[General] 100% Pass Oracle - 1Z0-106 - Oracle Linux 8 Advanced System Administration Lates
59
General 100% Pass Oracle - 1Z0-106 - Oracle Linux 8 Advanced System Administration Lates
Posted at 1/29/2026 04:23:44      View139 | Replies0        Print      Only Author   [Copy Link] 1#
2026 Latest Fast2test 1Z0-106 PDF Dumps and 1Z0-106 Exam Engine Free Share: https://drive.google.com/open?id=1tbQ65_FByKio_5pT9SnLb6F85QYT0CKc
Fast2test can promise that our 1Z0-106 training material have a higher quality when compared with other study materials. With over a decade's business experience, our 1Z0-106 study tool has attached great importance to customers' purchasing rights all along. The 1Z0-106 study materials of our website do not affect the user's normal working and learning, and greatly improves the utilization rate of time, killing two birds with one stone. It is no doubt that our study materials will help you pass your 1Z0-106 Exam in a shortest time.
Fast2test never sells the useless 1Z0-106 certification 1Z0-106 exam dumps out. You will receive our 1Z0-106 exam dumps in time and get Professional Oracle Linux 8 System Administrator Certified easily. Try 1Z0-106 Exam free demo before you decide to buy it in Fast2test. After you buy Fast2test certification 1Z0-106 exam dumps, you will get free update for ONE YEAR!
Valid Braindumps 1Z0-106 Ebook, 1Z0-106 Accurate AnswersFast2test helps you in doing self-assessment so that you reduce your chances of failure in the examination of Oracle Linux 8 Advanced System Administration (1Z0-106) certification. Similarly, this desktop 1Z0-106 practice exam software of Fast2test is compatible with all Windows-based computers. You need no internet connection for it to function. The Internet is only required at the time of product license validation.
Preparation for the Oracle 1Z0-106 Certification Exam requires knowledge and experience in Oracle Linux 8 administration. Candidates should have a deep understanding of Linux commands and tools, network configuration, security management, performance tuning, and kernel management. Several resources are available to prepare for the exam, such as training courses, online training modules, and hands-on labs. By successfully completing the Oracle 1Z0-106 Certification Exam, an Oracle Certified Professional (OCP) designation is awarded to the candidate, which validates their skills and knowledge in Oracle Linux 8 advanced system administration.
Oracle Linux 8 Advanced System Administration Sample Questions (Q24-Q29):NEW QUESTION # 24
Examine these requirements for a host with a user oracle:
Network services must run in a confined domain.
The oracle user must be confined.
The oracle user must be able to use Mozilla Firefox.
Access to files and directories must be granted based only on SELinux contexts.
The SELinux configuration must be persistent across system restarts.
Users must be able to publish private HTML content.
Now examine these commands and output:
# sestatus
SELinux status: enabled
SELinuxfs mount: /sys/fs/selinux
SELinux root directory: /etc/selinux
Loaded policy name: targeted
Current mode: permissive
Mode from config file: permissive
Policy MLS status: enabled
Policy deny_unknown status: allowed
Memory protection checking: actual (secure)
Max Kernel policy version: 31
# setenforce enforcing
# semanage login -a -s guest_u oracle
# setsebool -P http_enable_homedirs on
Which requirements are satisfied?
  • A. 1, 2, 3, 5, 6
  • B. 1, 2, 3, 4, 5, 6
  • C. 1, 2, 3, 6
  • D. 1, 2, 6
  • E. 1, 2, 4, 5, 6
  • F. 1, 2, 4, 6
Answer: E
NEW QUESTION # 25
Which two features does a user private group provide?
  • A. Ability for only a group's users to read files in a new directory
  • B. Capability to create new group users
  • C. Capability to execute sudo
  • D. Provision of a unique group.
  • E. Capability to prevent other users from modifying a file
Answer: D,E
* Option A (Correct):A user private group (UPG) ensures that each user has their own unique group created with the same name and ID as the user.
* Option E (Correct):The UPG model helps prevent other users from modifying files by default, as newly created files are assigned to the user's unique group and not to a shared group.
* Option B (Incorrect):UPG does not give the capability to create new group users; this is related to group management commands.
* Option C (Incorrect):UPG does not providesudocapabilities;sudoconfiguration is managed separately.
* Option D (Incorrect):UPGs do not limit reading files to group users by default; it depends on specific file permissions.
Oracle Linux Reference:Refer to:
* OracleLinux 8: Managing Users and Groups
NEW QUESTION # 26
Which command configures a fully functional and accessible interface on VLAN 800?
  • A. modprobe 8021q ip link add link eth0 name eth0.800 type vlan id 800 ip address add 10.135.1.120/24 dev eth0.800 ip link set eth0.800 up
  • B. modprobe 8021q ip address add 10.135.1.120/24 dev eth0.800 ip link set eth0.800 up
  • C. modprobe 8021q ip link add link eth0 name eth0.800 VLAN 800 ip address add 10.135.1.120/24 dev eth0.800 ip link set eth0.800 up
  • D. modprobe 8021q ip link add link eth0 name eth0.800 type vlan id 800 ip link set eth0.800 up
NEW QUESTION # 27
Which two methods of changing kernel parameters can you use to modify values for the running system?
  • A. Issuing the sysctl -w command to write values to specific files in the /sys directory.
  • B. Using the echo command to write values to specific files in the /sys directory.
  • C. Issuing the sysctl -w command to write values to specific files in the /proc/sys directory.
  • D. Adding to or modifying parameters and values in the /etc/sysctl.conf file followed by issuing the sysctl - p command.
  • E. Using the echo command to write values to specific files in the /proc/sys directory.
Answer: C,E
Explanation of Answer A:Thesysctl -wcommand is used to modify kernel parameters at runtime. It allows you to set the value of a specific parameter in the/proc/sysdirectory. For example,sysctl -w net.ipv4.
ip_forward=1will enable IP forwarding by writing the value directly to the corresponding file in/proc/sys.
Explanation of Answer B:Using theechocommand to write values directly to specific files in the/proc
/sysdirectory is another method to change kernel parameters dynamically for the running system. For instance, echo 1 > /proc/sys/net/ipv4/ip_forwardachieves the same effect as thesysctl -wcommand.
NEW QUESTION # 28
Examine this udev device naming rule which gets processed successfully:
makefile
KERNEL=="hdb", DRIVER=="ide-disk", SYMLINK+="sparedisk"
Which two statements are true?
  • A. Symbolic link /dev/sparedisk is created linking to /dev/hdb and with an ide-disk device driver, thus overwriting existing symbolic links.
  • B. Symbolic link /dev/sparedisk is created for a device named /dev/hdb or one that has an ide-disk device driver, whichever is discovered first.
  • C. The matching device will be named /dev/sparedisk.
  • D. The matching device will have the kernel device name /dev/hdb.
  • E. Symbolic link /dev/sparedisk is created for a device named /dev/hdb which has an ide-disk device driver if such a device is discovered.
Answer: D,E
NEW QUESTION # 29
Tracking and reporting features of this 1Z0-106 practice test enables you to assess and enhance your progress. The third format of Fast2test product is the desktop Oracle 1Z0-106 practice exam software. It is an ideal format for those users who dont have access to the internet all the time. After installing the software on Windows computers, one will not require the internet. The desktop 1Z0-106 Practice Test software specifies the web-based version.
Valid Braindumps 1Z0-106 Ebook: https://www.fast2test.com/1Z0-106-premium-file.html
