1z0-076 Reliable Exam Papers, 1z0-076 Minimum Pass Score
Posted at 1/21/2026 19:26:48
DOWNLOAD the newest TrainingQuiz 1z0-076 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=10yxsN2CE-B8bv_0X46Wz252Z0X1i8cUu
Our product boosts many merits and high passing rate. Our products have 3 versions and we provide free update of the Oracle exam torrent to you. If you are the old client you can enjoy the discounts. Most important of all, as long as we have compiled a new version of the 1z0-076 Exam Questions, we will send the latest version of our Oracle exam questions to our customers for free during the whole year after purchasing. Our product can improve your stocks of knowledge and your abilities in some area and help you gain the success in your career.
If you are craving for getting promotion in your company, you must master some special skills which no one can surpass you. To suit your demands, our company has launched the Oracle 1z0-076 exam materials especially for office workers. For on one hand, they are busy with their work, they have to get the Oracle 1z0-076 Certification by the little spread time.
Ace exam on your first attempt with actual Oracle 1z0-076 questionsIn order to allow our customers to better understand our 1z0-076 quiz prep, we will provide clues for customers to download in order to understand our 1z0-076 exam torrent in advance and see if our products are suitable for you. As long as you have questions, you can send us an email and we have staff responsible for ensuring 24-hour service to help you solve your problems. We do not charge extra service fees, but the service quality is high. Your satisfaction is the greatest affirmation for us and we sincerely serve you. Our 1z0-076 Exam Guide deliver the most important information in a simple, easy-to-understand language that you can learn efficiently learn with high quality. Whether you are a student or an in-service person, our 1z0-076 exam torrent can adapt to your needs.
Oracle Database 19c: Data Guard Administration Sample Questions (Q66-Q71):NEW QUESTION # 66
Which three are prerequisites for enabling Fast-Start Failover?
- A. The Fast-Start Failover target standby database must receive REDO synchronously when the configuration operates in Maximum Availability mode.
- B. A static service name must be configured only for the Fast-Start Failover target standby database.
- C. The Fast-Start Failover target standby database may receive REDO either synchronously or asynchronously when the configuration operates in Maximum Performance mode.
- D. Flashback Database must be enabled on the primary database.
- E. Flashback Database must be enabled on the Fast-Start Failover target standby database.
Answer: A,D,E
NEW QUESTION # 67
You are planning to perform block comparison using the dbms comp package:
Which TWO statements are true?
- A. It requires that the DB_LOST_WKITE_protect initialization parameter be enabled.
- B. Logical standby databases can be the target database for the dbms_dbcomp.dbcomp procedure.
- C. It can be used to detect lost writes and inconsistencies between the primary database and the cascaded standbys.
- D. You can monitor the progress of an ongoing block comparison operation by querying VS SES SION_LONGOPS.
- E. The databases should be at least mounted before block comparison.
Answer: D,E
The DBMS_COMPARISON package, used for comparing and converging data objects within a single database or between databases, requires that the databases involved in the block comparison be at least mounted (A). This allows the procedure to access the data blocks for comparison. Additionally, the progress of long-running operations such as block comparison can be monitored using the dynamic performance view V$SESSION_LONGOPS (D), which provides information on the operation's progress and estimated completion time.
Oracle Database PL/SQL Packages and Types Reference provides comprehensive details on the DBMS_COMPARISON package, including its procedures and how to monitor their progress. Additionally, Oracle Database Reference explains the V$SESSION_LONGOPS view, which is commonly used for monitoring long operations in the database.
NEW QUESTION # 68
Suppose that you manage the following databases in your environment:
* boston: Primary database with a single PDB called DEVI
* london: Physical standby database protecting the PDB called DEVI
* orcl: Stand-alone database with a single PDB called PDB1 as a remote clone source You are planning to run the following command to create a remote clone in the primary database (boston) using pdbi in orcl:
Which are the THREE prerequisites for automating instantiation of the PDB in the standby database (london)?
- A. Open PDBI (remote clone source) in Read Only.
- B. Enable Active Data Guard in the _ondon database.
- C. Open PDBI (remote clone source) in Read Write.
- D. Set STANDBY_FILE_MANAGEMENT to auto in the london database.
- E. Set STANDBY_PDB_SOURCE_FILE_DIRECTORY to <location of the PDB> in the london database.
- F. Set standby_pdb_source_file_dblink to clone_link in the london database.
Answer: A,D,E
To automate the instantiation of a PDB in the standby database after creating a remote clone in the primary database, certain conditions must be met:
Open PDBI (remote clone source) in Read Only (A): The source PDB from which the clone is created must be open in read-only mode to ensure a consistent state during cloning.
Set STANDBY_PDB_SOURCE_FILE_DIRECTORY to <location of the PDB> in the london database (C): This parameter specifies the location on the standby database where the files from the source PDB should be placed.
Set STANDBY_FILE_MANAGEMENT to auto in the london database (F): This parameter automates the management of file changes on the standby database when structural changes occur on the primary database, ensuring that the clone operation is reflected automatically on the standby.
Oracle Multitenant Administrator's Guide
Oracle Data Guard Broker documentation
NEW QUESTION # 69
You must configure flashback database for your Oracle 19c databases that will be part of a Data Guard Broker configuration.
The databases are all in ARCHIVELOG mode.
You will execute the SQL statement:
ALTER DATABASE FLASHBACK ON;
Which three are true concerning this command?
- A. It will execute successfully on an Oracle 19c physical standby database while Real Time Query is active.
- B. It will execute successfully on an Oracle 19c logical standby database while SQL apply is active.
- C. It will execute successfully while an Oracle 19c primary database is mounted.
- D. If executed successfully on an Oracle 19c primary database, flashback will also be enabled on all physical standby databases that are part of the configuration.
- E. It will execute successfully while an Oracle 19c primary database is open.
- F. If executed successfully on an Oracle 19c primary database, flashback will also be enabled on all logical standby databases that are part of the configuration.
Answer: B,C,E
The command ALTER DATABASE FLASHBACK ON; enables the Flashback Database feature, which provides a way to quickly revert an entire Oracle database back to a previous point in time. This command can be executed while an Oracle 19c primary database is either open (option A) or mounted (option B). It is also applicable to an Oracle 19c logical standby database while SQL Apply is active (option E). However, it's important to note that enabling Flashback Database on the primary does not automatically enable it on all associated standby databases, whether they are physical or logical. Each database in a Data Guard configuration must have Flashback Database explicitly enabled if desired. Real Time Query being active on a physical standby does not directly relate to the ability to execute this command on the standby. References:
The explanation is based on Oracle's concepts for Flashback Technology and Data Guard configurations as detailed in the Oracle Database Backup and Recovery User's Guide and the Oracle Data Guard Concepts and Administration guide.
NEW QUESTION # 70
Which three are true about using RMAN in a Data Guard environment?
- A. A recovery catalog is required when RMAN is used to take backups from a logical standby database in a Data Guard configuration if you plan to recover the primary using those backups.
- B. Backups of control files taken on a physical standby are not interchangeable with a primary.
- C. Backups of archived redo logs taken on a physical standby are interchangeable with a primary.
- D. A recovery catalog is required when RMAN is used to take backups from a physical standby database if you plan to recover the primary using those backups.
- E. Backups of data files taken on a physical standby are interchangeable with a primary.
Answer: B,C,E
NEW QUESTION # 71
TrainingQuiz offers a full refund guarantee according to terms and conditions if you are not satisfied with our 1z0-076 product. You can also get free Oracle Dumps updates from TrainingQuiz within up to 365 days of purchase. This is a great offer because it helps you prepare with the Latest 1z0-076 Dumps even in case of real Oracle Database 19c: Data Guard Administration (1z0-076) exam changes.
1z0-076 Minimum Pass Score: https://www.trainingquiz.com/1z0-076-practice-quiz.html
Why don't you just join them?There is a big chance that you will be glad you choose 1z0-076 Minimum Pass Score - Oracle Database 19c: Data Guard Administration exam study materials for well preparation, The contents of 1z0-076 study materials are all compiled by industry experts based on the examination outlines and industry development trends over the years, You may feel astonished and doubtful about this figure; but we do make our 1z0-076 exam dumps well received by most customers.
This change won't affect the generated JavaScript at all, Viewport Context 1z0-076 Trustworthy Exam Content Menu, Why don't you just join them?There is a big chance that you will be glad you choose Oracle Database 19c: Data Guard Administration exam study materials for well preparation.
Realistic 1z0-076 Reliable Exam Papers & Leader in Qualification Exams & Authoritative 1z0-076: Oracle Database 19c: Data Guard AdministrationThe contents of 1z0-076 Study Materials are all compiled by industry experts based on the examination outlines and industry development trends over the years.
You may feel astonished and doubtful about this figure; but we do make our 1z0-076 exam dumps well received by most customers, Yes you read it right, If our 1z0-076 exam dumps didn't help you pass, we will issue a refund - no other questions asked.
As long as you have a look at them, you will 1z0-076 find that there is no question of inaccuracy and outdated information in them.
- 100% Pass 2026 Oracle High Pass-Rate 1z0-076 Reliable Exam Papers 👹 Open website ➽ [url]www.prepawayexam.com 🢪 and search for ⏩ 1z0-076 ⏪ for free download ✈1z0-076 Torrent[/url]
- Intereactive 1z0-076 Testing Engine 🚚 1z0-076 Torrent 🚚 Top 1z0-076 Exam Dumps 🧜 Search for ✔ 1z0-076 ️✔️ and obtain a free download on ➥ [url]www.pdfvce.com 🡄 🔝Intereactive 1z0-076 Testing Engine[/url]
- 1z0-076 Valid Exam Duration 🥝 Testking 1z0-076 Learning Materials 🌲 New 1z0-076 Exam Price 🛣 Download ✔ 1z0-076 ️✔️ for free by simply entering ☀ [url]www.testkingpass.com ️☀️ website 🎹1z0-076 Trustworthy Dumps[/url]
- Oracle 1z0-076 Exam Dumps - Key To Getting Success 🥞 Open [ [url]www.pdfvce.com ] enter ▶ 1z0-076 ◀ and obtain a free download 🔊1z0-076 Torrent[/url]
- Intereactive 1z0-076 Testing Engine 🎈 New 1z0-076 Exam Price 🚪 1z0-076 Latest Guide Files 🦜 Search on ⇛ [url]www.examcollectionpass.com ⇚ for { 1z0-076 } to obtain exam materials for free download 🔃1z0-076 Exam Format[/url]
- Passing 1z0-076 Exam Prep Materials - 1z0-076 Valid Braindumps - Pdfvce 🍤 Open 《 [url]www.pdfvce.com 》 enter ➽ 1z0-076 🢪 and obtain a free download 🥒1z0-076 Torrent[/url]
- Oracle 1z0-076 Exam Dumps - Key To Getting Success 🍈 Download 「 1z0-076 」 for free by simply searching on ⇛ [url]www.testkingpass.com ⇚ 📗Top 1z0-076 Exam Dumps[/url]
- User-Friendly Oracle 1z0-076 Exam Questions in PDF Format 😜 Open ➽ [url]www.pdfvce.com 🢪 enter 《 1z0-076 》 and obtain a free download 🥨Intereactive 1z0-076 Testing Engine[/url]
- Braindumps 1z0-076 Torrent 🌶 1z0-076 100% Accuracy 🤎 Free 1z0-076 Pdf Guide 👆 Go to website ➽ [url]www.dumpsquestion.com 🢪 open and search for 【 1z0-076 】 to download for free 🌛1z0-076 Exam Format[/url]
- Passing 1z0-076 Exam Prep Materials - 1z0-076 Valid Braindumps - Pdfvce 🔗 Search on “ [url]www.pdfvce.com ” for ▛ 1z0-076 ▟ to obtain exam materials for free download 💖1z0-076 Exam Exercise[/url]
- Top 1z0-076 Exam Dumps 😎 1z0-076 Exam Exercise ⏪ Free 1z0-076 Pdf Guide ❤ Search for ⇛ 1z0-076 ⇚ and obtain a free download on 【 [url]www.vce4dumps.com 】 🩺1z0-076 Exam Format[/url]
- www.pcsq28.com, www.bandlab.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, k12.instructure.com, Disposable vapes
2026 Latest TrainingQuiz 1z0-076 PDF Dumps and 1z0-076 Exam Engine Free Share: https://drive.google.com/open?id=10yxsN2CE-B8bv_0X46Wz252Z0X1i8cUu
