[General] Latest NCP-DB-6.10 Exam Discount, Latest NCP-DB-6.10 Exam Tips
85
【General】 Latest NCP-DB-6.10 Exam Discount, Latest NCP-DB-6.10 Exam Tips
Posted at 1/13/2026 20:12:49      View:211 | Replies:3        Print      Only Author   [Copy Link] 1#
Forget your daydream! Forget living in cloud-cuckoo-land! Just be down-to-earth to prepare for an IT certification. Nutanix NCP-DB-6.10 latest exam sample questions on our website are free to download for your reference. If you still want to find a valid dump, our website will be your beginning. Our Nutanix NCP-DB-6.10 Latest Exam sample questions are a small part of our real products. If you think the free version is excellent, you can purchase our complete version.
You may be busy in your jobs, learning or family lives and can’t get around to preparing and takes the certificate exams but on the other side you urgently need some useful NCP-DB-6.10 certificates to improve your abilities in some areas. So is there a solution which can kill two birds with one stone to both make you get the certificate and spend little time and energy to prepare for the exam? If you choose the test Nutanix certification and then buy our NCP-DB-6.10 prep material you will get the panacea to both get the useful certificate and spend little time. Passing the test certification can help you stand out in your colleagues and have a bright future in your career.
Free PDF Nutanix - Trustable NCP-DB-6.10 - Latest Nutanix Certified Professional - Database Automation (NCP-DB) v6.10 Exam DiscountIn the past few years, our NCP-DB-6.10 study materials have helped countless candidates pass the NCP-DB-6.10 exam. After having a related certification, some of them encountered better opportunities for development, some went to great companies, and some became professionals in the field. NCP-DB-6.10 Study Materials have stood the test of time and market and received countless praises. We will transfer our NCP-DB-6.10 test prep to you online immediately, and this service is also the reason why our NCP-DB-6.10 study torrent can win people’s heart and mind.
Nutanix Certified Professional - Database Automation (NCP-DB) v6.10 Sample Questions (Q123-Q128):NEW QUESTION # 123
An administrator needs to patch an Oracle Database Server VM and must ensure Grid home is allocated sufficient storage space.
At a minimum, how much space must be available for Grid home prior to completing this task?
  • A. 5 GB
  • B. 20 GB
  • C. 10GB
  • D. 15GB
When patching an Oracle Database Server VM, it's important to ensure that there is sufficient storage space allocated for the Grid home. A minimum of 10GB space is required for this purpose to accommodate the patching process without storage constraints.
NEW QUESTION # 124
An administrator needs to protect a database with a Point In Time Recovery (PITR) SLA that provides a minimum of seven days of log recovery.
What is the minimum Default SLA that meets this requirement?
  • A. DEFAULT_008 SILVER SLA
  • B. DEFAULT_008 GOLD SLA
  • C. DEFAULT_008 BRONZE SLA
  • D. DEFAULT_008 BRASS SLA
Nutanix Era (NDB) utilizes DEFAULT_008 SLAs with varying frequencies for snapshots and log backups to achieve different recovery point objectives (RPOs). Here's how they compare:
DEFAULT_008 GOLD SLA: Typically has frequent log backups (e.g., every 15 minutes) and snapshots every few hours. This is designed for critical databases with very low RPOs.
DEFAULT_008 SILVER SLA: Offers a balance between protection and resource usage. Log backups might occur every hour with snapshots less frequently. This SLA is often suitable for databases requiring a good RPO without being overly resource-intensive. DEFAULT_008 BRONZE SLA: Has less frequent log backups (e.g., every few hours) and less frequent snapshots. This is used for databases with less stringent RPO requirements. DEFAULT_008 BRASS SLA: This has infrequent log backups and is usually considered the least protective SLA with the longest potential RPO
NEW QUESTION # 125
Which file type must be downloaded from the Nutanix Portal for NDB deployment?
  • A. TAR
  • B. QCOW2
  • C. OVA
  • D. ZIP
For deploying Nutanix Database Service (NDB), the required file type to download from the Nutanix Portal is an OVA (Open Virtual Appliance) file. The OVA format is a standardized package that includes a pre-configured virtual machine image, including the NDB software, which can be imported into supported hypervisors (e.g., VMware ESXi or Nutanix AHV). This simplifies the deployment process by providing a ready-to-use VM template with all necessary components.
NEW QUESTION # 126
An administrator needs to perform patching on a MongoDB server cluster within an NDB environment.
How should the administrator accomplish this task?
  • A. Apply the patch to all nodes at once.
  • B. Disable the replica set while patching.
  • C. Perform a rolling upgrade, applying the patch to the secondary members first, followed by the primary member.
  • D. Perform a rolling upgrade, applying the patch to the primary member first, followed by the secondary members.
The administrator should perform a rolling upgrade, applying the patch to the secondary members first, followed by the primary member, to accomplish the task of patching a MongoDB server cluster within an NDB environment. A rolling upgrade is a method of applying patches or updates to a cluster without downtime or interruption of service. The administrator can use the NDB patching feature to perform a rolling upgrade on a MongoDB server cluster, which consists of a primary member and one or more secondary members that form a replica set. The NDB patching feature allows the administrator to select the software profile version, the database parameters profile, and the network profile for the patching operation.
NEW QUESTION # 127
Refer to the exhibit. An administrator is attempting to take a manual snapshot of a database in ND8 on an AHV cluster. There are multiple Nutanix clusters in this environment and the administrator would like to replicate the snapshot to one of the remote clusters. When attempting to take the snapshot, only a single cluster appears, as shown in the exhibit.
What is the most likely reason that only a single cluster is shown?
  • A. NDB Multi-cluster has not been enabled.
  • B. The remote clusters have an older version of AOS installed.
  • C. The snapshot will be too big to replicate to a remote cluster.
  • D. The remote clusters are running ESXi.
The exhibit shows the "Create Snapshot" interface in NDB, where the administrator can select Nutanix clusters where the snapshot should be made available. However, only a single cluster appears despite multiple clusters in the environment. The most likely reason is that NDB Multi- cluster has not been enabled. Multi-cluster support in NDB requires explicit configuration to enable snapshot replication and data availability across remote clusters (e.g., via Prism Central and network profiles). Without this, NDB restricts snapshot operations to the local cluster where the database resides.
NEW QUESTION # 128
According to the market research, we have found that a lot of people preparing for the NCP-DB-6.10 exam want to gain the newest information about the exam. In order to meet all candidates requirement, we compiled such high quality NCP-DB-6.10 study materials to help you. It is believed that our products will be very convenient for you, and you will not find the better study materials than our NCP-DB-6.10 Exam Question. If you willing spend few hours to learn our study materials, you will pass the exam in a short time. Now we are going to introduce our NCP-DB-6.10 test questions to you.
Latest NCP-DB-6.10 Exam Tips: https://www.pass4surecert.com/Nutanix/NCP-DB-6.10-practice-exam-dumps.html
Nutanix Latest NCP-DB-6.10 Exam Discount As what we always said, the customer's satisfaction is our first consideration all the while, You want to obtain a NCP-DB-6.10 dumps VCE but they are sure which company is real and useful, Nutanix Latest NCP-DB-6.10 Exam Discount The passed data is leading in this area, You can pass your test at first try with our NCP-DB-6.10 training pdf, Nutanix Latest NCP-DB-6.10 Exam Discount If you want to find an ideal job and earn a high income you must boost good working abilities and profound major knowledge.
I found the bundle very user-friendly and it covers all NCP-DB-6.10 the exam topics in a very detailed manner as well, Jim lives with his wife and two children in Vancouver.
As what we always said, the customer's satisfaction is our first consideration all the while, You want to obtain a NCP-DB-6.10 dumps VCE but they are sure which company is real and useful.
Latest NCP-DB-6.10 Exam Discount Pass Certify| Professional Latest NCP-DB-6.10 Exam Tips: Nutanix Certified Professional - Database Automation (NCP-DB) v6.10The passed data is leading in this area, You can pass your test at first try with our NCP-DB-6.10 training pdf, If you want to find an ideal job and earn a high income you must boost good working abilities and profound major knowledge.
Posted at 2/2/2026 23:19:00        Only Author  2#
Thank you for the article; it really stood out and caught my attention. The extensive content in latest D-AV-DY-23 exam book is offered free of charge to support you.
Posted at 2/14/2026 19:45:54        Only Author  3#
That article made a lasting impact on me. Get your hands on the C1000-182 valid exam braindumps test that helped me achieve a promotion and salary increase, and it’s available for free today. I hope you hit your career goals soon!
Posted at 2/21/2026 23:29:29        Only Author  4#
Thank you for your insightful article, it’s truly eye-catching. Strengthen your IT expertise with free PSE-Cortex latest test braindumps. Best of luck in your exams!
