[Hardware] AIO-3568J firmare write problems
154
Hardware AIO-3568J firmare write problems
Posted at 4/15/2024 21:03:03      View3636 | Replies5        Print      Only Author   [Copy Link] 1#
  • SDK Package Name: rk356x_linux_release_v1.3.0b_20221213
  • Modification Content: mipi 2 cam configuration
  • Log: log.zip
I made ERASE ALL operation in RKDevTool_Release_v2.81 and after that my RK3568 went into MASKROM mode.
I made all operations under 4.3. Maskrom Mode in this link https://wiki.t-firefly.com/en/Core-3568J/03-upgrade_firmware_with_flash.html
but writing firmaware in LOADER mode is failed and i got Errorayer<1-7>ownload Firmware Fail (please see attached log.zip).
How can i write firmware into FLASH memory, not to NOR-FLASH ?
log.zip
738 Bytes, Down times: 1
Posted at 5/5/2024 17:10:00        Only Author  2#
Hi, please read this: https://wiki.t-firefly.com/en/Co ... ml#download-to-emmc andhttps://wiki.t-firefly.com/en/Core-3568J/03-upgrade_firmware.html
Posted at 11/15/2024 17:05:10        Only Author  3#
The ERASE ALL procedure seems to have caused a problem! I propose double-checking the instructions in the link to ensure all prerequisites are met because you're stuck in MASKROM mode and having problems writing firmware in LOADER mode. Try an alternative USB cable or port, as connectivity issues can cause firmware writing failures. If the situation persists, seek community or support for customized assistance. Good luck!
Posted at 11/29/2024 19:21:06        Only Author  4#
Good job! The ball rolls at increasing speeds, making each moment more intense than the last slope 3 online.
Posted at 3/11/2025 09:45:52        Only Author  5#
paweja Posted at 11/29/2024 19:21
Good job! The ball rolls at increasing speeds, making each moment more intense than the last slope 3 ...
@Subway Surfers Great work! With each passing second, the online experience becomes more thrilling as the ball races forward at ever-increasing speeds.
Posted at 3/8/2026 10:18:32        Only Author  6#
Thank you for sharing this thought-provoking article! The Valid API-1169 test camp sheet materials are excellent, and you can access them for free.
