New Construction-Manager Test Review | Reliable Construction-Manager Practice Qu
Posted at 5/17/2026 06:15:54
View100
Replies0
There are three formats of the Construction-Manager practice training material for your preparation. You can choose as your needs. The first one is the pdf files: Construction-Manager pdf dumps can be printed into papers which is very suitable for making notes. The Construction-Manager PC test engine & Construction-Manager online test engine are all VCE format and can simulate the actual test environment. The Construction-Manager PC test engine is suitable for any windows system, while the Construction-Manager online test engine can be installed on any electronic device. All the Construction-Manager exam content are the same and valid for different formats.
Choosing our Construction-Manager real dumps as your study guide means you choose a smart and fast way to get succeed in the certification exam. There are accurate Construction-Manager test answers and some explanations along with the exam questions that will boost your confidence to solve the difficulty of Construction-Manager Practice Test. You will enjoy great benefits if you buy our Construction-Manager braindumps now and free update your study materials one-year.
Quiz 2026 Construction-Manager: High Pass-Rate New Certified Construction Manager (CCM) Test ReviewCandidates who want to be satisfied with the Certified Construction Manager (CCM) (Construction-Manager) preparation material before buying can try a free demo. Customers who choose this platform to prepare for the Certified Construction Manager (CCM) (Construction-Manager) exam require a high level of satisfaction. For this reason, ActualTestsIT has a support team that works around the clock to help Construction-Manager applicants find answers to their concerns.
CMAA Certified Construction Manager (CCM) Sample Questions (Q51-Q56):NEW QUESTION # 51
The narrative accompanying a CM-developed construction cost estimate during the design phase should include which of the following?
- A. Suggestions for value management of building systems and other opportunities for savings
- B. Means and methods of construction
- C. Written confirmation of verbal data and assumptions made
- D. CM's recommendation of improvements to specifications and quality of materials
InCMAA Cost Managementguidelines, the SOP directs that a CM's cost estimate must be supported by a written narrative documentingall assumptions, clarifications, and qualificationsused in developing the estimate. This provides transparency and establishes a record for future reference.
As stated in the SOP:
"Each estimate shall include a written narrative identifying the basis of the estimate, assumptions made, data sources used, and confirmation of verbal or informal information obtained during the estimate preparation." Including means and methods (Option D) is outside the CM's role, and value management suggestions (Option B) belong in separate analyses. Therefore, the most accurate and compliant answer isA. Written confirmation of verbal data and assumptions made.
CMAA Construction Management Standards of Practice, 2010 Edition, Chapter 3 - Cost Management, Section: "Design Phase Cost Estimates," pp. 33-35.
CMAA Study Guide, Cost Management Domain, Objective 3.2.
NEW QUESTION # 52
As the owner's rep, a CM is providing on-site construction management services to a municipality for their new design-build city mall project.
The state requires a 40-hour value engineering workshop for all projects over $10 million. What are the key talking points about the VE process that the CM will highlight to the city's director of public works?
- A. Life cycle and maintenance costs should not be considered.
- B. A multi-discipline review on functions and alternate solutions.
- C. Interface with the design-build team is not needed at this time.
- D. Scope reduction will reduce overall project budget.
Value Engineering (VE) is intended to improve value by optimizing the relationship between function, cost, and life-cycle performance. The CM would emphasize that VE is amulti-discipline reviewof project functions and alternate design solutions to reduce cost without sacrificing essential performance. In a proper VE workshop, participants from multiple disciplines review function, identify alternatives, and propose changes.
The incorrect choices are:
A is wrong because life cycle and maintenance costsshouldbe considered - VE should look beyond initial cost to long-term costs.
C is simplistic: while scope reduction is one possible result, VE is not merely scope cutting but exploring alternatives to maintain functionality at lower cost.
D is incorrect, because interfacing with the design-build team is essential - VE must involve the DB team to ensure proposed changes are implementable and integrated.
NEW QUESTION # 53
NEW QUESTION # 54
A construction manager is responsible for the bid review and evaluation of an $85 million high school project.
All bids must be submitted in person at the clients Purchasing Office by 1:00 PM EST and stamped by the CM's team. While preparing for the bid opening, the CM noticed that one of the contractor's bids was submitted a day earlier to a new clerk, but was date and time stamped after the bids were due. What should the CM do in this situation?
- A. Send the bid back to the contractor and apologize for the mishap.
- B. Include the unopened bid. since it clearly was an oversight.
- C. Put the contractor's unopened bid in tight security until the bid opening has been completed.
- D. Inform the Owner and review the instructions to bidders for guidance on how to proceed.
According to theCMAA Construction Management Standards of Practice, underContract Administration - Procurement Phase, the CM must "review and verify bid compliance and take action consistent with the instructions to bidders." The CM is also responsible for maintaining integrity and fairness throughout the procurement process.
The SOP states:
"Any irregularity or deviation from bid requirements must be reported to the Owner immediately. The CM shall not make unilateral determinations on bid validity but should refer to the Owner's procurement policy or instructions to bidders for guidance." Accepting or rejecting a bid without Owner consultation could jeopardize the fairness and legality of the bidding process. Therefore, the CM shouldinform the Owner immediatelyandreview the instructions to biddersfor direction.
CMAA Construction Management Standards of Practice, 2010 Edition, Chapter 5 - Contract Administration, Section: "Procurement and Bidding," pp. 51-54.
CMAA Study Guide, Contract Administration Domain, Objective 5.3.
NEW QUESTION # 55
What are the essential components of the Risk Management process?
- A. Communicating and reporting, assessing, mitigation, tracking
- B. Avoiding, tracking, mitigation, transferring
- C. Avoiding, mitigating, transferring, accepting
- D. Communicating and reporting, tracking, mitigation, resolution
According to theCMAA Construction Management Standards of Practice, Chapter 10 - Risk Management, the fundamental components of the risk management process include:
Avoidance- Eliminating the risk entirely by altering plans or scope.
Mitigation- Reducing the likelihood or impact of a risk.
Transfer- Shifting risk responsibility to another party, typically through insurance or contracts.
Acceptance- Recognizing the risk and planning to manage its consequences.
CMAA defines risk management as:
"A systematic process of identifying, analyzing, responding to, and monitoring risks to minimize their impact on project objectives." These four response strategies-avoid, mitigate, transfer, and accept-are universally recognized as the essential framework for construction risk management.
CMAA Construction Management Standards of Practice, Chapter 10 - Risk Management, Section: "Risk Identification and Response," pp. 96-99.
CMAA CM Study Guide, Risk Management Domain, Objective 10.3: "Develop and apply risk response strategies: avoid, mitigate, transfer, and accept."
NEW QUESTION # 56
You many face many choices of attending the certificate exams and there are a variety of certificates for you to get. You want to get the most practical and useful certificate which can reflect your ability in some area. If you choose to attend the test Construction-Manager certification buying our Construction-Manager exam guide can help you pass the Construction-Manager test and get the valuable certificate. Our company has invested a lot of personnel, technology and capitals on our products and is always committed to provide the top-ranking Construction-Manager study material to the clients and serve for the client wholeheartedly.
Reliable Construction-Manager Practice Questions: https://www.actualtestsit.com/CMAA/Construction-Manager-exam-prep-dumps.html
CMAA New Construction-Manager Test Review Certification Mode (timed) prepares you for exam taking conditions, Those updates of our Construction-Manager exam questions will be sent to you accordingly for one year freely, CMAA New Construction-Manager Test Review Some certifications' passing rate is high up to 99%, CMAA New Construction-Manager Test Review Automatic renewal sending to the customers, With our help it is not a difficult thing to get Construction-Manager certificate.
You can then call functions written in it as if they were C functions, For Construction-Manager example, if a stool has one long or short leg, or a missing leg, the stool loses its functional purpose: to sit down on a stable platform.
CMAA Construction-Manager Questions To Gain Brilliant Result [2026]Certification Mode (timed) prepares you for exam taking conditions, Those updates of our Construction-Manager Exam Questions will be sent to you accordingly for one year freely.
Some certifications' passing rate is high up to 99%, Automatic renewal sending to the customers, With our help it is not a difficult thing to get Construction-Manager certificate.
- 100% Construction-Manager Exam Coverage 👬 Latest Construction-Manager Braindumps Free 🟩 Construction-Manager Relevant Answers 👴 Easily obtain free download of { Construction-Manager } by searching on [url]www.examcollectionpass.com 🌜Answers Construction-Manager Free[/url]
- Exam Construction-Manager Simulator 🍽 Construction-Manager Exam Bible 🌌 100% Construction-Manager Exam Coverage 🕙 Copy URL ➤ [url]www.pdfvce.com ⮘ open and search for Construction-Manager to download for free 🐜Construction-Manager Reliable Exam Bootcamp[/url]
- 100% Construction-Manager Exam Coverage ✅ Construction-Manager Exam Bible ✌ Construction-Manager Trustworthy Source 🤒 Immediately open ➠ [url]www.validtorrent.com 🠰 and search for ⇛ Construction-Manager ⇚ to obtain a free download 🔔Construction-Manager Latest Exam Papers[/url]
- Construction-Manager Latest Exam Papers ➿ Answers Construction-Manager Free 🚢 Construction-Manager Test Questions 🥓 Search for Construction-Manager on ⏩ [url]www.pdfvce.com ⏪ immediately to obtain a free download ♻Valid Construction-Manager Test Book[/url]
- Construction-Manager Practice Exam Online 🙀 Construction-Manager Actual Questions 👞 Construction-Manager Practice Exam Online 📝 Search for ⮆ Construction-Manager ⮄ and download it for free immediately on [ [url]www.examcollectionpass.com ] 😘Construction-Manager Lead2pass[/url]
- Construction-Manager Exam Registration 🕠 Latest Construction-Manager Braindumps Free 🐇 100% Construction-Manager Exam Coverage 🤏 Search for ➤ Construction-Manager ⮘ and download exam materials for free through ➤ [url]www.pdfvce.com ⮘ 🎈Test Construction-Manager Online[/url]
- New Construction-Manager Test Review | Pass-Sure CMAA Construction-Manager: Certified Construction Manager (CCM) 😒 Simply search for Construction-Manager for free download on ⇛ [url]www.troytecdumps.com ⇚ 📠Construction-Manager Relevant Answers[/url]
- Pass Guaranteed 2026 Trustable CMAA Construction-Manager: New Certified Construction Manager (CCM) Test Review 🏈 Search for Construction-Manager and download it for free on ➤ [url]www.pdfvce.com ⮘ website 🤚Construction-Manager Valid Test Fee[/url]
- Useful New Construction-Manager Test Review, Ensure to pass the Construction-Manager Exam 🎇 Open ▶ [url]www.torrentvce.com ◀ and search for ☀ Construction-Manager ️☀️ to download exam materials for free 🧸Construction-Manager Actual Questions[/url]
- Construction-Manager Valid Test Fee 👹 Construction-Manager Trustworthy Source 🚝 Construction-Manager Reliable Exam Bootcamp 🟡 Search for ➥ Construction-Manager 🡄 and easily obtain a free download on ➠ [url]www.pdfvce.com 🠰 🕣Construction-Manager Exam Bible[/url]
- Construction-Manager - Certified Construction Manager (CCM) Updated New Test Review ✍ The page for free download of Construction-Manager on ▷ [url]www.verifieddumps.com ◁ will open immediately 🧫Construction-Manager Lead2pass[/url]
- amberilyt320930.hamachiwiki.com, susangaff148657.bloggosite.com, jaysonlbnw901981.daneblogger.com, bookmarkmargin.com, blakeiokt793806.signalwiki.com, jadafzze175814.myparisblog.com, bookmarksbay.com, fanniejgqr721735.dgbloggers.com, antonwqkn588623.theisblog.com, roynbhi504856.blogars.com, Disposable vapes
