Fortinet NSE5_SSE_AD-7.6考古题推薦 - NSE5_SSE_AD-7.6最新試題
90
Posted at 2/15/2026 02:41:04      View:124 | Replies:1        Print      Only Author   [Copy Link] 1#
從Google Drive中免費下載最新的KaoGuTi NSE5_SSE_AD-7.6 PDF版考試題庫:https://drive.google.com/open?id=1anDD8VlgbVHfq2bqN3RqDkzcIIFVmEkb
當你進入KaoGuTi網站,你看到每天進入KaoGuTi網站的人那麼多,不禁感到意外。其實這很正常的,我們KaoGuTi網站每天給不同的考生提供培訓資料數不勝數,他們都是利用了我們的培訓資料才順利通過考試的,說明我們的Fortinet的NSE5_SSE_AD-7.6考試認證培訓資料真起到了作用,如果你也想購買,那就不要錯過我們KaoGuTi網站,你一定會非常滿意的。
Fortinet NSE5_SSE_AD-7.6 考試大綱:
主題簡介
主題 1
  • Rules and Routing: This section addresses configuring SD-WAN rules and routing policies to control and direct traffic flow across different links.
主題 2
  • Analytics: This domain covers analyzing SD-WAN and FortiSASE logs to monitor traffic behavior, identify security threats, and generate reports.
主題 3
  • Decentralized SD-WAN: This domain covers basic SD-WAN implementation including configuring members, zones, and performance SLAs to monitor network quality.
主題 4
  • Secure Internet Access (SIA) and Secure SaaS Access (SSA): This section focuses on implementing security profiles for content inspection and deploying compliance rules to managed endpoints.
主題 5
  • SASE Deployment: This domain covers FortiSASE administration settings, user onboarding methods, and integration with SD-WAN infrastructure.
值得信賴的NSE5_SSE_AD-7.6考古题推薦和資格考試中的領先供應商和考試認證Fortinet Fortinet NSE 5 - FortiSASE and SD-WAN 7.6 Core Administrator您應該尋找那些真實可信的題庫商提供的NSE5_SSE_AD-7.6題庫資料,這樣對您通過考試是更有利,可信度高的Fortinet NSE5_SSE_AD-7.6題庫可幫助您快速通過認證考試,而KaoGuTi公司就是這樣值得您信賴的選擇。NSE5_SSE_AD-7.6題庫資料中的每個問題都由我們專業人員檢查審核,為考生提供最高品質的考古題。如果您希望在短時間內獲得Fortinet NSE5_SSE_AD-7.6認證,您將永遠找不到比KaoGuTi更好的產品了。
最新的 Fortinet Network Security Expert NSE5_SSE_AD-7.6 免費考試真題 (Q32-Q37):問題 #32
What is a key use case for FortiSASE Secure Internet Access (SIA) in an agentless deployment? (Choose one answer)
  • A. It distributes a PAC file to secure non-web traffic protocols and applies antivirus protection only for managed endpoints.
  • B. It requires FortiClient endpoints and supports ZTNA tags to secure all network traffic for unmanaged endpoints.
  • C. It provides secure web browsing by isolating browser sessions and enforcing data loss prevention for temporary employees.
  • D. It acts as a secure web gateway (SWG) distributing a PAC file for explicit web proxy use, securing HTTP and HTTPS traffic with a full security stack, and is ideal for unmanaged endpoints like contractors.
答案:D
解題說明:
According to theFortiSASE 7.6 Administration Guideand theFCP - FortiSASE 24/25 Administrator curriculum, the Agentless deployment mode-commonly referred to asSecure Web Gateway (SWG)mode- is a vital component of the Secure Internet Access (SIA) framework.
* Deployment Mechanism: In an agentless deployment, FortiSASE functions as an explicit web proxy.
This is achieved by distributing aPAC (Proxy Auto-Configuration) fileto the user's browser, which instructs the device to send its web traffic to the nearest FortiSASE Point of Presence (PoP).
* Target Use Case: This mode is specifically designed forunmanaged endpoints, such as those used by contractors, partners, or temporary workers, where the organization does not have the authority or capability to install the FortiClient agent.
* Security Capabilities: Even without an agent, FortiSASE applies afull security stackto the redirected traffic. This includesWeb Filtering,Anti-Malware,SSL Inspection, andInline-CASBto secure HTTP and HTTPS sessions.
* Protocol Limitations: Because it relies on proxy settings, this mode is limited to web protocols (HTTP
/HTTPS) and does not inherently secure non-web traffic like ICMP, DNS, or custom TCP/UDP applications unless they are specifically proxied.
* Option A: While it provides secure browsing, session isolation (RBI) is a specific feature that can be used in either mode; the defining characteristic of the agentless use case is the proxy-based redirection for unmanaged devices.
* Option C: A PAC file can only secure web traffic (protocols that support proxying), not non-web traffic protocols.
* Option D: Agentless mode is the opposite of requiring FortiClient; ZTNA tags generally require the FortiClient agent to provide the necessary telemetry for tag evaluation.
問題 #33
You want FortiGate to use SD-WAN rules to steer local-out traffic.
Which two constraints should you consider? (Choose two.)
  • A. By default, FortiGate uses SD-WAN rules only for local-out traffic that corresponds to ping and traceroute.
  • B. You can steer local-out traffic only with SD-WAN rules that use the manual strategy.
  • C. By default, local-out traffic does not use SD-WAN.
  • D. You must configure each local-out feature individually to use SD-WAN.
答案:C,D
解題說明:
By default, local-out traffic does not use SD-WAN → FortiGate normally sends local-out traffic (e.g., DNS, NTP, FortiGuard updates) directly through its interfaces without applying SD-WAN rules.
You must configure each local-out feature individually to use SD-WAN → To steer local-out traffic via SD-WAN, you must explicitly configure the desired local-out features (e.g., DNS, FortiGuard, CAPWAP) to use SD-WAN rules.
問題 #34
You have configured the performance SLA with the probe mode as Prefer Passive.
What are two observable impacts of this configuration? (Choose two.)
  • A. FortiGate passively monitors the member if TCP traffic is passing through the member.
  • B. FortiGate passively monitors the member if ICMP traffic is passing through the member.
  • C. During passive monitoring, the SLA performance rule cannot detect dead members.
  • D. After FortiGate switches to active mode, the SLA performance rule falls back to passive monitoring after 3 minutes.
  • E. FortiGate can offload the traffic that is subject to passive monitoring to hardware.
答案:A,C
解題說明:
When "Prefer Passive" is set, FortiGate attempts to passively monitor the health of SD-WAN members using real application traffic like TCP sessions, collecting statistics such as latency, jitter, and packet loss from actual observed flows.
Passive monitoring does not generate probe packets; it relies entirely on existing traffic. If there is no matching traffic, health check data is unavailable, meaning dead members may go undetected when only passive monitoring is active.
問題 #35
Which statement is true about FortiSASE supported deployment?
  • A. FortiSASE supports VPN mode and Agentless mode, based on user requirements.
  • B. FortiSASE operates only in SWG mode, where all traffic is forced through FortiSASE POPs.
  • C. FortiSASE relies on ZTNA-only mode, which replaces SWG and endpoint functions.
  • D. FortiSASE supports both Endpoint mode and SWG mode, depending on deployment.
答案:D
解題說明:
FortiSASE supports multiple deployment options, including Endpoint mode (using FortiClient) and SWG mode (agentless), allowing organizations to choose the method that best fits their access and security requirements.
問題 #36
Which FortiSASE feature monitors SaaS application performance and connectivity to points of presence (POPs)?
  • A. FortiView dashboards
  • B. Event logs
  • C. Operations widgets
  • D. Digital experience monitoring
答案:D
解題說明:
The Digital Experience Monitor (DEM) feature on FortiSASE provides end-to-end network visibility by monitoring the performance and health of connections between FortiSASE security Points of Presence (PoPs) and specific SaaS applications, allowing IT teams to troubleshoot connectivity issues and ensure smooth user experience.
問題 #37
KaoGuTi是個可以滿足很多客戶的需求的網站。有些使用我們類比測試軟體已經通過相關IT認證考試的人成為了KaoGuTi的回頭客。KaoGuTi可以提供領先的Fortinet 培訓技術助你通過Fortinet NSE5_SSE_AD-7.6 認證考試。
NSE5_SSE_AD-7.6最新試題: https://www.kaoguti.com/NSE5_SSE_AD-7.6_exam-pdf.html
P.S. KaoGuTi在Google Drive上分享了免費的、最新的NSE5_SSE_AD-7.6考試題庫:https://drive.google.com/open?id=1anDD8VlgbVHfq2bqN3RqDkzcIIFVmEkb
Posted at 2/21/2026 20:58:02        Only Author  2#
The article is so amazing, I’m grateful for your share! This H11-861_V4.0 reliable dumps ppt helped me get promoted and earn a pay raise. Now it’s free for everyone. Best wishes for your career advancements!
