[General] CAS-004 Test Guide Online, New CAS-004 Real Exam
78
【General】 CAS-004 Test Guide Online, New CAS-004 Real Exam
Posted at 2/7/2026 04:33:44      View:115 | Replies:0        Print      Only Author   [Copy Link] 1#
P.S. Free & New CAS-004 dumps are available on Google Drive shared by ITExamSimulator: https://drive.google.com/open?id=1yl0hBiR-HZO6fjo0f_EmWxwS_pZ4-kD5
You can install CompTIA CAS-004 PRACTICE TEST file and desktop practice test software on your devices and easily start CompTIA Advanced Security Practitioner (CASP+) Exam (CAS-004) exam preparation right now. Whereas the "ITExamSimulator" CAS-004 web-based practice test software is concerned, it is a simple browser-based application that works with all the latest web browsers. Just put the link of ITExamSimulator CAS-004 web-based practice test application in your browser and start CompTIA CAS-004 exam preparation without wasting further time. The "ITExamSimulator" is quite confident that you will be the next successful CompTIA Advanced Security Practitioner (CASP+) Exam exam candidate.
Immediately after you have made a purchase for our CAS-004 practice test, you can download our exam study materials to make preparations for the exams. It is universally acknowledged that time is a key factor in terms of the success of exams. There is why our CAS-004 Test Prep exam is well received by the general public. I believe if you are full aware of the benefits the immediate download of our PDF study exam brings to you, you will choose our CAS-004 actual study guide.
New CAS-004 Real Exam & Cert CAS-004 GuideSince the childhood, we seem to have been studying and learning seems to take part in different kinds of the purpose of the test, at the same time, we always habitually use a person's score to evaluate his ability. And our CAS-004 study materials can help you get better and better reviews. This is a very intuitive standard, but sometimes it is not enough comprehensive, therefore, we need to know the importance of getting the test CAS-004 Certification, qualification certificate for our future job and development is an important role.
CompTIA Advanced Security Practitioner (CASP+) Exam Sample Questions (Q153-Q158):NEW QUESTION # 153
A company that uses AD is migrating services from LDAP to secure LDAP. During the pilot phase, services are not connecting properly to secure LDAP. Block is an except of output from the troubleshooting session:
openssl s_client -host ldapl.comptia.com -port 636
CONNECTED (00000003)
----- BEGIN CERTIFICATE -----
----- END CERTIFICATE -----
Subject =/CN=* Comptia.com / Issuer = / DC = com / DC = danville / CN = chicago Which of the following BEST explains why secure LDAP is not working? (Choose two.)
  • A. Danvills.com is under a DDoS-inator attack and cannot respond to OCSP requests.
  • B. The company is using the wrong port. It should be using port 389 for secure LDAP.
  • C. Secure LDAP does not support wildcard certificates.
  • D. The secure LDAP service is not started, so no connections can be made.
  • E. The clients may not trust idapt by default.
  • F. Secure LDAP should be running on UDP rather than TCP.
  • G. The clients may not trust Chicago by default.
Answer: C,E
The clients may not trust idapt by default because it is a self-signed certificate authority that is not in the trusted root store of the clients. Secure LDAP does not support wildcard certificates because they do not match the fully qualified domain name of the server.
NEW QUESTION # 154
Which of the following tools uses machine learning and advanced analytics to detect abnormal patterns of behavior, such as unusual access or actions by employees, and significantly reduces manual effort in breach investigations?
  • A. HIPS
  • B. HSM
  • C. OPSEC training
  • D. XDR
  • E. UEBA
Answer: E
* UEBA (User and Entity Behavior Analytics) uses machine learning and advanced analytics to detect abnormal patterns of behavior, such as unusual access or actions by employees.
* Implementing UEBA automates the analysis of logs and identifies suspicious activities, significantly reducing the manual effort required.
* Option B (HSM) is incorrect because a hardware security module is used for secure key management, not log analysis.
* Option C (HIPS) is incorrect because a host intrusion prevention system focuses on preventing attacks on endpoints rather than log analysis.
* Option D (XDR) extends threat detection and response across multiple domains, but it is broader in scope and does not focus specifically on user behavior analysis.
* Option E (OPSEC training) is valuable for educating employees but does not streamline the breach investigation process.
* CompTIA CASP+ Exam Objective 4.4: Implement security operations tools and automation solutions.
* CASP+ Study Guide, 5th Edition, Chapter 10, Security Operations and Behavioral Analysis.
NEW QUESTION # 155
A company is experiencing a large number of attempted network-based attacks against its online store. To determine the best course of action, a security analyst reviews the following logs.
Which of the following should the company do next to mitigate the risk of a compromise from these attacks?
  • A. Perform parameterized queries.
  • B. Restrict HTTP methods.
  • C. Validate content types.
  • D. Implement input sanitization.
Restricting HTTP methods can mitigate the risk of network-based attacks against an online store by limiting the types of HTTP requests that the server will accept, thus reducing the attack surface. This is a common method to prevent web-based attacks such as Cross-Site Scripting (XSS) and SQL Injection.
NEW QUESTION # 156
Which of the following BEST sets expectation between the security team and business units within an organization?
  • A. Business partnership agreement
  • B. Risk assessment
  • C. Memorandum of understanding
  • D. Services level agreement
  • E. Business impact analysis
Answer: E
NEW QUESTION # 157
A company has decided to purchase a license for software that is used to operate a mission-critical process.
The third-party developer is new to the industry but is delivering what the company needs at this time.
Which of the following BEST describes the reason why utilizing a source code escrow will reduce the operational risk to the company if the third party stops supporting the application?
  • A. The company will be able to force the third-party developer to continue support.
  • B. The company will have access to the latest version to continue development.
  • C. The company will be paid by the third-party developer to hire a new development team.
  • D. The company will be able to manage the third-party developer's development process.
NEW QUESTION # 158
Our CAS-004 study materials are famous for instant download, and if you want to start practicing as quickly as possible, you can have a try. After purchasing CAS-004 exam dumps , you will receive the downloading link and password within ten minutes, and if you don’t receive, just contact us. In addition, CAS-004 Exam Dumps are high-quality, and they can ensure you pass the exam just one time. We also pass guarantee and money back guarantee if you fail to pass the exam, and money will be returned to your payment account.
New CAS-004 Real Exam: https://www.itexamsimulator.com/CAS-004-brain-dumps.html
Then our PC version of our CAS-004 exam questions can fully meet their needs only if their computers are equipped with windows system, Due to this, they fail the CompTIA Advanced Security Practitioner (CASP+) Exam (CAS-004) test, losing money and time, Our latest CAS-004 exam torrent was designed by many experts and professors, The ITExamSimulator CAS-004 exam practice test questions will provide you with everything that you need to learn, prepare and pass the CompTIA Advanced Security Practitioner (CASP+) Exam CAS-004 exam, The New CAS-004 Real Exam - CompTIA Advanced Security Practitioner (CASP+) Exam prepare torrent can be based on the analysis of the annual questions, it is concluded that a series of important conclusions related to the qualification examination, combining with the relevant knowledge of recent years, then predict the direction which can determine this year's exam.
They all can be obtained in short time once New CAS-004 Real Exam you place your order, and there are many discounts occasionally for your support, Thethen( method on a future takes a function as Fresh CAS-004 Dumps an argument, which will be passed the result of the future as soon as it completes.
100% Pass Quiz CAS-004 CompTIA Advanced Security Practitioner (CASP+) Exam Marvelous Test Guide OnlineThen our PC version of our CAS-004 Exam Questions can fully meet their needs only if their computers are equipped with windows system, Due to this, they fail the CompTIA Advanced Security Practitioner (CASP+) Exam (CAS-004) test, losing money and time.
Our latest CAS-004 exam torrent was designed by many experts and professors, The ITExamSimulator CAS-004 exam practice test questions will provide you with everything that you need to learn, prepare and pass the CompTIA Advanced Security Practitioner (CASP+) Exam CAS-004 exam.
The CompTIA Advanced Security Practitioner (CASP+) Exam prepare torrent can be based on the CAS-004 analysis of the annual questions, it is concluded that a series of important conclusions related tothe qualification examination, combining with the New CAS-004 Real Exam relevant knowledge of recent years, then predict the direction which can determine this year's exam.
What's more, part of that ITExamSimulator CAS-004 dumps now are free: https://drive.google.com/open?id=1yl0hBiR-HZO6fjo0f_EmWxwS_pZ4-kD5
