[Hardware] GitHub GitHub-Advanced-Security認定試験で困っているのか
101
【Hardware】 GitHub GitHub-Advanced-Security認定試験で困っているのか
Posted at 1/24/2026 17:40:21      View:231 | Replies:0        Print      Only Author   [Copy Link] 1#
2026年CertJukenの最新GitHub-Advanced-Security PDFダンプおよびGitHub-Advanced-Security試験エンジンの無料共有:https://drive.google.com/open?id=16W9_GaUQBaHMkUDheR4aOQeLyoxGNA6E
あなたのGitHubのGitHub-Advanced-Security認証試験に合格させるのはCertJukenが賢明な選択で購入する前にインターネットで無料な問題集をダウンロードしてください。そうしたらあなたがGitHubのGitHub-Advanced-Security認定試験にもっと自信を増加して、もし失敗したら、全額で返金いたします。
GitHub GitHub-Advanced-Security 認定試験の出題範囲:
トピック出題範囲
トピック 1
  • Describe GitHub Advanced Security best practices: This section of the exam measures skills of a GitHub Administrator and covers outlining recommended strategies for adopting GitHub Advanced Security at scale. Test?takers will explain how to apply security policies, enforce branch protections, shift left security checks, and use metrics from GHAS tools to continuously improve an organization’s security posture.
トピック 2
  • Configure and use dependency management: This section of the exam measures skills of a DevSecOps Engineer and covers configuring dependency management workflows to identify and remediate vulnerable or outdated packages. Candidates will show how to enable Dependabot for version updates, review dependency alerts, and integrate these tools into automated CI
  • CD pipelines to maintain secure software supply chains.
トピック 3
  • Configure GitHub Advanced Security tools in GitHub Enterprise: This section of the exam measures skills of a GitHub Administrator and covers integrating GHAS features into GitHub Enterprise Server or Cloud environments. Examinees must know how to enable advanced security at the enterprise level, manage licensing, and ensure that scanning and alerting services operate correctly across multiple repositories and organizational units.
トピック 4
  • Configure and use secret scanning: This section of the exam measures skills of a DevSecOps Engineer and covers setting up and managing secret scanning in organizations and repositories. Test?takers must demonstrate how to enable secret scanning, interpret the alerts generated when sensitive data is exposed, and implement policies to prevent and remediate credential leaks.
トピック 5
  • Configure and use code scanning: This section of the exam measures skills of a DevSecOps Engineer and covers enabling and customizing GitHub code scanning with built?in or marketplace rulesets. Examinees must know how to interpret scan results, triage findings, and configure exclusion or override settings to reduce noise and focus on high?priority vulnerabilities.
GitHub-Advanced-Securityトレーニング & GitHub-Advanced-Security日本語問題集GitHub-Advanced-Security試験問題の更新を1年以内にクライアントに無料で提供し、1年後にクライアントは50%の割引を受けることができます。クライアントが古いクライアントの場合、一定の割引を享受できます。当社GitHubの専門家は、毎日GitHub-Advanced-Securityガイドトレントを更新し、GitHub-Advanced-Securityスタディガイドの最新の更新をクライアントに提供します。私たちはクライアントに割引を提供し、彼らがより少ないお金を使うようにします。あなたが古いクライアントである場合、あなたは特別割引を享受することができますので、お金を節約することができます。したがって、GitHub-Advanced-Securityテストトレントを購入することは非常に価値があります。
GitHub Advanced Security GHAS Exam 認定 GitHub-Advanced-Security 試験問題 (Q62-Q67):質問 # 62
What is a security policy?
  • A. A file in a GitHub repository that provides instructions to users about how to report a security vulnerability
  • B. An alert about dependencies that are known to contain security vulnerabilities
  • C. A security alert issued to a community in response to a vulnerability
  • D. An automatic detection of security vulnerabilities and coding errors in new or modified code
A security policy is defined by a SECURITY.md file in the root of your repository or .github/ directory. This file informs contributors and security researchers about how to responsibly report vulnerabilities. It improves your project's transparency and ensures timely communication and mitigation of any reported issues.
Adding this file also enables a "Report a vulnerability" button in the repository's Security tab.
質問 # 63
Which patterns are secret scanning validity checks available to?
  • A. Push protection patterns
  • B. High entropy strings
  • C. Partner patterns
  • D. Custom patterns
Validity checks- where GitHub verifies if a secret is still active - are available forpartner patternsonly.
These are secrets issued by GitHub's trusted partners (like AWS, Slack, etc.) and have APIs for GitHub to validate token activity status.
Custom patterns and high entropy patterns donotsupport automated validity checks.
質問 # 64
When secret scanning detects a set of credentials on a public repository, what does GitHub do?
  • A. It sends a notification to repository members.
  • B. It scans the contents of the commits for additional secrets.
  • C. It displays a public alert in the Security tab of the repository.
  • D. It notifies the service provider who issued the secret.
When apublic repositorycontains credentials that match known secret formats, GitHub willautomatically notify the service providerthat issued the secret. This process is known as"secret scanning partner notification". The provider may then revoke the secret or contact the userdirectly.
GitHub doesnotpublicly display the alert and does not send internal repository notifications for public detections.
質問 # 65
What does a CodeQL database of your repository contain?
  • A. A build of the code and extracted data
  • B. A representation of all of the source code GitHub Agentic AI for AppSec Teams
  • C. A build for Go projects to set up the project
  • D. Build commands for C/C++, C#, and Java
A CodeQL database contains a representation of your codebase, including the build of the code and extracted data. This database is used to run CodeQL queries to analyze your code for potential vulnerabilities and errors.
GitHub Docs
質問 # 66
Who can fix a code scanning alert on a private repository?
  • A. Users who have Read permissions within the repository
  • B. Users who have the Triage role within the repository
  • C. Users who have the security manager role within the repository
  • D. Users who have Write access to the repository
In private repositories, users with write access can fix code scanning alerts. They can do this by committing changes that address the issues identified by the code scanning tools. This level of access ensures that only trusted contributors can modify the code to resolve potential security vulnerabilities.
GitHub Docs
Users with read or triage roles do not have the necessary permissions to make code changes, and the security manager role is primarily focused on managing security settings rather than directly modifying code.
質問 # 67
クライアントが当社のGitHub-Advanced-Securityガイド資料の習熟度を理解し、テストの準備を整えるために、テストプラクティスソフトウェアをクライアントに提供します。 GitHub-Advanced-Security実践ガイドのテスト実践ソフトウェアは、実際のテスト問題に基づいており、そのインターフェースは使いやすいです。テスト練習ソフトウェアは、実際のテストを刺激し、複数の練習モデル、GitHub-Advanced-Securityトレーニング教材の練習の履歴記録、自己評価機能を高めるテストスキームを向上させます。
GitHub-Advanced-Securityトレーニング: https://www.certjuken.com/GitHub-Advanced-Security-exam.html
さらに、CertJuken GitHub-Advanced-Securityダンプの一部が現在無料で提供されています:https://drive.google.com/open?id=16W9_GaUQBaHMkUDheR4aOQeLyoxGNA6E
