[General] Make an upgrade microsd card on linux host: how?
66
General Make an upgrade microsd card on linux host: how?
Posted at 7/14/2022 06:45:28      View3410 | Replies4        Print      Only Author   [Copy Link] 1#
There's a wiki page that describes how to upgrade the board firmware using an upgrade MicroSD card. A procedure that is described involves an SD_Firmware_Tool.exe binary, it's obviously for Windows. Is there a Linux way to make an SD card that will upgrade the firmware?
* Maybe devs a Linux script that allows to do this. If yes can you share this?
* Maybe I can create an update image on Windows just once, save the file, identify where the actual firmware image is and just replace this part of the file to make a new upgrade SD image
The MicroSD update method is more appealing since the button is not very easy to access, but I don't really want to use Windows for this. Maybe once to create a sample image
Posted at 7/14/2022 09:24:04        Only Author  2#
Currently, it is not supported to make SDcard in Linux. There may be program support later
Posted at 7/14/2022 09:53:20        Only Author  3#
In fact, update with SD card is less efficient
Use USB cable, connect linux PC and 3588S-PC (type C), then run command "reboot loader" in 3588S
It will reboot and enter download mode, you don't need to press any buttons...
Then return to PC, use "sudo upgrade_tool uf xxx.img" to update firmware.
The download speed through USB is faster than SD card.
https://wiki.t-firefly.com/en/RO ... firmware.html#linux
Posted at 1/23/2026 13:10:27        Only Author  4#
The content of the article is very practical, and I have gained a lot of knowledge. Level up your IT knowledge with free CWAP-405 exam labs. Wishing you success in your exams!
Posted at 1/27/2026 02:46:12        Only Author  5#
The article is full of motivational insights, thank you for sharing! Sharpen your IT skills with free New exam ACD201 braindumps. Best of luck to everyone!
