[General] JavaScript-Developer-I Test Passing Score | Test JavaScript-Developer-I Dates
10
General JavaScript-Developer-I Test Passing Score | Test JavaScript-Developer-I Dates
Posted at 1/12/2026 00:13:34      View270 | Replies2        Print      Only Author   [Copy Link] 1#
P.S. Free & New JavaScript-Developer-I dumps are available on Google Drive shared by Actual4Cert: https://drive.google.com/open?id=1W7K0m-sDpaM2V2AxfvlE-Php9rBwxdG9
The Salesforce Certified JavaScript Developer I Exam (JavaScript-Developer-I) examination is necessary for career advancement, therefore, doing your best to prepare for the Salesforce Certified JavaScript Developer I Exam (JavaScript-Developer-I) certification exam is essential. To succeed on the Salesforce Certified JavaScript Developer I Exam (JavaScript-Developer-I) exam, you require a specific Salesforce Certified JavaScript Developer I Exam (JavaScript-Developer-I) exam environment to practice. But before settling on any one method, you make sure that it addresses their specific concerns about the JavaScript-Developer-I Exam, such as whether or not the platform they are joining will aid them in passing the Salesforce Certified JavaScript Developer I Exam (JavaScript-Developer-I) exam on the first try, whether or not it will be worthwhile, and will it provide the necessary JavaScript-Developer-I Questions.
Achieving the Salesforce Certified JavaScript Developer I certification is a great way to demonstrate your expertise in JavaScript and your ability to build custom applications that can be integrated with Salesforce. Salesforce Certified JavaScript Developer I Exam certification can help you stand out from other developers and can open up new career opportunities in the Salesforce ecosystem.
Test Salesforce JavaScript-Developer-I Dates, Free JavaScript-Developer-I Practiceour company is determined to help provide the most accurate JavaScript-Developer-I Exam Questions and help more people get the JavaScript-Developer-I certificate successfully. Our company has a long history of 10 years in designing JavaScript-Developer-I study materials and enjoys a good reputation across the globe. Now we can be the leader in this exam field and have a large number of regular customers from different countries. We are looking forward to your joining in us.
Salesforce Certified JavaScript Developer I Exam Sample Questions (Q222-Q227):NEW QUESTION # 222
A developer wants to create an object from a function in the browser using the code below.
What happens due to lack of the new keyword on line 02?
  • A. The n variable is assigned the correct object but this- remains undefined.
  • B. Window. === name is assigned to ''hello'' and the variable a n remain undefined.
  • C. The a variable is assigned the correct object.
  • D. Window. n is assigned the correct object.
NEW QUESTION # 223
Teams at Universal Containers (CU) work on multiple JavaScript projects at the same time. UC us thinking about reusability and how each team can benefit from the work of others.
Going open-source or public is not an option at this time.
Which option is available to UC with npm?
  • A. Private packages can be scoped, and scopes can be associated to a private registries.
  • B. Private register are not supported by npm, but packages can be installed via git.
  • C. Private packages are not supported, but they can use another package manager like yarm.
  • D. Private registries are not supported by spm, but packages can be installed vis URL.
NEW QUESTION # 224
A developer wants to set up a secure web server with Node.js. The developer creates a
directory locally called app-server, and the first file is app-server/index.js
Without using any third-party libraries, what should the developer add to index.js to create the
secure web server?
  • A. const server =require('secure-server');
  • B. const tls = require('tls');
  • C. const http =require('http');
  • D. const https =require('https');
NEW QUESTION # 225
Refer to thefollowing code that imports a module named utils:
import (foo, bar) from '/path/Utils.js';
foo() ;
bar() ;
Which two implementations of Utils.js export foo and bar such that the code above runs without error?
Choose 2 answers
  • A. // FooUtils.js and BarUtils.js existImport (foo) from '/path/FooUtils.js';Import (boo) from '
    /path/NarUtils.js';
  • B. const foo = () => { return 'foo' ; }const bar = () => { return 'bar' ; }export { bar, foo }
  • C. const foo = () => { return 'foo';}const bar = () => {return 'bar'; }Export default foo, bar;
  • D. Export default class {foo() { return 'foo' ; }bar() { return 'bar' ; }}
NEW QUESTION # 226
A developer has the following array of student test grades:
Let arr - [7, 8, 5, 9]
How should want to double each score and then see an array of the students who scored more than 15 points.
How should the developer implement the request?
  • A. Let arr1 = arr.map ((num) => num + 2 .filter ((val) => val 15 );
  • B. Let arr1 = arr.mapBy ((num) => return num + 2 )) .filterBy ((val) => ( return val > 15 )) ;
  • C. Let arr1 = arr .filter ((filter ((val) => ( return val > 15 )) .map (( num => ( return num +2 ));
  • D. Let arr1 = arr .map ((num => ( num + 2 )) .filterBy ((val => ( val 15 )) ;
NEW QUESTION # 227
In order to make you confirm the quality of our JavaScript-Developer-I Dumps and let you know whether the dumps suit you, pdf and software version in Actual4Cert exam dumps can let you download the free part of our JavaScript-Developer-I training materials. We will offer free the part of questions and answers for you and you can visit Actual4Cert.com to search for and download these certification training materials. You cannot buy the dumps until you experience it so that you can avoid buying ignorantly the exam dumps without fully understanding the quality of questions and answers.
Test JavaScript-Developer-I Dates: https://www.actual4cert.com/JavaScript-Developer-I-real-questions.html
DOWNLOAD the newest Actual4Cert JavaScript-Developer-I PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1W7K0m-sDpaM2V2AxfvlE-Php9rBwxdG9
Posted at 1/16/2026 04:25:43        Only Author  2#
I was amazed by the insights in that article. The F5CAB2 new study guide files exam was the turning point for my career and salary increaseget it for free today!
Posted at 2/6/2026 07:23:43        Only Author  3#
Wenn Sie die Microsoft AZ-204-Deutsch nicht bestehen, nachdem Sie unsere Unterlagen gekauft hat, bieten wir eine volle Rckerstattung. Diese Versprechung bedeutet nicht, dass wir nicht unserer Microsoft AZ-204-Deutsch Software nicht zutrauen, sondern unsere herzliche und verantwortungsvolle Einstellung, weil wir die Kunden sorgenfrei lassen wollen. Mit professionelle Microsoft AZ-204-Deutsch Prfungssoftware und der nach wie vor freundliche Kundendienst hoffen wir, dass Sie sich keine Sorge machen.
