[Linux] UART Communication
36
【Linux】 UART Communication
Posted at 9/7/2022 21:16:27      View:3822 | Replies:6        Print      Only Author   [Copy Link] 1#
Hi everyone, recently i get a Firefly ROC 3566-PC. I flashed it with Ubuntu 18.04, and i want create an UART communication with one microcontroller. I'm using this Embedded board as central PC, to work with AI using the RKNN, but, i need an UART communication between this board, and microcontroller board (Designed by own)..
In the  /dev/, i see /dev/ttyFQI0 and /dev/ttyS0, but, i dont get any information in the pins of attached for UART.
I'm new using these microprocessor, i used raspberry and microcontrollers, but in this case, i'm new in this plaftform for embedded systems.
I recent see about modify dts files in kernel, is necessary? pyserial is compatible with this board?
Posted at 9/8/2022 19:36:51        Only Author  2#
You need to modify dts to enable serial port function. The serial ports available on the expansion port(J1) are uart3/uart5/uart9.
It will be easier to configure uart3, as follows:
&uart3 {
         status = "okay";
Schematic: https://en.t-firefly.com/doc/download/93.html#other_385
已有 1评分Prestige +10 Pack up reason
alexxowo + 10
View all ratings
Posted at 9/29/2022 19:59:23        Only Author  3#
EDIT: I solved my problem
Posted at 1/10/2026 02:44:55        Only Author  4#
I’m truly grateful for your article, it made an unforgettable impact. Free 300-620 valid test tutorial to improve your IT knowledge. Wishing you all the best!
Posted at 1/10/2026 18:32:06        Only Author  5#
The article gave me so many new ideas. Wishing you all the best! Here’s the free OGBA-101 valid test camp materials material.
Posted at 1/10/2026 19:20:46        Only Author  6#
I really appreciate your article, it had a profound effect on me. The rich content of PSP valid exam vce free is available for free, designed to assist you in your studies.
Posted at 1/24/2026 05:30:31        Only Author  7#
I really appreciate this inspiring article, thank you for sharing! Let’s do this! Wishing for success in the 100% JN0-452 exam coverage exam!
