[General] Training Nutanix NCA-6.10 Kit & New NCA-6.10 Test Notes
93
【General】 Training Nutanix NCA-6.10 Kit & New NCA-6.10 Test Notes
Posted at 1/21/2026 00:25:21      View:96 | Replies:0        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 Nutanix NCA-6.10 dumps are available on Google Drive shared by TestBraindump: https://drive.google.com/open?id=13b5ndTTGGW5xGZW4cKNdhw4H_Evd8Ft5
There are a lot of the functions on our NCA-6.10 exam questions to help our candidates to reach the best condition befor they take part in the real exam. I love the statistics report function and the timing function most. The statistics report function helps the learners find the weak links and improve them accordingly. The timing function of our NCA-6.10 training quiz helps the learners to adjust their speed to answer the questions and keep alert and our NCA-6.10 study materials have set the timer.
Our NCA-6.10 study questions in every year are summarized based on the test purpose, every answer is a template, there are subjective and objective NCA-6.10 exams of two parts, we have in the corresponding modules for different topic of deliberate practice. To this end, our NCA-6.10 training materials in the qualification exam summarize some problem- solving skills, and induce some generic templates. The user can scout for answer and scout for score based on the answer templates we provide, so the universal template can save a lot of precious time for the user to study and pass the NCA-6.10 Exam.
NCA-6.10 Valid Test & NCA-6.10 Cert Material & NCA-6.10 Sure Pass ExamIt is known to us that the NCA-6.10 exam braindumps have dominated the leading position in the global market with the decades of painstaking efforts of our experts and professors. There are many special functions about study materials to help a lot of people to reduce the heavy burdens when they are preparing for the exams. For example, the NCA-6.10 study practice question from our company can help all customers to make full use of their sporadic time. Just like the old saying goes, time is our product by a good at using sporadic time person, will make achievements. If you can learn to make full use of your sporadic time to preparing for your NCA-6.10 Exam, you will find that it will be very easy for you to achieve your goal on the exam. Using our study materials, your sporadic time will not be wasted, on the contrary, you will spend your all sporadic time on preparing for your NCA-6.10 exam.
Nutanix Certified Associate v6.10 Sample Questions (Q62-Q67):NEW QUESTION # 62
What is the purpose of the OpLog?
  • A. Global metadata
  • B. Dynamic read cache
  • C. Persistent data storage
  • D. Persistent write buffer
The OpLog (Operational Log) in Nutanix serves as apersistent write bufferfor incoming I/O operations. It temporarily stores write requests to ensure fast acknowledgment to clients and better performance. The data is later coalesced and written to the Extent Store for long-term storage.
* A. Persistent write buffer:Correct, as the OpLog optimizes write performance by buffering writes temporarily.
* B. Persistent data storage:Incorrect, as this describes the Extent Store, not the OpLog.
* C. Global metadata:Incorrect, as metadata operations are handled by the Metadata Store.
* D. Dynamic read cache:Incorrect, as read caching is managed separately, often involving SSD-based caches.
Nutanix Bible: Explanation of OpLog and Extent Store.
Nutanix University: NCP Certification Study Materials.
NEW QUESTION # 63
An administrator has been directed to ensure that all Prism Element and Prism Central clusters allow Nutanix Support to gather logs without needing engagement.
What should the administrator enable to meet this requirement?
  • A. NKP
  • B. Proxy Server
  • C. Pulse
  • D. Self-Service
NEW QUESTION # 64
Which Nutanix offering allows for extending an on-prem datacenter into the public cloud?
  • A. Nutanix Kubernetes Engine
  • B. Nutanix Cloud Clusters
  • C. Nutanix Cloud Security
  • D. Nutanix Data Services
NEW QUESTION # 65
An administrator needs to ensure that the three VMs of an application cluster are never placed onto the same hypervisor by creating a VM- VM Anti-Affinity Policy.
What should the administrator use to complete this task?
  • A. acli
  • B. Prism Central
  • C. Ncli
  • D. Prism Element
To create a VM-VM Anti-Affinity Policy ensuring VMs are not placed on the same hypervisor,Prism Central is required. Anti-affinity policies are cluster-wide configurations managed through Prism Central's policy- based interface, enabling placement rules to distribute workloads effectively.
Steps:
* Navigate toPrism Central > Policies.
* Create a new Anti-Affinity Policy.
* Select the VMs and configure the policy to ensure separation.
Nutanix Prism Central Guide - Policy Management.
Nutanix Best Practices for VM Placement Policies.
NEW QUESTION # 66
An administrator is considering a data protection strategy between two sites. There is a 10ms round trip latency between the two clusters. Which data protection solution can the administrator implement that minimizes data loss in the event of a disaster?
  • A. Metro Availability
  • B. Synchronous Replication
  • C. Async DR
  • D. NearSync Replication
The correct answer isA. NearSync Replication.
Key Concepts from Official Nutanix Documentation:
Nutanix supports various types of data replication methods depending on the Recovery Point Objective (RPO), Recovery Time Objective (RTO), and the latency between the sites.
* Metro Availabilityrequires a maximum latency of<5ms RTTand is used forzero RPO synchronous replication. Since the given latency is 10ms,Metro Availability is not supportedin this case.
Reference: Nutanix Bible - Metro Availability Section
Prism UI Navigation: Protection Domains > Metro Availability
Synchronous Replicationis often synonymous withMetro Availabilityin Nutanix's implementation. Thus, it is similarly bound by the <5ms RTT requirement.
Async DR (Asynchronous Disaster Recovery)allows for more relaxed RPOs, typically1 hour or more, which doesnot minimize data lossin the event of a disaster.
NearSync Replicationsupports anRPO as low as 1 minuteand issuitable for up to 20ms RTT latency. It utilizeslightweight snapshotsandschedule-based replicationto deliverlow-RPO protectioneven over relatively long distances and moderate latencies.
Reference: Nutanix Data Protection Guide - NearSync Overview
Prism UI Navigation: Data Protection > Protection Domains > Schedule (with 1-minute RPO option) Detailed Source References:
Nutanix Data Protection and DR Guide - v5.x and later:"NearSync replication enables you to achieve RPOs as low as 1 minute and is designed to work with round-trip latencies of up to 20ms." Prism Central UI:Navigate toProtection > Data Protection > Protection Domains > Create Schedule# Set schedule type to "NearSync" and observe the 1-minute RPO options.
Hence, since 10ms RTTexceeds Metro Availability requirementsbut iswell within NearSync's acceptable latency, the best choice thatminimizes data lossis:
NEW QUESTION # 67
Choosing our NCA-6.10 real dumps as your study guide means you choose a smart and fast way to get succeed in the certification exam. There are accurate NCA-6.10 test answers and some explanations along with the exam questions that will boost your confidence to solve the difficulty of NCA-6.10 Practice Test. You will enjoy great benefits if you buy our NCA-6.10 braindumps now and free update your study materials one-year.
New NCA-6.10 Test Notes: https://www.testbraindump.com/NCA-6.10-exam-prep.html
therefore, it has made the Nutanix Certified Associate v6.10 NCA-6.10 dumps format to facilitate you to prepare for the Nutanix Certified Associate v6.10 NCA-6.10 exam, Nutanix Training NCA-6.10 Kit So passing this exam means success to ambitious workers, Our NCA-6.10 actual collection: Nutanix Certified Associate v6.10 are the secret to offer help here which overshadow other practice materials flooded into the market, While, when facing the NCA-6.10 actual test, do you prepare well for it?
As long as visitors receive all content, it doesn't NCA-6.10 matter that the site will look better in compliant browsers than it does in old ones, A network in which data packets sent over the public Internet and are Training NCA-6.10 Kit encapsulated in a protocol that provides for data encapsulation as well as encryption of the user data.
NCA-6.10 Exam Study Guide Materials: Nutanix Certified Associate v6.10 is high pass-rate - TestBraindumptherefore, it has made the Nutanix Certified Associate v6.10 NCA-6.10 Dumps format to facilitate you to prepare for the Nutanix Certified Associate v6.10 NCA-6.10 exam, So passing this exam means success to ambitious workers.
So our NCA-6.10 real quiz is versatile and accessible to various exam candidates.
