Free PDF Quiz Accurate Salesforce - Integration-Architect Latest Study Plan
Posted at 2/9/2026 04:08:02
View114
Replies0
What's more, part of that RealValidExam Integration-Architect dumps now are free: https://drive.google.com/open?id=1CmEwnp0bdbDn279DsgqtZ8bEeBHmelKy
We provide Salesforce Integration-Architect exam product in three different formats to accommodate diverse learning styles and help candidates prepare successfully for the Integration-Architect exam. These formats include Integration-Architect web-based practice test, desktop-based practice exam software, and Salesforce Certified Integration Architect (Integration-Architect) pdf file. Before purchasing, customers can try a free demo to assess the quality of the Salesforce Integration-Architect practice exam material.
Salesforce Integration-Architect exam is a certification that is designed to test a professional's ability to integrate Salesforce with other systems. Salesforce Certified Integration Architect certification is provided by Salesforce, which is a cloud-based software company that provides customer relationship management (CRM) services. The Integration-Architect Exam is one of the most important certifications offered by Salesforce, as it highlights a professional's expertise in integrating Salesforce with other systems.
Exam Integration-Architect Pattern - Integration-Architect Pass GuaranteeOur website always checks the update of Integration-Architect test questions to ensure the accuracy of our study materials and keep the most up-to-dated exam requirements. There are Integration-Architect free demo in our exam page for your reference and one-year free update are waiting for you. Valid Integration-Architect Real Dumps will the guarantee of your success and make you more confident in your career.
Salesforce Integration-Architect Certification is designed to test your knowledge and expertise in the field of Salesforce Integration. Salesforce Certified Integration Architect certification covers a broad range of topics, including integration architecture, data architecture, API management, data migration, web services, and more. Salesforce Certified Integration Architect certification is ideal for technical architects, solution architects, and developers who are looking to validate their expertise in Salesforce Integration.
Salesforce Certified Integration Architect Sample Questions (Q100-Q105):NEW QUESTION # 100
An Integration Architect has built a solutionusing REST API, updating Account, Contact, and other related information. The data volumes have increased, resulting in higher API calls consumed, and some days the limits are exceeded. A decision was made to decrease the number of API calls using bulk updates. The customer prefers to continue using REST API to avoid architecture changes.
Which REST API composite resources should the Integration Architect use to allow up to 200 records in one API call?
- A. Batch
- B. Composite
- C. SObject Tree
- D. SObject Collections
SObject Collections is a REST API composite resource that allows you to create, update, or delete up to 200 records in one API call. You can specify the type of operation (create, update, or delete) for eachrecord in the request body, andthe response body will contain the status and IDs of each record. SObject Collections is suitable for bulk operations on records that are not related to each other1.
SObject Tree is another REST API composite resource that allows you to create up to 200 records in one API call. However, unlike SObject Collections, SObject Tree requires the records to be related to each other in a hierarchy. You can specify the parent and child records in a JSON tree structure, and the response body will contain the reference IDs and URLs of each record. SObject Tree is suitable forcreating nesteddata in one request2.
Batch is a REST API composite resource that allows you to combine up to 25 requests in one API call. Each request can be a different type of operation (query, create, update, delete, etc.) on different objects. The response body will contain the status and results of each request. Batch is suitable for grouping multiple requests into one transaction3.
Composite is a REST API composite resource that allows you to execute aseries of REST API requests in one API call. You can use the output of one request as the input of another request using a reference ID. The response body will contain the status and results of each request. Composite is suitable for chaining requests that depend on each other.
Therefore, the correct answer is A, because SObject Collections is the only REST API composite resource that allows bulk updates on records that are not related to each other.
References: 1: SObject Collections | REST API Developer Guide | Salesforce Developers 2: SObject Tree | REST API Developer Guide | Salesforce Developers 3: Batch | REST API Developer Guide | Salesforce Developers :[Composite | REST API Developer Guide | Salesforce Developers]
NEW QUESTION # 101
A new Salesforce program has the following high level abstract requirement: Business processes executed on Salesforce require data updates between the internal systems and Salesforce Which three relevant details should a Salesforce Integration Architect seek to specifically solve for Integration architecture needs of the program?
Choose 3 answers
- A. Integration skills, SME availability and Program Governance details.
- B. Integration Style Process based, Data based, Virtual integration. E Core functional and non-functional requirements for User Experience design, Encryption needs, Community, and license choices.
- C. Timing aspects - real-time/near real-time (synchronous or asynchronous), batch; update frequency.
- D. Source and Target system, Directionality, data volume & transformation complexity long with any middleware that can be leveraged.
Answer: B,C,D
The correct answer is A, C, and D. These are three relevant details that a Salesforce Integration Architect should seek to specifically solve for Integration architecture needs of the program. These details can help the Integration Architect to understand the scope, requirements, and constraints of the integration solution, and to choose the appropriate tools, methods, and patterns. The details are:
Source and Target system, Directionality, data volume & transformation complexity along with any middleware that can be leveraged. This detail can help the Integration Architect to identify the systems involved in the integration, the direction of data flow, the amount and complexity of data to be exchanged, and the middleware or platform capabilities that can facilitate the integration.
Timing aspects - real-time/near real-time (synchronous or asynchronous), batch; update frequency. This detail can help the Integration Architect to determine the latency, reliability, and scalability requirements of the integration solution, and to choose the suitable integration protocols and techniques.
Integration Style - Process based, Data based, Virtual integration. This detail can help the Integration Architect to select the appropriate integration style that matches the business needs and objectives.
Process based integration focuses on orchestrating business processes across systems, data based integration focuses on synchronizing data across systems, and virtual integration focuses on providing a unified view of data across systems.
References: Certification - Integration Architect - Trailhead, [Integration Patterns and Practices]
NEW QUESTION # 102
What should an integration architect consider when recommending Platform Events as an integration solution?
- A. Subscribe to an AssetTokenEvent stream to monitor OAuth 2.0 authentication activity.
- B. Event Monitoring is used to track user activity, such as logins and running reports.
- C. When an event definition is deleted, it's permanently removed and can't be restored.
When recommending Platform Events, an architect must account for the metadata lifecycle and the permanence of administrative actions. Unlike standard or custom objects, which can often be recovered from the Recycle Bin for a limited time, Platform Event definitions are handled with stricter permanence. Once a Platform Event definition is deleted, it is permanently removed from the organization's metadata, and it cannot be restored. This deletion also immediately invalidates any associated triggers, subscriptions, and stored events in the bus.
Beyond metadata management, the architect must consider the Event Retention window. High-volume platform events are stored for 72 hours, allowing subscribers to use a Replay ID to recover missed messages.
However, this durability is predicated on the definition existing; if the definition is deleted, the historical data in the bus becomes inaccessible. Option A refers to Real-Time Event Monitoring, which is a separate product feature used for security auditing rather than general integration. Option B describes a specific system event (AssetTokenEvent) used for IoT device authentication, which is a niche use case and not a general consideration for platform event architecture. Therefore, understanding the permanent nature of metadata deletion is a fundamental "Maintenance" and "Governance" consideration that the architect must highlight to ensure the stability of the enterprise's event-driven landscape.
NEW QUESTION # 103
Universal Containers (UC) currently owns a middleware tool and they have developed an API-led integration architecture with three API tiers. The first tier interfaces directly with the systems of engagement, the second tier implements business logic and aggregates data, while the third tier interfaces directly with systems of record. Some of the systems of engagement will be a mobile application, a web application, and Salesforce.
UC has a business requirement to return data to the systems of engagement in different formats while also enforcing different security protocols.
What should an Integration Architect recommend to meet these requirements?
- A. Enforce separate security protocols and return formats at the first tier of the API-led architecture.
- B. Enforce separate security protocols and return formats at the second tier of the API-led architecture.
- C. Leverage an Identity Provider solution that communicates with the API tiers via SAML
- D. Implement an API gateway that all systems of engagement must interface with first.
NEW QUESTION # 104
An Integration Architect has built a solution using REST API, updating Account, Contact, and other related information. The data volumes have increased, resulting in higher API calls consumed, and some days the limits are exceeded. A decision was made to decrease the number of API calls using bulk updates. The customer prefers to continue using REST API to avoid architecture changes.
- A. Batch
- B. SObject Tree
- C. Composite
SObject Collections is a REST API composite resource that allows you to create, update, or delete up to 200 records in one API call. You can specify the type of operation (create, update, or delete) for each record in the request body, and the response body will contain the status and IDs of each record. SObject Collections is suitable for bulk operations on records that are not related to each other1.
SObject Tree is another REST API composite resource that allows you to create up to 200 records in one API call. However, unlike SObject Collections, SObject Tree requires the records to be related to each other in a hierarchy. You can specify the parent and child records in a JSON tree structure, and the response body will contain the reference IDs and URLs of each record. SObject Tree is suitable for creating nested data in one request2.
Composite is a REST API composite resource that allows you to execute a series of REST API requests in one API call. You can use the output of one request as the input of another request using a reference ID. The response body will contain the status and results of each request. Composite is suitable for chaining requests that depend on each other.
References: 1: SObject Collections | REST API Developer Guide | Salesforce Developers 2: SObject Tree | REST API Developer Guide | Salesforce Developers 3: Batch | REST API Developer Guide | Salesforce Developers : [Composite | REST API Developer Guide | Salesforce Developers]
NEW QUESTION # 105
Exam Integration-Architect Pattern: https://www.realvalidexam.com/Integration-Architect-real-exam-dumps.html
- Valid Integration-Architect Test Forum 😟 Integration-Architect Braindumps Torrent 🛕 Integration-Architect Braindumps Torrent 🐔 Search for { Integration-Architect } and download exam materials for free through ⮆ [url]www.examcollectionpass.com ⮄ 🦢Reliable Integration-Architect Study Guide[/url]
- Integration-Architect Reliable Test Tips 🤍 Integration-Architect Latest Real Test 🤹 Integration-Architect Test Engine Version 🤣 Enter [url]www.pdfvce.com and search for ✔ Integration-Architect ️✔️ to download for free 🧍Valid Integration-Architect Test Forum[/url]
- Best way to practice test for Salesforce Integration-Architect? 🥋 Easily obtain ☀ Integration-Architect ️☀️ for free download through ▛ [url]www.easy4engine.com ▟ 🎑Exam Integration-Architect Pass4sure[/url]
- Latest Integration-Architect Latest Study Plan offer you accurate Exam Pattern | Salesforce Salesforce Certified Integration Architect 🍪 Go to website [ [url]www.pdfvce.com ] open and search for { Integration-Architect } to download for free 🔦Integration-Architect Braindumps Torrent[/url]
- Latest Integration-Architect Latest Study Plan offer you accurate Exam Pattern | Salesforce Salesforce Certified Integration Architect 🥉 Easily obtain ☀ Integration-Architect ️☀️ for free download through ⮆ [url]www.practicevce.com ⮄ 🐇Integration-Architect Latest Real Test[/url]
- Critical Information Integration-Architect Online Learning Environment ✔ Download { Integration-Architect } for free by simply searching on [url]www.pdfvce.com 🥎Reliable Integration-Architect Test Braindumps[/url]
- 2026 Integration-Architect Latest Study Plan | Useful Salesforce Certified Integration Architect 100% Free Exam Pattern 😫 Enter ✔ [url]www.torrentvce.com ️✔️ and search for ⏩ Integration-Architect ⏪ to download for free 📕Detailed Integration-Architect Study Plan[/url]
- Pass Guaranteed Quiz 2026 Perfect Integration-Architect: Salesforce Certified Integration Architect Latest Study Plan ✡ Search for ➠ Integration-Architect 🠰 and download it for free immediately on ➡ [url]www.pdfvce.com ️⬅️ 🟥Valid Integration-Architect Test Forum[/url]
- Critical Information Integration-Architect Online Learning Environment 💳 Enter [ [url]www.dumpsquestion.com ] and search for ⇛ Integration-Architect ⇚ to download for free 🍨Integration-Architect Test Engine Version[/url]
- Integration-Architect Examcollection Vce 🚼 New Integration-Architect Test Topics 🍧 Integration-Architect Reliable Test Tips 🕒 ⮆ [url]www.pdfvce.com ⮄ is best website to obtain ➥ Integration-Architect 🡄 for free download 🪁Valid Braindumps Integration-Architect Files[/url]
- Integration-Architect Test Engine Version 🍻 Integration-Architect Braindumps Torrent 🎈 Latest Integration-Architect Test Online 📗 Easily obtain ▷ Integration-Architect ◁ for free download through ⏩ [url]www.vceengine.com ⏪ 🧪Integration-Architect Examcollection Vce[/url]
- balvishwamarathi.com, www.stes.tyc.edu.tw, paint-academy.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, competitivebengali.in, bbs.t-firefly.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
2026 Latest RealValidExam Integration-Architect PDF Dumps and Integration-Architect Exam Engine Free Share: https://drive.google.com/open?id=1CmEwnp0bdbDn279DsgqtZ8bEeBHmelKy
