312-50v13 Valid Dumps Ppt | 312-50v13 Reliable Study Guide
Posted at 1/21/2026 06:02:31
View161
Replies0
2026 Latest TrainingDumps 312-50v13 PDF Dumps and 312-50v13 Exam Engine Free Share: https://drive.google.com/open?id=17PA8ORM1rKKNqMO-EYK_eiSZa3HsYaLj
It is impossible to overstate the significance of valid 312-50v13 exam questions. The latest and actual 312-50v13 exam questions are essential to clear the 312-50v13 exam in one go. Applicants are better prepared to succeed when they prepare with the updated ECCouncil 312-50v13 Questions. These 312-50v13 exam questions give applicants the knowledge they need to quickly ace the 312-50v13 examination.
We take so much pride in the high pass rate of our 312-50v13 study questions because according to the statistics from the feedbacks of all of our customers, under the guidance of our 312-50v13 exam materials the pass rate has reached as high as 98% to 100%, which marks the highest pass rate in the field. So if you really want to pass the 312-50v13 Exam as well as getting the certification with no danger of anything going wrong, just feel rest assured to buy our 312-50v13 learning guide.
Certified Ethical Hacker Exam (CEHv13) cexamkiller practice dumps & 312-50v13 test training reviewsUsers using our 312-50v13 study materials must be the first group of people who come into contact with new resources. When you receive an update reminder from 312-50v13 practice questions, you can update the version in time and you will never miss a key message. If you use our study materials, you must walk in front of the reference staff that does not use valid 312-50v13 Real Exam. And you will get the according 312-50v13 certification more smoothly.
ECCouncil Certified Ethical Hacker Exam (CEHv13) Sample Questions (Q825-Q830):NEW QUESTION # 825
You are a penetration tester and are about to perform a scan on a specific server. The agreement that you signed with the client contains the following specific condition for the scan: "The attacker must scan every port on the server several times using a set of spoofed sources IP addresses. " Suppose that you are using Nmap to perform this scan. What flag will you use to satisfy this requirement?
- A. The -D flag
- B. The -A flag
- C. The -f flag
- D. The -g flag
flags -source-port and -g are equivalent and instruct nmap to send packets through a selected port. this option is used to try to cheat firewalls whitelisting traffic from specific ports. the following example can scan the target from the port twenty to ports eighty, 22, 21,23 and 25 sending fragmented packets to LinuxHint.
NEW QUESTION # 826
An Nmap SMTP enumeration script returns valid usernames. What misconfiguration is being exploited?
- A. SMTP authentication bypass
- B. SMTP VRFY/EXPN/RCPT commands exposed
- C. Misconfigured MX records
- D. STARTTLS disabled
This scenario demonstrates SMTP Enumeration, a classic enumeration technique described in CEH v13 Network Enumeration. SMTP servers may expose commands such as VRFY, EXPN, and RCPT TO, which can be abused to validate user accounts.
When these commands are enabled without restriction, attackers can enumerate valid usernames without authentication. The Nmap script used explicitly leverages these commands, confirming the misconfiguration.
Option B is incorrect because authentication is not bypassed. Option C concerns DNS routing, not user enumeration. Option D relates to encryption, not enumeration capability.
CEH v13 strongly recommends disabling or restricting SMTP user verification commands. Thus, Option A is correct.
NEW QUESTION # 827
A Security Engineer at a medium-sized accounting firm has been tasked with discovering how much information can be obtained from the firm's public-facing web servers. The engineer decides to start by using netcat to port 80.
The engineer receives this output:
HTTP/1.1 200 OK
Server: Microsoft-IIS/6
Which of the following is an example of what the engineer performed?
- A. Whois database query
- B. Cross-site scripting
- C. Banner grabbing
- D. SQL injection
In CEH v13 Module 03: Scanning Networks, banner grabbing is defined as a technique used during reconnaissance to capture service banners that provide information about:
Web server version
Operating system
Service details
In This Case:
The engineer used Netcat to connect to port 80 (HTTP).
The response reveals the web server software (Microsoft-IIS/6), which is typical of a banner returned in the server's HTTP response headers.
This technique helps identify vulnerable versions of services.
Other Options:
B). SQL injection: Involves sending SQL payloads - unrelated here.
C). Whois query: Provides domain registration info - unrelated.
D). Cross-site scripting: Requires injecting scripts into a web app - not relevant here.
Module 03 - Banner Grabbing and Service Identification Techniques
CEH Labs: Using Netcat and Telnet for Manual Banner Grabbing
NEW QUESTION # 828
Elante company has recently hired James as a penetration tester. He was tasked with performing enumeration on an organization's network. In the process of enumeration, James discovered a service that is accessible to external sources. This service runs directly on port 21.
What is the service enumerated by James in the above scenario?
- A. Remote Procedure Call (RPC)
- B. Border Gateway Protocol (BGP)
- C. Network File System (NFS)
- D. File Transfer Protocol (FTP)
In CEH v13 Module 04: Enumeration, identifying services based on well-known port numbers is foundational for enumeration and scanning activities.
Port 21/TCP is assigned to the File Transfer Protocol (FTP).
FTP is a standard protocol used to upload, download, and manage files on a remote server.
During enumeration, open FTP ports can be probed for:
Anonymous login
Banner grabbing
Directory traversal vulnerabilities
Option Clarification:
A: BGP: Runs on TCP port 179.
C: NFS: Commonly uses port 2049.
D: RPC: Dynamically uses multiple ports.
Correct answer is B. FTP (port 21).
Module 04 - Enumeration Ports and Services
CEH eBook Appendix: Common Port Numbers and Protocols
NEW QUESTION # 829
Suppose that you test an application for the SQL injection vulnerability. You know that the backend database is based on Microsoft SQL Server. In the login/password form, you enter the following credentials:
Username: attack' or 1=1 --
Password: 123456
Based on the above credentials, which of the following SQL commands are you expecting to be executed by the server, if there is indeed an SQL injection vulnerability?
- A. select * from Users where UserName = 'attack or 1=1 -- and UserPassword = '123456'
- B. select * from Users where UserName = 'attack'' or 1=1 -- and UserPassword = '123456'
- C. select * from Users where UserName = 'attack' or 1=1 --' and UserPassword = '123456'
- D. select * from Users where UserName = 'attack' or 1=1 -- and UserPassword = '123456'
In CEH v13 Module 10: Injection Attacks, the SQL Injection technique is covered extensively. A common attack method is to manipulate the input fields so that the resulting SQL query becomes logically always true, effectively bypassing authentication.
Given the input:
Password: 123456
And assuming the original SQL query is:
SELECT * FROM Users WHERE UserName = '<input_username>' AND UserPassword =
'<input_password>';
When inputs are substituted, the query becomes:
SELECT * FROM Users WHERE UserName = 'attack' or 1=1 --' AND UserPassword = '123456'; The -- sequence is used in SQL to indicate a comment. Everything after -- is ignored by the SQL engine. So the query essentially becomes:CopyEdit SELECT * FROM Users WHERE UserName = 'attack' or 1=1; This query is always true due to 1=1, and if the application is vulnerable, it grants access regardless of the password.
Option Analysis:
A). Incorrect - Contains '' (double quote) after attack, which would cause a syntax error due to extra quotation marks.
B). Correct - This is the accurate representation of what the SQL query would look like with a successful injection.
C). Incorrect - The input string is malformed, combining input into one literal string.
D). Incorrect - Misplacement of ' after the comment token -- invalidates the SQL syntax.
Reference from CEH v13 Study Materials:
Module 10 - Injection Attacks, Section: SQL Injection - Authentication Bypass CEH v13 eCourseware Practical Lab: Exploiting SQL Injection Vulnerability in Login Forms CEH Engage - Web Application Testing Phase: SQLi Exploitation in Login Panels
NEW QUESTION # 830
We have three versions of our 312-50v13 certification guide, and they are PDF version, software version and online version. With the PDF version, you can print our materials onto paper and learn our 312-50v13 exam study guide in a more handy way as you can take notes whenever you want to, and you can mark out whatever you need to review later. With the software version, you are allowed to install our 312-50v13 Guide Torrent that operate in windows system. With the online version, you can study the 312-50v13 guide torrent wherever you like as it can used on all kinds of eletronic devices.
312-50v13 Reliable Study Guide: https://www.trainingdumps.com/312-50v13_exam-valid-dumps.html
312-50v13 valid exam question is the best training materials, It means you do not need to search for important messages, because our 312-50v13 real material covers all the things you need to prepare, ECCouncil 312-50v13 Valid Dumps Ppt Actual, it is a very common thought, Don't believe it, If you have interests with our 312-50v13 practice materials, we prefer to tell that we have contacted with many former buyers of our 312-50v13 exam questions and they all talked about the importance of effective 312-50v13 practice material playing a crucial role in your preparation process, We have hired a team who analyze past papers, ECCouncil Certified Ethical Hacker Exam (CEHv13) Exam examination syllabus and add the most probable ECCouncil 312-50v13 exam questions in three easy-to-use formats.
Other Libraries Macintosh) Sample Files Folder, Proper measurement 312-50v13 of trading and investment strategies requires appropriate risk measurement and an understanding of basic statistical techniques.
Pass-Sure 312-50v13 - Certified Ethical Hacker Exam (CEHv13) Valid Dumps Ppt312-50v13 valid exam question is the best training materials, It means you do not need to search for important messages, because our 312-50v13 real material covers all the things you need to prepare.
Actual, it is a very common thought, Don't believe it, If you have interests with our 312-50v13 practice materials, we prefer to tell that we have contacted with many former buyers of our 312-50v13 exam questions and they all talked about the importance of effective 312-50v13 practice material playing a crucial role in your preparation process.
- Verified 312-50v13 Valid Dumps Ppt - Leader in Qualification Exams - Reliable 312-50v13: Certified Ethical Hacker Exam (CEHv13) 🛶 Download 312-50v13 for free by simply searching on [url]www.pass4test.com 🕧312-50v13 Latest Test Online[/url]
- ECCouncil 312-50v13 Valid Dumps Ppt Exam 100% Pass | 312-50v13 Reliable Study Guide 🥏 Immediately open [ [url]www.pdfvce.com ] and search for ✔ 312-50v13 ️✔️ to obtain a free download 🎿312-50v13 Study Tool[/url]
- Pass Guaranteed Quiz 2026 High Pass-Rate ECCouncil 312-50v13 Valid Dumps Ppt 🐧 Open [url]www.practicevce.com and search for 312-50v13 to download exam materials for free 🤢312-50v13 Dumps Questions[/url]
- 312-50v13 Dumps Vce 🍧 312-50v13 Latest Test Online 👖 312-50v13 Latest Dumps Ppt 🎪 ▛ [url]www.pdfvce.com ▟ is best website to obtain [ 312-50v13 ] for free download 🐕312-50v13 Examinations Actual Questions[/url]
- Free PDF 2026 312-50v13: Trustable Certified Ethical Hacker Exam (CEHv13) Valid Dumps Ppt ⚾ Download ✔ 312-50v13 ️✔️ for free by simply entering [url]www.vce4dumps.com website 🪁312-50v13 Latest Braindumps Ppt[/url]
- Real 312-50v13 Valid Dumps Ppt, 312-50v13 Reliable Study Guide ↩ Download ✔ 312-50v13 ️✔️ for free by simply entering [url]www.pdfvce.com website 💈312-50v13 Latest Test Online[/url]
- Free PDF 2026 312-50v13: Trustable Certified Ethical Hacker Exam (CEHv13) Valid Dumps Ppt 🔗 Search for ➤ 312-50v13 ⮘ and download exam materials for free through ⏩ [url]www.prepawayete.com ⏪ 🥅312-50v13 Examinations Actual Questions[/url]
- Exam 312-50v13 Preview 🌄 312-50v13 Exam Online 🛵 312-50v13 Best Preparation Materials 🎾 Search for ▶ 312-50v13 ◀ and obtain a free download on ☀ [url]www.pdfvce.com ️☀️ 📧312-50v13 Exam PDF[/url]
- 312-50v13 Latest Braindumps Ppt 🚼 312-50v13 New Study Guide 🍽 312-50v13 Dumps Vce ⛹ Search for ▛ 312-50v13 ▟ and download it for free on ➠ [url]www.examdiscuss.com 🠰 website 🔃312-50v13 Examinations Actual Questions[/url]
- 312-50v13 Exam Online 🎱 312-50v13 Best Preparation Materials 🩲 Exam 312-50v13 Preview 🧶 Search for 312-50v13 and obtain a free download on ☀ [url]www.pdfvce.com ️☀️ 🚃Reliable 312-50v13 Learning Materials[/url]
- 312-50v13 Valid Dumps Ppt - 2026 Realistic ECCouncil Certified Ethical Hacker Exam (CEHv13) Reliable Study Guide 🌵 Search for 312-50v13 and easily obtain a free download on ⇛ [url]www.verifieddumps.com ⇚ 🧞312-50v13 Exam Discount Voucher[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, Disposable vapes
