Free PDF 2026 Efficient Amazon SOA-C03 Exam Cram Review
100
Posted at 2/16/2026 09:12:34      View:148 | Replies:2        Print      Only Author   [Copy Link] 1#
P.S. Free & New SOA-C03 dumps are available on Google Drive shared by Test4Cram: https://drive.google.com/open?id=1GvvD9WjLlluWY73mO-lBB1eH3F1nxFIY
Obtaining an IT certification shows you are an ambitious individual who is always looking to improve your skill set. Most companies think highly of this character. Our SOA-C03 exam original questions will help you clear exam certainly in a short time. You don't need to worry about how difficulty the exams are. Test4Cram release the best high-quality SOA-C03 Exam original questions to help you most candidates pass exams and achieve their goal surely.
Test4Cram provides you with actual Amazon SOA-C03 dumps in PDF format, Desktop-Based Practice tests, and Web-based Practice exams. These 3 formats of AWS Certified CloudOps Engineer - Associate exam preparation are easy to use. This is a printable Amazon SOA-C03 PDF dumps file. The Amazon SOA-C03 Pdf Dumps enables you to study without any device, as it is a portable and easily shareable format, thus you can study Amazon SOA-C03 dumps on your preferred smart device such as your smartphone or in hard copy format.
Amazing SOA-C03 Exam Simulation: AWS Certified CloudOps Engineer - Associate give you the latest Practice Dumps - Test4CramTime and tides wait for no man. Take away your satisfied SOA-C03 preparation quiz and begin your new learning journey. You will benefit a lot after you finish learning our SOA-C03 study materials just as our other loyal customers. Live in the moment and bravely attempt to totally new things. You will harvest meaningful knowledge as well as the shining SOA-C03 Certification that so many candidates are dreaming to get.
Amazon AWS Certified CloudOps Engineer - Associate Sample Questions (Q65-Q70):NEW QUESTION # 65
A SysOps administrator monitors and maintains the availability of resources in an AWS environment. The SysOps administrator notices that the CPU utilization of an Amazon EC2 instance that runs web server software peaks above 80% at various times during each day. The CPU spikes correlate with peak daily loads.
The high CPU load has resulted in performance issues for customers.
The SysOps administrator needs to resolve the system performance issue without causing any service disruptions. Which solution will meet these requirements?
  • A. Configure an Amazon CloudWatch alarm that invokes an AWS Systems Manager Automation runbook to vertically scale the EC2 instance when the CPU utilization exceeds 80%.
  • B. Set up an Auto Scaling group with an Amazon CloudWatch alarm that triggers a scaling policy to launch additional EC2 instances when the CPU utilization exceeds 80%.
  • C. Configure an AWS Systems Manager Automation runbook to run a script that automatically restarts the application when CPU utilization exceeds 80%.
  • D. Configure an Amazon EventBridge rule that invokes an AWS Systems Manager Automation document.
    Configure the document to increase the EC2 instance size when CPU utilization exceeds 80%.
Comprehensive and Detailed Explanation From Exact Extract of AWS CloudOps Documents:
The requirement is to fix performance degradation from predictable peak CPU load without service disruptions. The most reliable and operationally standard approach is horizontal scaling with an Auto Scaling group driven by CloudWatch metrics/alarms (or target tracking). Launching additional instances and distributing traffic (typically behind a load balancer) increases capacity while keeping existing instances serving requests-no reboot or stop/start required.
Option D meets the requirement because Auto Scaling can add capacity when CPU exceeds a threshold and remove capacity when demand falls. This improves performance during peak periods and maintains availability. It is also operationally efficient: scaling actions are automated, consistent, and can be tuned with cooldowns/health checks.
Options A and C describe vertical scaling (instance resize). Resizing an EC2 instance type generally requires stopping the instance, changing the type, and starting it again-this is disruptive for a single-instance web server and often causes downtime. Option B (restarting the application) directly introduces disruption and does not address underlying capacity constraints; it can also worsen customer impact during peaks.
Amazon EC2 Auto Scaling User Guide - Scaling policies and CloudWatch integration Amazon CloudWatch User Guide - Alarms triggering Auto Scaling actions AWS Well-Architected Framework - Performance Efficiency and Reliability guidance
NEW QUESTION # 66
Application A runs on Amazon EC2 instances behind a Network Load Balancer (NLB). The EC2 instances are in an Auto Scaling group and are in the same subnet that is associated with the NLB. Other applications from an on-premises environment cannot communicate with Application A on port 8080.
To troubleshoot the issue, a CloudOps engineer analyzes the flow logs. The flow logs include the following records:
ACCEPT from 192.168.0.13:59003 → 172.31.16.139:8080
REJECT from 172.31.16.139:8080 → 192.168.0.13:59003
What is the reason for the rejected traffic?
  • A. The security group of the EC2 instances has no Allow rule for the traffic from the NLB.
  • B. The security group of the NLB has no Allow rule for the traffic from the on-premises environment.
  • C. The network ACL that is associated with the subnet does not allow outbound traffic for the ephemeral port range.
  • D. The ACL of the on-premises environment does not allow traffic to the AWS environment.
Comprehensive and Detailed Explanation From Exact Extract of AWS CloudOps Doocuments:
VPC Flow Logs show the request arriving and being ACCEPTed on dstport 8080 and the corresponding response being REJECTed on the return path to the client's ephemeral port (59003). AWS networking guidance states that security groups are stateful (return traffic is automatically allowed) while network ACLs are stateless and require explicit inbound and outbound rules for both directions. CloudOps operational guidance for VPC networking further notes that when you allow an inbound request (for example, TCP 8080) through a subnet's network ACL, you must also allow the outbound ephemeral port range (typically 1024-65535) for the response traffic; otherwise, the return packets are dropped and appear as REJECT in flow logs. The observed pattern-request accepted to 8080, response rejected to 59003-matches a missing outbound ephemeral-range allow on the subnet's NACL. Therefore, the cause is the subnet NACL, not security groups or on-premises ACLs. The remediation is to add an outbound ALLOW rule on the NACL for the appropriate ephemeral TCP port range back to the on-premises CIDR (and the corresponding inbound rule if asymmetric).
References (AWS CloudOps documents / Study Guide):
* AWS Certified CloudOps Engineer - Associate (SOA-C03) Exam Guide - Networking and Content Delivery
* Amazon VPC - Network ACLs (stateless behavior and rule requirements)
* Amazon VPC - Security Groups (stateful return traffic)
* VPC Flow Logs - Record fields, ACCEPT/REJECT analysis
NEW QUESTION # 67
A company runs several workloads on AWS. The company identifies five AWS Trusted Advisor service quota metrics to monitor in a specific AWS Region. The company wants to receive email notifications each time resource usage exceeds 60% of one of the service quotas.
  • A. Use the AWS Health Dashboard to monitor each Trusted Advisor service quota metric. Configure an Amazon SQS queue for email notification.
  • B. Use the AWS Health Dashboard to monitor each Trusted Advisor service quota metric. Configure an Amazon SNS topic for email notification.
  • C. Create five Amazon CloudWatch alarms, one for each Trusted Advisor service quota metric. Configure an Amazon Simple Notification Service (Amazon SNS) topic for email notification each time that usage exceeds 60% of one of the service quotas.
  • D. Create five Amazon CloudWatch alarms, one for each Trusted Advisor service quota metric. Configure an Amazon Simple Queue Service (Amazon SQS) queue for email notification.
Comprehensive Explanation (250-350 words):
AWS Trusted Advisor publishes service quota metrics to Amazon CloudWatch. These metrics can be monitored using CloudWatch alarms, which support threshold-based alerting. By creating a CloudWatch alarm for each service quota metric, the CloudOps engineer can trigger alerts when usage exceeds 60%.
Amazon SNS is the AWS-native service for email notifications. CloudWatch alarms integrate directly with SNS, making this the most straightforward solution. SNS supports email subscriptions without additional infrastructure.
Options B and C incorrectly use SQS for email notifications, which requires additional processing and does not natively send emails. Option D relies on the AWS Health Dashboard, which does not support configurable threshold-based alerts for service quotas.
Therefore, CloudWatch alarms combined with SNS provide the correct and most efficient solution.
NEW QUESTION # 68
A CloudOps engineer must manage the security of an AWS account. Recently, an IAM user's access key was mistakenly uploaded to a public code repository. The engineer must identify everything that was changed using this compromised key.
How should the CloudOps engineer meet these requirements?
  • A. Search VPC Flow Logs for all events initiated with the compromised access key within the suspected timeframe.
  • B. Create an Amazon EventBridge rule to send all IAM events to an AWS Lambda function for analysis.
  • C. Search AWS CloudTrail event history for all events initiated with the compromised access key within the suspected timeframe.
  • D. Query Amazon EC2 logs by using Amazon CloudWatch Logs Insights for all events initiated with the compromised access key within the suspected timeframe.
According to the AWS Cloud Operations and Security documentation, AWS CloudTrail is the authoritative service for recording API activity across all AWS services within an account.
When an access key is compromised, CloudTrail logs all API requests made using that key, including details such as:
* The user identity (access key ID) that made the request,
* The service, operation, resource, and timestamp affected, and
* The source IP address and region of the request.
By searching the CloudTrail event history for the specific access key ID, the CloudOps engineer can identify every action performed by that key during the suspected breach window.
Other options are incorrect:
* EventBridge (A) is event-driven, not historical.
* CloudWatch Logs (B) monitors system logs, not AWS API activity.
* VPC Flow Logs (D) track network-level traffic, not API calls.
Therefore, the correct solution is Option C - using AWS CloudTrail event history to audit and trace all actions executed via the compromised access key.
Reference: AWS Cloud Operations & Security Management Guide - Investigating Compromised Access Keys Using AWS CloudTrail
NEW QUESTION # 69
A web application runs on Amazon EC2 instances in the us-east-1 Region and the us-west-2 Region. The instances run behind an Application Load Balancer (ALB) in each Region. An Amazon Route 53 hosted zone controls DNS records.
The instances in us-east-1 are production resources. The instances in us-west-2 are for disaster recovery. EC2 Auto Scaling groups are configured based on the ALBRequestCountPerTarget metric in both Regions.
A SysOps administrator must implement a solution that provides failover from us-east-1 to us-west-2. The instances in us-west-2 must be used only for failover.
  • A. Implement a Route 53 health check and a failover routing policy for the hosted zone. Configure the failover routing policy to automatically redirect traffic to the resources in us-west-2.
  • B. Implement a Route 53 health check and a latency routing policy for the hosted zone. Configure the latency routing policy to automatically redirect traffic to the resources in us-west-2.
  • C. In us-east-1, create an Amazon CloudWatch alarm that enters ALARM state when an EC2 instance is terminated. In us-west-2, create an AWS Lambda function that modifies the Route 53 hosted zone records to send traffic to us-west-2. Configure the CloudWatch alarm to invoke the Lambda function.
  • D. In us-west-2, create an Amazon CloudWatch alarm that enters ALARM state when resources in us-east-
    1 cannot be resolved. In us-west-2, create an AWS Lambda function that modifies the Route 53 hosted zone records to send traffic to us-west-2. Configure the CloudWatch alarm to invoke the Lambda function.
The requirement is classic active-passive (production in us-east-1, DR in us-west-2 "only for failover"). The most operationally efficient and purpose-built solution is Route 53 failover routing combined with health checks. With failover routing, Route 53 designates one record as PRIMARY (us-east-1) and another as SECONDARY (us-west-2). Route 53 continuously evaluates the health check associated with the primary endpoint (commonly the ALB DNS name or a specific health-check path). If the primary fails, Route 53 automatically returns the secondary record, directing client DNS resolution to the DR region. This ensures us- west-2 is used only when us-east-1 is unhealthy, directly matching the requirement.
Latency routing (Option B) is designed to route users to the region with the lowest latency, which can actively send traffic to us-west-2 even when us-east-1 is healthy-violating the "DR only" constraint. Options C and D introduce custom automation (CloudWatch + Lambda + DNS record updates) that increases operational overhead, adds failure modes, and is unnecessary because Route 53 already provides managed health-check- based failover. Additionally, "EC2 instance terminated" is not a reliable proxy for full application availability, and DNS modification automation is more complex than using native Route 53 failover policies.
Amazon Route 53 Developer Guide - Health checks and failover routing policy AWS Well-Architected Framework - Reliability pillar (failover, DR patterns) AWS SysOps Administrator Study Guide - DNS failover and Route 53 routing policies
NEW QUESTION # 70
The latest SOA-C03 exam prep is created by our IT experts and certified trainers who are dedicated to Amazon braindumps pdf for a long time. All questions of our SOA-C03 PDF VCE are written based on the real questions. Besides, we always check the updating of SOA-C03 exam questions to make sure exam preparation smoothly.
SOA-C03 Latest Study Questions: https://www.test4cram.com/SOA-C03_real-exam-dumps.html
Amazon SOA-C03 Exam Cram Review What kinds of study material ITBraindumps provides, That's why Amazon SOA-C03 vce is so popular, Experts of the SOA-C03 reliable training vce will have a check at the question pool every day to see whether it has been renewed, If you have some knowledge of our SOA-C03 training materials, but are not sure whether it is suitable for you, you can email us to apply for a free trial version, Amazon SOA-C03 Exam Cram Review Now you have all the necessary information that assists you in take the best decision for your professional career.
This approach nearly works, but has serious New SOA-C03 Test Cram limitations, and it runs somewhat contrary to how we think, Note that you can have only one Quick Collection at a time but that SOA-C03 Pdf Pass Leader you can make further selections and keep adding fresh images to the Quick Collection.
Utilizing SOA-C03 Exam Cram Review - Get Rid Of AWS Certified CloudOps Engineer - AssociateWhat kinds of study material ITBraindumps provides, That's why Amazon SOA-C03 vce is so popular, Experts of the SOA-C03 reliable training vce will have a check at the question pool every day to see whether it has been renewed.
If you have some knowledge of our SOA-C03 training materials, but are not sure whether it is suitable for you, you can email us to apply for a free trial version.
Now you have all the necessary information SOA-C03 that assists you in take the best decision for your professional career.
Posted at 2/23/2026 11:32:16        Only Author  2#
I’m grateful for your article, it truly stood out to me. The Valid 3V0-22.25 exam questions vce exam questions are available for free—your ticket to a promotion and salary increase!
Posted at 4/20/2026 08:37:07        Only Author  3#
Such an amazing article, I appreciate your generosity in sharing it. Free CPC valid exam blueprint available for improving your IT skills. Wishing you the best!
