[General] Make Exam Preparation Simple ExamsTorrent Real Oracle 1Z0-1042-25 Exam Questions
102
【General】 Make Exam Preparation Simple ExamsTorrent Real Oracle 1Z0-1042-25 Exam Questions
Posted at 1/20/2026 05:21:33      View:122 | Replies:1        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of ExamsTorrent 1Z0-1042-25 dumps for free: https://drive.google.com/open?id=1NJrvYtoSZfB25YGqeSW_Sfhjf6dU-9oC
The Oracle Cloud Infrastructure 2025 Application Integration Professional (1Z0-1042-25) PDF dumps format can be accessed from any smart device such as laptops, tablets, and smartphones. ExamsTorrent regularly updates the Oracle 1Z0-1042-25 PDF Questions to reflect the latest Oracle 1Z0-1042-25 exam content. All test questions in the Oracle Cloud Infrastructure 2025 Application Integration Professional (1Z0-1042-25) exam PDF format are real and latest.
Oracle 1Z0-1042-25 Exam Syllabus Topics:
  • Testing, Monitoring, and Troubleshooting Integrations: This section assesses the abilities of Support Engineers and Integration Administrators in managing integration lifecycles. It includes activating and deactivating integrations, testing REST-triggered integrations, importing and exporting integrations, as well as monitoring and troubleshooting integration instances to ensure smooth operations.
  • Getting Started with OIC Integrations: This section of the exam measures the skills of Integration Specialists and Cloud Engineers in understanding the foundational components of Oracle Integration Cloud (OIC). It covers key integration concepts, how integrations work, and web services fundamentals such as WSDL, SOAP, REST, and JSON. The focus is on building a strong understanding of OIC’s integration capabilities.
  • Using OIC Connections & Adapters: This section evaluates the expertise of Integration Developers and Solution Architects in creating and configuring OIC connections. It includes setting up trigger and invoke connections, understanding the role of the Connectivity Agent, and effectively using adapters to connect cloud and on-premises applications seamlessly.
  • Creating Orchestrated Integrations: This section tests the knowledge of Orchestration Developers and Business Process Analysts in managing orchestrated integrations within OIC. It includes using lookups, data mappers, and custom JavaScript libraries, configuring orchestration flow actions, implementing file handling options, and leveraging the fault-handling framework to manage errors effectively.
Topic 5
  • Creating Scheduled Integrations: This domain measures the skills of Automation Engineers and Cloud Administrators in defining integration schedules and converting scheduled integrations to app-driven ones. It also includes using scheduled parameters to automate workflows efficiently.
1Z0-1042-25 Study Questions - 1Z0-1042-25 Guide Torrent & 1Z0-1042-25 Exam TorrentBased on the credibility in this industry, our 1Z0-1042-25 study braindumps have occupied a relatively larger market share and stable sources of customers. Such a startling figure --99% pass rate is not common in this field, but we have made it with our endless efforts. As this new frontier of personalizing the online experience advances, our 1Z0-1042-25 exam guide is equipped with comprehensive after-sale online services. It’s a convenient way to contact our staff, for we have customer service people 24 hours online to deal with your difficulties. If you have any question or request for further assistance about the 1Z0-1042-25 study braindumps, you can leave us a message on the web page or email us.
Oracle Cloud Infrastructure 2025 Application Integration Professional Sample Questions (Q70-Q75):NEW QUESTION # 70
Your design of an asynchronous Oracle Integration Cloud (OIC) integration flow includes the requirement for additional processing logic that is conditionally based on the results returned to the integration instance from earlier external service invocations. You decide to leverage the Switch action to facilitate this implementation.
Which is a valid consideration concerning the configuration and capabilities of the Switch action?
  • A. Data objects returned from actions within a branch of a switch action are not visible in the main flow of the integration after the switch action.
  • B. Nested switch actions are not supported, and you may need to create more complex conditional expressions, if necessary.
  • C. The Switch action must include an otherwise branch.
  • D. XPath version 2.0 functions can be used to create more complex conditional expressions for a branch.
XPath version 2.0 functions can be used within the Switch action to create more complex conditional expressions for defining branches in Oracle Integration Cloud.
NEW QUESTION # 71
Which are types of certificates in Oracle Integration Cloud (OIC) that can be imported from the Certificates page under settings? Select THREE.
  • A. Message protection certificates
  • B. Trust Certificate
  • C. Multi Domain SSL Certificate
  • D. Unified Communications Certificate
  • E. Identity certificates
Answer: A,B,E
OIC supports certificate management:
Identity certificates (A):Used for client authentication (e.g., two-way SSL).
Message protection certificates (B):Encrypt/sign messages for security.
Trust Certificate (E):Validates trusted external services.
Multi Domain SSL Certificate (C):Not a distinct OIC category; handled as identity or trust.
Unified Communications Certificate (D):Specific to communication platforms, not OIC-supported.
A, B, E are standard OIC certificate types.
NEW QUESTION # 72
Which two statements about lookups are correct?
  • A. Create a lookup to map values between applications.
  • B. Lookups are deployed as part of integration activation.
  • C. Changes made to lookups already used in active integrations take effect immediately.
  • D. You cannot clone a copy of an existing lookup.
A: Lookups are used to map values between different applications and systems.
C: Changes made to lookups in OIC are applied in real time, affecting active integrations immediately.
B is incorrect as lookups are independent entities and not tied to integration activation.
D is incorrect because you can clone existing lookups.
NEW QUESTION # 73
When leveraging the Oracle Integration (OIC) Connectivity Agent for high availability on-premises environments, which two are valid considerations?
  • A. Each host on which the agent is installed must be configured on separate subnets and assigned to the same OIC Agent group.
  • B. You should install the connectivity agents on the same host as the target application, and then specify different Agent group identifiers for each Agent during its installation.
  • C. Since the File Adapter is not supported in high-availability environments, you must use an Agent Group that uses only one installed active Agent.
  • D. You cannot have more than two Agent instances per Agent group. Attempting to include a third Agent instance in the same group during installation results in an error.
  • E. You must have the OIC ServiceDeployer role or higher permissions to download and install the OIC Connectivity Agent.
Answer: D,E
HA Agent:
E, B:True-two-agent limit, role requirement.
NEW QUESTION # 74
You have an Oracle Integration (OIC) synchronous integration flow that updates external systems with several invocations. However, several of your OIC integration clients are reporting that they are experiencing timeouts waiting for the response confirmation from this processing. Which is a legitimate strategy to mitigate this issue?
  • A. Change the design implementation strategy to an asynchronous flow that provides a separate notification to clients when the processing is complete.
  • B. Change the implementation logic to invoke multiple fine-grained external API calls within a single loop.
  • C. Increase the blocking timeout within the OIC integration settings to allow for extended time.
Timeouts:
B:True-async flow resolves client wait issues.
NEW QUESTION # 75
On the one thing, our company has employed a lot of leading experts in the field to compile the 1Z0-1042-25 exam torrents, so you can definitely feel rest assured about the high quality of our 1Z0-1042-25 question torrents. On the other thing, the pass rate among our customers who prepared the exam under the guidance of our 1Z0-1042-25 Study Materials has reached as high as 98% to 100%. What's more, you will have more opportunities to get promotion as well as a pay raise in the near future after using our 1Z0-1042-25 question torrents since you are sure to get the 1Z0-1042-25 certification.
Valid 1Z0-1042-25 Vce: https://www.examstorrent.com/1Z0-1042-25-exam-dumps-torrent.html
Posted at 1/27/2026 08:46:52        Only Author  2#
Thank you for the article, it was a real eye-catching read. Security-Operations-Engineer latest exam cram review played a major role in my promotion and salary increase—get it for free today!
