100% Pass Quiz 2026 1z0-076: Perfect Oracle Database 19c: Data Guard Administrat
96
Posted at 1/23/2026 22:15:48      View:94 | Replies:0        Print      Only Author   [Copy Link] 1#
What's more, part of that TestkingPass 1z0-076 dumps now are free: https://drive.google.com/open?id=18YF_vMKcIc-5Jvs1sGWVL2II0V6DGBHA
The 1z0-076 Practice Questions are designed and verified by experienced and renowned Oracle Database 19c: Data Guard Administration exam trainers. They work collectively and strive hard to ensure the top quality of TestkingPass 1z0-076 exam practice questions all the time. The 1z0-076 Exam Questions are real, updated, and error-free that helps you in Oracle Database 19c: Data Guard Administration exam preparation and boost your confidence to crack the upcoming 1z0-076 exam easily.
After choose TestkingPass's 1z0-076 exam training materials, you can get the latest edition of 1z0-076 exam dumps and answers. The accuracy rate of TestkingPass 1z0-076 exam training materials can ensure you to Pass 1z0-076 Test. After you purchase our 1z0-076 test training materials, if you fail 1z0-076 exam certification or there are any quality problems of 1z0-076 exam dumps, we guarantee a full refund.
Quiz Oracle - 1z0-076 - Oracle Database 19c: Data Guard Administration High Hit-Rate Dumps TorrentTo pass the Oracle 1z0-076 certification exam, you need to master complicated subjects related to Oracle Database 19c: Data Guard Administration. TestkingPass verified Oracle 1z0-076 pdf questions can help you prepare for this exam by covering every topic in the exam and giving you the opportunity to practice for the actual exam. Download TestkingPass Oracle 1z0-076 PDF Questions today and get ready to demonstrate your expertise in solving complex Oracle real-life problems.
Oracle Database 19c: Data Guard Administration Sample Questions (Q58-Q63):NEW QUESTION # 58
You have a Data Guard Broker configuration called 'Somewhere' as shown:
DGMGRL> SHOW CONFIGURATION;
Configuration - Somewhere
Protection Mode: MaxPerformance
Databases:
Nearby - Primary database
FS - Far Sync
Farout - Physical standby database
Fast-Start Failover: DISABLED
Configuration Status:
SUCCESS
You then run this command:
DGMGRL> SHOW DATABASE 'Nearby' 'InconsistentProperties';
Which two are true about the output of this DGMGRL command?
  • A. Any inconsistency reported is on an instance-specific basis.
  • B. It shows all properties whose broker configuration values for database Nearby are inconsistent with the values in the corresponding server parameter file or the runtime values for database instance Nearby.
  • C. A far sync instance cannot have inconsistent properties because it has no database.
  • D. It shows all properties whose broker configuration values for database Nearby are inconsistent with the broker configuration values for database Farout.
NEW QUESTION # 59
Examine the fast-start failover configuration:
  • A. The observer will initiate a failover when the primary database is unable to produce local archived redo log files.
  • B. The observer is running.
  • C. A failover may occur if the observer has lost connectivity to the primary database, even if the Fast-Start Failover target standby database has a good connection to the primary database
  • D. If South_Sales develops a problem and cannot be the target of a failover, the broker automatically changes the fast-start failover target to one of the other candidate targets.
  • E. You must disable fast-start failover first to change the fast-start failover target to East sales.
Answer: A,B,C
NEW QUESTION # 60
Which three statements are true about snapshot standby databases?
  • A. A resize command to extend the size of a datafile in the snapshot standby database, which was created in the snapshot standby database, will succeed.
  • B. A resize command to reduce the size of an empty datafile in the snapshot standby database, which was created in the snapshot standby database, will succeed.
  • C. A resize command to extend the size of a datafile in the snapshot standby database, which was created in the primary database, will succeed.
  • D. A resize command to reduce the size of an empty datafile in the snapshot standby database, which was created in the primary database, will succeed.
  • E. A resize command to reduce the size of an empty datafile in the snapshot standby database, which was created in the physical standby database, will succeed.
Answer: A,B,C
NEW QUESTION # 61
A customer asks for your recommendation regarding this requirement:
1. We plan to have a Data Guard Configuration with one primary database and one physical standby database.
2. We want zero data loss in case of a disaster involving the loss of one component.
3. We want to do Real Application Testing occasionally on the Standby Database.
Which solution, if any, satisfies these requirements?
  • A. These requirements cannot be met.
  • B. A snapshot standby database with real time query that can be converted regularly into a physical standby database open read write, to do real application testing
  • C. A far sync instance plus a snapshot standby database and real time apply that can be converted regularly into logical standby database to do real application testing
  • D. A physical standby database with synchronous redo transport that can be converted regularly into a snapshot standby to do real application testing
* Synchronous redo transport for zero data loss (B): To guarantee zero data loss in the case of a disaster, synchronous redo transport must be configured between the primary and standby databases.
* Conversion to snapshot standby for testing (B): A physical standby database can be temporarily converted into a snapshot standby database to perform real application testing. After testing is completed, the snapshot standby can be converted back to a physical standby to resume its disaster recovery role.
* Oracle Data Guard Concepts and Administration Guide
* Oracle Database Testing Guide
NEW QUESTION # 62
Which TWO statements are true about Real-Time Query?
  • A. Real-Time Query sessions can be connected to a Far Sync instance.
  • B. Real-Time Query has no limitations regarding the protection level of the Data Guard environment.
  • C. Setting standby_max_data_delay=0 requires synchronous redo transport.
  • D. A standby database enabled for Real-Time Query cannot be the Fast-Start Failover target of the Data Guard configuration.
  • E. Disabling Real-Time Query prevents the automatic start of redo apply when a physical standby databases opened read only.
Answer: C,E
Real-Time Query is a feature that allows queries to be run on a physical standby database while it is applying redo data. The relevant truths about it are:
* Setting standby_max_data_delay=0 requires synchronous redo transport (A): For the real-time apply feature to function with no data delay (zero delay), synchronous redo transport must be used. This setting ensures that the data on the standby database is as current as possible before queries are executed against it.
* Disabling Real-Time Query prevents the automatic start of redo apply when a physical standby database is opened read-only (C): If Real-Time Query is disabled, opening the standby database in read-only mode will not start the redo apply process automatically. Redo apply needs to be manually started to synchronize the standby database with the primary.References:
NEW QUESTION # 63
TestkingPass promise that we will spare no effort to help you pass Oracle certification 1z0-076 exam. Now you can free download part of practice questions and answers of Oracle certification 1z0-076 exam on TestkingPass. When you select TestkingPass, you can not only pass Oracle Certification 1z0-076 Exam, but also have one year free update service. TestkingPass can also promise if you fail to pass the exam, TestkingPass will 100% refund.
Latest 1z0-076 Exam Pdf: https://www.testkingpass.com/1z0-076-testking-dumps.html
Each question from 1z0-076 prep material is checked and verified by our professional experts, Oracle 1z0-076 Dumps Torrent Besides, printed material would be suitable for some candidates who are not convenient to use electronic products, Our Oracle 1z0-076 practice exam highlights mistakes at the end of each attempt, allowing you to overcome them before it's too late, Once you choose our learning materials, your dream that you have always been eager to get Oracle Latest 1z0-076 Exam Pdf certification which can prove your abilities will realized.
Hold iPad-based video conferences and virtual meetings, Or, you Latest 1z0-076 Exam Pdf can select one of the supplied Keyword Set presets such as Outdoor Photography, Portrait Photography, or Wedding Photography.
Oracle 1z0-076 exam Dumps [2026] to Achieve Higher ResultsEach question from 1z0-076 prep material is checked and verified by our professional experts, Besides, printed material would be suitable for some candidates who are not convenient to use electronic products.
Our Oracle 1z0-076 practice exam highlights mistakes at the end of each attempt, allowing you to overcome them before it's too late, Once you choose our learning materials, your dream that you have 1z0-076 always been eager to get Oracle certification which can prove your abilities will realized.
Our website promises that you can pass test at your first time to participate in the 1z0-076 exam dumps and enhance yourself by practicing exam questions.
P.S. Free & New 1z0-076 dumps are available on Google Drive shared by TestkingPass: https://drive.google.com/open?id=18YF_vMKcIc-5Jvs1sGWVL2II0V6DGBHA
