SPLK-2003 Reliable Exam Answers | SPLK-2003 Certification Practice
Posted at 1/9/2026 18:59:18
BONUS!!! Download part of TestkingPDF SPLK-2003 dumps for free: https://drive.google.com/open?id=1uR-8UEUahHMfGOS0JS8IDYETs6pICAqG
TestkingPDF examines it regularly for new updates so that you always get new Splunk Phantom Certified Admin (SPLK-2003) practice questions. Since it is a printable format, you can do a paper study. The Splunk Phantom Certified Admin (SPLK-2003) PDF Dumps document is accessible from every location at any time. This Splunk Phantom Certified Admin (SPLK-2003) software has a simple-to-use interface. By using the Splunk Phantom Certified Admin (SPLK-2003) practice exam software, you can evaluate your mistakes at the end of every take and overcome them. Our software helps you to get familiar with the format of the original Splunk Phantom Certified Admin (SPLK-2003) test.
Splunk SPLK-2003 exam is an essential certification for IT professionals who want to demonstrate their expertise in administering Splunk Phantom. Splunk Phantom Certified Admin certification can help individuals advance their careers, increase their earning potential, and stand out in a competitive job market. By preparing for the exam and passing it, candidates can prove that they have the knowledge and skills to manage and maintain Splunk Phantom effectively.
Splunk SPLK-2003: Splunk Phantom Certified Admin exam is designed for professionals who want to demonstrate their expertise in administering and managing the Splunk Phantom platform. SPLK-2003 Exam is intended for individuals who have experience in managing and automating security operations using Splunk Phantom.
2026 SPLK-2003 – 100% Free Reliable Exam Answers | Perfect Splunk Phantom Certified Admin Certification PracticeThe only way to save yourself from this scenario is by relying on Splunk SPLK-2003 study material. TestkingPDF equips you with the excellent Splunk SPLK-2003 dumps material to help you clear the Splunk SPLK-2003 real examination on the maiden attempt. One of the leading factors of TestkingPDF in this industry is offering only top-rated and updated SPLK-2003 Exams practice questions.
Splunk is a leading software platform that helps organizations collect, analyze, and visualize machine data in real-time. To make the most of Splunk's capabilities, organizations need skilled administrators who can manage the platform effectively. That's where the Splunk Phantom Certified Admin exam comes in. The SPLK-2003 Exam is designed to test an individual's knowledge of Splunk's Phantom platform and their ability to manage it.
Splunk Phantom Certified Admin Sample Questions (Q73-Q78):NEW QUESTION # 73
Which of the following is a reason to create a new role in SOAR?
- A. To define a set of users who have access to a restricted app.
- B. To define a set of users who have access to a special label.
- C. To define a set of users who have access to an event's reports.
- D. To define a set of users who have access to a sensitive tag.
In Splunk SOAR, roles serve multiple purposes, including granting users permission to access system functionality or restricting access to parts of the system1. Creating a new role is often necessary when there is a need to define a specific set of users who have access to a restricted app. This allows for granular control over who can interact with certain apps, ensuring that only authorized users can use them. While roles can also be used to manage access to labels, reports, and tags, the primary reason for creating a new role is typically related to controlling access to apps and their associated functionalities within the SOAR platform1.
Splunk SOAR documentation on managing roles and permissions1.
NEW QUESTION # 74
Which of the following are the steps required to complete a full backup of a Splunk Phantom deployment' Assume the commands are executed from /opt/phantom/bin and that no other backups have been made.
- A. On the command line enter: rode sudo python ibackup.pyc --setup, then audo phenv python ibackup.pyc
--backup. - B. Within the UI: Select from the main menu Administration > Product Settings > Backup.
- C. On the command line enter: sudo phenv python ibackup.pyc --backup -backup-type full, then sudo phenv python ibackup.pyc --setup.
- D. Within the UI: Select from the main menu Administration > System Health > Backup.
NEW QUESTION # 75
Which of the following applies to filter blocks?
- A. Can select containers by seventy or status.
- B. Can select which blocks have access to container data.
- C. Can be used to select data for use by other blocks.
- D. Can select assets by tenant, approver, or app.
NEW QUESTION # 76
Which of the following can be configured in the ROl Settings?
- A. Annual analyst salary.
- B. Number of full time employees (FTEs).
- C. Time lost.
- D. Analyst hours per month.
NEW QUESTION # 77
What users are included in a new installation of SOAR?
- A. Only the admin user is included by default.
- B. The admin and automation users are included by default.
- C. No users are included by default.
- D. The admin, power, and user users are included by default.
The admin and automation users are included by default. Comprehensive Explanation and References of answer: According to the Splunk SOAR (On-premises) default credentials, script options, and sample
configuration files documentation1, the default credentials on a new installation of Splunk SOAR (On-premises) are:
Web Interface Username: soar_local_admin password: password
On Splunk SOAR (On-premises) deployments which have been upgraded from earlier releases the user account admin becomes a normal user account with the Administrator role.
The automation user is a special user account that is used by Splunk SOAR (On-premises) to run actions and playbooks. It has the Automation role, which grants it full access to all objects and data in Splunk SOAR (On-premises).
The other options are incorrect because they either omit the automation user or include users that are not created by default. For example, option B includes the power and user users, which are not part of the default installation. Option C only includes the admin user, which ignores the automation user. Option D claims that no users are included by default, which is false.
In a new installation of Splunk SOAR, two default user accounts are typically created: admin and automation.
The admin account is intended for system administration tasks, providing full access to all features and settings within the SOAR platform. The automation user is a special account used for automated processes and scripts that interact with the SOAR platform, often without requiring direct human intervention. This user has specific permissions that can be tailored for automated tasks. Options B, C, and D do not accurately represent the default user accounts included in a new SOAR installation, making option A the correct answer.
NEW QUESTION # 78
SPLK-2003 Certification Practice: https://www.testkingpdf.com/SPLK-2003-testking-pdf-torrent.html
- Splunk - Reliable SPLK-2003 Reliable Exam Answers 🦰 Easily obtain [ SPLK-2003 ] for free download through ⏩ [url]www.validtorrent.com ⏪ 😀Online SPLK-2003 Training Materials[/url]
- Free PDF 2026 Splunk SPLK-2003 –High-quality Reliable Exam Answers ✡ Copy URL ✔ [url]www.pdfvce.com ️✔️ open and search for “ SPLK-2003 ” to download for free 🙄SPLK-2003 New Questions[/url]
- Pass Guaranteed Quiz Perfect SPLK-2003 - Splunk Phantom Certified Admin Reliable Exam Answers 🕡 Open ☀ [url]www.vceengine.com ️☀️ and search for ➠ SPLK-2003 🠰 to download exam materials for free ◀SPLK-2003 Test Topics Pdf[/url]
- Free PDF 2026 Splunk SPLK-2003 –High-quality Reliable Exam Answers 🚣 Search for ➽ SPLK-2003 🢪 and download it for free immediately on [ [url]www.pdfvce.com ] 🔚SPLK-2003 New Question[/url]
- Related SPLK-2003 Certifications 😞 SPLK-2003 New Questions 🔰 Verified SPLK-2003 Answers 🦽 Go to website ▛ [url]www.vceengine.com ▟ open and search for [ SPLK-2003 ] to download for free 🕙SPLK-2003 New Question[/url]
- Pass Guaranteed 2026 Splunk Marvelous SPLK-2003: Splunk Phantom Certified Admin Reliable Exam Answers 🌘 Immediately open ➠ [url]www.pdfvce.com 🠰 and search for ➥ SPLK-2003 🡄 to obtain a free download 🔑Verified SPLK-2003 Answers[/url]
- SPLK-2003 New Questions 🅰 Online SPLK-2003 Training Materials 🧦 Exam SPLK-2003 Pass4sure 🥕 Download ▶ SPLK-2003 ◀ for free by simply searching on { [url]www.vce4dumps.com } ➖Valid SPLK-2003 Exam Voucher[/url]
- Valid SPLK-2003 Exam Voucher ⛅ SPLK-2003 Labs 🐫 SPLK-2003 Real Testing Environment 🖋 ➥ [url]www.pdfvce.com 🡄 is best website to obtain { SPLK-2003 } for free download 😵SPLK-2003 New Questions[/url]
- SPLK-2003 Test Prep is Effective to Help You Get Splunk Certificate - [url]www.validtorrent.com 👾 Search for ▷ SPLK-2003 ◁ and download exam materials for free through ➥ www.validtorrent.com 🡄 🏘SPLK-2003 Valid Exam Preparation[/url]
- New SPLK-2003 Test Papers ♻ SPLK-2003 Guaranteed Success 🧿 Verified SPLK-2003 Answers 🧛 Download 《 SPLK-2003 》 for free by simply entering ➠ [url]www.pdfvce.com 🠰 website 🦛Unlimited SPLK-2003 Exam Practice[/url]
- Top SPLK-2003 Questions 🌲 Practice Test SPLK-2003 Fee 🪂 SPLK-2003 Real Testing Environment 📦 Simply search for [ SPLK-2003 ] for free download on ⇛ [url]www.exam4labs.com ⇚ 🍤New SPLK-2003 Test Papers[/url]
- www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, bbs.t-firefly.com, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.du71l.cn, shortcourses.russellcollege.edu.au, umsr.fgpzq.online, www.stes.tyc.edu.tw, Disposable vapes
P.S. Free & New SPLK-2003 dumps are available on Google Drive shared by TestkingPDF: https://drive.google.com/open?id=1uR-8UEUahHMfGOS0JS8IDYETs6pICAqG
