[Hardware] Exam CTS-I Revision Plan - CTS-I Free Sample Questions
94
【Hardware】 Exam CTS-I Revision Plan - CTS-I Free Sample Questions
Posted at 1/25/2026 15:44:27      View:131 | Replies:1        Print      Only Author   [Copy Link] 1#
2026 Latest TroytecDumps CTS-I PDF Dumps and CTS-I Exam Engine Free Share: https://drive.google.com/open?id=18N18IhHhaoWHRHB5U4WbrDO4hnoyGG5j
To improve our products’ quality we employ first-tier experts and professional staff and to ensure that all the clients can pass the test we devote a lot of efforts to compile the CTS-I learning guide. Even if you unfortunately fail in the test we won’t let you suffer the loss of the money and energy and we will return your money back at the first moment. After you pass the CTS-I test you will enjoy the benefits the certificate brings to you such as you will be promoted by your boss in a short time and your wage will surpass your colleagues. In short, buying the CTS-I exam guide deserves your money and energy spent on them.
AVIXA CTS-I - Installation Exam Syllabus Topics:
TopicWeight
Duty A: Conducting Pre-Installation Activities20%
Task 1: Review Audiovisual Project Documentation4%
Task 2: Conduct Technical Site Survey4%
Task 3: Prepare for Audiovisual Installation4%
Task 4: Evaluate Overall Facility Readiness4%
Task 5: Conduct On-Site Preparations for Installation4%
Duty B: Conducting Site Rough-In/First-Fix10%
Task 1: Deinstallation of Existing Equipment and cabling2%
Task 2: Mount Substructure4%
Task 3: Pull Cable4%
Duty C: Installing Audiovisual Systems38%
Task 1: Assemble AV Rack4%
Task 2: Wire the AV Equipment Rack5%
Task 3: Distribute AV Equipment4%
Task 4: Mount AV Equipment4%
Task 5: Terminate Cables5%
Task 6: Configure Network Properties of Equipment4%
Task 7: Load Configuration and Control Programs4%
Task 8: Test the AV System4%
Task 9: Calibrate the AV System4%
Duty D: Perform Systems Close Out11%
Task 1: Demonstrate to Client or Client's Representative that System Performs to Specifications4%
Task 2rovide Training on System Operation4%
Task 3:Obtain Project Completion Sign Off from Client or Client's Representative3%
Duty E: Conducting Ongoing Project Responsibilities21%
Task 1: Complete Progress Reports3%
AVIXA CTS-I Exam Certification Details:
Schedule ExamPearson VUE
Number of Questions110
Passing Score350 / 500
Books / TrainingCandidate Handbook
MemberExam Price$475(USD)
Exam CodeCTS-I
Sample QuestionsAVIXA CTS-I Sample Questions
Exam NameAVIXA Certified Technology Specialist - Installation (CTS-I)
Duration150 mins
Free PDF 2026 AVIXA High Hit-Rate CTS-I: Exam Certified Technology Specialist - Installation Revision PlanThe CTS-I learning materials are of high quality, mainly reflected in the adoption rate. As for our CTS-I exam question, we guaranteed a higher passing rate than that of other agency. More importantly, we will promptly update our CTS-I quiz torrent based on the progress of the letter and send it to you. 99% of people who use our CTS-I Quiz guide has passed the exam and successfully obtained their certificates, which undoubtedly show that the passing rate of our CTS-I exam question is 99%. So our product is a good choice for you. Choose our CTS-I learning materials, you will gain a lot and lay a solid foundation for success.
AVIXA Certified Technology Specialist - Installation Sample Questions (Q131-Q136):NEW QUESTION # 131
Which mounting hardware will provide the MOST support when mounting a camera bracket to sheetrock/plasterboard not located near a wall stud?
Response:
  • A. Self tapping screws
  • B. Snap toggles / hollow wall anchors
  • C. Masonry bolts
  • D. Plastic wall anchors / wall plugs
NEW QUESTION # 132
Cameras installed _________ will capture the side of a participants head while they look at the display in front of them.
  • A. Too high up
  • B. Behind the presenter
  • C. Too low down
  • D. Too far to the left
NEW QUESTION # 133
Which is the preferred method for the correction of keystone distortion?
  • A. Electronic
  • B. Digital
  • C. Analog
  • D. Optical
NEW QUESTION # 134
Which of the following must the as-built drawings show?
  • A. Mechanical drawings
  • B. Details of the system as finally installed
  • C. Original system design specification
  • D. The client's vision for the finished system
NEW QUESTION # 135
What are the limitations of a Wi-Fi network for streaming live HD video? (Choose all that apply.)
  • A. Lower bandwidth than wired connections
  • B. Restrictions on range
  • C. Expensive infrastructure
  • D. Potential RF interference
Answer: A,B,D
NEW QUESTION # 136
It is time for you to plan your life carefully. After all, you have to make money by yourself. If you want to find a desirable job, you must rely on your ability to get the job. Now, our CTS-I study materials will help you master the popular skills in the office. Believe it or not, our CTS-I Study Materials will relieve you from poverty. It is important to make large amounts of money in modern society.
CTS-I Free Sample Questions: https://www.troytecdumps.com/CTS-I-troytec-exam-dumps.html
P.S. Free & New CTS-I dumps are available on Google Drive shared by TroytecDumps: https://drive.google.com/open?id=18N18IhHhaoWHRHB5U4WbrDO4hnoyGG5j
Posted at 2/3/2026 15:29:25        Only Author  2#
What a fantastic article, thank you so much for sharing. The Reliable FCP_FML_AD-7.4 exam review resources are excellent, and there’s no cost to access them.
