an OCI component, but it doesn't provide the Service Key needed for the Azure connection.
From OCI when setting up the FastConnect virtual circuit: While you use the Service Key when setting up the FastConnect virtual circuit, you obtain it from Microsoft, not OCI.
From Microsoft when setting up a Site-to-Site VPN connection: A Site-to-Site VPN is a different type of connection and doesn't use the same Service Key mechanism as ExpressRoute and FastConnect.
NEW QUESTION # 56
In a disaster recovery scenario for Oracle Database@Azure using Data Guard, where would the standby database typically reside?
  • A. On a set of Azure Virtual Machines in the same Azure region.
  • B. In a different Azure region.
  • C. In a separate OCI region.
  • D. In a separate Availability Domain within the same Azure data center.
For a true disaster recovery scenario, the standby database needs to be geographically separated from the primary database to protect against region-wide outages. Since the Oracle database runs on Exadata infrastructure within OCI, the standby database would also reside on Exadata in a different OCI region. This provides the necessary redundancy and resilience in case the primary OCI region becomes unavailable. The other options are not suitable for a full DR scenario:
A different Azure region is irrelevant because the database itself is not running on Azure infrastructure.
Azure Virtual Machines are not used for the database tier in this architecture.
Availability Domains provide fault tolerance within the same region, not across region
NEW QUESTION # 57
Do you feel bored about current jobs and current life? Go and come to obtain a useful certificate! 1Z0-1151-25 study guide is the best product to help you achieve your goal. If you pass exam and obtain a certification with our 1Z0-1151-25 study materials, you can apply for satisfied jobs in the large enterprise and run for senior positions with high salary and high benefits. Excellent Oracle 1Z0-1151-25 Study Guide make candidates have clear studying direction to prepare for your test high efficiently without wasting too much extra time and energy.
1Z0-1151-25 Flexible Learning Mode: https://www.exams4sures.com/Oracle/1Z0-1151-25-practice-exam-dumps.html
Oracle 1Z0-1151-25 Flexible Learning Mode test Demo is free, so get your hands on it now, Most of them give us feedback that they have learnt a lot from our 1Z0-1151-25 test online and think it has a lifelong benefit, We offer you our 1Z0-1151-25 dumps torrent: Oracle Cloud Infrastructure 2025 Multicloud Architect Professional here for you reference, Oracle 1Z0-1151-25 Exam Questions Vce All the questions are compiled and verified by our professionals for several times checkout, Oracle 1Z0-1151-25 Exam Questions Vce Furthermore, we will do our best to provide best products with reasonable price and frequent discounts.
Each list widget represents a project, Scalable Authentic 1Z0-1151-25 Exam Hub Is Still) the New Fast, Oracle test Demo is free, so get your hands on it now, Most of them give us feedback that they have learnt a lot from our 1Z0-1151-25 Test Online and think it has a lifelong benefit.
Free PDF Quiz Oracle - 1Z0-1151-25 - Perfect Oracle Cloud Infrastructure 2025 Multicloud Architect Professional Exam Questions VceWe offer you our 1Z0-1151-25 dumps torrent: Oracle Cloud Infrastructure 2025 Multicloud Architect Professional here for you reference, All the questions are compiled and verified by our professionals for several times checkout.
Furthermore, we will do our best to 1Z0-1151-25 provide best products with reasonable price and frequent discounts.
2026 Latest Exams4sures 1Z0-1151-25 PDF Dumps and 1Z0-1151-25 Exam Engine Free Share: https://drive.google.com/open?id=1PeBRW4Yq4hxOvebaKjnlCr-uf-NiaXjD
Posted at 1/19/2026 16:29:24        Only Author  2#
This article is absolutely excellent, Im grateful for your share. Get free Cybersecurity-Practitioner reliable test sims to improve your IT knowledge. Wishing you all the best!
Posted at 2/5/2026 05:45:01        Only Author  3#
Clicking like instantlythis is fantastic. The Pass leader XSOAR-Engineer dumps test played a big part in my career growth, and Im offering it to you for free today!
