[General] 100% Pass Salesforce - AP-202 - Pass-Sure B2B Commerce for Developers Accredited
94
【General】 100% Pass Salesforce - AP-202 - Pass-Sure B2B Commerce for Developers Accredited
Posted at 2/3/2026 15:04:35      View:94 | Replies:1        Print      Only Author   [Copy Link] 1#
All we want you to know is that people are at the heart of our manufacturing philosophy, for that reason, we place our priority on intuitive functionality that makes our AP-202 Exam Question to be more advanced. So with our AP-202 guide torrents, you are able to pass the exam more easily in the most efficient and productive way and learn how to study with dedication and enthusiasm, which can be a valuable asset in your whole life. It must be your best tool to pass your exam and achieve your target.
We are the fastest to pursue acquiring AP-202 certification; we are the highest to pursue protecting your benefits. Our PrepAwayExam ensures the accuracy and the most coverage of AP-202 Certification Exam Dumps. If you purchase AP-202 certification exam dumps, we will ensure that you can get free update service in one year.
Reliable Salesforce AP-202 Exam Question, AP-202 Regualer UpdateThe experts in our company have been focusing on the AP-202 examination for a long time and they never overlook any new knowledge. The content of our AP-202 study materials has always been kept up to date. Don't worry if any new information comes out after your purchase of our AP-202 Study Guide. We will inform you by E-mail when we have a new version. We can ensure you a pass rate as high as 99%. If you don't pass the AP-202 exam, you will get a refund. Why not study and practice for just 20 to 30 hours and then pass the examination?
Salesforce B2B Commerce for Developers Accredited Professional Sample Questions (Q83-Q88):NEW QUESTION # 83
Which three files comprise the essential pieces of a Lightning Web Component that is named myComponent?
  • A. myNewComponent.css
  • B. myComponent.js-meta.xml
  • C. myComponent.html
  • D. myComponent.aura
  • E. myComponent.js
Answer: B,C,E
A Lightning Web Component (LWC) consists of a minimum of three core files: the template file (.html), the JavaScript file (.js), and the metadata configuration file (.js-meta.xml). These files are essential for defining the structure, functionality, and configuration of the component. For more information, review the Salesforce LWC documentation: Salesforce LWC Documentation.
NEW QUESTION # 84
What are three ways to test the value of Page Label on any Salesforce B2B Commerce Community Page? (3 answers)
  • A. Enable the 'display page label names' in cc admin.
  • B. Access the source HTML for the page viathe browser developer tools.
  • C. Execute CCRZ.processPageLabelMap('PAGE_LABEL_NAME') in the JavaScript console.
  • D. Execute CCRZ.pagevars.pageLabels['PAGE_LABEL_NAME') in the JavaScript console.
  • E. Execute (('PAGE_LABEL_NAME')) in the JavaScript console
Answer: A,C,D
Three ways to test the value of Page Label on any Salesforce B2B Commerce Community Page are:
Execute CCRZ.pagevars.pageLabels['PAGE_LABEL_NAME'] in the JavaScript console. This will return the value of the page label with the given name from the pagevars object, which contains all the page labels that are used on the page.
Execute CCRZ.processPageLabelMap('PAGE_LABEL_NAME') in the JavaScript console. This will return the value of the page label with the given name from the pageLabelMap object, which contains all the page labels that are defined in CCAdmin.
Enable the 'display page label names' in cc admin. This will display the name of each page label next to its value on the storefront pages, which can help identify and verify the page labels. Salesforce B2B Commerce and D2C Commerce Developer Guide,Page Labels
NEW QUESTION # 85
Which handlebars helper expression is used in Salesforce B2B Commerce pages and components to toggle the display of a block of markup?
  • A. {{#ifStoreSetting 'Field__c'}} ... {{/ifStoreSetting}}
  • B. {{#ifDisplay 'Page.cfg'}} ... {{/ifDisplay}}
  • C. {{#ifConfig 'Field__c'}} ... {{/ifConfig}}
  • D. {{#ifSetting 'Page.cfg}} ... {{/ifSetting}}
The handlebars helper expression that is used in Salesforce B2B Commerce pages and components to toggle the display of a block of markup is {{#ifConfig 'Field__c'}} ... {{/ifConfig}}. This expression will evaluate the value of the configuration setting with the API name Field__c and render the block of markup if the value is true, or skip it if the value is false. For example,{{#ifConfig 'CO.showMiniCart'}} <div id="mini-cart"> ... </div> {{/ifConfig}}will render the mini-cart div only if the configuration setting CO.showMiniCart is true. Salesforce B2B Commerce and D2C Commerce Developer Guide,Handlebars Helpers
NEW QUESTION # 86
Which element can be used to pass HTML from a parent component to a child component? 03m 19s
  • A. <template></template>
  • B. <p></p>
  • C. <html></html>
  • D. <slot></slot>
:To pass HTML from a parent component to a child component, the child component needs to have a<slot></slot>element in its template. A slot is a placeholder for markup that a parent component passes into a component's body. Slots are part of the Web Component specification. The parent component can use the slot name or the default slot to specify which HTML content goes into which slot of the child component. The other options are not valid elements for passing HTML from parent to child.Reference:
Slots
Pass HTML Markup From Parent TO CHILD In Lightning Web Component
How parent component pass HTML to child component in Angular?
NEW QUESTION # 87
Which practice is allowed when it comes to naming a Lightning web component's folder and associated files?
  • A. Using consecutive underscores
  • B. Using a single hyphen (dash)
  • C. Including whitespace
  • D. Using a single underscore
To name a Lightning web component's folder and associated files, the developer should follow these naming rules:
Must begin with a lowercase letter
Must contain only alphanumeric or underscore characters
Must be unique in the namespace
Can't include whitespace
Can't end with an underscore
Can't contain two consecutive underscores
Can't contain a hyphen (dash)
The only exception to the last rule is when separating the namespace from the component name in markup. For example, if the component is in the example namespace and has the name myComponent, the folder name should be myComponent, but the markup tag should be <example-my-component>. The hyphen character (-) is required by the HTML standard for custom element names. The other options are either invalid or not recommended. For example, including whitespace or using consecutive underscores will cause errors, and using a single underscore will look odd and may confuse developers consuming the component.B2B Commerce and D2C Commerce Developer Guide,Lightning Web Components Developer Guide
NEW QUESTION # 88
AP-202 practice dumps offers you more than 99% pass guarantee, which means that if you study our AP-202 learning guide by heart and take our suggestion into consideration, you will absolutely get the certificate and achieve your goal. Meanwhile, if you want to keep studying this course , you can still enjoy the well-rounded services by AP-202 Test Prep, our after-sale services can update your existing AP-202 study quiz within a year and a discount more than one year.
Reliable AP-202 Exam Question: https://www.prepawayexam.com/Salesforce/braindumps.AP-202.ete.file.html
This is because you have hands-on the most updated and most reliable Salesforce AP-202 questions created under the supervision of 90,000 Salesforce professionals, Salesforce AP-202 Latest Mock Test The latest updated and actual material is provided with 100% accuracy according to the real exam, The PrepAwayExam AP-202 certification exam assists you to climb the corporate ladder easily and helps you to achieve your professional career objectives, To assist you in the objective of cracking the Salesforce AP-202 Exam, Salesforce AP-202 Dumps is offering a study material which comes in three versions and meets all needs of your exam preparation.
In After Effects, when a comp is nested in Reliable AP-202 Exam Question another comp, effectively becoming a layer, the ordinary behavior is for the nested comp to render completely before the layer is AP-202 animated, blended, or otherwise adjusted with effects or masks) in the master comp.
AP-202 Latest Mock Test 100% Pass | Professional Reliable AP-202 Exam Question: B2B Commerce for Developers Accredited ProfessionalAbstraction and Generalization, This is because you have hands-on the most updated and most reliable Salesforce AP-202 Questions created under the supervision of 90,000 Salesforce professionals.
The latest updated and actual material is provided with 100% accuracy according to the real exam, The PrepAwayExam AP-202 certification exam assists you to climb the corporate AP-202 Exam Simulator Free ladder easily and helps you to achieve your professional career objectives.
And here, fortunately, you have found the AP-202 study materials, a learning platform that can bring you unexpected experiences.
Posted at 2/10/2026 22:45:12        Only Author  2#
Your article is outstanding, thank you for sharing! Best of luck with your exam preparation! FCSS_ADA_AR-6.7 test topics pdf questions are free for you to use!
