[Linux] How do I get linux-headers for the 5.10.66 kernel?
25
Linux How do I get linux-headers for the 5.10.66 kernel?
Posted at 10/30/2023 17:32:50      View4471 | Replies9        Print      Only Author   [Copy Link] 1#
  • SDK Package Name: rk3588_linux_release_20231027_v1.1.1e
  • Modification Content: ??
  • Log: log.zip
Hi everyone. I want linux-headers for my Firefly device.
I downloaded the SDK-archive: "rk3588_linux_release_20230114_v1.0.6c"
command:
realpath .repo/manifest.xml
give out:
.repo/manifests/rk3588/rk3588_linux_release_20231027_v1.1.1e.xml
I vaguely imagine how images are assembled, but I need to get linux-headers for kernel version 5.10.66 and Ubuntu 20.04
Okay, I'm starting to do.
Prepared a docker container, because if we believe the instructions we need Ubuntu 18.04 for build:
# syntax=docker/dockerfile:1
FROM ubuntu:18.04
RUN apt update -y && apt install build-essential -y && apt install python2.7 -y
RUN ln -s /usr/bin/python2.7 /usr/bin/python
RUN apt install repo bc rsync kmod cpio bison flex flex:native libssl-dev:native -y
RUN apt install git ssh make gcc libssl-dev liblz4-tool expect g++ patchelf chrpath gawk texinfo chrpath diffstat binfmt-support qemu-user-static live-build bison flex fakeroot cmake gcc-multilib g++-multilib unzip device-tree-compiler ncurses-dev -y
WORKDIR /home
I bind the directory with the SDK to the container and I run this container:
docker run -it --mount type="bind",src="/home/hoop/0_Programs_or_Libraries/FIREFLY_RK3588_SDK_LINUX/rk3588_another_popytka/",target=/home/sdk my_image /bin/bash
And I follow this instruction.
I'm not sure which mk-file I need, but I don't build with anyone.
./build itx-3588j-ubuntu.mk
./build.sh kerneldeb
I get a mistake
dpkg-buildpackage: error: debian/rules binary subprocess returned exit status 2
scripts/Makefile.package:82: recipe for target 'bindeb-pkg' failed
make[1]: *** [bindeb-pkg] Error 2
Makefile:1665: recipe for target 'bindeb-pkg' failed
make: *** [bindeb-pkg] Error 2
ERROR: Running build_kerneldeb failed!
ERROR: exit code 2 from line 766:
make ARCH=$RK_ARCH bindeb-pkg RK_KERNEL_DTS=$RK_KERNEL_DTS -j$RK_JOBS
_____________________________________________________________
P.S.
Even if the build was successful, I do not understand how I would choose the kernel version exactly 5.10.66
log.zip
3.35 KB, Down times: 0
Posted at 10/31/2023 09:41:48        Only Author  2#
Hello, did you check this linux-headers: https://en.t-firefly.com/doc/download/140.html
Posted at 10/31/2023 15:09:17        Only Author  3#
Hello, this is 5.10.110, but i need 5.10.66
I tried the build on the real Ubuntu 18.04 (without using a docker). The error is the same
Perhaps someone can provide me with a file with linux-headers 5.10.66
Posted at 1/10/2026 20:40:22        Only Author  4#
It was one of the most beneficial pieces Ive read in a while. Ready to crush the XSOAR-Engineer current exam content exam! Hope it goes great!
Posted at 1/14/2026 12:55:06        Only Author  5#
This article is incredibly thought-provoking, I appreciate you sharing it! The NCM-MCI valid test questions was my key to successpromotion and salary raise. Its now free for everyone. Wishing you all a fast track to promotions!
Posted at 1/15/2026 10:40:24        Only Author  6#
This is a stellar article, thank you for sharing it with us. Level up your IT abilitiesfree New C-BCSSS-2502 test questions and answers for you! Wishing you all the best!
Posted at 1/16/2026 20:18:09        Only Author  7#
Thank you for your wonderful article; it was truly shocking! The Actual NCP-DB-6.10 tests resources are available for freegood luck, everyone!
Posted at 1/16/2026 20:57:23        Only Author  8#
I really appreciate your article, it was so enlightening and refreshing. Enhance your IT knowledge and get free New guide 78202T files. Wishing you success!
Posted at 1/16/2026 22:29:53        Only Author  9#
Im so thankful for your article, it really made me think. Sharing EX-Con-101 reliable mock test exam questions for freepromotions and salary growth await!
Posted at 1/17/2026 04:53:05        Only Author  10#
Your article was remarkable, Im truly thankful for it. This is the CPB valid real test exam that helped me get promoted and earn a pay raise. Its available for free todaygood luck with your career goals!
