[General] 2026 Pass-Sure 100% Free ZDTE–100% Free Reliable Test Sims | Zscaler Digital Tra
95
【General】 2026 Pass-Sure 100% Free ZDTE–100% Free Reliable Test Sims | Zscaler Digital Tra
Posted at 2/20/2026 14:32:13      View:87 | Replies:0        Print      Only Author   [Copy Link] 1#
A free demo of ZDTE practice test questions and up to 1 year of free updates are also available at BraindumpStudy. So, this is the time to download valid Zscaler ZDTE exam questions and start studying. There is no room for delays in Zscaler Digital Transformation Engineer (ZDTE) preparation exams or second thoughts when you know that you have to survive the competition and safeguard your job.
Why do we need so many certifications? One thing has to admit, more and more certifications you own, it may bring you more opportunities to obtain a better job, earn more salary. This is the reason why we need to recognize the importance of getting the test ZDTE certification. Our passing rate is 98%-100% and there is little possibility for you to fail in the exam. But if you are unfortunately to fail in the exam we will refund you in full immediately. Some people worry that if they buy our ZDTE Exam Questions they may fail in the exam and the procedure of the refund is complicated.
Zscaler ZDTE Exam | Reliable ZDTE Test Sims - Useful Tips & Questions for your ZDTE LearningIf you are still hesitate to choose our BraindumpStudy, you can try to free download part of Zscaler ZDTE exam certification exam questions and answers provided in our BraindumpStudy. So that you can know the high reliability of our BraindumpStudy. Our BraindumpStudy will be your best selection and guarantee to pass Zscaler ZDTE Exam Certification. Your choose of our BraindumpStudy is equal to choose success.
Zscaler Digital Transformation Engineer Sample Questions (Q49-Q54):NEW QUESTION # 49
Which protocol allows users to configure a passwordless authentication method for their ZIdentity account?
  • A. OIDC
  • B. SCIM
  • C. SAML
  • D. FIDO2
Zscaler Identity (ZIdentity) supports modern, phishing-resistant passwordless authentication using the FIDO2 standard. FIDO2 combines Web Authentication (WebAuthn) and the Client to Authenticator Protocol (CTAP2) to enable users to authenticate with security keys or built-in platform authenticators (such as biometric sensors) without transmitting or storing a reusable password. The Digital Transformation Engineer documentation explains that when a user registers a FIDO2 authenticator with ZIdentity, the service stores a public key tied to that device and account. Future logins are validated using a cryptographic challenge- response, providing strong protection against credential theft and replay attacks.
By contrast, SAML (option B) and OIDC (option C) are federation protocols used for single sign-on (SSO) and identity delegation between an identity provider and service providers; they do not themselves define how passwordless authentication is performed. They can carry assertions from an IdP that might use FIDO2 behind the scenes, but SAML and OIDC are not the passwordless method. SCIM (option D) is a provisioning standard for creating, updating, and deprovisioning identities and groups, not an authentication protocol.
Therefore, the only option that directly represents the protocol enabling passwordless login to a ZIdentity account is FIDO2.
NEW QUESTION # 50
What is the primary benefit of using a Custom Zscaler Connector for SaaS Application?
  • A. Broad access to all SaaS Application Tenants across Microsoft and Google
  • B. Temporary user credentials to access the SaaS Application Tenants
  • C. Minimum set of required credentials to access the SaaS Application Tenants
  • D. Full administrator credentials to access the SaaS Application Tenants
In Zscaler's SaaS Security and Data Protection services, a Custom Zscaler Connector (for example, for Google Workspace, Microsoft 365, or Salesforce) is designed so that Zscaler can connect to a specific SaaS tenant using only the minimum set of required credentials and scopes. The documentation for onboarding custom connectors explicitly emphasizes that, instead of providing full administrator rights, you authorize narrowly scoped API/OAuth permissions that allow Zscaler to scan data at rest and enforce security controls while adhering to least-privilege principles.
This minimal-credential approach reduces risk if the connector credentials are ever compromised, simplifies compliance audits, and aligns with modern security best practices. Zscaler needs just enough access to read, classify, and (where applicable) remediate or quarantine sensitive content in sanctioned SaaS applications, not broad tenant-wide admin access. Options suggesting temporary credentials, broad cross-tenant access, or full administrator rights contradict this design philosophy and the way the connectors are documented. Therefore, the primary benefit-and the key phrase you should associate with Custom Zscaler Connectors for the exam-is that they enable Zscaler to operate using a minimum set of required credentials for each SaaS Application tenant.
NEW QUESTION # 51
A customer requires 2 Gbps of throughput through the GRE tunnels to Zscaler. Which is the ideal architecture?
  • A. Two primary and two backup GRE tunnels from internal routers with NAT disabled
  • B. Two primary and two backup GRE tunnels from border routers with NAT enabled
  • C. Two primary and two backup GRE tunnels from border routers with NAT disabled
  • D. Two primary and two backup GRE tunnels from internal routers with NAT enabled
Zscaler design guidance for GRE connectivity emphasizes three key principles: terminate GRE on border (edge) devices, avoid NAT on GRE source addresses, and scale bandwidth by using multiple tunnels. In Zscaler documentation and engineering training, each GRE tunnel is typically sized for up to about 1 Gbps of throughput. For a 2 Gbps requirement, customers are advised to deploy at least two primary GRE tunnels, with two additional backup tunnels for redundancy and failover.
These tunnels should terminate on border routers that own public IP addresses, ensuring optimal routing and simplifying troubleshooting. Zscaler specifically recommends that the public source IPs used for GRE must not be translated by NAT, because the Zscaler cloud must see the original, registered public IP to associate tunnels with the correct organization and enforce policy. Enabling NAT on GRE traffic can break tunnel establishment and lead to asymmetric or unpredictable routing.
Using internal routers introduces extra hops and complexity and often requires NAT or policy-based routing, which goes against recommended best practices. Similarly, any architecture with NAT enabled on GRE traffic conflicts with Zscaler's published requirements. Therefore, the ideal and recommended design for 2 Gbps via GRE is two primary and two backup GRE tunnels from border routers with NAT disabled.
NEW QUESTION # 52
How many minutes of data can the Log Streaming Service retransmit once the connection is restored between App Connectors and Zscaler Private Access (ZPA)?
  • A. Last 30 minutes
  • B. Last 20 minutes
  • C. Last 60 minutes
  • D. Last 15 minutes
Zscaler Private Access (ZPA) uses the Log Streaming Service (LSS) to deliver ZPA logs (such as user activity and connector/authentication logs) to external SIEM and analytics platforms. LSS relies on a ZPA App Connector as the local relay between the ZPA service and the downstream log receiver. If network connectivity between ZPA and the local App Connector is interrupted, log delivery may be temporarily disrupted.
According to Zscaler integration guidance, when connectivity between ZPA and the local App Connectors is restored, LSS can retransmit up to 15 minutes of previously undelivered log data, although this retransmission is not guaranteed in all circumstances. This limited replay window is designed to provide reasonable resilience for short outages without requiring large local storage on the connector.
The 15-minute buffer applies specifically to ZPA log streaming scenarios and is distinct from longer-term log retention in Zscaler's logging cluster or external SIEM. Options A, C, and D overstate the supported replay duration and do not match Zscaler's documented behavior. To minimize log gaps beyond this 15-minute window, Zscaler recommends resilient network paths for App Connectors and careful monitoring of connector health so that LSS can operate continuously.
NEW QUESTION # 53
What is Zscaler Deception?
  • A. A simple and more effective targeted threat detection solution built on the Zscaler Zero Trust architecture.
  • B. A set of decoys representing network elements used to identify an attacker accessing our infrastructure.
  • C. An early detection system supported via servers located inside our corporate infrastructure.
  • D. A set of decoys representing users and server elements used to identify an attacker accessing our infrastructure.
In the Zscaler Digital Transformation Engineer material, Zscaler Deception is introduced as an advanced threat-detection capability that is tightly integrated with the Zero Trust Exchange. The official description emphasizes that it is a simple, cloud-delivered, and highly effective targeted threat detection solution built on Zscaler's Zero Trust architecture, which is almost word-for-word reflected in option C.
Deception works by deploying high-fidelity decoys, lures, and credentials-designed to be indistinguishable from real assets-from the attacker's point of view. Any interaction with these decoys is inherently suspicious, yielding high-confidence, low-noise alerts that help security teams quickly identify lateral movement, credential theft, and post-compromise activity. The key point in the training is that this capability is delivered from the Zscaler cloud, leveraging the existing Zero Trust platform; it does not require additional on-premise detection servers or traditional network-centric sensors.
Options A and B reduce the concept to "sets of decoys" and ignore the integrated Zero Trust detection value and cloud-native delivery model. Option D incorrectly suggests on-prem server infrastructure as the foundation. The exam materials clearly frame Zscaler Deception as a Zero Trust-based targeted threat detection solution, making option C the correct choice.
NEW QUESTION # 54
Our PDF version of the ZDTE learning braindumps can print on papers and make notes. Then windows software of the ZDTE exam questions, which needs to install on windows software. Also, the windows software is intelligent to simulate the real test environment. Then the online engine of the ZDTE Study Materials, which is convenient for you because it doesn’t need to install on computers. It supports Windows, Mac, Android, iOS and so on. This version just can run on web browser.
ZDTE Test Preparation: https://www.braindumpstudy.com/ZDTE_braindumps.html
Zscaler Reliable ZDTE Test Sims After all, this society really needs us to be efficient, To do this you just need to enroll in the Zscaler ZDTE certification exam and put all your efforts to pass this important Zscaler ZDTE Exam Questions, We provide you with everything you need to pass the ZDTE exam, which verifies you as a Zscaler certified specialist in the domain of Zscaler Data Modeling, Zscaler Reliable ZDTE Test Sims The design of the content conforms to the examination outline.
My Favorite Categories, Marketing Charts has more information ZDTE on the study, After all, this society really needs us to be efficient, To do this you just need to enroll in the Zscaler ZDTE Certification Exam and put all your efforts to pass this important Zscaler ZDTE Exam Questions.
ZDTE Pass-Sure Materials - ZDTE Quiz Bootcamp & ZDTE Test QuizWe provide you with everything you need to pass the ZDTE exam, which verifies you as a Zscaler certified specialist in the domain of Zscaler Data Modeling.
The design of the content conforms to the examination outline, After learning everything related to the Zscaler Digital Transformation Engineer (ZDTE)certification, it is the right time to take a self-test and check whether you can clear the Zscaler Digital Transformation Engineer (ZDTE) certification exam or not.
