[Hardware] Free PDF Quiz 2026 Ping Identity PT-AM-CPE: Updated Certified Professional - Pin
117
Hardware Free PDF Quiz 2026 Ping Identity PT-AM-CPE: Updated Certified Professional - Pin
Posted at 2/19/2026 22:42:33      View117 | Replies0        Print      Only Author   [Copy Link] 1#
According to the market research, we have found that a lot of people preparing for the PT-AM-CPE exam want to gain the newest information about the exam. In order to meet all candidates requirement, we compiled such high quality PT-AM-CPE study materials to help you. It is believed that our products will be very convenient for you, and you will not find the better study materials than our PT-AM-CPE Exam Question. If you willing spend few hours to learn our study materials, you will pass the exam in a short time. Now we are going to introduce our PT-AM-CPE test questions to you.
Ping Identity PT-AM-CPE Exam Syllabus Topics:
  • Installing and Deploying AM: This domain encompasses installing and upgrading PingAM, hardening security configurations, setting up clustered environments, and deploying PingOne Advanced Identity Platform to the cloud.
  • Extending Services Using OAuth2-Based Protocols: This domain addresses integrating applications with OAuth 2.0 and OpenID Connect, securing OAuth2 clients with mutual TLS and proof-of-possession, transforming OAuth2 tokens, and implementing social authentication.
  • Federating Across Entities Using SAML2: This domain covers implementing single sign-on using SAML v2.0 and delegating authentication responsibilities between SAML2 entities.
  • Enhancing Intelligent Access: This domain covers implementing authentication mechanisms, using PingGateway to protect websites, and establishing access control policies for resources.
Topic 5
  • Improving Access Management Security: This domain focuses on strengthening authentication security, implementing context-aware authentication experiences, and establishing continuous risk monitoring throughout user sessions.
Looking to Advance Your IT Career? Try Ping Identity PT-AM-CPE Exam QuestionsPracticeMaterial also has a Ping Identity Practice Test engine that can be used to simulate the genuine Certified Professional - PingAM Exam (PT-AM-CPE) exam. This online practice test engine allows you to answer questions in a simulated environment, giving you a better understanding of the exam's structure and format. With the help of this tool, you may better prepare for the Certified Professional - PingAM Exam (PT-AM-CPE) test.
Ping Identity Certified Professional - PingAM Exam Sample Questions (Q34-Q39):NEW QUESTION # 34
What happens when an end user accesses the following login page: .../XUI/?ForceAuth=true#login?
  • A. The end user will be presented with second factor authentication
  • B. Even if the end user is already authenticated, they will be redirected to the login page
  • C. Nothing. ForceAuth is not a parameter that PingAM knows how to process
  • D. A screen is presented to the end user suggesting they enable second factor authentication
The ForceAuth=true parameter is a standard directive used in various authentication protocols (specifically SAML2 and OIDC) and is natively supported by the PingAM 8.0.2 XUI (the modern End-User User Interface).
According to the "Authentication and SSO" documentation:
Normally, if a user has an active, valid session cookie (iPlanetDirectoryPro), and they navigate to the AM login URL, PingAM will recognize the session and automatically redirect the user to their destination (the "Success URL") without prompting for credentials. This is the core benefit of Single Sign-On.
However, when the ForceAuth=true parameter is appended to the query string, it instructs the PingAM authentication engine to bypass the session check for the purpose of re-authentication. The engine will:
Ignore the existing valid session cookie.
Force the user back to the login page (rendering the initial nodes of the configured authentication tree).
Require the user to provide their credentials again.
This is a critical security feature for high-value transactions. For instance, if a user is already logged in but attempts to change their bank transfer details, the application can redirect them to AM with ForceAuth=true to ensure the person sitting at the computer is indeed the authorized user. Option B is incorrect because ForceAuth only forces a re-authentication; whether that includes MFA depends on the tree configuration, not the parameter itself. Option C is incorrect as PingAM explicitly processes this parameter. Therefore, the primary outcome is the redirection to the login page regardless of the current session state.
NEW QUESTION # 35
What is the purpose of HTTP-only cookies?
  • A. Cookies can not be read by client-side scripts
  • B. Cookies can only be transmitted over HTTP
  • C. Cookies can not be read by the server
  • D. Cookies can only be transmitted over HTTPS
In the "Additional Cookie Security" section of the PingAM 8.0.2 documentation, HttpOnly is described as a critical security attribute for session cookies (like iPlanetDirectoryPro). Its primary purpose is to mitigate the risk of session hijacking via Cross-Site Scripting (XSS) attacks.
When a cookie is marked with the HttpOnly flag, the browser is instructed to restrict access to that cookie. Specifically, it prevents client-side scripts-such as those written in JavaScript-from accessing the cookie through the document.cookie API. If an attacker successfully injects a malicious script into a page, the script will be unable to "read" the session token, even though the cookie is still automatically sent by the browser with every valid HTTP request to the server.
Option B describes the Secure flag, which ensures cookies are only sent over encrypted (HTTPS) connections.
Option C is incorrect because the server must be able to read the cookie to validate the user's session.
Option D is a common misconception; the HttpOnly flag does not restrict the transport to "HTTP-only" (non-secure) protocols; rather, it restricts the access method within the browser environment.
By default, PingAM 8.0.2 enables the HttpOnly flag for all session cookies. This is considered a best practice in modern identity management because it ensures that even if a web application has a vulnerability that allows for script injection, the user's primary authentication token remains protected from being exfiltrated by the attacker's script.
NEW QUESTION # 36
Which of the following best represents the information that is typically contained in the debug output?
  • A. The component that created the debug entry, A header with the time and date, The debug level, A general message, Optional stack trace
  • B. The component that created the debug entry, A header with the time and date, The running thread ID, A general message, Optional stack trace
  • C. The component that created the debug entry, A header with the time and date, The running thread ID, The debug level, A general message, Optional stack trace
  • D. A header with the time and date, The running thread ID, The debug level, A general message, Optional stack trace
In PingAM 8.0.2, troubleshooting complex issues often requires moving beyond audit logs to Debug Logs. These logs capture the internal operations of the AM engine and its various components (e.g., Authentication, Core Token Service, Session Management).7 According to the "Debug Logging" section of the PingAM 8.0.2 Maintenance Guide, the standard format for a debug log entry is designed to provide maximum context for support engineers and developers. A typical entry includes:
Time and Date Header: Precise timestamp of when the event occurred.
The Component (Category): Identifies which part of the code issued the message (e.g., amAuth, amSession, amOAuth2).
The Debug Level: Indicates the verbosity/severity, such as ERROR, WARNING, INFO, MESSAGE, or OFF.
The Thread ID: Crucial for multi-threaded environments like Tomcat, allowing administrators to trace a single user's request across multiple log entries.
The Message: A descriptive string explaining the internal operation or the error encountered.
Stack Trace: If the entry is recording an exception, a full Java stack trace is optionally included to pinpoint the exact line of code where the failure occurred.
Option A is the most complete and accurate representation of this structured output. Options B, C, and D are incorrect because they omit essential troubleshooting fields like the Thread ID or the Component name, which are necessary for correlating logs in a high-concurrency production environment. Understanding this structure is fundamental for any administrator using tools like ssoadm or the REST API to capture and analyze troubleshooting information.
NEW QUESTION # 37
In a default PingAM configuration, what type of keystore stores the secret ID named storepass, which contains the encrypted password of the default-keystore secret store?
  • A. Keystore secret store
  • B. Hardware Security Module secret store
  • C. Filesystem secret store
  • D. Environment and system property secret store
In PingAM 8.0.2, the management of sensitive data such as passwords and cryptographic keys is handled through a unified Secret Store framework. This framework abstracts the source of the secret from the component that consumes it using Secret IDs. One of the most critical secret IDs in a standard installation is storepass.
The storepass secret ID is specifically used by the default-keystore (which is typically a "Keystore secret store" pointing to keystore.jks or keystore.p12). Before AM can access the keys within the default-keystore to sign tokens or encrypt data, it must first unlock the keystore itself using the password mapped to the storepass secret ID.
According to the PingAM "Secrets, certificates, and keys" documentation, in a default file-based configuration, PingAM initializes a Filesystem secret store as its primary global store. This store is configured to look into a specific directory within the AM configuration path (usually .../openam/secrets/). Inside this directory, AM expects to find files named after the secret IDs they contain. For the storepass ID, there is typically a corresponding file (such as storepass or .storepass) containing the cleartext or encrypted password required to open the primary keystore.
While AM can be configured to use an Environment and system property secret store (Option B) for high-portability cloud deployments, the "out-of-the-box" default behavior during a standard installation relies on the filesystem. Option A is incorrect because the storepass is the key to the keystore, not a secret inside it, and Option D refers to specialized hardware integrations not used in a default software-only setup. Therefore, the Filesystem secret store is the correct technical answer for the default location of the storepass.
NEW QUESTION # 38
Which of the following is an incorrect statement about session upgrade outcomes?
  • A. In a client-side session configuration, PingAM replaces the client's original session token with a new session token
  • B. In a server-side session configuration, when using advices, PingAM copies the session properties to a new session and replaces the client's original session token with a new session token
  • C. In a server-side or client-side session configuration, PingAM issues a new session token to a user who reauthenticates, only when the current session does not meet the security requirements
  • D. In a server-side session configuration, when using the ForceAuth parameter and an authentication tree, PingAM issues a new session token to a user who reauthenticates, even if the current session already meets the security requirements
In PingAM 8.0.2, a Session Upgrade occurs when a user is required to authenticate at a higher security level (Auth Level). The outcomes of these upgrades depend on the session storage (server-side vs. client-side) and the parameters used.
Statement B is incorrect because it claims that a new token is issued only when the current session does not meet requirements. In reality, if a request explicitly includes a parameter like ForceAuth=true or prompt=login, PingAM will force a re-authentication and issue a new session token regardless of the current session's state.
According to the "Session Upgrade" and "Step-up Authentication" documentation:
Statement A is correct: When ForceAuth=true is used, the AM engine ignores the existing session's Auth Level and forces the user through the tree. A new session/token is generated upon success.
Statement C is correct: This describes the standard "Advice" flow (e.g., from a policy). AM creates a new session, copies existing properties from the old one, and replaces the token.
Statement D is correct: In client-side sessions, since the state is in a JWT cookie, any change (like an Auth Level increase) requires the issuance of a brand-new signed JWT to replace the old one.
Therefore, because PingAM allows for forced re-authentication even when requirements are met, the restrictive "only when" condition in Statement B makes it the incorrect (and thus the target) answer. This behavior is key for security scenarios where a fresh proof of presence is required regardless of previous activity.
NEW QUESTION # 39
Being anxious for the exam ahead of you? Have a look of our PT-AM-CPE practice materials please. Presiding over the line of PT-AM-CPE practice materials over ten years, our experts are proficient as elites who made our PT-AM-CPE practice materials, and it is their job to officiate the routines of offering help for you. All points are predominantly related with the exam ahead of you. Every page is full of well-turned words for your reference related wholly with the real exam.
Free PT-AM-CPE Dumps: https://www.practicematerial.com/PT-AM-CPE-exam-materials.html
