[General] Exam Questions CTS Vce - Test CTS Dates
98
General Exam Questions CTS Vce - Test CTS Dates
Posted at 2/16/2026 23:19:40      View142 | Replies1        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 AVIXA CTS dumps are available on Google Drive shared by VCETorrent: https://drive.google.com/open?id=121T908TR1TewfRdRSNC_5cTwFywFXpCH
A free trial of the product allows users to test the material before buying. These different formats allow CTS exam aspirants to practice using their preferred method. The support offered by the VCETorrent is another significant advantage for applicants. The VCETorrent CTS provides 24/7 support for guidance of users. Our team of professionals is highly qualified and have years of experience in the industry. They are available to answer any AVIXA CTS Questions that customers may have. The support team is always available to help applicants use the product.
AVIXA CTS Exam Certification Details:
Non-Member Exam Price$475(USD)
Number of Questions110
Exam NameAVIXA Certified Technology Specialist (CTS)
Books / TrainingCandidate Handbook
Schedule ExamPearson VUE
MemberExam Price$375(USD)
Test CTS Dates, Valid CTS Exam GuideOur users can prove to you that the hit rate of our CTS exam questions is very high. And you can just see the data how many customers are visiting our CTS study materials everyday. And the pass rate is also high as 98% to 100%. You can walk into the examination room with peace of mind, after which you will experience a very calm examination. As for the result, please come home and wait. Our CTS training prep will not disappoint you.
AVIXA CTS - General Exam Syllabus Topics:
TopicWeight
Duty A:Creating AV Solutions47%
Task 1:Gather Customer Information10%
Task 2:Conduct Initial Site Survey9%
Task 3: Evaluate Site Environment (acoustics, lighting, seating, finishing, etc.)9%
Task 4evelop an AV Project Scope9%
Task 5: Design AV Solutions10%
Domain 2:Implementing AV Solutions27%
Task 1:Integrate AV Solutions10%
Task 2:Operate AV Solutions9%
Task 3:Manage AV Projects8%
AVIXA Certified Technology Specialist Sample Questions (Q63-Q68):NEW QUESTION # 63
The FIRST step in troubleshooting an AV system is to
  • A. change only one component at a time.
  • B. clearly identify the failure symptoms.
  • C. ensure that all the system components have power.
  • D. divide the system in half to identify the portion that is not working.
The first step in any troubleshooting process is to clearly identify the failure symptoms to understand the nature and extent of the issue. This step is critical as it guides the entire troubleshooting process by providing a clear description of the problem.
CTS Technology Specialist ReferenceCTS materials on troubleshooting stress the importance of identifying symptoms accurately before proceeding to diagnostics, which helps in forming a systematic approach to problem-solving.
NEW QUESTION # 64
Identify the portion of the connector that carries the signal. Select the answer by clicking anywhere on the correct part of the connector.
The tip portion of the connector.
This is a 1/4-inch TS (Tip-Sleeve) connector, commonly known as an unbalanced mono plug. For these connectors, the tip is the portion responsible for carrying the signal, while the sleeve serves as the ground or return path. In audio applications, TS connectors are typically used for unbalanced signals, such as instrument cables for guitars.
* The tip of the connector is at the very end, identifiable by the small section separated by an insulating ring. This section is where the signal travels.
* The sleeve is the long metal section that connects to the ground.
CTS Technology Specialist ReferenceThe CTS materials on audio connectors detail how TS connectors carry signals, with the tip designated for signal and the sleeve for ground. Recognizing the signal-carrying part is crucial for proper AV connections and troubleshooting.
NEW QUESTION # 65
The MOST important information to come away with from an initial site survey is the
  • A. key decision maker.
  • B. manufacturers which will be used in the AV system.
  • C. final budget for the entire project.
  • D. overall scope AV solution needed.
During an initial site survey, understanding the overall scope of the AV solution provides the foundational insight needed for designing a system that meets client requirements. This ensures alignment with objectives and informs subsequent phases of the project.
CTS Technology Specialist ReferenceThe CTS curriculum advises focusing on the AV solution scope to guide design and implementation processes effectively, ensuring client needs are addressed.
NEW QUESTION # 66
When calibrating a loudspeaker system, which weight setting on the SPi. meter is used for its mdus>on of low frequency sound levels in the measurement?
  • A. Weighted
  • B. Weighted
  • C. Weighted
  • D. Weighted
When calibrating a loudspeaker system, the C-weighted setting on an SPL (Sound Pressure Level) meter is typically used because it provides a relatively flat frequency response, including low-frequency sound levels.
This makes it more suitable for accurately measuring the overall sound pressure level, especially in environments where low-frequency performance is critical, such as in audio and home theater systems. The C-weighted setting captures the full range of audible frequencies, ensuring a comprehensive and precise calibration.
Top of Form
Bottom of Form
NEW QUESTION # 67
Which of the following testing metrics would BEST be applied towards testing a distributed audio system for proper speaker wattages and cabling?
  • A. Low-end system response 60 Hz and below
  • B. High-end frequency response 10 kHz and above
  • C. Audio uniformity in the range of intelligible speech 100 Hz - 2 kHz
  • D. Audio uniformity across the entire spectrum of humanhearing60 Hz - 20 kHz
When testing a distributed audio system, focusing on the audio uniformity in the range of intelligible speech (100 Hz - 2 kHz) is most important. This range is crucial for ensuring that speech is clear and understandable, which is often the primary function of distributed audio systems in environments like schools, offices, and public spaces. Ensuring uniform sound distribution within this frequency range helps achieve consistent audio quality and speech intelligibility across the covered area.
NEW QUESTION # 68
Test CTS Dates: https://www.vcetorrent.com/CTS-valid-vce-torrent.html
BONUS!!! Download part of VCETorrent CTS dumps for free: https://drive.google.com/open?id=121T908TR1TewfRdRSNC_5cTwFywFXpCH
Posted at 2/24/2026 07:06:08        Only Author  2#
What an extraordinary piece of writing, thank you for sharing! The Valid test L4M5 tips questions are freeuse them to unlock promotions and higher earnings!
