[Hardware] New HPE0-S59 Test Prep, HPE0-S59 Reliable Exam Pdf
38
【Hardware】 New HPE0-S59 Test Prep, HPE0-S59 Reliable Exam Pdf
Posted at 3/10/2026 15:18:12      View:103 | Replies:0        Print      Only Author   [Copy Link] 1#
P.S. Free & New HPE0-S59 dumps are available on Google Drive shared by VCEEngine: https://drive.google.com/open?id=1Qtw6D-3nxEQChbGk9WMvC3zfH9FfoKmB
Our HPE0-S59 exam braindumps can lead you the best and the fastest way to reach for the certification and achieve your desired higher salary by getting a more important position in the company. Because we hold the tenet that low quality exam materials may bring discredit on the company. So we only creat the best quality of our HPE0-S59 Study Materials to help our worthy customers pass the exam by the first attempt. Tens of thousands of our customers have passed their exam. And you will be the next one if you buy our HPE0-S59 practice engine.
To be eligible for the HP HPE0-S59 certification exam, candidates should have a strong background in IT and preferably several years of experience working with HPE compute solutions. Candidates should also have a good understanding of server architecture, storage solutions, virtualization, and cloud computing. HPE0-S59 Exam is designed to test the candidate's ability to design, deploy, and manage HPE compute solutions in a variety of environments.
HPE0-S59 Reliable Exam Pdf | HPE0-S59 Valid Exam PdfVCEEngine is a professional website. It focuses on the most advanced HP HPE0-S59 for the majority of candidates. With VCEEngine, you no longer need to worry about the HP HPE0-S59 exam. VCEEngine exam questions have good quality and good service. As long as you choose VCEEngine, VCEEngine will be able to help you pass the exam, and allow you to achieve a high level of efficiency in a short time.
HPE Compute Solutions Sample Questions (Q32-Q37):NEW QUESTION # 32
What is a restriction of using a RoCE network?
  • A. It is by default configured as an untagged network and cannot be a part of a network set.
  • B. it is not supported with HPE Virtual Connect SE 40 GD F8 Module for HPE Synergy.
  • C. It does not support smart link and private network features.
  • D. It does not support Private VLAN and Multicast VLAN.
NEW QUESTION # 33
Which statement about the HPE OneView Update Readiness Checker is true?
  • A. It can be used to verify compatibility of a given Synergy Service Pack with a specific version of HPE OneView.
  • B. It can be used to evaluate the health of an HPE OneView appliance before proceeding with an appliance update.
  • C. It can be used to examine the firmware version installed on compute nodes and compliance with HPE OneView version.
  • D. It can be used to determine whether the latest milestone HPE OneView edition is currently installed.
The HPE OneView Update Readiness Checker is used to verify the compatibility of a given Synergy Service Pack (SSP) with a specific version of HPE OneView. This ensures that updates are safe and supported before applying them to the environment.
NEW QUESTION # 34
Drag and Drop Question
Match each HPE OneView network type with its definition.
1. Internal network:
A network that does not utilize any uplink ports and is used for communication between servers in the same frame.
2. Tagged network:
A network that contains multiple networks on a single uplink set that allows your customer to share uplinks with those networks.
3. Tunnel network:
A network with a dedicated set of uplink ports used to pass a group of VLANs without changing the VLAN tags.
4. Untagged network:
A network in which any tagged packets are dropped, and forwarding is done by a MAC address.
Internal networks: Used for intra-frame communication without external connectivity.
Tagged networks: Enable VLAN tagging to share uplinks across multiple networks.
Tunnel networks: Preserve VLAN tags while passing them through uplinks to external systems.
Untagged networks: Do not use VLAN tagging; they rely on MAC address-based communication.
NEW QUESTION # 35
Your customer uses HPE OneView to manage their HPE Synergy environment.
They plan to use it to manage a new set equipment that includes.
- 20 HPE ProLiant DL365 Gen10 Plus servers
- 20 HPE ProLiant DL380 Gen10 Plus servers
- 5 HPE Primera 650
- 5 HPE MSA 2062 Storage Array
Which statements about now OneView will work with this new equipment are true? (Select two)
  • A. HPE OneView replaces array management tools for both types of array
  • B. HPE ProLiant DL380 Gen10 Plus servers have an HPE OneView license included
  • C. HPE ProLiant DL365 Gen10 Plus servers are not supported in HPE OneView
  • D. HPE MSA 2062 Storage Array is not supported in HPE OneView
  • E. HPE Primera 650 can be managed using HPE OneView.
Answer: D,E
HPE MSA 2062 Storage Array is not supported in HPE OneView: HPE OneView does not provide management capabilities for the HPE MSA series, which includes the MSA 2062. These arrays must be managed using their dedicated management tools.
HPE Primera 650 can be managed using HPE OneView: HPE OneView supports the management of HPE Primera storage arrays, including the Primera 650, allowing for integrated management and monitoring within the OneView environment.
NEW QUESTION # 36
An HPE Synergy customer needs to prevent a timeout and loss of communication during an external switch firmware upgrade.
Click the parameter that the customer should configure within an uplink set to meet this requirement
To prevent a timeout and loss of communication during an external switch firmware upgrade, the customer should configure the LACP failover trigger within the uplink set. By setting the LACP failover trigger to "All active uplinks transition to offline," the configuration ensures that the traffic will be redirected to available uplinks in the event of an uplink failure or during the upgrade process, maintaining communication and preventing timeouts.
NEW QUESTION # 37
With HPE0-S59 test training materials of VCEEngine, you will own the key to pass HPE0-S59 exam, which will make you develop better in IT. All of this just need you trust us, trust in VCEEngine, and trust in HPE0-S59 test training materials. Our training material of HPE0-S59 exam is absolutely real and reliable. What's more, the passing rate of HPE0-S59 test is as high as 100%.
HPE0-S59 Reliable Exam Pdf: https://www.vceengine.com/HPE0-S59-vce-test-engine.html
What's more, part of that VCEEngine HPE0-S59 dumps now are free: https://drive.google.com/open?id=1Qtw6D-3nxEQChbGk9WMvC3zfH9FfoKmB
