[General] Pass Guaranteed 2026 Oracle Fantastic Knowledge 1z0-1104-25 Points
116
【General】 Pass Guaranteed 2026 Oracle Fantastic Knowledge 1z0-1104-25 Points
Posted at 2/19/2026 12:10:51      View:77 | Replies:0        Print      Only Author   [Copy Link] 1#
P.S. Free & New 1z0-1104-25 dumps are available on Google Drive shared by FreeCram: https://drive.google.com/open?id=1PhKoPxnCkGBLojakQToscBLz8ZwmXL1-
The FreeCram Oracle Cloud Infrastructure 2025 Security Professional (1z0-1104-25) exam dumps are being offered in three different formats. The names of these formats are 1z0-1104-25 PDF questions file, desktop practice test software, and web-based practice test software. All these three Oracle Cloud Infrastructure 2025 Security Professional in 1z0-1104-25 Exam Dumps formats contain the real Oracle 1z0-1104-25 exam questions that will help you to streamline the 1z0-1104-25 exam preparation process.
In order to serve you better, we have a complete service system for you if you purchasing 1z0-1104-25 learning materials. We offer you free demo to have a try before buying, so that you can have a better understanding of what you are going to buy. After your payment for 1z0-1104-25 exam dumps, you can receive your downloading link and password within ten minutes, if you don’t receive, you can contact with us, and we will solve it for you. You can enjoy free update for 365 days after buying 1z0-1104-25 Exam Dumps, and the update version will be sent to your email automatically. If you have any questions about 1z0-1104-25 exam dumps after buying, you can contact with our after-sale service.
Quiz 2026 Latest Oracle Knowledge 1z0-1104-25 PointsAs the development of the science and technology is fast, so the information of the 1z0-1104-25 exam materials changes fast accordingly. The updated version of the 1z0-1104-25 study guide will be different from the old version. Some details will be perfected and the system will be updated. You will enjoy learning on our 1z0-1104-25 Exam Questions for its wonderful and latest design with the latest technologies applied.
Oracle Cloud Infrastructure 2025 Security Professional Sample Questions (Q23-Q28):NEW QUESTION # 23
You're managing an Oracle Cloud Infrastructure (OCI) environment where a public website hosts downloadable assets stored in Object Storage buckets. These buckets need to be publicly accessible for website visitors, but Cloud Guard keeps flagging them as security risks.
How can Cloud Guard be configured to ignore problems specific to public buckets while still ensuring security checks are applied to other resources that require them?
  • A. A public bucket is a security risk, so Cloud Guard will keep detecting it.
  • B. Fix the baseline by configuring the Conditional groups for the detector.
  • C. Resolve or remediate the problems by making the buckets private.
  • D. Dismiss problems associated with those resources.
NEW QUESTION # 24
Task 4: Create a Certificate Authority (CA)
Create a certificate authority, where:
CA name: PBT-CERT-CA-01-<username>
For example, if your username is 99008677-lab.user01, then the certificate authority name should be PBT- CERT-CA-01990086771abuser01 Ensure you eliminate special characters from the user name.
Common name: PBT-CERT-OCICA-01
Master Encryption Key: PBT-CERT-MEK-01 (created in the previous task)
See the solution below in Explanation.
Step 1: Access the OCI Vault
* Log in to the OCI Console.
* Navigate toIdentity & Security>Vault.
* Select the root compartment.
* Locate and click on the vault named PBI_Vault_SP.
Step 2: Create the Certificate Authority
* In the PBI_Vault_SP vault details page, underResources, clickCertificate Authorities.
* ClickCreate Certificate Authority.
* Enter the following details:
* Name: Replace <username> with your username (e.g., if your username is 99008677-lab.user01, remove special characters like - and . to get 99008677labuser01, then use PBT-CERT-CA-
0199008677labuser01).
* Common Name: Enter PBT-CERT-OCICA-01.
* Master Encryption Key: Select the PBT-CERT-MEK-01<username> key created in Task 3 (e.
g., PBT-CERT-MEK-0199008677labuser01).
* Subject: Leave as default or adjust (e.g., Organization, Country) if required by your setup.
* Validity Period: Set as needed (e.g., 10 years), or use the default.
* Compartment: Ensure it's set to the root compartment.
* ClickCreate Certificate Authorityand wait for the CA to be provisioned.
Step 3: Verify the Certificate Authority
* After creation, go to theCertificate Authoritiessection under PBI_Vault_SP.
* Confirm the CA PBT-CERT-CA-01<username> (e.g., PBT-CERT-CA-0199008677labuser01) is listed and its status is active.
NEW QUESTION # 25
Task 7: Verify the OCI Certificate with Load Balancer
Verify HTTPS connection to the load balancer by running the following command in Cloud Shell curl -k https://<Public IP of PBT-CERT-LB-01> Enter the following URL in the web browser:
If prompted with a certificate error, accept the risk and continue.
Verify web page content by ensuring the text, "You are visiting Web Server 1" from the index.html file is displayed in the browser See the solution below in Explanation.
Step 1: Obtain the Public IP of the Load Balancer
* Navigate toNetworking>Load Balancers.
* Click on PBT-CERT-LB-01.
* Note thePublic IP Addressfrom the load balancer details page.
Step 2: Verify HTTPS Connection Using Cloud Shell
* Open the OCI Cloud Shell from the top-right corner of the OCI Console.
* Run the following command, replacing <Public IP of PBT-CERT-LB-01> with the public IP you noted:
* Expected output: You should see the text "You are visiting Web Server 1" if the connection is successful. The -k flag ignores certificate validation errors (common during initial testing with self- signed or newly issued certificates).
* If you encounter an error, ensure the load balancer is active, the listener is configured correctly, and the backend server (PBT-CERT-VM-01) is reachable.
Step 3: Verify in a Web Browser
* Open a web browser.
* Enter the following URL, replacing <Public IP of PBT-CERT-LB-01> with the public IP you noted:
* If prompted with a certificate warning (e.g., due to a self-signed certificate or untrusted CA), accept the risk and proceed (click "Advanced" and "Proceed" or similar, depending on your browser).
* Verify that the web page displays the text "You are visiting Web Server 1" from the index.html file created on PBT-CERT-VM-01.
Step 4: Troubleshoot (if needed)
* If the text is not displayed:
* Check the load balancer health status underBackend Sets>Healthin the OCI Console.
* Ensure the security list PBT-CERT-LB-SL-01 allows port 443 and the compute instance security list allows port 80.
* Verify the Apache service is running on PBT-CERT-VM-01 by SSHing in and running sudo systemctl status httpd.
NEW QUESTION # 26
According to the Oracle Cloud Infrastructure (OCI) Shared Responsibility Model, which statement accurately reflects OCI's responsibility for security?
  • A. Customers are responsible for securing both infrastructure and data.
  • B. OCI provides security only for free-tier services; customers secure everything else.
  • C. OCI has no security responsibilities; customers need to secure their resources.
  • D. OCI is responsible for securing the underlying infrastructure but not customer data.
NEW QUESTION # 27
In Oracle Cloud Infrastructure (OCI), bare metal instances provide customers with direct access to the underlying hardware. To mitigate security risks when a customer terminates a bare metal instance, OCI utilizes Root-of-Trust hardware.
What is the primary function of the Root-of-Trust hardware in this context?
  • A. It guarantees complete isolation between customer workloads on different instances.
  • B. It ensures all non-volatile memory on the terminated instance is securely wiped before reuse.
  • C. It automatically encrypts data at rest on the bare metal instance.
  • D. It eliminates the need for hypervisors, reducing the potential attack surface.
NEW QUESTION # 28
For the Oracle Cloud Infrastructure 2025 Security Professional (1z0-1104-25) web-based practice exam no special software installation is required. Because it is a browser-based Oracle Cloud Infrastructure 2025 Security Professional (1z0-1104-25) practice test. The web-based Oracle Cloud Infrastructure 2025 Security Professional (1z0-1104-25) practice exam works on all operating systems like Mac, Linux, iOS, Android, and Windows.
New 1z0-1104-25 Test Sample: https://www.freecram.com/Oracle-certification/1z0-1104-25-exam-dumps.html
Oracle Knowledge 1z0-1104-25 Points Do you want to pass the exam just for one time, Just as I have just mentioned, almost all of our customers have passed the exam as well as getting the related certification easily with the help of our 1z0-1104-25 exam torrent, we strongly believe that it is impossible for you to be the exception, Oracle Knowledge 1z0-1104-25 Points We designed it like you are taking real exam, it has two phase first is practice mode and second is real exam mode.
Virtual Machine Defined, People found that it's really useful 1z0-1104-25 to send a photo or send some other information as well, Do you want to pass the exam just for one time?
Just as I have just mentioned, almost all New 1z0-1104-25 Exam Format of our customers have passed the exam as well as getting the related certification easily with the help of our 1z0-1104-25 Exam Torrent, we strongly believe that it is impossible for you to be the exception.
100% Pass Fantastic 1z0-1104-25 - Knowledge Oracle Cloud Infrastructure 2025 Security Professional PointsWe designed it like you are taking real exam, it has two phase first is practice mode and second is real exam mode, Now is the ideal time to prepare for and crack the Oracle 1z0-1104-25 exam.
Whenever you are in library or dormitory, you can learn the PDF version of 1z0-1104-25 exam questions & answers by yourself.
What's more, part of that FreeCram 1z0-1104-25 dumps now are free: https://drive.google.com/open?id=1PhKoPxnCkGBLojakQToscBLz8ZwmXL1-
