Test Nokia 4A0-D01 Online - Best 4A0-D01 Study Material
Posted at 1/15/2026 16:43:59
P.S. Free & New 4A0-D01 dumps are available on Google Drive shared by PassCollection: https://drive.google.com/open?id=1-B-P4t5Xc0PDMJpuweMwBWPZSFmqS-B3
The Nokia 4A0-D01 PDF format is printable which enables you to do paper study. It contains pool of actual and updated Nokia Data Center Fabric Fundamentals Exam (4A0-D01) exam questions. You can carry this portable file of Nokia 4A0-D01 Real Questions to any place via smartphones, laptops, and tablets. This simple and convenient format of PassCollection's Nokia Data Center Fabric Fundamentals Exam (4A0-D01) practice material is being updated regularly.
It helps you to pass the Nokia 4A0-D01 test with excellent results. Nokia 4A0-D01 imitates the actual 4A0-D01 exam environment. You can take the 4A0-D01 practice exam many times to evaluate and enhance your Nokia 4A0-D01 Exam Preparation level. Desktop 4A0-D01 practice test software is compatible with windows and the web-based software will work on these operating systems: Android, IOS, Windows, and Linux.
New Launch 4A0-D01 PDF Dumps [2026] - Nokia 4A0-D01 Exam QuestionsThe second format is a web-based format that can be accessed from browsers like Firefox, Microsoft Edge, Chrome, and Safari. It means you don't need to download or install any software or plugins to take the Nokia Data Center Fabric Fundamentals Exam practice test. The web-based format of the Nokia 4A0-D01 Certification Exams practice test supports all operating systems. The third and last format is desktop software format which can be accessed after installing the software on your Nokia Data Center Fabric Fundamentals Exam (4A0-D01) Windows Pc or Laptop. These formats are built especially for the students so they don't stop preparing for the Nokia Data Center Fabric Fundamentals Exam (4A0-D01) certification.
Nokia 4A0-D01 Exam Syllabus Topics:| Topic | Details | | Topic 1 | - SR Linux Configuration and Routing: This section of the exam measures skills of a Network Automation Specialist and focuses on configuring and managing SR Linux systems. It examines the YANG-driven CLI, JSON output, environment variables, and static and dynamic routing. Learners also explore BGP, ECMP, IP-VRF, MAC-VRF, and the use of VXLAN with EVPN to implement both Layer 2 and Layer 3 overlays, including symmetric and asymmetric models.
| | Topic 2 | - This section of the exam measures skills of a Network Automation Specialist and introduces the principles of Event Driven Automation in SR Linux environments. It covers integration with Kubernetes and explores core use cases such as intent-based automation for fabrics and services, as well as enhanced network observability.
| | Topic 3 | - SR Linux User and System Management: This section of the exam measures skills of a Network Automation Specialist and includes managing user roles, TLS configurations for secure communication, and automation features like Zero-Touch Provisioning (ZTP). It covers ZTP setup, configuration processes, and common issues that may arise during deployment.
| | Topic 4 | - Module 5 – EDA (Event Driven Automation) Introduction
| | Topic 5 | - Nokia DC Fabric Solution: This section of the exam measures skills of a Data Center Network Engineer and covers the architecture and benefits of modern Layer 3 data center networks. It includes an overview of BGP-based routing, VXLAN and EVPN overlays for multi-tenant environments, and key features of the SR Linux operating system. The section also explains how APIs are used for external configuration and introduces the Fabric Services System's management capabilities.
Nokia Data Center Fabric Fundamentals Exam Sample Questions (Q34-Q39):NEW QUESTION # 34
Which of the following statements about the MAC table shown in the exhibit output is FALSE?
- A. Mac-duplication detection is enabled in mac-vrf-1.
- B. The MAC re-learning rate has exceeded the threshold within the specified time frame.
- C. The MAC address 00:25: BA:00:00:10 is learnt on more than one interface.
- D. [interface ethernet-1/10 is configured with the MAC address 00:25:BA:00:00:10.
The MAC address 00:25:BA:00:00:10 is listed as "duplicate," but it appears only once associated with interface ethernet-1/10. Therefore, it is not learned on more than one interface.
NEW QUESTION # 35
Examine the exhibit. Which of the following statements is TRUE?
- A. A recursive lookup is performed to resolve 10.1.1.0 to use 10.2.1.0.
- B. The next-hop selected for this route will be based on the preference value configured for each next-hop.
- C. The next-hop group for this static route is configured with two next-hops.
- D. A recursive lookup is performed to resolve 10.2.1.0 to use 10.1.1.0.
The static route shows two next-hop IP addresses (10.1.1.0 and 10.2.1.0) listed, indicating that a next-hop group with multiple next-hops is configured for load balancing or redundancy.
NEW QUESTION # 36
A static route is configured in two steps in Nokia's SR Linux. Which of the following items CANNOT be configured in the static-routes container?
- A. Next-hop group
- B. IPv4 destination prefix
- C. blackhole
- D. Preference value
The static-routes container in Nokia SR Linux does not support configuring a blackhole route directly; it is used to configure destination prefixes, preference values, and next-hop groups for static routing.
NEW QUESTION # 37
How does Nokia's Fabric Services System use a fabric intent to build the DC switch fabric?
- A. It uses a digital sandbox to connect workloads to the DC fabric.
- B. It uses a YAML file that defines the intended configuration state of the DC fabric.
- C. It uses a digital sandbox to build the configuration files for the DC fabric.
- D. It uses telemetry data to build the configuration files for the DC fabric.
Nokia's Fabric Services System uses a fabric intent defined in a declarative YAML file to specify the desired state of the data center fabric, which is then used to build and configure the fabric accordingly.
NEW QUESTION # 38
Which of the following Nokia's SR Linux ACLs is instantiated on all line cards to copy incoming packets to the CPM?
- A. Ingress ACL
- B. Capture-filter ACL
- C. CPM-filter ACL
- D. Egress ACL
The CPM-filter ACL is instantiated on all line cards in Nokia's SR Linux to copy incoming packets to the Control Plane Manager (CPM) for processing.
NEW QUESTION # 39
To gain a full understanding of our product please firstly look at the introduction of the features and the functions of our 4A0-D01 exam torrent. The page of our product provide the demo and the aim to provide the demo is to let the you understand part of our titles before their purchase and see what form the software is after the you open it. The client can visit the page of our product on the website. So the client can understand our 4A0-D01 Quiz torrent well and decide whether to buy our product or not at their wishes. The client can see the forms of the answers and the titles.
Best 4A0-D01 Study Material: https://www.passcollection.com/4A0-D01_real-exams.html
