[General] Fortinet FCSS_SDW_AR-7.4 Web-Based Practice Exam Questions
89
【General】 Fortinet FCSS_SDW_AR-7.4 Web-Based Practice Exam Questions
Posted at 1/17/2026 15:26:47      View:146 | Replies:1        Print      Only Author   [Copy Link] 1#
2Pass4sure guarantee the best valid and high quality FCSS_SDW_AR-7.4 study guide which you won’t find any better one available. FCSS_SDW_AR-7.4 training pdf will be the right study reference if you want to be 100% sure pass and get satisfying results. From our FCSS_SDW_AR-7.4 free demo which allows you free download, you can see the validity of the questions and format of the FCSS_SDW_AR-7.4 actual test. In addition, the price of the FCSS_SDW_AR-7.4 dumps pdf is reasonable and affordable for all of you.
Fortinet FCSS_SDW_AR-7.4 Exam Syllabus Topics:
  • SD-WAN Troubleshooting: This part assesses the troubleshooting skills of network support specialists. Candidates should be able to diagnose and resolve issues related to SD-WAN rules, session behaviors, routing inconsistencies, and ADVPN connectivity problems to maintain seamless network operations.
  • Centralized Management: This domain evaluates network administrators’ competence in deploying and managing SD-WAN configurations centrally using FortiManager. It includes tasks such as implementing branch configurations and utilizing overlay templates to streamline network management.
  • Configure Performances SLAs: Designed for network administrators, this part focuses on setting up performance Service Level Agreements (SLAs) within SD-WAN environments. Candidates must show proficiency in defining criteria to monitor and maintain network performance and reliability.
  • Advanced IPsec: Intended for security engineers, this section covers the deployment of advanced IPsec topologies for SD-WAN, including hub-and-spoke models, ADVPN configurations, and complex multi-hub or multi-region deployments. Candidates need to demonstrate expertise in securing wide-area networks using IPsec technologies.
Fortinet FCSS_SDW_AR-7.4 Exam Sample Questions - FCSS_SDW_AR-7.4 Reliable Test SimsThe passing rate of our FCSS_SDW_AR-7.4 guide materials is high as 98% to 100% and you don’t need to worry that you have spent money but can’t pass the test. We can’t list all the advantages with several words and please read the introduction of the features and advantages of our FCSS_SDW_AR-7.4 training quiz in detail on the website. You will find that every button on the page is fast and convenient to use. And we also have the free demos of the FCSS_SDW_AR-7.4 exam questions for you to download before purchase.
Fortinet FCSS - SD-WAN 7.4 Architect Sample Questions (Q59-Q64):NEW QUESTION # 59
In which SD-WAN template field can you use a metadata variable?
  • A. All SD-WAN template fields support metadata variables.
  • B. Any field identified with an "M" in a circle.
  • C. You can use metadata variables only to define interface members and the gateway IP.
  • D. Any field identified with a dollar sign (S) in a magnifying glass.
NEW QUESTION # 60
An administrator is troubleshooting SD-WAN on FortiGate. A device behind branch1_fgt generates traffic to the 10.0.0.0/8 network.
The administrator expects the traffic to match SD-WAN rule ID 1 and be routed over HUB1-VPN1. However, the traffic is routed over HUB1-VPN3.
Based on the output shown in the exhibit, which two reasons, individually or together, could explain the observed behavior? (Choose two.)
  • A. HUB1-VPN3 has a higher member configuration priority than HUB1-VPN1.
  • B. The traffic matches a regular policy route configured with HUB1-VPN3 as the outgoing device
  • C. HUB1-VPN3 has a lower route priority value (higher priority) than HUB1-VPN1.
  • D. HUB1-VPN1 does not have a valid route to the destination
NEW QUESTION # 61
You have a FortiGate configuration with three user-defined SD-WAN zones and two members in each of these zones. One SD-WAN member is no longer in use in health-check and SD-WAN rules. You want to delete it.
What happens if you delete the SD-WAN member from the FortiGate GUI?
  • A. FodiGate accepts the deletion and removes routes as required.
  • B. FortiGate displays an error message. SD-WAN zones must contain at least two members
  • C. FortiGate displays an error message. You must use the CLI to delete an SD-WAN member.
  • D. FortiGate accepts the deletion and places the member in the default SD-WAN zone.
NEW QUESTION # 62
Refer to the exhibits.
The exhibits show the source NAT (SNAT) global setting. port2 interface settings, and the routing table on FortiGate.
The administrator increases the member priority on port2 to 20.
Upon configuration changes and the receipt of new packets, which two actions does FortiGate perform on existing sessions established over port2? (Choose two.)
  • A. FortiGate continues routing all existing sessions over port2.
  • B. FortiGate routes only new sessions over port2.
  • C. FortiGate updates the gateway information of the sessions with SNAT so that they use port1 instead of port2.
  • D. FortiGate flags the SNAT session as dirty only if the administrator has assigned an IP pool to the firewall policies with NAT.
  • E. FortiGate flags the sessions as dirty.
Answer: C,E
NEW QUESTION # 63
What are three key routing principles of SD-WAN? (Choose three.)
  • A. SD-WAN rules are skipped if the best route to the destination is a static route
  • B. SD-WAN members are skipped if they do not have a valid route to the destination.
  • C. Policy routes have precedence over SD-WAN rules.
  • D. Directly connected routes have precedence over SD-WAN rules.
  • E. SD-WAN rules are skipped if the best route to the destination is not an SD-WAN member.
Answer: B,C,E
NEW QUESTION # 64
We check the updating of Fortinet exam dumps everyday to make sure customer to pass the exam with latest vce dumps. Once the latest version of FCSS_SDW_AR-7.4 exam pdf released, our system will send it to your mail immediately. You will be allowed to free update your FCSS_SDW_AR-7.4 Top Questions one-year after purchased. Please feel free to contact us if you have any questions about our dumps.
FCSS_SDW_AR-7.4 Exam Sample Questions: https://www.2pass4sure.com/Fortinet-Certified-Solution-Specialist/FCSS_SDW_AR-7.4-actual-exam-braindumps.html
Posted at 1/28/2026 02:18:32        Only Author  2#
What an incredible read, thank you for this outstanding article. My promotion and raise were made possible by the Valid CV0-004 mock exam questions—today, I’m sharing them with you at no cost!
