[General] I can not connect to board
44
General I can not connect to board
Posted at 1/24/2024 13:55:39      View3450 | Replies7        Print      Only Author   [Copy Link] 1#
  • Type: Official Firmware
  • Filename: no file
  • Download Address: no file
  • Log: boot.zip
Hi,
Debug port on AIO-1126-JD4 board is UART, 3.3 Volt.
It is written in Wiki that:  Set the baud rate to the 1.5 M !!!
In the attached image, You can see my minicom configs. But I can't communicate with the boar yet !
I can't even connect to the board via LAN  (SSH, 192.168.22.33).
I don't know how to find out if it's Debian on my board or something else.
boot.zip
100.73 KB, Down times: 1
Posted at 2/10/2024 01:35:49        Only Author  2#
With USB-to-TTL with CH340 IC, my problem solved.
Posted at 1/22/2025 19:16:50        Only Author  3#
did you connected with ssh? and how you learn the ip adress of card,?
Posted at 1/9/2026 07:55:23        Only Author  4#
Your article was truly stunning, thank you for sharing! Best of luck! Heres the free Latest test L6M3 cram review test content for everyone.
restricted members
Posted at 1/16/2026 04:02:10        Only Author  5#
Your article was incredibly refreshing and inspiring, thank you! Here are the free Reliable SAFe-Practitioner real test question questions. Wishing you all the best for your exams!
restricted members
Posted at 1/20/2026 19:26:52        Only Author  6#
Im genuinely grateful for your share, this article is fantastic! Thanks to the Reliable N16291GC10 exam answers exam, I reached a new level in my career. Now Im sharing it for free with all of you!
Posted at 2/1/2026 02:13:48        Only Author  7#
This article has helped me understand related concepts better, and Ive gained a lot. I used the PRINCE2-Agile-Foundation valid study questions to get promoted and get a pay raise. Now its free to all. I hope you all get promoted soon!
Posted at 2/22/2026 23:58:05        Only Author  8#
DumpTOP의 제품을 구매하시면 우리는 일년무료업데이트 서비스를 제공함으로 여러분을 인증시험을 패스하게 도와줍니다. 만약 인증시험내용이 변경이 되면 우리는 바로 여러분들에게 알려드립니다.그리고 최신버전이 있다면 바로 여러분들한테 보내드립니다. DumpTOP는 한번에Cisco 300-745인증시험을 패스를 보장합니다.
