[General] 最有效的UiPath-ADPv1考題寶典,免費下載UiPath-ADPv1考試題庫幫助妳通過UiPath-ADPv1考試
103
【General】 最有效的UiPath-ADPv1考題寶典,免費下載UiPath-ADPv1考試題庫幫助妳通過UiPath-ADPv1考試
Posted at 1/30/2026 06:22:27      View:134 | Replies:1        Print      Only Author   [Copy Link] 1#
此外,這些KaoGuTi UiPath-ADPv1考試題庫的部分內容現在是免費的:https://drive.google.com/open?id=1mlCLdD-Teh7N2V9K6mU4OZ_z24kPEnoE
KaoGuTi就是一個能成就很多IT專業人士夢想的網站。如果你有IT夢,就趕緊來KaoGuTi吧,它有超級好培訓資料即KaoGuTi UiPath的UiPath-ADPv1考試培訓資料, 這個培訓資料是每個IT人士都非常渴望的,因為它會讓你通過考試獲得認證,從此以後在職業道路上步步高升。
UiPath UiPath-ADPv1 考試大綱:
主題簡介
主題 1
  • UiPath Activities: In this section, the discussion is related to various UiPath activities for UI interaction, data manipulation, control flow, and more.
主題 2
  • Debugging and Testing: This section is about utilizing logging and debugging tools and adopting unit testing and test automation strategies.
主題 3
  • UiPath Studio Fundamentals: In this section, the focus is given to the understanding of Robotic Process Automation (RPA) concepts; it covers UiPath Studio and its components, Working with the UiPath user interface, project creation, management, and version control.
主題 4
  • Design and Development: This section covers designing workflows using sequences, flowcharts, and state machines, building reusable components with libraries, exception handling and debugging techniques, etc.
UiPath-ADPv1考題寶典 |準備通過UiPath (ADPv1) Automation Developer Professional快人一步現在IT行业競爭越來越激烈,通過UiPath UiPath-ADPv1認證考試可以有效的帮助你在现在这个竞争激烈的IT行业中稳固和提升自己的地位。在我們KaoGuTi中你可以獲得關UiPath UiPath-ADPv1認證考試的培訓工具。我們KaoGuTi的IT精英團隊會及時為你提供準確以及詳細的關UiPath UiPath-ADPv1認證考試的培訓材料。通過我們KaoGuTi提供的學習材料以及考試練習題和答案,我們KaoGuTi能確保你第一次參加UiPath UiPath-ADPv1认证考试時挑戰成功,而且不用花費大量時間和精力來準備考試。
最新的 UiPath Certified Professional - Developer Track UiPath-ADPv1 免費考試真題 (Q102-Q107):問題 #102
A developer configured the properties for a Click activity as shown below:
What happens if the activity cannot find its target at runtime?
  • A. The next activity is executed after 10 seconds.
  • B. An exception is thrown after 10 milliseconds.
  • C. The next activity is executed after 10 milliseconds.
  • D. An exception is thrown after 10 seconds.
答案:D
解題說明:
The Click activity has a property called TimeoutMS. This property specifies the amount of time (in milliseconds) to wait for the activity to be executed before an error is thrown. In this case, the TimeoutMS property is set to 10000 milliseconds (10 seconds). Therefore, if the activity cannot find its target at runtime, an exception will be thrown after 10 seconds.
問題 #103
A developer is using a Type into activity with the Input Method set to Simulate Which property needs to Be enabled for the activity to execute even it the target Ul element is deactivated or read-only?
  • A. Click before typing.
  • B. Deselect at end.
  • C. Alter disabled element.
  • D. Activate.
答案:C
解題說明:
When using the Type Into activity with the Input Method set to Simulate, the 'Alter disabled element' property should be enabled to execute the activity even if the target UI element is deactivated or read-only.
問題 #104
In a UlPath State Machine, what Is the primary function or the Trigger section of a State activity?
  • A. To establish the exit actions when moving out of a state.
  • B. To specify the condition or event that initiates a transition from the current state
  • C. To define the entry actions when transitioning into a state.
  • D. To execute the final state actions before terminating the state machine.
答案:B
解題說明:
In a UiPath State Machine, the Trigger section of a State activity is used to specify the condition or event that initiates a transition from the current state to another state.
問題 #105
Which activity should a developer use to add custom information to logs related to transactions for tracing purposes?
  • A. Update Logs
  • B. Add Custom Log
  • C. Build Log
  • D. Add Log Fields
答案:D
解題說明:
The Add Log Fields activity enables you to add custom information to logs related to transactions for tracing purposes1. The activity takes a collection of string arguments as input, which are added to every subsequent log message throughout the entire workflow, unless a Remove Log Fields activity is used1. The custom log fields can be useful for adding more information and visibility to the logs, especially for transactional data processes2. For example, you can use the Add Log Fields activity to add the transaction ID, the transaction status, the business process name, or any other relevant data to the logs2. Therefore, the correct answer is A.
Add Log Fields.
問題 #106
In the context of UiPath Orchestrator, what is the primary purpose of the Monitoring feature?
  • A. Real-time tracking of Robots, Machines, Queues, and Jobs.
  • B. Consolidating event logs and records related to executed tasks and runtime anomalies.
  • C. Handling version control and collaboration among team members.
  • D. Facilitating the design and deployment of automation workflows.
答案:A
解題說明:
The Monitoring feature in UiPath Orchestrator is a solution that provides real-time metrics to help you keep an eye on the health and state of your system1. It enables you to check the status and performance of your Robots, Machines, Queues, and Jobs in either the last hour or last day1. You can also use the Monitoring feature to filter, sort, and search for specific resources, view detailed information and charts for each resource, and access the Error Feed widget to see the errors that occurred during execution1.
Option A describes the purpose of the Source Control feature in UiPath Studio, which allows you to manage your automation projects using Git or TFS2.
Option C describes the purpose of the Processes feature in UiPath Orchestrator, which allows you to deploy, configure, and run automation workflows on Robots3.
Option D describes the purpose of the Logs feature in UiPath Orchestrator, which allows you to view and download event logs and records related to executed tasks and runtime anomalies.
Orchestrator - About Monitoring - UiPath Documentation Portal
Studio - Source Control - UiPath Documentation Portal
Orchestrator - Processes - UiPath Documentation Portal
[Orchestrator - Logs - UiPath Documentation Portal]
問題 #107
UiPath UiPath-ADPv1 認證考試是一個檢驗IT專業知識的認證考試。KaoGuTi是個能幫你快速通過UiPath UiPath-ADPv1 認證考試的網站,很多參加UiPath UiPath-ADPv1 認證考試的人花費大量的時間和精力,或者花錢報補習班,都是為了通過UiPath UiPath-ADPv1 認證考試。KaoGuTi可以讓你不需要花費那麼多時間,金錢和精力,KaoGuTi會為你提供針對性訓練來準備UiPath UiPath-ADPv1認證考試,僅需大約20個小時你就能通過考試。
UiPath-ADPv1熱門題庫: https://www.kaoguti.com/UiPath-ADPv1_exam-pdf.html
P.S. KaoGuTi在Google Drive上分享了免費的、最新的UiPath-ADPv1考試題庫:https://drive.google.com/open?id=1mlCLdD-Teh7N2V9K6mU4OZ_z24kPEnoE
Posted at 1/30/2026 19:01:14        Only Author  2#
Amazon인증 DOP-C02시험준비중이신 분들은Amazon인증 DOP-C02시험통과가 많이 어렵다는것을 알고 있을것입니다. 학교공부하랴,회사다니랴 자격증공부까지 하려면 너무 많은 정력과 시간이 필요할것입니다. 그렇다고 자격증공부를 포기하면 자신의 위치를 찾기가 힘들것입니다. ITDumpsKR 덤프는 IT인증시험을 대비하여 제작된것이므로 시험적중율이 높아 다른 시험대비공부자료보다 많이 유용하기에 IT자격증을 취득하는데 좋은 동반자가 되어드릴수 있습니다. ITDumpsKR 덤프를 사용해보신 분들의 시험성적을 통계한 결과 시험통과율이 거의 100%에 가깝다는 놀라운 결과를 얻었습니다.
